RoHS
Compliant
SMD CRYSTAL UNITS
ETSB Series
Pb
Free
1.6*1.2 Seam Sealing Crystal
FEATURES
Very compact and thin (1.6*1.2*0.37mm max.)
Frequency range of 24 to 96M with Fund
Ideal for Wearable device and Short-range Wireless module
Lead-free. Meets the requirements for re-flow profiling using
lead-free solder
Electrical Specifications
ETSB
Type
Item
Frequency Range
F0
24 to 29.999MHz
40 to 60.000MHz
30 to 39.999MHz
Mode of Vibration
60.1 to 96.00MHz
Fundamental
Load Capacitance
Frequency Tolerance
CL
8 to 16pF
△F/ F0
±10ppm,±30ppm,±50ppm(At 25℃)
100Ω max.
80Ω max.
60Ω max.
Equivalent Series Resistance
ESR
Temperature Stability
TC
±10ppm,±15ppm,±30ppm(Refer to 25℃)
Operating Temperature Range
TOPR
-20~+70℃,-30~+85℃ Option
Storage Temperature Range
TSTG
-55~+125℃
Shunt Capacitance
C0
2pF max.
Insulator Resistance
IR
500MΩ min. (At 100VDC)
Drive Level
DL
50µW(100µW max.)
Aging
Fa
±2ppm max. (At 25℃,First year)
3000pcs/reel
Packing Unit
**Please contact us for inquiries regarding other Specifications
Mechanical Dimensions(mm)
Top View
1.60±0.10
4
3
0.55
0.50
0.55
4
3
1
2
MARKING
AREA
1
2
Recommended
Solder Pattern
0.65
0.40
0.65
40Ω max.
很抱歉,暂时无法提供与“ETSB38E0X0005E”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.88800
- 200+1.55520
- 500+1.50120
- 1000+1.47960
