25HK-AB-090A250-D56
25HK-AB-090A250-D56
    IDEALPOWER(理想电源)
    9V 23 W AC/DC 外部 壁装(I 类) 适配器 电线,多插片 输入
25HK-AB-090A250-D56 数据手册
25HK-AB-xxxAzzz-CP 30W Interchangeable Series • • • • • • Universal Input 100~240VAC 50/60Hz UL/IEC/EN 62368-1 Approved Compliant to LVD & EMC safety standards RoHS & CE Directive Compliant Level VI efficiency OVP, OCP, OTP & Short Circuit Protection The purpose of the document is to specify a Single-phase AC input, single output switching power supply. This specification is suitable for: 25HK-AB-xxxAzzz-CP 30W Series. This product is AC to DC switching power supply, it can provide 5-24V 30W max DC output constant voltage source. This Specification defines the input, output, performance characteristics, environment, noise and safety requirements. Models Model Number Output Voltage Output Current Output Power 25HK-AB-050A400-CP 5V DC 4A 20W 25HK-AB-090A250-CP 9V DC 2.5A 22.5W 25HK-AB-120A250-CP 12V DC 2.5A 30W 25HK-AB-150A200-CP 15V DC 2A 30W 25HK-AB-240A100-CP 24V DC 1.25A 30W Input Data Min Input Voltage Input Frequency Input Current Inrush Current Leakage Current Typical 90 47 Max Units Notes 264 63 V AC Hz A A mA 100-240VAC +/- 10% 50-60Hz +/- 5% 0.8 0 50 0.25 At cold start, 100 / 240V AC Output Data Min Output Voltage tolerance Ripple & Noise Over Current Protection Short Circuit Protection Over Voltage Protection Typical Max Units 120 % mV 5% Notes Overload conditions shall decrease the output voltage. Auto Recovery Will recover if fault condition is removed Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 25HK-AB-xxxAzzz-CP 30W Interchangeable Series Environmental Data Minimum Operating Temperature Storage Temperature Operating Humidity Storage Humidity Typical 0 -20 10 10 Maximum Units Notes 40 +70 95 95 ºC ºC % % Operating 10% to 90% Storage 5% to 95% Other Information Minimum Dielectric Strength MTBF Weight Dimensions Typical Maximum Units Notes AC 3KV, 2 second, 4mA, Max primary to secondary/case. 50,000 hrs 200 +/-10g Refer to mechanical drawings EMC Emissions (2014/30/EU) Conducted Radiated Harmonic Standard Voltage fluctuations Standard Test Level Criteria EN 55032 EN 55032 Pass Pass B B EN 61000-3-2 EN 61000-3-3 N/A Notes EMC Directive 2014/30/EU Class D Voltage fluctuations & Flicker Meets requirements EMC Immunity (2014/30/EU) Standard ESD RS EFT Surge Conducted PFMF Dips and Interruptions IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-5 IEC 61000-4-6 IEC 61000-4-8 IEC 61000-4-11 Test Level Criteria Pass Notes Contact: +/- 4KV; Air: +/- 8KV Frequency: 80-1000MHz; Field Strength: 3V/M ' 80% AM (1KHz) 0.5/1.0KV on input AC power ports Line to Line: +/- 1KV (peak); Line to F.G: +/- 2KV (peak) CS: 0.15~ 80MHz, 3Vrm, 80% AM, 1kHz 50 Hz or 60Hz, 1A/m V/D: >95% reduction for 0.5 period VI:>95% reduction for 250 peroid. Safety Approvals Safety Standards RoHS/REACH CE LVD Directive 2014/35/EU cULus TUV RCM & C-Tick RoHS Directive (EU) 2015/863 & REACH (205 SVHC) Yes (UK/European) Yes – (US) Yes (German/European) Yes –(Australian plug) Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 25HK-AB-xxxAzzz-CP 30W Interchangeable Series Mechanical Drawing Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 25HK-AB-xxxAzzz-CP 30W Interchangeable Series Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 25HK-AB-xxxAzzz-CP 30W Interchangeable Series Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400
25HK-AB-090A250-D56 价格&库存
很抱歉,暂时无法提供与“25HK-AB-090A250-D56”相匹配的价格&库存,您可以联系我们找货
25HK-AB-090A250-D56
  • 1+117.484211+15.27257
  • 5+108.010815+14.04106
  • 10+104.1743110+13.54233
  • 25+99.3181525+12.91104
  • 50+95.7971550+12.45332
  • 100+92.39880100+12.01155
  • 250+88.09163250+11.45163
  • 500+84.96682500+11.04542
库存:110
