MA35-16P-2DS(51)
MA35-16P-2DS(51)
    HRS(广濑)
    弯插,P=2mm
    排针 间距:2mm 2x8P 弯插
MA35-16P-2DS(51) 数据手册
APPLICABLE STANDARD OPERATING TEMPERATURE RANGE RATING 200 V AC STORAGE TEMPERATURE RANGE OPERATING HUMIDITY RANGE 2A STORAGE HUMIDITY RANGE -55 C VOLTAGE CURRENT TO 85 C (1) -10 C TO 60 C (2) 40 % TO 80 %. 40 % TO 70 % (2) SPECIFICATIONS ITEM CONSTRUCTION TEST METHOD REQUIREMENTS QT AT × × × × × × - - × - × - × - ①CONTACT RESISTANCE: 20 m MAX. ②INSULATION RESISTANCE:1000 M MIN. ③NO DAMAGE, CRACK AND LOOSENESS OF PARTS. × - × - ①CONTACT RESISTANCE: 20 m MAX. ②NO HEAVY CORROSION. × - × - NO DEFORMATION OF CASE OF EXCESSIVE LOOSENESS OF THE TERMINALS. × - × - A NEW UNIFORM COATING OF SOLDER SHALL COVER A MINIMUM OF 95 % OF THE SURFACE BEING IMMERSED. × - ACCORDING TO DRAWING. GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT. MARKING CONFIRMED VISUALLY. ELECTRIC CHARACTERISTICS CONTACT RESISTANCE INSULATION RESISTANCE VOLTAGE PROOF 100 mA (DC OR 1000 Hz). 15 mΩ MAX . 1000 MΩ MIN. 500 V DC 650 V AC FOR 1 min. NO FLASHOVER OR BREAKDOWN. MECHANICAL CHARACTERISTICS DRAWING FOR REFERENCE:This is subject to change without notice VIBRATION ①NO ELECTRICAL DISCONTINUITY OF 1 s. ②NO DAMAGE, CRACK AND LOOSENESS OF PARTS. FREQUENCY 10 TO 55 Hz, AMPLITUDE : 1.5 mm, AT 2 h FOR 3 DIRECTIONS. 490 m/s2 , DURATION OF PULSE 11 ms AT 3 TIMES FOR 3 DIRECTIONS. SHOCK ENVIRONMENTAL CHARACTERISTICS DAMP HEAT (STEADY STATE) RAPID CHANGE OF TEMPERATURE EXPOSED AT 40±2 C, 90 ~ 95 %, 96 h. TEMPERATURE-55→+15~+35→+85→+15~+35C TIME 30 → 10~15 → 30 → 10~15 min. UNDER 5 CYCLES. CORROSION SALT MIST EXPOSED IN 5 % SALT WATER SPRAY FOR 48 h. SULPHUR DIOXIDE EXPOSED IN 10 PPM FOR 96 h. (TEST STANDARD: JEIDA - 39) RESISTANCE TO 1) SOLDER BATH:SOLDER TEMPERATURE, SOLDERING HEAT 260±5℃ FOR IMMERSION,DURATION,10±1s. 2) SOLDERING IRONS : 350 C FOR 3 s MAX. SOLDERABILITY 0 △ COUNT REMARK (1) (2) SOLDERED AT SOLDER TEMPERATURE, 245±3C, FOR IMMERSION DURATION, 2 s. DESCRIPTION OF REVISIONS DESIGNED TEMPERATURE RISE INCLUDED WHEN ENERGIZED. THIS STORAGE INDICATES A LONG-TERM STORAGE STATE FOR THE UNUSED PRODUCT BEFORE THE BOARD MOUNTED. Unless otherwise specified, refer to MIL-STD-1344. Note QT:Qualification Test FORM HD0011-2-1 AT:Assurance Test X:Applicable Test CHECKED APPROVED NH.NAKATA 17.04.10 CHECKED HT.YAMAGUCHI 17.04.10 DESIGNED HR.NAGAYASU 17.04.10 DRAWN HR.NAGAYASU 17.04.10 DRAWING NO. SPECIFICATION SHEET PART NO. HIROSE ELECTRIC CO., LTD. CODE NO. DATE ELC-375933-00-00 MA35-*P-2DS(51) CL588 0 1/1 △ DRAWING FOR REFERENCE:This is subject to change without notice
MA35-16P-2DS(51) 价格&库存
很抱歉,暂时无法提供与“MA35-16P-2DS(51)”相匹配的价格&库存,您可以联系我们找货
MA35-16P-2DS(51)
  • 130+8.23021130+1.06954
