MINIBEND-13
MINIBEND-13
    HUBER
    同轴电缆组件 SMA 至 SMA 0.086" 半刚性电缆 13.00"(330.20mm)
MINIBEND-13 数据手册
Data Sheet HUBER+SUHNER® MINIBEND™ Cable Description     Impedance 50 Ω Applicable up to 65 GHz Direct replacement for 0.086 inch semi-rigid cables Stock delivery on standard lengths What is it? MINIBEND® is a truly flexible coaxial cable assembly which is designed for use in low profile, internal, point-to-point interconnections between RF modules within communications systems. MINIBEND replaces 0.086 inch custom semi-rigid cables with standard flexible cables, eliminating the need for predefined custom lengths and bend configurations. MINIBEND provides you with a preassembled and tested high performance, cost-effective alternative in a variety of standard lengths and connector configurations. MINIBEND – Available Cable Connectors/Interfaces Compatible Connectors (Other connectors may be made available upon request) Requirements SMA SK SMP SSMA PC 1.85 PC 2.4 Technical Drawing Cable 32081 Cable 32081 Inner Conductor Dielectric Outer Conductor Barrier Outer Braid Jacket 1 2 3 4 5 6 CuAg (SPC) Wire PTFE CuAg (SPC) flat wire braid Aluminum / Polyimide Tape Stainless Steel Braid FEP Outer Diameter 2.5 mm Operating Frequency Velocity (nominal) Weight (nominal) Static Min. Bend Radius Impedance Temp. Range GHz % g/m mm Ω °C 65 70.3 14.9 5.08 50 -55 to +200           HUBER+SUHNER is certified according to EN(AS) 9100, ISO 9001, ISO 14001, ISO/TS 16949, and ISO/TS 22163. MICROBEND and MICROBEND are registered trademarks of HUBER+SUHNER in the United States of America Waiver: Fact and figures herein are for information only and do not represent any warranty of any kind. Document: Draft Rev. 1 / Date of publication: 03.2021 / uncontrolled copy Author: HUBER+SUHNER ASTROLAB / Verified: 05.2021 / Approved: 05.2021 HUBER+SUHNER and ASTROLAB are registered trademarks. All other mentioned copyrights and trademarks are property of their respective owners. www.hubersuhner.com
MINIBEND-13 价格&库存
很抱歉,暂时无法提供与“MINIBEND-13”相匹配的价格&库存,您可以联系我们找货
MINIBEND-13
库存:10
