KDEMOA5-E.IT
KDEMOA5-E.IT
    IDEAL-TEK
    TOOLS KIT FOR ELECTRONICS
KDEMOA5-E.IT 数据手册
LEFT PAGE 152.S.0 | Tweezers Micro tip cutting tweezers | Perfect for performing small cuts and cutting soft, Copper, Gold, Silver, magnetic wires. 15A.C.0 | Tweezers High precision cutting tweezers | Suitable to cut small material or perform small cuts. The strong blades are designed to apply moderate cutting force. 5.SA.DR.0 | Tweezers Soft ESD safe ergonomic rubber grip tweezers | Designed to provide enhanced operator comfort when handling ESD sensitive components or small static items. 0C9.SA.0 | Tweezers High precision short tweezers with straight, fine, sharp tips | Suitable to hold small components firmly while granting good visibility. 2A.SA.0 | Tweezers High Precision tweezers | Specially designed for applications which require holding a flat component firmly. ES5235.CR | Cutters Cutters with short, narrow jaws – Ideal to cut at the very tip in micro working areas and to perform very clean cuts on small size material. ES6024.CR | Cutters Snipe nose pliers with smooth jaws | Commonly used in electro­nic assembly and rework, as well as in fine jewellery. www.ideal-tek.com RIGHT PAGE ES5140.CR | Cutters Small oval head cutters with robust, slim shape | Designed to grant optimum balance between durability and accessibility. ES5542.CR | Cutters Tapered & relieved cutters with small pointed head shape and deep relief for a very low profile | Designed to maximize accessibility in limited areas. 259CFR.SA.1 | Tweezers Plastic replaceable tip tweezers | Specially designed for the electronics industry with durable, self-aligning replacement tips and anti-magnetic stainless steel handles. 4X.SA.1 | Tweezers Reverse action tweezers | Specially designed for applications where a precise self-closing action is required - e.g. in microscopy and assembly applications. 71ZJ.SA.0 | Tweezers Ceramic replaceable tip tweezers | Contamination free and resistant to high temperatures, wear and solder. SM111.SA.1 | Tweezers Grooved SMD tweezers for positioning 0.5mm cylindrical devices | Ideal for electronics assembly, labs, clean rooms and circuit board repair and rework. MPT1RCP | Plastic Probes Carbon PEEK plastic probes | Suitable to scraping delicate components. The pointed tip allows access in small working areas. www.ideal-tek.com
KDEMOA5-E.IT 价格&库存
很抱歉,暂时无法提供与“KDEMOA5-E.IT”相匹配的价格&库存,您可以联系我们找货
KDEMOA5-E.IT
  • 1+6326.07392
库存:1
KDEMOA5-E.IT
    • 1+9756.669461+1268.12911
    库存:1
