15DYS830-050400W-1-2.5
    IDEALPOWER(理想电源)
    5V 20 W AC/DC 外部 壁装(II 类) 适配器 固定插片 输入
15DYS830-050400W-1-2.5 数据手册
15DYS830-xyW-z 30W Fixed Plug Series • • • • • • • Universal Input 100~240VAC 50/60Hz Universal Input 100~240VAC 50/60Hz • UL/IEC/EN 62368-1 Approved UL/IEC/EN 62368-1 Approved • Compliant EMC standards safety standards Compliant to LVDto & LVD EMC&safety • &RoHS & CE Directive Compliant RoHS CE Directive Compliant • VILevel VI efficiency Level efficiency • OCP, OVP,OTP OCP, Short Circuit Protection OVP, & OTP Short&Circuit Protection The purpose of the document is to specify a Single-phase AC input, single output switching power supply. This specification is suitable for: 15DYS830-xyW-Z 30W Series. This product is AC to DC switching power supply, it can provide 5-30V 30W max DC output constant voltage source. This Specification defines the input, output, performance characteristics, environment, noise and safety requirements. Models Model Number Output Voltage Output Current Output Power 15DYS830-050400W-z 5V DC 4A 20W 15DYS830-120250W-z 12V DC 2.5A 30W 15DYS830-150200W-z 15V DC 2A 30W 15DYS830-180166W-z 18V DC 1.66A 30W 15DYS830-240125W-z 24V DC 1.25A 30W 15DYS830-300100W-z 30V DC 1A 30W ‘z’ can be: 1 = US, 2 = EU, 3 = UK, AUS = 4 Input Data Min Input Voltage Input Frequency Input Current Inrush Current Leakage Current Typical 90 47 Max Units Notes 264 63 V AC Hz A A mA 100-240VAC +/- 10% 50-60Hz +/- 5% 0.8 0 60 0.25 At cold start, 100 / 240V AC Output Data Min Output Voltage tolerance Ripple & Noise Over Current Protection Short Circuit Protection Over Voltage Protection Typical 5% 150 Max Units Notes % MVp-p Over Current Point Limited >2.6A Continuous short circuit proof. Will recover if fault condition is removed Will recover if fault condition is removed Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 15DYS830-xyW-z 30W Fixed Plug Series Environmental Data Minimum Operating Temperature Storage Temperature Operating Humidity Storage Humidity Typical 0 -20 10 5 Maximum Units Notes +40 +80 90 95 ºC ºC % % Operating 10% to 90% Storage 5% to 95% Other Information Minimum Isolation MTBF Weight Dimensions Typical Maximum Units Notes 2KVdc, between primary and secondary circuit 50,000 hrs 200 +/-10g Refer to mechanical drawings EMC Emissions (2014/30/EU) Conducted Radiated Harmonic Standard Standard Test Level Criteria EN 55032 EN 55032 Pass Pass B B EN 61000-3-2 Class D Notes EMC Directive 2014/30/EU P.F. shall >0.95 @100Vac input and >0.9 @240Vac input EMC Immunity (2014/30/EU) Standard EMS EMS ESD RS EFT Surge Conducted PFMF Dips and Interruptions EN 55035 EN 61204-3 IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-5 Test Level Criteria Notes B Contact: +/- 4KV; Air: +/- 8KV Frequency: 80-1000MHz; Field Strength: 3V/M ' 80% AM (1KHz) 0.5/1.0KV on input AC power ports Line to Line: +/- 1KV (peak); Line to F.G: +/- 2KV (peak) A/B A Safety Approvals Safety Standards RoHS/REACH CE LVD Directive 2014/35/EU cULus TUV RCM & C-Tick RoHS Directive (EU) 2015/863 & REACH (205 SVHC) Yes (UK/European) – Only applicable for UK & EURO plugs. (-1) (-2) Yes – Only applicable for US plug. (-1) Yes (German/European) – Only applicable for EURO plug. (-2) Yes – Only applicable for Australian plug. (-4) Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 15DYS830-xyW-z 30W Fixed Plug Series Mechanical Drawing Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 15DYS830-xyW-z 30W Fixed Plug Series Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400
15DYS830-050400W-1-2.5 价格&库存
很抱歉,暂时无法提供与“15DYS830-050400W-1-2.5”相匹配的价格&库存,您可以联系我们找货
  • 96+95.9457096+12.39927
