23SW-00120500-S10B-US
    IDEALPOWER(理想电源)
    12V 60 W AC/DC 外部 台式(类 II) 适配器 缆线(单独出售) 输入
23SW-00120500-S10B-US 数据手册
23SW 54-65W Lugged Series • • • • • • • • Universal Input 100~240VAC 50/60Hz UL/IEC/EN 62368-1 Approved Compliant to LVD & EMC safety standards RoHS & CE Directive Compliant Level VI efficiency OVP, OCP, OTP & Short Circuit Protection C8 Inlet 2.1 & 2.5x5.5 DC Connector Available The purpose of the document is to specify a Single-phase AC input, single output switching power supply. This specification is suitable for: 23SW 65W Series. This product is AC to DC switching power supply, it can provide 9-24V 60W max DC output constant voltage source. This Specification defines the input, output, performance characteristics, environment, noise and safety requirements. Models Model Number Output Voltage Output Current Output Power 23SW-00090600-S10B 9V DC 6A 54W 23SW-00120500-S10B 12V DC 5A 60W 23SW-00150400-S10B 15V DC 4A 60W 23SW-00180330-S10B 18V DC 3.3A 60W 23SW-00240271-S10B 24V DC 2.71 65W Input Data Min Input Voltage Input Frequency Input Current Inrush Current Leakage Current Typical 90 47 0 Max Units Notes 264 63 0.6 50 0.25 V AC Hz A A mA 100-240VAC +/- 10% 50-60Hz +/- 5% At cold start, 100 / 240V AC Output Data Min Output Voltage tolerance Ripple & Noise Over Current Protection Short Circuit Protection Over Voltage Protection Typical 5% 120 Max Units Notes % mV OCP Limits to 120~150& Auto Start. PSU will auto recover after OC. Continuous short circuit proof. Will recover if fault condition is removed Will recover if fault condition is removed Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 23SW 54-65W Lugged Series Environmental Data Minimum Operating Temperature Storage Temperature Operating Humidity Storage Humidity Typical 0 -20 10 5 Maximum Units Notes +40 +85 90 95 ºC ºC % % Operating 10% to 90% Storage 5% to 95% Other Information Minimum Dielectric Strength MTBF Weight Dimensions Typical Maximum Units Notes Primary to Secondary: 4242VDC/5mAMax (3 seconds) hrs At 25°C, Full load and nominal 200 +/-10g Depending on model Refer to mechanical drawings 50,000 EMC Emissions (2014/30/EU) Conducted Radiated Harmonic Standard Standard Test Level Criteria EN 55032 EN 55032 Pass Pass B B EN 61000-3-2 Class D Notes EMC Directive 2014/30/EU P.F. shall >0.95 @100Vac input and >0.9 @240Vac input EMC Immunity (2014/30/EU) Standard EMS EMS ESD RS EFT Surge Test Level Criteria Notes EN 55035 EN 61204-3 IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-5 Safety Approvals Safety Standards RoHS/REACH CE LVD Directive 2014/35/EU cULus FCC TUV RCM & C-Tick RoHS Directive (EU) 2015/863 & REACH (205 SVHC) Yes (UK/European) Yes Yes Yes Yes Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 23SW 54-65W Lugged Series Mechanical Drawing Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400
23SW-00120500-S10B-US 价格&库存
很抱歉,暂时无法提供与“23SW-00120500-S10B-US”相匹配的价格&库存,您可以联系我们找货
