943434033
943434033
    BELDEN
    网络 交换机 - 托管型 18 个端口 IP20
943434033 数据手册
Product information Compact OpenRail Gigabit Ethernet Switch 8-24 ports RS30-1602T1T1SDAEHH09.0. Industrial Ethernet:Compact configurable managed switches:with Classic Software 9.0:Compact OpenRail Gigabit Ethernet Switch 8-24 ports https://e-catalog.beldensolutions.com:443/link/57078-24455-49854-458702-458695/en/RS30-1602T1T1SDAEHH09.0./uistate Name Compact OpenRail Gigabit Ethernet Switch 8-24 ports   18 port Gigabit/Fast-Ethernet-Switch (2 x Gigabit Ethernet, 16 x Fast Ethernet), managed, software Layer 2 Enhanced, for DIN rail store-and-forward-switching, fanless design Delivery informations Availability available Product description Description 18 port Gigabit/Fast-Ethernet-Switch (2 x Gigabit Ethernet, 16 x Fast Ethernet), managed, software Layer 2 Enhanced, for DIN rail store-and-forward-switching, fanless design Port type and quantity 18 Ports in total, 2 Gigabit Ethernet ports; 1. uplink: 10/100/1000BASE-TX, RJ45; 2. uplink: 10/100/1000BASE-TX, RJ45; 16 x standard 10/100 BASE TX, RJ45 Type RS30-1602T1T1SDAEHH09.0. Order No. 943 434-033 More Interfaces Power supply/signaling contact 1 x plug-in terminal block, 6-pin V.24 interface 1 x RJ11 socket USB interface 1 x USB to connect the AutoConfiguration Adapter ACA21-USB Network size - length of cable Twisted pair (TP) 0 m ... 100 m Network size - cascadibility Line - / star topology any Ring structure (HIPER-Ring) quantity switches 50 (reconfiguration time < 0.3 sec.) Power requirements Operating voltage 12/24/48 V DC (9,6-60) V and 24 V AC (18-30) V (redundant) Current consumption at 24 V DC 542 mA Current consumption at 48 V DC 271 mA Power output in Btu (IT) h 44.4 Software Management TFTP; LLDP (802.1AB); V.24; HTTP; Traps; SNMP v1/v2/v3; Telnet Diagnostics Management Address Conflict Detection; Address Relearn Detection; Signal Contact; Device Status Indication; LEDs; Syslog; Duplex Mismatch Detection; RMON (1,2,3,9); Port Mirroring 1:1; Port Mirroring 8:1; System Information; Self-Tests on Cold Start; SFP Management; Switch Dump Configuration AutoConfiguration Adapter ACA11 Limited Support (RS20/30/40, MS20/30); Automatic Configuration Undo (roll-back); Configuration Fingerprint; BOOTP/DHCP Client with Auto-Configuration; AutoConfiguration Adapter ACA21/22 (USB); HiDiscovery; DHCP Relay with Option 82; Command Line Interface (CLI); Fullfeatured MIB Support; Web-based Management; Context-sensitive Help Security IP-based Port Security; MAC-based Port Security; Access to Management restricted by VLAN; SNMP Logging; Local User Management Redundancy functions HIPER-Ring (Manager); HIPER-Ring (Ring Switch); Media Redundancy Protocol (MRP) (IEC62439-2); Redundant Network Coupling; RSTP 802.1D-2004 (IEC62439-1); RSTP Guards; RSTP over MRP Industrial Profiles EtherNet/IP Protocol; PROFINET IO Protocol Time synchronisation SNTP server and client Miscellaneous Manual Cable Crossing Switching Disable Learning (hub functionality); Independent VLAN Learning; Fast Aging; Static Unicast/Multicast Address Entries; QoS / Port Prioritization (802.1D/p); TOS/ DSCP Prioritization; Egress Broadcast Limiter per Port; Flow Control (802.3X); VLAN (802.1Q); IGMP Snooping/Querier (v1/v2/v3) Ambient conditions Operating temperature 0 ºC ... 60 ºC Storage/transport temperature -40 ºC ... 70 ºC Relative humidity (non-condensing) 10 % ... 95 %     Hirschmann Automation and Control GmbH   www.beldensolutions.com 09-08-2018 Page 1 of 2   Industrial Ethernet:Compact configurable managed switches:with Classic Software 9.0:Compact OpenRail Gigabit Ethernet Switch 8-24 ports https://e-catalog.beldensolutions.com:443/link/57078-24455-49854-458702-458695/en/RS30-1602T1T1SDAEHH09.0./uistate MTBF 39.7 years (MIL-HDBK-217F) Protective paint on PCB No Mechanical construction Dimensions (W x H x D) 110 mm x 131 mm x 111 mm Mounting DIN Rail Protection class IP20 Mechanical stability IEC 60068-2-27 shock 15 g, 11 ms duration, 18 shocks IEC 60068-2-6 vibration 1 mm, 2 Hz-13.2 Hz, 90 min.; 0.7 g, 13.2 Hz-100 Hz, 90 min.; 3.5 mm, 3 Hz-9 Hz, 10 cycles, 1 octave/min.; 1 g, 9 Hz-150 Hz, 10 cycles, 1 octave/min EMC interference immunity EN 61000-4-2 electrostatic discharge (ESD) 6 kV contact discharge, 8 kV air discharge EN 61000-4-3 electromagnetic field 10 V/m (80-1000 MHz) EN 61000-4-4 fast transients (burst) 2 kV power line, 1 kV data line EN 61000-4-5 surge voltage power line: 2 kV (line/earth), 1 kV (line/line), 1 kV data line EN 61000-4-6 conducted immunity 3 V (10 kHz-150 kHz), 10 V (150 kHz-80 MHz) EMC emitted immunity FCC CFR47 Part 15 FCC 47 CFR Part 15 Class A EN 55022 EN 55022 Class A Approvals Safety of industrial control equipment cUL 508 Hazardous locations ISA 12.12.01 Class 1 Div. 2 Shipbuilding n/a Railway norm n/a Substation n/a Scope of delivery and accessories Scope of delivery Device, terminal block, operating manual For more information please contact:   Hirschmann Automation and Control GmbH Stuttgarter Strasse 45-51 72654 Neckartenzlingen Germany Phone: +49 7127/14-1809 E-Mail: inet-sales@belden.com The information published in the websites has been compiled as carefully as possible. It is subject to alteration without notice in technical as well as in price-related/commercial respect. The complete information and data were available on user documentation. Mandatory information can only be obtained by a concrete query.     Hirschmann Automation and Control GmbH   www.beldensolutions.com 09-08-2018 Page 2 of 2
943434033 价格&库存
很抱歉,暂时无法提供与“943434033”相匹配的价格&库存,您可以联系我们找货
