15DYS818-xyW-z 18W Fixed Plug Series
Universal Input 100~240VAC 50/60Hz
UL/IEC/EN 62368-1 Approved
Compliant to LVD & EMC safety
standards
RoHS & CE Directive Compliant
Level VI efficiency
OVP, OCP, OTP & Short Circuit
The purpose of the document is to specify a Single-phase AC input, single output switching power
supply. This specification is suitable for: 15DYS818-xyW-Z-2.5 12W Series. This product is AC to DC
switching power supply, it can provide 5-24V 18W max DC output constant voltage source. This
Specification defines the input, output, performance characteristics, environment, noise and safety
requirements.
Models
Model Number
Output Voltage
Output Current
Output Power
15DYS818-050300W-z
5V DC
3A
15W
15DYS818-090200W-z
9V DC
2A
18W
15DYS818-120150W-z
12V DC
1.5A
18W
15DYS818-150120W-z
15V DC
1.2A
18W
15DYS818-180100W-z
18V DC
1A
18W
15DYS818-240075W-z
24V DC
0.75A
18W
‘z’ can be: 1 = US, 2 = EU, 3 = UK, AUS = 4
Input Data
Min
Input Voltage
Input Frequency
Input Current
Inrush Current
Leakage Current
Typical
90
47
Max
Units
Notes
264
63
V AC
Hz
A
A
mA
100-240VAC +/- 10%
50-60Hz +/- 5%
0.5
0.25
At cold start, 100 / 240V AC
Output Data
Min
Output Voltage tolerance
Ripple & Noise
Over Current Protection
Short Circuit Protection
Over Voltage Protection
Typical
5%
150
Max
Units
Notes
mVp-p
Over Current Point Limited >3.9A
Continuous short circuit proof. Will recover if fault condition is removed
Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple,
Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400
Environmental Data
Minimum
Operating Temperature
Storage Temperature
Operating Humidity
Storage Humidity
Typical
10
5
Maximum
Units
Notes
+45
+80
90
95
ºC
ºC
Operating 10% to 90%
Storage 5% to 95%
Other Information
Minimum
Isolation
MTBF
Weight
Dimensions
Typical
Maximum
Units
Notes
2KVdc, between primary and secondary circuit
50,000
hrs
200 +/-10g
Refer to mechanical drawings
EMC Emissions (2014/30/EU)
Conducted
Radiated
Harmonic Standard
Standard
Test Level
Criteria
EN 55032
EN 55032
Pass
Pass
B
B
EN 61000-3-2
Class D
Notes
EMC Directive 2014/30/EU
P.F. shall >0.95 @100Vac input and >0.9 @240Vac input
EMC Immunity (2014/30/EU)
Standard
EMS
EMS
ESD
RS
EFT
Surge
Conducted
PFMF
Dips and Interruptions
EN 55035
EN 61204-3
IEC 61000-4-2
IEC 61000-4-3
IEC 61000-4-4
IEC 61000-4-5
Test Level
Criteria
Notes
B
Contact: +/- 4KV; Air: +/- 8KV
Frequency: 80-1000MHz; Field Strength: 3V/M ' 80% AM (1KHz)
0.5/1.0KV on input AC power ports
Line to Line: +/- 1KV (peak); Line to F.G: +/- 2KV (peak)
A/B
A
Safety Approvals
Safety Standards
RoHS/REACH
CE LVD Directive 2014/35/EU
cULus
TUV
RCM & C-Tick
RoHS Directive (EU) 2015/863 & REACH (205 SVHC)
Yes (UK/European) – Only applicable for UK & EURO plugs. (-1) (-2)
Yes – Only applicable for US plug. (-1)
Yes (German/European) – Only applicable for EURO plug. (-2)
Yes – Only applicable for Australian plug. (-4)
Mechanical Drawing
很抱歉,暂时无法提供与“15DYS818-150120W-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+91.815371+11.91913
- 5+84.415265+10.95848
- 10+81.4160810+10.56913
- 25+77.6179725+10.07608
- 50+74.8651050+9.71871
- 100+72.20987100+9.37402
- 250+68.84406250+8.93708
- 500+66.40184500+8.62004
