44ATM160T-P 160W Desktop Series
Features
Universal Input 100~240VAC 50/60Hz
IEC/EN/ANSI/AAMI ES 60601-1 (ED 3.1)
EMC: IEC60601-1-2:2014(ED 4.0)
Safety Approvals: cULus / UKCA / CB / PSE /
FCC / CE / TUV / RoHS / REACH
Means of Protection: 2 X MOPP
Touch Current: < 100µA
Single Output to 160W
Regulated Output with Low Ripple Noise
Safety Agency Requirements and EMI/EMS
Certified
Meets DoE Level VI, Energy Star, ErP Stage 2
No Load Power Consumption Less Than
0.21W
IEC C14 Connector
Dimensions: L 183 x W 81 x H 42 (mm)
Weight: 820g
The purpose of the document is to specify a Single-phase AC input, single output switching power supply. This
specification is for: Desktop Power Supplies 160W Series. This product is suitable for use in medical applications.
This Specification defines the input, output, performance characteristics, environment, noise and safety
requirements.
Models
Model Number
Output Voltage
Output Current
Output Power
44ATM160T-P120
44ATM160T-P240
44ATM160T-P480
12V DC
24V DC
48V DC
12.5A
6.6A
3.3A
150W
158.4W
158.4W
General Specification
Type
Switched Mode Power Supply
Input Connector
IEC 320-C14
Output Connection
4 Pin Kycon
1
Number of Outputs
Energy Efficiency Level
Mounting Style
VI
Desktop
MTBF
300,000 hours calculated at 25ºC, by Telcoria SR-332
Power Indicator
LED Indicator for power on
Cable Length
1200mm(±30mm) – 1500mm(±30mm) Depending on Model
Cable Type
16AWG/18AWG/20AWG (Depending on model)
Medical Approved
Yes
Ideal Power Limited
14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ.
www.idealpower.co.uk | +44 (0) 845 260 3400
Mechanical Specifications
Housing Material
Overall Dimensions
Overall Length
Overall Height
Overall Width
Weight
Fully Enclosed Plastic Case
183mm x 81mm x 42mm
183mm
42mm
81mm
820g
Input Specifications
Rated Input Voltage
Rated Frequency
Efficiency Level VI
Input Current
Inrush Current
Touch Current
Input Protection
100~240Vac (±10%)
50/60Hz
Level VI / Efficiency (EU) 2019/1782
1.8A-0.9A
100A Max. / 230Vac (Cold Start At 25ºC, Full Load)
Less than 100μA
Internal Primary Current Fuse
Output Specifications
Output Regulation
Ripple & Noise (max.)
Voltage Tolerance
Load Regulation
Number of Outputs
Insulation Class
Dielectric Strength
Isolation Resistance
Short Circuit Protection
Over Voltage Protection
Over Current Protection
±5%
240 mV for 12V Model, 480 mV for 24V Model , 960 mV for 48V Model
±5%
±5%
很抱歉,暂时无法提供与“44ATM160T-P240”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+960.121231+124.20634
