APPLICABLE STANDARD
OPERATING
TEMPERATURE RANGE
RATING
200 V AC
STORAGE
TEMPERATURE RANGE
OPERATING HUMIDITY
RANGE
2A
STORAGE HUMIDITY
RANGE
-55 C
VOLTAGE
CURRENT
TO
85 C (1)
-10 C
TO
60 C (2)
40 %
TO
80 %.
40 %
TO
70 % (2)
SPECIFICATIONS
ITEM
CONSTRUCTION
TEST METHOD
REQUIREMENTS
QT AT
①CONTACT RESISTANCE: 20 m MAX.
②INSULATION RESISTANCE:1000 M MIN.
③NO DAMAGE, CRACK AND LOOSENESS
OF PARTS.
②NO HEAVY CORROSION.
NO DEFORMATION OF CASE OF
EXCESSIVE LOOSENESS OF THE
TERMINALS.
A NEW UNIFORM COATING OF SOLDER
SHALL COVER A MINIMUM OF 95 % OF
THE SURFACE BEING IMMERSED.
ACCORDING TO DRAWING.
GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT.
MARKING
CONFIRMED VISUALLY.
ELECTRIC CHARACTERISTICS
CONTACT RESISTANCE
INSULATION
RESISTANCE
VOLTAGE PROOF
100 mA (DC OR 1000 Hz).
15 mΩ MAX .
1000 MΩ MIN.
500 V DC
650 V AC FOR 1 min.
NO FLASHOVER OR BREAKDOWN.
MECHANICAL CHARACTERISTICS
DRAWING FOR REFERENCE:This is subject to change without notice
VIBRATION
①NO ELECTRICAL DISCONTINUITY OF
1 s.
②NO DAMAGE, CRACK AND LOOSENESS
OF PARTS.
FREQUENCY 10 TO 55 Hz,
AMPLITUDE : 1.5 mm,
AT 2 h FOR 3 DIRECTIONS.
490 m/s2 , DURATION OF PULSE 11 ms
AT 3 TIMES FOR 3 DIRECTIONS.
SHOCK
ENVIRONMENTAL CHARACTERISTICS
DAMP HEAT
(STEADY STATE)
RAPID CHANGE OF
TEMPERATURE
EXPOSED AT
40±2 C,
90 ~ 95 %,
96
h.
TEMPERATURE-55→+15~+35→+85→+15~+35C
TIME
30 → 10~15 → 30 → 10~15 min.
UNDER
5 CYCLES.
CORROSION SALT MIST EXPOSED IN
5 % SALT WATER SPRAY FOR
48 h.
SULPHUR DIOXIDE
EXPOSED IN 10 PPM FOR 96 h.
(TEST STANDARD: JEIDA - 39)
RESISTANCE TO
1) SOLDER BATH:SOLDER TEMPERATURE,
SOLDERING HEAT
260±5℃ FOR IMMERSION,DURATION,10±1s.
2) SOLDERING IRONS : 350 C FOR 3 s MAX.
SOLDERABILITY
COUNT
REMARK
(1)
(2)
SOLDERED AT SOLDER TEMPERATURE,
245±3C,
FOR IMMERSION DURATION,
2 s.
DESCRIPTION OF REVISIONS
DESIGNED
TEMPERATURE RISE INCLUDED WHEN ENERGIZED.
THIS STORAGE INDICATES A LONG-TERM STORAGE STATE
FOR THE UNUSED PRODUCT BEFORE THE BOARD MOUNTED.
Unless otherwise specified, refer to MIL-STD-1344.
Note
QT:Qualification Test
FORM HD0011-2-1
AT:Assurance Test
X:Applicable Test
CHECKED
APPROVED
NH.NAKATA
17.04.10
CHECKED
HT.YAMAGUCHI
17.04.10
DESIGNED
HR.NAGAYASU
17.04.10
DRAWN
HR.NAGAYASU
17.04.10
DRAWING NO.
SPECIFICATION SHEET
PART NO.
HIROSE ELECTRIC CO., LTD.
CODE NO.
DATE
ELC-375933-00-00
MA35-*P-2DS(51)
CL588
0 1/1
很抱歉,暂时无法提供与“MA35-44P-2DS(51)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+18.43560
- 200+7.35480
- 480+7.11720
- 1000+6.98760
