15DYS902-480200G
15DYS902-480200G
    IDEALPOWER(理想电源)
    48V 96 W AC/DC 外部 台式(类 II) 适配器 缆线(单独出售) 输入
15DYS902-480200G 数据手册
15DYS902-xyG C8 Inlet 96W Desktop Series • • • • • • • Universal Input 100~240VAC 50/60Hz UL/IEC/EN 62368-1 Approved Compliant to LVD & EMC safety standards RoHS & CE Directive Compliant Level VI efficiency OVP, OCP, OTP & Short Circuit Protection C8 Inlet The purpose of the document is to specify a Single-phase AC input, single output switching power supply. This specification is suitable for: 15DYS902-xyW 96W Series. This product is AC to DC switching power supply, it can provide 9-30V 96W max DC output constant voltage source. This Specification defines the input, output, performance characteristics, environment, noise and safety requirements. Models Model Number Output Voltage Output Current Output Power 15DYS902-090750G 9V DC 7.5A 67.5W 15DYS902-120750G 12V DC 7.5A 90W 15DYS902-150600G 15V DC 6A 90W 15DYS902-240400G 24V DC 4A 96W 15DYS902-320300G 32V DC 3A 96W 15DYS902-480200G 48V DC 2A 96W Input Data Min Input Voltage Input Frequency Input Current Inrush Current Leakage Current Typical 90 47 0 Max Units Notes 264 63 1.5 80 0.25 V AC Hz A A mA 100-240VAC +/- 10% 50-60Hz +/- 5% At cold start, 100 / 240V AC Output Data Min Output Voltage tolerance Ripple & Noise Over Current Protection Short Circuit Protection Over Voltage Protection Typical 5% 200 Max Units Notes % mVp-p Over Current Point Limited >3.9A Continuous short circuit proof. Will recover if fault condition is removed Will recover if fault condition is removed Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 15DYS902-xyG C8 Inlet 96W Desktop Series Environmental Data Minimum Operating Temperature Storage Temperature Operating Humidity Storage Humidity Typical 0 -20 10 5 Maximum Units Notes +40 +80 90 95 ºC ºC % % Operating 10% to 90% Storage 5% to 95% Other Information Minimum Dielectric Strength MTBF Weight Dimensions Typical Maximum Units Notes Primary to Secondary: 4242VDC/5mAMax (3 seconds) hrs At 25°C, Full load and nominal 450 g -10/+10 Depending on model Refer to mechanical drawings 50,000 EMC Emissions (2014/30/EU) Conducted Radiated Standard Test Level Criteria EN 55032 EN 55032 Pass Pass B B Notes EMC Directive 2014/30/EU EMC Immunity (2014/30/EU) Standard EMS ESD EFT Surge EN 55035 IEC 61000-4-2 IEC 61000-4-4 IEC 61000-4-5 Test Level Criteria Notes B A/B A Contact: +/- 4KV; Air: +/- 8KV 0.5/1.0KV on input AC power ports Differential mode: +/- 2KV, Common mode: +/- 2KV Safety Approvals Safety Standards RoHS/REACH CE LVD Directive 2014/35/EU cULus TUV RCM & C-Tick RoHS Directive (EU) 2015/863 & REACH (205 SVHC) Yes (UK/European) Yes Yes Yes Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 15DYS902-xyG C8 Inlet 96W Desktop Series Mechanical Drawing Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 15DYS902-xyG C8 Inlet 96W Desktop Series Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400
15DYS902-480200G 价格&库存
很抱歉,暂时无法提供与“15DYS902-480200G”相匹配的价格&库存,您可以联系我们找货
