44ATM250T-P120
44ATM250T-P120
    IDEALPOWER(理想电源)
    12V AC/DC 外部 台式(类 I) 适配器 缆线(单独出售) 输入
44ATM250T-P120 数据手册
44ATM250T-P 250W Desktop Series Features • • • • • • • • • • • • • • Universal Input 100~240VAC 50/60Hz IEC/EN/ANSI/AAMI ES 60601-1 (ED 3.1) EMC: IEC60601-1-2:2014(ED 4.0) Safety Approvals: cULus / UKCA / CB / PSE / FCC / CE / TUV / RoHS / REACH Means of Protection: 2 X MOPP Touch Current: < 100µA Single Output to 250W Regulated Output with Low Ripple Noise Safety Agency Requirements and EMI/EMS Certified Meets DoE Level VI, Energy Star, ErP Stage 2 No Load Power Consumption Less Than 0.21W IEC C14 Connector Dimensions: L 204 x W 94 x H 43.5 (mm) Weight: 1145g The purpose of the document is to specify a Single-phase AC input, single output switching power supply. This specification is for: Desktop Power Supplies 250W Series. This product is suitable for use in medical applications. This Specification defines the input, output, performance characteristics, environment, noise and safety requirements. Models Model Number Output Voltage Output Current Output Power 44ATM250T-P120 44ATM250T-P150 44ATM250T-P240 12V DC 15V DC 24V DC 20A 16.66A 10.4A 240W 250W 250W General Specification Type Switched Mode Power Supply Input Connector IEC 320-C14 Output Connection 6 Pin Molex 39-01-2060 1 Number of Outputs Energy Efficiency Level Mounting Style VI Desktop MTBF 300,000 hours calculated at 25ºC, by Telcoria SR-332 Power Indicator LED Indicator for power on Cable Length 1200mm(±30mm) Cable Type 16AWG Medical Approved Yes Ideal Power Limited 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ. www.idealpower.co.uk | +44 (0) 845 260 3400 44ATM250T-P 250W Desktop Series Mechanical Specifications Housing Material Overall Dimensions Overall Length Overall Height Overall Width Weight Fully Enclosed Plastic Case 204mm x 94mm x 43.5mm 204mm 43.5mm 94mm 1145g Input Specifications Rated Input Voltage Rated Frequency Efficiency Level VI Input Current Inrush Current Touch Current Input Protection 100~240Vac (±10%) 50/60Hz Level VI / Efficiency (EU) 2019/1782 3.3A-1.3A 100A Max. / 230Vac (Cold Start At 25ºC, Full Load) Less than 100μA Internal Primary Current Fuse Output Specifications Output Regulation Ripple & Noise (max.) Voltage Tolerance Load Regulation No Load Power Consumption Number of Outputs Insulation Class Dielectric Strength Isolation Resistance Over Circuit Protection Over Voltage Protection Over Current Protection ±5% 1% Vp-p Max. for Output Voltage @ Full Load ±5% ±5%
44ATM250T-P120 价格&库存
很抱歉,暂时无法提供与“44ATM250T-P120”相匹配的价格&库存,您可以联系我们找货
