ETSB60E003700E
ETSB60E003700E
    HOSONIC(鸿星)
    SIP-4
    无源晶振 9pF -30℃~+105℃
ETSB60E003700E 数据手册
RoHS Compliant SMD CRYSTAL UNITS ETSB Series Pb Free 1.6*1.2 Seam Sealing Crystal FEATURES Very compact and thin (1.6*1.2*0.37mm max.) Frequency range of 24 to 96M with Fund Ideal for Wearable device and Short-range Wireless module Lead-free. Meets the requirements for re-flow profiling using lead-free solder Electrical Specifications ETSB Type Item Frequency Range F0 24 to 29.999MHz 40 to 60.000MHz 30 to 39.999MHz Mode of Vibration 60.1 to 96.00MHz Fundamental Load Capacitance Frequency Tolerance CL 8 to 16pF △F/ F0 ±10ppm,±30ppm,±50ppm(At 25℃) 100Ω max. 80Ω max. 60Ω max. Equivalent Series Resistance ESR Temperature Stability TC ±10ppm,±15ppm,±30ppm(Refer to 25℃) Operating Temperature Range TOPR -20~+70℃,-30~+85℃ Option Storage Temperature Range TSTG -55~+125℃ Shunt Capacitance C0 2pF max. Insulator Resistance IR 500MΩ min. (At 100VDC) Drive Level DL 50µW(100µW max.) Aging Fa ±2ppm max. (At 25℃,First year) 3000pcs/reel Packing Unit **Please contact us for inquiries regarding other Specifications Mechanical Dimensions(mm) Top View 1.60±0.10 4 3 0.55 0.50 0.55 4 3 1 2 MARKING AREA 1 2 Recommended Solder Pattern 0.65 0.40 0.65 40Ω max.
ETSB60E003700E 价格&库存
很抱歉,暂时无法提供与“ETSB60E003700E”相匹配的价格&库存,您可以联系我们找货
ETSB60E003700E
    • 1+4.09320
    • 200+1.63080
    • 500+1.57680
    • 1000+1.55520
