AP8M122-R
AP8M122-R
    IDEC(日本和泉)
    LED 面板指示器 红色 24V 焊片
AP8M122-R 数据手册
Switches & Pilot Devices Signaling Lights Switches & Pilot Devices Miniature ø8-16mm AP Series AP Series — Miniature Pilot Lights Key features: • Long service life, low maintenance • Space saving miniature style • Dome or flat lens models • Built-in current-limiting resistor • Five illumination colors: red, green, amber, yellow, and white • Transformer (120V AC and 240V AC) and DC-DC Converter (110V DC) options on 12mm and 16mm units Contactors Timers Relays & Sockets UL Recognized File No. E55996 * CSA Certified File No. LR21451 *AP8/AP1 series only. Specifications Lamp Built-in LED with current limiting resistor Operational Voltage 5, 6, 12, 24VDC (full voltage), 110/120, 220/240VAC, (with transformer) 110VDC (with converter) Current Ratings AP8: 5V DC/9mA, 12V DC/9mA, 24V DC/9mA, 12V AC/15mA, 24V AC/15mA AP1: 5V DC/9mA, 12V DC/9mA, 24V DC/9mA, 12V AC/15mA, 24V AC/15mA AP2: 6V DC/33mA, 12V DC/22mA, 24V DC/11mA AP6: 6V DC/33mA, 12V DC/22mA, 24V DC/11mA Operating Temp. -20ºC to +55ºC Operating Humidity 45 to 85% RH Insul. Resistance 100MΩ min. (500V DC megger) Between live and dead parts Rev. Withstand Voltage AP2/AP6: 100V AP1/AP8: 200V Solder Terminal Soldering 260ºC maximum (5 sec.) Degree of Protection AP8: IP40 (dustproof) Other Series: IP65 (oiltight) Optional Adaptors/Converters Transformer Model Terminal Blocks Applicable Units AP2 & AP6 (with 6V LED only) Operating Voltage 110/120VAC 50/60 Hz 220/240VAC 50/60 Hz 110V DC (90 to 140V DC) Power Consumption 1.6 VA maximum 1W maximum Insulation Voltage 250 V AC 140V DC Insulation Resistance Dielectric Strength Circuit Breakers DC-DC Converter 10MΩ min. (500V DC megger) Between live and dead parts 2,000V AC, 1 minute Between live/dead parts 2,000V AC, 1 minute Between terminals 2,000V AC, 1 minute Between live/dead parts 1,500V AC, 1 minute Between terminals Available as one piece only (replacement LEDs are not available). 486 www.IDEC.com 1705151131 Switches & Pilot Devices Miniature ø8-16mm AP Series Switches & Pilot Devices Miniature Pilot Lights AP Miniature Pilot Lights - ø8 & ø10mm Style Operating Voltage Part Numbers Dome 5V DC +/- 5% 12V AC/DC +/- 10% 24V AC/DC +/- 10% AP8M255-k AP8M211-k AP8M222-k Flat 5V DC +/- 5% 12V AC/DC +/- 10% 24V AC/DC +/- 10% AP8M155-k AP8M111-k AP8M122-k Dome 5V DC +/- 5% 12V AC/DC +/- 10% 24V AC/DC +/- 10% AP1M255-k AP1M211-k AP1M222-k Flat 5V DC +/- 5% 12V AC/DC +/- 10% 24V AC/DC +/- 10% AP1M155-k AP1M111-k AP1M122-k AP8 Series - Ø8mm AP1 Series - Ø10mm k Color Codes Color Code Amber A Green G Red R Blue S* Warm White W Cool White PW Yellow Y Signaling Lights Lens Style * Available in only the AP8 and AP1 series. 1. In place of k, specify the color code. 2. For dimensions, see page 489. 3. For accessories, see page 488. Relays & Sockets AP Miniature Pilot Lights - ø12 & ø16mm Style Operating Voltage Part Numbers Dome 6V DC +/- 5% 12V DC +/- 10% 24V DC +/- 10% AP2M266-k AP2M211-k AP2M222-k Flat 6V DC +/- 5% 12V DC +/- 10% 24V DC +/- 10% AP2M166-k AP2M111-k AP2M122-k Dome 6V DC +/- 5% 12V DC +/- 10% 24V DC +/- 10% AP2 Series - Ø12mm AP6 Series - Ø16mm Flat 6V DC +/- 5% 12V DC +/- 10% 24V DC +/- 10% k Color Codes Color Code AP6M266-k AP6M211-k AP6M222-k Amber A Green G Red R AP6M166-k AP6M111-k AP6M122-k Warm White W Yellow Y Timers Lens Style Contactors 1. In place of k, specify the color code. 2. For dimensions, see page 489. 3. For accessories, see page 488. Optional Transformers and DC-DC Converters (for AP2 and AP6 only) Style Voltage Part Numbers Used with AP2 Series Used with AP6 Series 110/120V AC 220/240V AC AP2-0126D AP2-0246D AP6-0126D AP6-0246D DC-DC Converter 110V DC (90–140V DC) AP2-016DD AP6-016DD Terminal Blocks Transformer 1705151131 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1. Optional Transformers and DC-DC converters snap onto the back of AP2 or AP6 pilot lights. 2. Transformers and DC-DC Converters step down to 6V. 3. For dimensions, see page 489. 487 Switches & Pilot Devices Relays & Sockets Signaling Lights Switches & Pilot Devices Miniature ø8-16mm AP Series Accessories — AP Series Item Appearance Description Made of metal. Used for tightening plastic locking ring during installation. Tightening torque should not exceed 3kgf-cm Locking Ring Wrench Mounting Hole Plug Made of rubber. Fills unused mounting holes to provide IP65 protection Transformer Removal Tool A Series Blank/Lens Removal Tool Replacement Lenses Lenses (included with all units). Used With Part Number Ø 16mm units MT-001 Ø 12mm units MT-002 Ø 10mm units MT-003 Ø 8mm units MT-004 Unused 8mm panel cutouts AL-B8 Unused 10mm panel cutouts AL-B1 Unused 12mm panel cutouts AL-B2 Unused 16mm panel cutouts AL-B6 AP2 and AP6 snap on transformer and DC-DC converter MT-100 AP1M Flat AP1M-L1-k AP1M Dome AP1M-L2-k AP2M Flat AP2M-L1-k AP2M Dome AP2M-L2-k AP6M Flat AP6M-L1-k AP6M Dome AP6M-L2-k 1. In place of k, specify the Lens Color Code. 2. Internal LED is fixed and cannot be removed or replaced. Color Code Amber A Green G Red R Blue S* White W Yellow Y *Blue available in AP8/AP1 series only. Circuit Breakers Terminal Blocks Contactors Timers k Lens Color Codes 488 www.IDEC.com 1705151131 Switches & Pilot Devices Miniature ø8-16mm AP Series Switches & Pilot Devices Dimensions — AP Series Pilot Lights (AP Series) AP8 Style AP1 Flat Panel Cut-out Dome Flat AP2 Dome Ø 0.319” (+0.0118, –0) 8.1mm (+0.3, –0) Ø 0.398” (+0.0118, –0) 10.1mm (+0.3, –0) Ø 0.386” (9.8mm) Ø 0.472” (12mm) Outside Dimension Flat Dome Flat Ø 0.480” (+0.0118, –0) 12.2mm (+0.3, –0) Ø 0.551” (14mm) w/ Adaptor or Converter Dome Ø 0.638” (+0.0118, –0) 16.2mm (+0.3, –0) Ø 0.709” (18mm)  0.709” (18mm)  0.709” (18mm) Signaling Lights AP6 AP6 w/ Adaptor or Converter AP2 Panel Thickness: 0.8 to 6 mm Dome 7 5 11.5 29.5 Panel Cut-out ø15.6 .2 +0 0 9.5 When using the Transformer unit (When using the DC-DC converter unit) 9.5 Transformer unit (or DC-DC converter unit) M3 terminal screw + Terminal 18 TOP 18 X2 X1 TOP X2 71 58.7 1.3 Timers 71 18 1.3 18 58.7 + Terminal X1 M3 terminal screw Transformer unit (or DC-DC converter unit) .2 0 +0 2 2. ø1 5.5 2 6. ø1 ø12 ø14 Panel Cut-out 5.5 When using the Transformer unit (When using the DC-DC converter unit) 29.5 Flat Relays & Sockets 8 21.5 21.5 5.5 - 13.5 ø18 1.5 2.2 + 5.5 Flat ø14 1.5 ø15.6 ø18 2.2 ø12 Gasket Dome Gasket - + Panel Thickness: 0.8 to 6 mm – Terminal – Terminal AP1 AP8 2.2 1.5 Panel Thickness: 0.8 to 6 mm Panel Thickness: 0.8 to 6 mm 2.8 3 5.5 9.5 21.5 8 29.5 Panel Cut-out ø1 +0 0 .2 5.5 .1 0. 1 +0 . 0 2 ø10 9.5 Terminal Blocks ø9.8 Flat ø8 Panel Cut-out 5.5 ø8 + 8 29.5 Flat ø12 ø9.8 - 21.5 ø8 2.8 4 ø10 ø12 5.5 10 Gasket Dome Contactors Gasket Dome 1.5 2.2 8.5 Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 489
AP8M122-R 价格&库存
很抱歉,暂时无法提供与“AP8M122-R”相匹配的价格&库存,您可以联系我们找货
AP8M122-R
  • 1+113.187501+14.41590
  • 10+93.0479010+11.85090
  • 100+74.00450100+9.42540
  • 500+70.93750500+9.03480
  • 1000+68.803401000+8.76300
库存:45
AP8M122R
  • 1+117.76013
  • 5+114.52098
  • 10+109.26479
  • 25+106.83246
  • 50+104.32895
  • 100+101.89662
库存:34
