25HK-AY-090A266-CP
25HK-AY-090A266-CP
    IDEALPOWER(理想电源)
    9V 24 W AC/DC 外部 壁装(II 类) 适配器 多插片(包括) 输入
25HK-AY-090A266-CP 数据手册
25HK-AY-xxxAzzz-CP 24W Interchangeable Series • • • • • • Universal Input 100~240VAC 50/60Hz UL/IEC/EN 62368-1 Approved Compliant to LVD & EMC safety standards RoHS & CE Directive Compliant Level VI efficiency OVP, OCP, OTP & Short Circuit Protection The purpose of the document is to specify a Single-phase AC input, single output switching power supply. This specification is suitable for: 25HK-AY-xxxAzzz-CP 24W Series. This product is AC to DC switching power supply, it can provide 5-24V 24W max DC output constant voltage source. This Specification defines the input, output, performance characteristics, environment, noise and safety requirements. Models Model Number Output Voltage Output Current Output Power 25HK-AY-050A300-CP 5V DC 3A 15W 25HK-AY-090A266-CP 9V DC 2.66A 24W 25HK-AY-120A200-CP 12V DC 2A 24W 25HK-AY-150A160-CP 15V DC 1.60A 24W 25HK-AY-240A100-CP 24V DC 1A 24W Input Data Min Input Voltage Input Frequency Input Current Inrush Current Leakage Current Typical 90 47 Max Units Notes 264 63 V AC Hz A A mA 100-240VAC +/- 10% 50-60Hz +/- 5% 0.8 0 60 0.25 At cold start, 100 / 240V AC Output Data Min Output Voltage tolerance Ripple & Noise Over Current Protection Short Circuit Protection Over Voltage Protection Typical Max Units 200 % mV 5% Notes Overload conditions shall decrease the output voltage. Auto Recovery Will recover if fault condition is removed Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 25HK-AY-xxxAzzz-CP 24W Interchangeable Series Environmental Data Minimum Operating Temperature Storage Temperature Operating Humidity Storage Humidity Typical 0 -20 10 10 Maximum Units Notes 40 +70 95 95 ºC ºC % % Operating 10% to 90% Storage 5% to 95% Other Information Minimum Dielectric Strength MTBF Weight Dimensions Typical Maximum Units Notes AC 3000Vrms, 4mA, 1 Minute for type test. 50,000 hrs 200 +/-10g Refer to mechanical drawings EMC Emissions (2014/30/EU) Conducted Radiated Harmonic Standard Voltage fluctuations Standard Test Level Criteria EN 55032 EN 55032 Pass Pass B B EN 61000-3-2 EN 61000-3-3 Pass Notes EMC Directive 2014/30/EU Class A Voltage fluctuations & Flicker EMC Immunity (2014/30/EU) Standard ESD RS EFT Surge Conducted PFMF Dips and Interruptions IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-5 IEC 61000-4-6 IEC 61000-4-8 IEC 61000-4-11 Test Level Criteria Pass Notes Contact: +/- 4KV; Air: +/- 8KV Frequency: 80-1000MHz; Field Strength: 3V/M ' 80% AM (1KHz) 0.5/1.0KV on input AC power ports Line to Line: +/- 1KV (peak); Line to F.G: +/- 2KV (peak) CS: 0.15~ 80MHz, 3Vrm, 80% AM, 1kHz 50 Hz or 60Hz, 1A/m V/D: >95% reduction for 0.5 period VI:>95% reduction for 250 peroid. Safety Approvals Safety Standards RoHS/REACH CE LVD Directive 2014/35/EU cULus TUV RCM & C-Tick RoHS Directive (EU) 2015/863 & REACH (205 SVHC) Yes (UK/European) Yes – (US) Yes (German/European) Yes – (Australian) Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 25HK-AY-xxxAzzz-CP 24W Interchangeable Series Mechanical Drawing Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 25HK-AY-xxxAzzz-CP 24W Interchangeable Series Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 25HK-AY-xxxAzzz-CP 24W Interchangeable Series Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400 25HK-AY-xxxAzzz-CP 24W Interchangeable Series Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400
25HK-AY-090A266-CP 价格&库存
很抱歉,暂时无法提供与“25HK-AY-090A266-CP”相匹配的价格&库存,您可以联系我们找货
