44ATM120T-P240
44ATM120T-P240
    IDEALPOWER(理想电源)
    24V 120 W AC/DC 外部 台式(类 I) 适配器 缆线(单独出售) 输入
44ATM120T-P240 数据手册
44ATM120T-P 120W Desktop Series Features • • • • • • • • • • • • • • Universal Input 100~240VAC 50/60Hz IEC/EN/ANSI/AAMI ES 60601-1 (ED 3.1) EMC: IEC60601-1-2:2014(ED 4.0) Safety Approvals: cULus / UKCA / CB / PSE / FCC / CE / TUV / RoHS / REACH Means of Protection: 2 X MOPP Touch Current: < 100µA Single Output to 120W Regulated Output with Low Ripple Noise Safety Agency Requirements and EMI/EMS Certified Meets DoE Level VI, Energy Star, ErP Stage 2 No Load Power Consumption Less Than 0.21W IEC C14 Connector Dimensions: L 168 x W 66 x H 39 (mm) Weight: 590g The purpose of the document is to specify a Single-phase AC input, single output switching power supply. This specification is for: Desktop Power Supplies 120W Series. This product is suitable for use in medical applications. This Specification defines the input, output, performance characteristics, environment, noise and safety requirements. Models Model Number Output Voltage Output Current Output Power 44ATM120T-P120 44ATM120T-P150 44ATM120T-P180 44ATM120T-P200 44ATM120T-P240 44ATM120T-P480 12V DC 15V DC 18V DC 20V DC 24V DC 48V DC 9A 8A 6.67A 6A 5A 2.5A 108W 120W 120W 120W 120W 120W General Specification Type Switched Mode Power Supply Input Connector IEC 320-C14 Output Connection 4 Pin Kycon 1 Number of Outputs Energy Efficiency Level Mounting Style VI Desktop MTBF 300,000 hours calculated at 25ºC, by Telcoria SR-332 Power Indicator LED Indicator for power on Cable Length 1200mm(±30mm) – 1500mm(±30mm) Depending on Model Cable Type 16AWG/18AWG/20AWG (Depending on model) Medical Approved Yes Ideal Power Limited 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ. www.idealpower.co.uk | +44 (0) 845 260 3400 44ATM120T-P 120W Desktop Series Mechanical Specifications Housing Material Overall Dimensions Overall Length Overall Height Overall Width Weight Fully Enclosed Plastic Case 168mm x 66mm x 39mm 168mm 39mm 66mm 590g Input Specifications Rated Input Voltage Rated Frequency Efficiency Level VI Input Current Inrush Current Touch Current Input Protection 100~240Vac (±10%) 50/60Hz Level VI / Efficiency (EU) 2019/1782 1.5A-0.7A 100A Max. / 230Vac (Cold Start At 25ºC, Full Load) Less than 100μA Internal Primary Current Fuse Output Specifications Output Regulation Ripple & Noise (max.) Voltage Tolerance Load Regulation No Load Power Consumption Number of Outputs Insulation Class Dielectric Strength Isolation Resistance Short Circuit Protection Over Voltage Protection Over Current Protection ±5% 1% Vp-p Max. for Output Voltage @ Full Load (1.25% for 12V Model) ±5% ±5%
44ATM120T-P240 价格&库存
很抱歉,暂时无法提供与“44ATM120T-P240”相匹配的价格&库存,您可以联系我们找货
