BN15MW
BN15MW
    IDEC(日本和泉)
    端子块连接器 2 位置 馈通式 黑色 14-22 AWG
BN15MW 数据手册
Terminal Blocks BNH/BN Key features: • Touch-down terminals with spring-loaded captive screws • Jumpers available up to 50A model • Fuse block with or without blown-fuse indicator in neon or LED • Mounts on 35mm standard DIN rail Signaling Lights UL Recognized File No. E78117 File No. R9551701 J9551516 (power blocks) R9650688 (dual-deck blocks) CSA Certified File No. LR64803 BNH10W BNH15MW BNH15LW BNH30W Relays & Sockets Specifications Model Switches & Pilot Lights BNH/BN Series Appearance 0.275” (7mm) 0.315” (8mm) 0.413” (10.5mm) 0.472” (12mm) Approvals UL, CSA, TUV UL, CSA, TUV UL, CSA, TUV UL, CSA, TUV No. of Poles 1 1 1 1 Wire Sizes 22 to 16 AWG 22 to 14 AWG 22 to 14 AWG 18 to 10 AWG 600V / 10A 600V / 10A 600V / 15A 600V / 30A M3 M3 M3.5 M4 Voltage/Current Terminals Size Terminal Torque (N-m) (in-lbs.) End Plate DIN Rail Stop Touch-down Touch-down Touch-down 35mm DIN rail 35mm DIN rail 35mm DIN rail 0.6 - 1.0 0.6 - 1.0 1.0 - 1.3 1.4 - 2.0 5.3 - 8.9 5.3 - 8.9 8.9 - 11.5 12.4 - 17.8 BNE15W BNE15W BNE15W BNE30W BNL-5 BNL-5 BNL-5 BNC230 BNC230 BNC230 PVC BNM7 BNM7 BNM7 BNM7 Fiberglass BNM9 BNM9 BNM9 BNM9 BNM3 BNM3 BNM3 BNM3 Ring Terminal Jumpers End clip BNJ16 BNJ26W BNJ46 BNJ56 Fork Terminal Jumpers BNJ16F BNJ26FW BNJ46F BNJ56F Terminal Blocks BNL-5 BNC230 Dust Cover Marking Strip Touch-down 35mm DIN rail Contactors Type Mounting Timers Width 1705151137 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1. BNDN1000 aluminum DIN rails are available in 1 meter lengths. 2. Marking strips are sold in 1 meter lengths. 3. Most jumpers are provided with 6 poles (except for BNH50W jumper that is 2-poles only). 4. Remove the “H” in the terminal block part number for standard screw type (ex. BNH10W becomes BN10W). 1007 Terminal Blocks Signaling Lights Switches & Pilot Lights BNH/BN Specifications, continued Model Width Approvals Relays & Sockets BN150W BNDH15W 0.610” (15.5mm) 0.787” (20mm) 1.024” (26mm) 0.315” (8mm) UL, CSA, TUV UL, CSA, TUV UL, CSA, TUV UL, CSA, TUV No. of Poles 1 1 1 2 Wire Sizes 16 to 6 AWG 16 to 4 AWG 16 to 0 AWG 22 to 14 AWG 600V / 10A Terminals 600V / 50A 600V / 75A 600V / 150A Size M5 M6 M8 M3 Type Touch-down Hex bolt Hex bolt Touch-down 35mm DIN rail 35mm DIN rail 35mm DIN rail 35mm DIN rail, surface 2.6 - 3.7 3.9 - 5.4 10 - 13.5 0.6 - 1.0 23.1 - 32.8 34.6 - 47.9 88.8 - 119.8 5.3 - 8.9 BNE50W BNE75W BNE150W BNDE15W BNL-5 BNL-6 BNL-6 BNL-8 Mounting Terminal Torque (N-m) (in-lbs.) End Plate DIN Rail Stop BNC320 BNC420 BNC520 BNC230 (top level) BNC240 (bottom Level) PVC BNM7 BNM7 BNM7 BNM7 Fiberglass BNM9 BNM9 BNM9 BNM9 End clip BNM3 BNM3 BNM3 BNM3 Dust Cover Timers BN75W Appearance Voltage/Current Marking Strip Connecting Rods — — — BNR1 10.34” (265mm) BNR2 19.69” (500mm) Connecting Nuts — — — BNN1 (2 pieces) Base Mount Brackets — — — BNDL2 Ring Terminal Jumpers BNJ62 (2 pole) — — BNJ26 Fork Terminal Jumpers — — — BNJ26FW 1. BNDN1000 aluminum DIN rails are available in 1 meter lengths. 2. Marking strips are available in 1 meter lengths. 3. Most jumpers are six poles (except for BNJ62 which is 2 poles only). 4. Remove the “H” in the terminal block part number for standard screw type (ex. BNH50W becomes BN50W). Circuit Breakers Terminal Blocks Contactors BNH50W 1008 www.IDEC.com 1705151137 Terminal Blocks BNF Fuse Blocks Model BNF10SW BNF10NW BNF10DW 0.591” (15mm) 0.591” (15mm) 0.591” (15mm) None Neon (100–300VAC) LED (24V DC) UL, CSA UL, CSA UL, CSA Switches & Pilot Lights Specifications, continued Appearance Blown Fuse Indicator Approvals No. of Poles 1 1 1 Wire Sizes 18 to 10 AWG 18 to 10 AWG 18 to 10 AWG Voltage/Current 600V/10A maximum 600V/10A maximum M4 M4 M4 Type Standard screw Standard screw Standard screw 35mm DIN rail 35mm DIN rail 35mm DIN rail Mounting (N-m) 1.4 - 2.0 1.4 - 2.0 1.4 - 2.0 (in-lbs.) 12.4 - 17.8 12.4 - 17.8 12.4 - 17.8 End Plate BNE20 BNE20 BNE20 DIN Rail Stop BNL-5 BNL-5 BNL-5 — — — Terminal Torque Dust Cover Marking Strip BNM7 BNM7 1/4” x 1-1/4” (6.35 x 31.8mm) 1/4” x 1-1/4” (6.35 x 31.8mm) Timers Applicable Fuse Size BNM7 1/4” x 1-1/4” (6.35 x 31.8mm) Relays & Sockets Terminals 600V/10A maximum Size Signaling Lights Width 1. BNDN1000 aluminum DIN rails are available in 1 meter lengths. 2. Fuses not included. Contactors Terminal Blocks Circuit Breakers 1705151137 Canada: 888-317-4332 • USA: 800-262-4332 1009 Terminal Blocks Dimensions BNH Series Part No. 6.7 11.3 8 BNH30W 29.5 23.5 5 max. 48 24.4 4 min. 29.5 23.5 5 max. 3.3 min. 15.8 12 9.6 ø4.2 min. 9.5 max. 6 max. 31.4 25.4 ø3.6 min. 8.5 max. 38 19.4 When using C Rail: 44 36.5 14.3 10.5 8.5 When using DIN Rail: 38 38 18 3.3 min. When using C Rail: 41 33.5 29.5 23.5 5 max. 6.6 max. 4.5 min. 18 15.5 13 When using C Rail: 50 ø5.2 min. 42.5 12.8 max. 34.3 28.3 6.5 max. 4.5 min. BN Series Part No. Diagrams BN150W 31.7 25.7 8.5 max. 6 min. Part No. 11 max. 10 min. BND15W 17.5 15 13 62 38 18 12 8 6.7 ø3.2 min. 5 min. 59.5 6.6 max. 5 max. 55.5 49.5 5.2 max. When using 35-mm DIN Rai: 61 Whem using C Rail: 67 ø4.2 min. 11.3 max. 33 27 When using C Rail: 59.5 52 63 43 3.3 min. 8 Circuit Breakers BNDH15W ø8.5 min. 22.8 max. Diagrams BNF10SW/BNF10NW/BNF10DW When using DIN Rail: 53.5 BNF10SW BNF10NW BNW10DW 29.8 26 23 29 42.5 When using C Rail: 50 16.8 max. 74 63 33 35 22.5 20 17 ø6.2 min. When using DIN Rail: 44 Contactors BN75W BN150W 53 26 When using DIN Rail: 52 When using C Rail: 50 50.5 BN75W Terminal Blocks 38 18 ø3.2 min. When using 35-mmD IN Rail: 35 33.5 5.8 max. 33.5 When using DIN Rail: 35 Relays & Sockets BNH50W BNH50W 5.9 BNH15MW 10.3 7 ø3.2 min. When using C Rail: 41 BNH15LW BNH15LW BNH30W 38 18 When using C Rail: 41 When using DIN Rail: 35 Signaling Lights BNH10W BNH15MW Timers Diagrams BNH10W When using DIN Rail: 44 Switches & Pilot Lights BNH/BN 1010 www.IDEC.com 1705151137
BN15MW 价格&库存
很抱歉,暂时无法提供与“BN15MW”相匹配的价格&库存,您可以联系我们找货
BN15MW
    • 1+14.88138
    库存:339
