56YSD15S-0502400
56YSD15S-0502400
    IDEALPOWER(理想电源)
    AC/DC DIN RAIL SUPPLY 5V 12W
56YSD15S-0502400 数据手册
56YSD15S 15W DIN Rail Series Features • • • • • • • • • • • • Universal Input 90~264VAC 50/60Hz Output Voltages: 5-24V DC IEC/UL/EN 60950-1 Meets the latest Safety Standards and Approvals Single Output to 15W High Efficiency 100% Full load burn-in Test Low Ripple & Noise ClassⅡ Protection: Overload/Over voltage/Short circuit Dimensions: 58 x 18 x 90mm Weight: 78g The 15W Series is a cost-effective, energy efficient DIN-rail mount AC-DC converter. The products offers cULus, LVD 60950-1 & EMC EN 55032 compliant products. These AC-DC converters come in at 78gm meaning they are light and compact. They are ideal for applications such as Industrial automation, control equipment and electronic systems as well as many other applications. Models Model Number Output Voltage Output Current Output Power 56YSD15S-0502400 56YSD15S-1201250 56YSD15S-2400630 5V DC 12V DC 24V DC 2.4A 1.25A 0.63A 12W 15W 15W General Specification Type DIN Rail Power Supply AC or DC Input Voltage AC AC or DC Output Voltage Number of Outputs DC 1 Mounting Style Din Rail Mount Connection Type Screw Terminal Type Overload Protection Over Current Protection >130%-200% rated output power (Hiccup mode, recovers automatically after fault condition is removed) 110% - 180% Short Circuit Protection Protection to Zero Voltage Over Voltage Protection 110~145% (Protection Type: Clamp by zener diode) Ideal Power Limited 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ. www.idealpower.co.uk | +44 (0) 845 260 3400 56YSD15S 15W DIN Rail Series Mechanical Specifications Housing Material Overall Dimensions Overall Length Overall Depth Overall Width Weight Fully Enclosed Plastic Case 58mm x 18mm x 90mm 90mm 58mm 18mm 78g Input Specifications Input Electrical Phase Line Frequency Inrush Current AC Current Efficiency Type Leakage Current Single 47-63Hz 25 Amps max. at 115VAC/60Hz,full load & 45Amps max. at 240VAC/50Hz,full load 0.5A/115VAC 0.25A/230VAC 79~86% Depending on Model <0.25mA/240VAC Output Specifications Output Voltage Adjustment Ripple and Noise Line Regulation Load Regulation Isolation Resistance Setup, Rise, Hold Up time MTBF +/- 10% Depending on Model 80~150 mV Depending on Model ± 1% ± 1% I/P-O/P:100M Ohms / 500VDC / 25 / 70% RH 2S/80mS/15mS(115V/60HZ MAX ROAD), 1S/80mS/30mS(230V/50HZ MAX ROAD) 200000 h Operational Environment Operating Humidity Operating Temperature Range Storage Temperature Range Storage Humidity Cooling 20% ~ 90% RH non-condensing -20℃ to 50℃,Full load, Normal operation. -40℃ to 80℃ 10% ~ 90% RH Cooling Protection Category IP Rating IP20 Ideal Power Limited 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ. www.idealpower.co.uk | +44 (0) 845 260 3400 56YSD15S 15W DIN Rail Series Approvals Safety Standard UL60950-1, UL508, , BSMI CNS14336-1,TUV EN61558-2-16 IEC60950-1, EAC TPTC 004,TUV EN60950-1 EMC Emissions EN55032(CISPR32), CNS13438 Class B ,EN61000-3-2 ClassA ,EN61000-3-3,EN61000-4-2,3,4,5,6,8,11, EN55024, EN55035, EN61000-6-2, EN61204-3 Mechanical Drawing Ideal Power Limited 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ. www.idealpower.co.uk | +44 (0) 845 260 3400
56YSD15S-0502400 价格&库存
很抱歉,暂时无法提供与“56YSD15S-0502400”相匹配的价格&库存,您可以联系我们找货
56YSD15S-0502400
  • 1+120.113781+15.50569
  • 10+105.5567110+13.62649
  • 25+100.2693125+12.94393
  • 50+96.4492650+12.45080
  • 100+92.77339100+11.97627
  • 300+87.23321300+11.26108
  • 500+84.77060500+10.94318
  • 1000+81.540721000+10.52623
库存:370
