EXLX.ITU
EXLX.ITU
    IDEAL-TEK
    侧面(对角) 切割器 锥形 凹槽 5.00"(127.0mm)
EXLX.ITU 数据手册
Switzerland Ergo-tek Micro-Shear Cutters The new Ergo-tek handles for the Ideal-tek Micro-Shears line were designed with a user centered design (UCD) philosophy. Ergo-tek Micro-Shears are designed to maximize productivity while minimizing worker repetitive motion injuries. New Ergo-tek Micro-Shears features: • superior ergonomics • bi-component design • particulate free grip surface New Ergo-tek Micro-Shears benefits: • Ergonomic handle reduces repetitive motion strain • Anti-slip rubber outer surface for improved grip • Perfect stiffness for increased productivity • Easy pick up with or without gloves • Ultimate operator comfort from UCP intelligent design • ESD-safe material ERGO -TEK MICRO-SHEARS Past Present UCD Approach User-Centered Design (UCD) is a design philosophy and a process in which the needs, wants, and limitations of end-users are given extensive attention at each stage of the design process. User-centered design can be characterized as a multi-stage problem solving process that not only requires designers to analyze and foresee how users are likely to use a tool, but also to test the validity of their assumptions with regards to user behaviour in real world tests with actual users. 1. Understand User activity and environment 2. Measure Usability 3. Interactive design 4. Market implementation www.ideal-tek.com Switzerland Micro-Shear ® Lightweight shear action tools Micro-shears utilize a shearing cut to provide a clean and smooth cut. Anti-shock shear cutting greatly reduces mechanical shock delivered to the component and requires less effort to cut a wire as compared to compression wire cutters. Shear flush cutters utilize a shearing cut, with the by-pass cutting edges slicing cleanly through the metal EX9100 EX9200 Oval Head Micro-Shear® Flush Cutter - ESD safe Tapered Head Micro-Shear® Flush Cutter - ESD safe Strong and Durable. Size and shape reflect the latest advances in enhanced ergonomics. Tapered Head version of 9100AS. Improved access in high density areas and added precision. Cutting edges are an ultra durable 56-58 RC. Precision-ground Micro-Shear® cutting edges guarantee a clean cut. Cutting capacity: 12 AWG (2.0 mm) soft wire. Cutting capacity: 14 AWG (1.6 mm) soft wire. EX410 EX420 Micro-Shear® Flush Cutter - ESD safe Angled Micro-Shear® Flush Cutter - ESD safe Size and shape are optimized to work in high density areas. Slim profile for accessibility allows easier cutting in difficult areas. Rockwell hardness of 55-57 RC. Angled head provides excellent sight lines when used in either the vertical or horizontal position. Cutting capacity: 18 AWG (1.02 mm) soft wire. Cutting capacity: 20 AWG (0.8 mm) soft wire. www.ideal-tek.com Switzerland EX2175 EX2193 Maxi-Shear™ Flush Cutter - ESD safe Music Wire Shear - ESD safe Extremely durable and versatile wire cutter. Designed specifically for cutting music wire and other types of hardened wire. Used to cut hardened and tempered steel wire up to 12 AWG. Tough enough for harnesses and cables with the precision to cut material less than 1 mm thick or work in high density areas. Cutting capacity: 12 AWG (2.0 mm) soft wire. Cuts music wire up to 0.040’’ (1.0 mm) diameter. Cutting capacity: 12 AWG (2.0 mm) hard wire. EXLX EX175 Micro-Shear® Flush Cutter - ESD safe Micro-Shear® Flush Cutter - ESD safe Ultra slim profile for access in high density areas. Carefully crafted precision cutting blades combine seamlessly with curved, palm shaped handles to deliver effortless lead cutting. Extra tough high carbon steel blades. Sized for smaller hands and maximum maneuverability. Cutting capacity: 16 AWG (1.29 mm) soft wire. www.ideal-tek.com Lead Catcher Cutting capacity: 18 AWG (copper, nickel, etc. up to 1mm) Switzerland Scissors EX440 EX9180 Mini-Shear - ESD safe Kevlar® Fiber Shear - ESD safe Ultra precise scissor, cuts fine or delicate items with a clean, square edge. Designed and manufactured specifically for cutting the Kevlar® fiber strength component of fiber optic cables. Innovative design lessens operator hand strain. Serrated edge prevents the fibers from sliding out the front of the shear while cutting. Cutting edges 58-60 RC. Cutting capacity: 20 AWG (0.8 mm) soft wire. 0.005’’ (0.127 mm) mylar, plastic and shielded cable. www.ideal-tek.com Cutting capacity: 12 AWG (2.0 mm) soft wire. 030’’ (0.8 mm) soft sheet metal. Switzerland Jewellery Crimper 494 - Four in One Crimper A bead crimping plier that precisely crimps/folds 1, 2, and 3 millimeter crimp tubes and includes a chain nose plier for handling delicate beads, micro-crimps and for adding an extra squeeze to your crimps. The folding stations are designed to fit three different size crimp tubes (1, 2 & 3 mm) and ensure a secure and attractive result. Crimper has soft rubber hand grips and a return spring that opens the tool after each squeeze. Split Ring Plier 496 Designed for performance and ease of use, the split ring plier’s curved catch tip opens the ring and securly grasps it, simplifying installation of clasps, charms or other jewelry pieces. Low profile return spring automatically brings tool back to open position after each installation. www.ideal-tek.com
EXLX.ITU 价格&库存
很抱歉,暂时无法提供与“EXLX.ITU”相匹配的价格&库存,您可以联系我们找货
EXLX.ITU
  • 1+259.427261+33.56088
