Switzerland
Ergo-tek Micro-Shear Cutters
The new Ergo-tek handles for the Ideal-tek Micro-Shears line were designed with a user centered design (UCD) philosophy.
Ergo-tek Micro-Shears are designed to maximize productivity while minimizing worker repetitive motion injuries.
New Ergo-tek Micro-Shears features:
superior ergonomics
bi-component design
particulate free grip surface
New Ergo-tek Micro-Shears benefits:
Ergonomic handle reduces repetitive motion strain
Anti-slip rubber outer surface for improved grip
Perfect stiffness for increased productivity
Easy pick up with or without gloves
Ultimate operator comfort from UCP intelligent design
ESD-safe material
ERGO -TEK
MICRO-SHEARS
Past
Present
UCD Approach
User-Centered Design (UCD) is a design philosophy and a process in which the needs, wants, and limitations of end-users
are given extensive attention at each stage of the design process.
User-centered design can be characterized as a multi-stage problem solving process that not only requires designers to
analyze and foresee how users are likely to use a tool, but also to test the validity of their assumptions with regards to user
behaviour in real world tests with actual users.
1. Understand User activity and environment
2. Measure Usability
3. Interactive design
4. Market implementation
www.ideal-tek.com
Switzerland
Micro-Shear
Lightweight shear action tools
Micro-shears utilize a shearing cut to provide a clean and smooth cut. Anti-shock shear
cutting greatly reduces mechanical shock delivered to the component and requires less
effort to cut a wire as compared to compression wire cutters.
Shear flush cutters utilize a shearing cut,
with the by-pass cutting edges slicing
cleanly through the metal
EX9100
EX9200
Oval Head Micro-Shear® Flush Cutter - ESD safe
Tapered Head Micro-Shear® Flush Cutter - ESD safe
Strong and Durable. Size and shape reflect the latest
advances in enhanced ergonomics.
Tapered Head version of 9100AS. Improved access in
high density areas and added precision.
Cutting edges are an ultra durable 56-58 RC.
Precision-ground Micro-Shear® cutting edges guarantee
a clean cut.
Cutting capacity: 12 AWG (2.0 mm) soft wire.
Cutting capacity: 14 AWG (1.6 mm) soft wire.
EX410
EX420
Angled Micro-Shear® Flush Cutter - ESD safe
Size and shape are optimized to work in high density
areas.
Slim profile for accessibility allows easier cutting in
difficult areas.
Rockwell hardness of 55-57 RC.
Angled head provides excellent sight lines when used in
either the vertical or horizontal position.
Cutting capacity: 18 AWG (1.02 mm) soft wire.
Cutting capacity: 20 AWG (0.8 mm) soft wire.
www.ideal-tek.com
Switzerland
EX2175
EX2193
Maxi-Shear™ Flush Cutter - ESD safe
Music Wire Shear - ESD safe
Extremely durable and versatile wire cutter.
Designed specifically for cutting music wire and other
types of hardened wire.
Used to cut hardened and tempered steel wire up to 12
AWG.
Tough enough for harnesses and cables with the
precision to cut material less than 1 mm thick or work in
high density areas.
Cuts music wire up to 0.040’’ (1.0 mm) diameter.
Cutting capacity: 12 AWG (2.0 mm) hard wire.
EXLX
EX175
Ultra slim profile for access in high density areas.
Carefully crafted precision cutting blades combine
seamlessly with curved, palm shaped handles to deliver
effortless lead cutting.
Extra tough high carbon steel blades.
Sized for smaller hands and maximum maneuverability.
Cutting capacity: 16 AWG (1.29 mm) soft wire.
www.ideal-tek.com
Lead Catcher
Cutting capacity: 18 AWG (copper, nickel, etc. up to 1mm)
Switzerland
Scissors
EX440
EX9180
Mini-Shear - ESD safe
Kevlar® Fiber Shear - ESD safe
Ultra precise scissor, cuts fine or delicate items with a
clean, square edge.
Designed and manufactured specifically for cutting the
Kevlar® fiber strength component of fiber optic cables.
Innovative design lessens operator hand strain.
Serrated edge prevents the fibers from sliding out the
front of the shear while cutting. Cutting edges 58-60 RC.
0.005’’ (0.127 mm) mylar, plastic and
shielded cable.
www.ideal-tek.com
030’’ (0.8 mm) soft sheet metal.
Switzerland
Jewellery Crimper
494 - Four in One Crimper
A bead crimping plier that precisely crimps/folds 1, 2,
and 3 millimeter crimp tubes and includes a chain nose
plier for handling delicate beads, micro-crimps and for
adding an extra squeeze to your crimps.
The folding stations are designed to fit three different
size crimp tubes (1, 2 & 3 mm) and ensure a secure and
attractive result. Crimper has soft rubber hand grips and
a return spring that opens the tool after each squeeze.
Split Ring Plier
496
Designed for performance and ease of use, the split ring
plier’s curved catch tip opens the ring and securly grasps
it, simplifying installation of clasps, charms or other jewelry
pieces. Low profile return spring automatically brings tool
back to open position after each installation.
www.ideal-tek.com
很抱歉,暂时无法提供与“EX410.ITU”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+226.670391+29.46642
