MINIBEND R-12
MINIBEND R-12
    HUBER
    同轴电缆组件 SMA 至 SMA 0.086" 半刚性电缆 12.00"(304.80mm)
MINIBEND R-12 数据手册
Data Sheet HUBER+SUHNER® MINIBEND™ R Cable Description     Impedance 50 Ω Applicable up to 65 GHz Direct replacement for 0.086 inch semi-rigid cables Stock delivery on standard lengths What is it? MINIBEND® R is designed for use in complex, congested environments where higher cable retention force is required. MINIBEND R's pull strength is more than 70% greater than a standard MINIBEND. When installed and bent at the minimum bend radius, MINIBEND R will tolerate multiple 90° rotations at the cable/connector junction. The "R" ruggedization can be added to any MINIBEND style. All materials used in MINIBEND R assemblies meet or exceed NASA TML and CVCM requirements for use in spacecraft applications. MINIBEND™ R – Available Cable Connectors/Interfaces Compatible Connectors (Other connectors may be made available upon request) Requirements SMA SK SMP SSMA PC 1.85 PC 2.4 Technical Drawing Cable 32081 Cable 32081 Inner Conductor Dielectric Outer Conductor Barrier Outer Braid Jacket 1 2 3 4 5 6 CuAg (SPC) Wire PTFE CuAg (SPC) flat wire braid Aluminum / Polyimide Tape Stainless Steel Braid FEP Outer Diameter 2.5 mm Operating Frequency Velocity (nominal) Weight (nominal) Static Min. Bend Radius Impedance Temp. Range GHz % g/m mm Ω °C 65 70.3 14.9 5.08 50 -55 to +200           HUBER+SUHNER is certified according to EN(AS) 9100, ISO 9001, ISO 14001, ISO/TS 16949, and ISO/TS 22163. MICROBEND and MICROBEND are registered trademarks of HUBER+SUHNER in the United States of America Waiver: Fact and figures herein are for information only and do not represent any warranty of any kind. Document: Draft Rev. 1 / Date of publication: 03.2021 / uncontrolled copy Author: HUBER+SUHNER ASTROLAB / Verified: 05.2021 / Approved: 05.2021 HUBER+SUHNER and ASTROLAB are registered trademarks. All other mentioned copyrights and trademarks are property of their respective owners. www.hubersuhner.com
MINIBEND R-12 价格&库存
很抱歉,暂时无法提供与“MINIBEND R-12”相匹配的价格&库存,您可以联系我们找货
MINIBEND R-12
  • 1+886.792801+114.61727
  • 5+796.825335+102.98904
  • 10+685.6367510+88.61801
  • 20+647.4311420+83.67996
库存:48
