44ATM200T-P190
44ATM200T-P190
    IDEALPOWER(理想电源)
    19V AC/DC 外部 台式(类 I) 适配器 缆线(单独出售) 输入
44ATM200T-P190 数据手册
44ATM200T-P 200W Desktop Series Features • • • • • • • • • • • • • • Universal Input 100~240VAC 50/60Hz IEC/EN/ANSI/AAMI ES 60601-1 (ED 3.1) EMC: IEC60601-1-2:2014(ED 4.0) Safety Approvals: cULus / UKCA / CB / PSE / FCC / CE / TUV / RoHS / REACH Means of Protection: 2 X MOPP Touch Current: < 100µA Single Output to 200W Regulated Output with Low Ripple Noise Safety Agency Requirements and EMI/EMS Certified Meets DoE Level VI, Energy Star, ErP Stage 2 No Load Power Consumption Less Than 0.21W IEC C14 Connector Dimensions: L 204 x W 81 x H 42.5 (mm) Weight: 880g The purpose of the document is to specify a Single-phase AC input, single output switching power supply. This specification is for: Desktop Power Supplies 200W Series. This product is suitable for use in medical applications. This Specification defines the input, output, performance characteristics, environment, noise and safety requirements. Models Model Number Output Voltage Output Current Output Power 44ATM200T-P120 44ATM200T-P150 44ATM200T-P180 44ATM200T-P190 44ATM200T-P240 44ATM200T-P480 12V DC 15V DC 18V DC 19V DC 24V DC 48V DC 16A 13A 11A 10.5A 8.3A 4.17A 192W 195W 198W 199.5W 199.2W 200W General Specification Type Switched Mode Power Supply Input Connector IEC 320-C14 Output Connection 4 Pin Kycon 1 Number of Outputs Energy Efficiency Level Mounting Style VI Desktop MTBF 300,000 hours calculated at 25ºC, by Telcoria SR-332 Power Indicator LED Indicator for power on Cable Length 1200mm(±30mm) or 1500mm(±30mm) Depending on Model Cable Type 16AWG/18AWG/20AWG (Depending on model) Medical Approved Yes Ideal Power Limited 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ. www.idealpower.co.uk | +44 (0) 845 260 3400 44ATM200T-P 200W Desktop Series Mechanical Specifications Housing Material Overall Dimensions Overall Length Overall Height Overall Width Weight Fully Enclosed Plastic Case 204mm x 116mm x 47mm 204mm 42.5mm 81mm 880g Input Specifications Rated Input Voltage Rated Frequency Efficiency Level VI Input Current Inrush Current Touch Current Input Protection 100~240Vac (±10%) 50/60Hz Level VI / Efficiency (EU) 2019/1782 2.5A-0.9A 100A Max. / 230Vac (Cold Start At 25ºC, Full Load) Less than 100μA Internal Primary Current Fuse Output Specifications Output Regulation Ripple & Noise (max.) Voltage Tolerance Load Regulation No Load Power Consumption Number of Outputs Insulation Class Dielectric Strength Isolation Resistance Over Circuit Protection Over Voltage Protection Over Current Protection ±5% 1% Vp-p Max. for Output Voltage @ Full Load ±5% ±5%
44ATM200T-P190 价格&库存
很抱歉,暂时无法提供与“44ATM200T-P190”相匹配的价格&库存,您可以联系我们找货
