TM3P-44P01-HYSH-HF120-1
    HRS(广濑)
    CONN MOD PLUG
TM3P-44P01-HYSH-HF120-1 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. CL 222 TM Plug for copper foil, stranded wire flat type cable ●Material・Finish Condition Specification Plug case Polycarbonate Clear Current rating Per pin 0.5A Terminal Phosphor Bronze Gold plated Voltage rating Per pin 125V AC Insulation Resistance 100V DC 100 M Ω Min. Withstanding Voltage 1 minute 500V r.m.s AC Part name Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Electrical Performance Material Finish Applicable Cable Conductor diameter Copper foil or AWG # 26 Insulator diameter φ0.9-φ1.0 Item ●TM3P-44P CL No. 222-0207-2 Part No. TM3P-44P RoHS YES Insulator Applicable cable section (Packing unit: 100 Pcs.) CL No. 222-0278-0 222-0208-5 222-0209-8 ●TM3P-62P, 64P & 66P Part No. TM3P-62P TM3P-64P TM3P-66P RoHS YES Insulator Applicable cable section Note: Shown TM3P-64P. (Packing unit: 100 Pcs.) −31− The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. CL 222 TM Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●TM8P-88P CL No. 222-1817-9 Part No. TM8P-88P RoHS YES Insulator Applicable cable section (Packing unit: 100 Pcs.) −32− The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. CL 222 TM Plug for copper foil, stranded wire circular type cable ●Material・Finish Condition Specification Plug case Polycarbonate Material Clear Current rating Per pin 0.5A Terminal Phosphor Bronze Gold plated Voltage rating Per pin 125V AC Insulation Resistance 100V DC 100 M Ω Min. Withstanding Voltage 1 minute 500V r.m.s AC Part name Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Electrical Performance Finish Applicable Cable Conductor diameter Copper foil or AWG # 26 Insulator diameter φ0.9-φ1.0 Item ●TM4P-44P CL No. 222-0279-3 Part No. TM4P-44P RoHS YES Insulator Applicable cable section (Packing unit: 100 Pcs.) ●TM4P-64P & 66P CL No. 222-0280-2 222-0281-5 Part No. TM4P-64P TM4P-66P RoHS YES TM4P-64P TM4P-66P Insulator Applicable cable section Note: Shown TM4P-64P. (Packing unit: 100 Pcs.) −33− The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. CL 222 TM ●TM10P-88P CL No. 222-1818-1 Part No. TM10P-88P RoHS YES Insulator Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Applicable cable section (Packing unit: 100 Pcs.) −34− The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. CL 222 TM CL No. Part No. Applicable connector 902-0030-8-01 TC-2220-44( 01) TM3P-44P、TM4P-44P 902-0031-0-01 TC-2220-64( 01) TM3P-64P、TM4P-64P TM3P-62P 902-0032-3-01 TC-2220-66( 01) TM3P-66P、TM4P-66P 250-0228-1 TC-2220-8/10P-88-1 TM8P-88P、TM10P-88P TM10P1-88P * This tool is made of metal and offers rigidity and durability. The handle is equipped with a ratchet mechanism that allows the press fit height of the plate contact to be set uniformly, and also permits the prevention of insufficient clamping. * The tool can be used for insulation stripping of flat cables and round cables. Note that model TC2220-66(01) is for use with flat cables only. Also note that model TC-2220-8/10P-88-1 is not equipped with an insulation stripping mechanism. * The cable is pulled out by the lever which permits consistent insulation stripping. Note: Please note that depending on the specifications of the cable, there may be instances in which the insulation cannot be stripped. When using the tool with products other than Hirose Electric modular plugs, the wiring quality cannot be guaranteed; therefore, please be sure to use Hirose Electric plugs. Item Part No. CL No. Applicable connector Press CM-105 901-0005-4 Applicator Applicator 105-TMP-44 901-0195-1 TM3P-44P、TM4P-44P Applicator 105-TMP-64 901-0194-9 TM3P-64P、TM4P-64P Applicator 105-TMP-66 901-0193-6 TM3P-66P、TM4P-66P AP105-TM10P1-88P 901-2569-0 TM8P-88P、TM10P-88P TM2P-62P −35− The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. CL 222 TM Plug for Solid Wire Cable ●Material・Finish ●Electrical Performance Condition Specification Plug case Polycarbonate Material Clear Current rating Per pin 0.5A Terminal Phosphor Bronze Gold plated Voltage rating Per pin 30V AC Insulation Resistance 100V DC 100 M Ω Min. Withstanding Voltage 1 minute 500V r.m.s AC Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part name Finish Item Applicable Cable Conductor diameter φ0.4∼φ0.65 * Insulator diameter φ0.96 max. * In case of use φ0.65, not to be connected fully for 6 pins and 8 pins depend on size of insulator diameter. ●TM20P-66P CL No. 222-2275-3 Mating Condifiton Figure Part No. TM20P-66P RoHS YES (Packing unit: 100 Pcs.) Mating Condifiton Figure ●TM20P-88P CL No. 222-2217-7 Part No. TM20P-88P RoHS YES (Packing unit: 100 Pcs.) Exclusive Hand Tool for Connection CL No. 250-0240-7 250-0241-0 −36− Part No. TC2-TM20P-66P TC2-TM20P/30P-88P Applicable Connector TM20P-66P TM20P-88P The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. CL 222 TM Plug for Thin Wire Cable ●Material・Finish Part name Plug case Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Terminal Powered by TCPDF (www.tcpdf.org) ●Electrical Performance Condition Specification Polycarbonate Material 6 Pins Clear blue Finish Current rating Per pin 0.5A       * 8 Pins Clear Voltage rating Per pin 125V AC Gold plated Insulation Resistance 100V DC 100 M Ω Min. Withstanding Voltage 1 minute 500V r.m.s AC Phosphor Bronze Item *UL94V-0 Applicable Cable Conductor diameter AWG # 28(7/0.127) Insulator diameter φ0.787 max. ●TM30P-66P CL No. 222-2684-2 Part No. TM30P-66P RoHS YES Vinyl Sheath Drain wire Insulator ●TM30P-88P CL No. 222-2685-5 Part No. TM30P-88P RoHS YES Vinyl Sheath Drain wire Insulator Exclusive Hand Tool for Connection CL No. 250-0145-6 250-0241-0 −37− Part No. TC1-TM30P-66P TC2-TM20P/30P-88P Applicable Connector TM30P-66P TM30P-88P
TM3P-44P01-HYSH-HF120-1 价格&库存
很抱歉,暂时无法提供与“TM3P-44P01-HYSH-HF120-1”相匹配的价格&库存,您可以联系我们找货
