44ATM300T-P120
44ATM300T-P120
    IDEALPOWER(理想电源)
    12V AC/DC 外部 台式(类 I) 适配器 缆线(单独出售) 输入
44ATM300T-P120 数据手册
44ATM300T-P 300W Desktop Series Features • • • • • • • • • • • • • • Universal Input 100~240VAC 50/60Hz IEC/EN/ANSI/AAMI ES 60601-1 (ED 3.1) EMC: IEC60601-1-2:2014(ED 4.0) Safety Approvals: cULus / UKCA / CB / PSE / FCC / CE / TUV / RoHS / REACH Means of Protection: 2 X MOPP Touch Current: < 100µA Single Output to 300W Regulated Output with Low Ripple Noise Safety Agency Requirements and EMI/EMS Certified Meets DoE Level VI, Energy Star, ErP Stage 2 No Load Power Consumption Less Than 0.21W IEC C14 Connector Dimensions: L 254 x W 116 x H 47 (mm) Weight: 1600g The purpose of the document is to specify a Single-phase AC input, single output switching power supply. This specification is for: Desktop Power Supplies 300W Series. This product is suitable for use in medical applications. This Specification defines the input, output, performance characteristics, environment, noise and safety requirements. Models Model Number Output Voltage Output Current Output Power 44ATM300T-P120 44ATM300T-P240 12V DC 24V DC 25A 12.5A 300W 300W General Specification Type Switched Mode Power Supply Input Connector IEC 320-C14 Output Connection 8 Pin Molex 39-01-2080 1 Number of Outputs Energy Efficiency Level Mounting Style VI Desktop MTBF 300,000 hours calculated at 25ºC, by Telcoria SR-332 Power Indicator LED Indicator for power on Cable Length 1000mm(±30mm) Cable Type 16AWG/18AWG/20AWG (Depending on model) Medical Approved Yes Ideal Power Limited 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple, Devon, EX32 7NZ. www.idealpower.co.uk | +44 (0) 845 260 3400 44ATM300T-P 300W Desktop Series Mechanical Specifications Housing Material Overall Dimensions Overall Length Overall Depth Overall Width Weight Fully Enclosed Plastic Case 254mm x 116mm x 47mm 254mm 116mm 47mm 1600g Input Specifications Rated Input Voltage Rated Frequency Efficiency Level VI Input Current Inrush Current Touch Current Input Protection 100~240Vac (±10%) 50/60Hz Level VI / Efficiency (EU) 2019/1782 3.5A-1.5A 150A Max. / 230Vac (Cold Start At 25ºC, Full Load) Less than 100μA Internal Primary Current Fuse Output Specifications Output Regulation Ripple & Noise (max.) Voltage Tolerance Load Regulation No Load Power Consumption Hold-up Time Transient Response Number of Outputs Insulation Class Dielectric Strength Isolation Resistance Over Circuit Protection Over Voltage Protection Over Current Protection ±5% 1% Vp-p Max. for Output Voltage @ Full Load ±5% ±5%
44ATM300T-P120 价格&库存
很抱歉,暂时无法提供与“44ATM300T-P120”相匹配的价格&库存,您可以联系我们找货
44ATM300T-P120
  • 1+1420.464221+183.75873
