Terminal Blocks
BNH/BN
Key features:
• Touch-down terminals with spring-loaded captive screws
• Jumpers available up to 50A model
• Fuse block with or without blown-fuse indicator in neon or LED
• Mounts on 35mm standard DIN rail
Signaling Lights
UL Recognized
File No. E78117
File No. R9551701
J9551516 (power blocks)
R9650688 (dual-deck blocks)
CSA Certified
File No. LR64803
BNH10W
BNH15MW
BNH15LW
BNH30W
Relays & Sockets
Specifications
Model
Switches & Pilot Lights
BNH/BN Series
Appearance
0.275” (7mm)
0.315” (8mm)
0.413” (10.5mm)
0.472” (12mm)
Approvals
UL, CSA, TUV
UL, CSA, TUV
UL, CSA, TUV
UL, CSA, TUV
No. of Poles
1
1
1
1
Wire Sizes
22 to 16 AWG
22 to 14 AWG
22 to 14 AWG
18 to 10 AWG
600V / 10A
600V / 10A
600V / 15A
600V / 30A
M3
M3
M3.5
M4
Voltage/Current
Terminals
Size
Terminal
Torque
(N-m)
(in-lbs.)
End Plate
DIN Rail Stop
Touch-down
Touch-down
Touch-down
35mm DIN rail
35mm DIN rail
35mm DIN rail
0.6 - 1.0
0.6 - 1.0
1.0 - 1.3
1.4 - 2.0
5.3 - 8.9
5.3 - 8.9
8.9 - 11.5
12.4 - 17.8
BNE15W
BNE15W
BNE15W
BNE30W
BNL-5
BNL-5
BNL-5
BNC230
BNC230
BNC230
PVC
BNM7
BNM7
BNM7
BNM7
Fiberglass
BNM9
BNM9
BNM9
BNM9
BNM3
BNM3
BNM3
BNM3
Ring Terminal Jumpers
End clip
BNJ16
BNJ26W
BNJ46
BNJ56
Fork Terminal Jumpers
BNJ16F
BNJ26FW
BNJ46F
BNJ56F
Terminal Blocks
BNL-5
BNC230
Dust Cover
Marking
Strip
Touch-down
35mm DIN rail
Contactors
Type
Mounting
Timers
Width
1705151137
800-262-IDEC (4332) • USA & Canada
Circuit Breakers
1. BNDN1000 aluminum DIN rails are available in 1 meter lengths.
2. Marking strips are sold in 1 meter lengths.
3. Most jumpers are provided with 6 poles (except for BNH50W jumper that is 2-poles only).
4. Remove the “H” in the terminal block part number for standard screw type (ex. BNH10W becomes BN10W).
1007
Terminal Blocks
Signaling Lights
BNH/BN
Specifications, continued
Model
Width
Approvals
Relays & Sockets
BN150W
BNDH15W
0.610” (15.5mm)
0.787” (20mm)
1.024” (26mm)
0.315” (8mm)
UL, CSA, TUV
UL, CSA, TUV
UL, CSA, TUV
UL, CSA, TUV
No. of Poles
1
1
1
2
Wire Sizes
16 to 6 AWG
16 to 4 AWG
16 to 0 AWG
22 to 14 AWG
600V / 10A
Terminals
600V / 50A
600V / 75A
600V / 150A
Size
M5
M6
M8
M3
Type
Touch-down
Hex bolt
Hex bolt
Touch-down
35mm DIN rail
35mm DIN rail
35mm DIN rail
35mm DIN rail, surface
2.6 - 3.7
3.9 - 5.4
10 - 13.5
0.6 - 1.0
23.1 - 32.8
34.6 - 47.9
88.8 - 119.8
5.3 - 8.9
BNE50W
BNE75W
BNE150W
BNDE15W
BNL-5
BNL-6
BNL-6
BNL-8
Mounting
Terminal
Torque
(N-m)
(in-lbs.)
End Plate
DIN Rail Stop
BNC320
BNC420
BNC520
BNC230 (top level)
BNC240 (bottom Level)
PVC
BNM7
BNM7
BNM7
BNM7
Fiberglass
BNM9
BNM9
BNM9
BNM9
End clip
BNM3
BNM3
BNM3
BNM3
Dust Cover
Timers
BN75W
Appearance
Voltage/Current
Marking
Strip
Connecting Rods
BNR1 10.34” (265mm)
BNR2 19.69” (500mm)
Connecting Nuts
BNN1 (2 pieces)
Base Mount Brackets
BNDL2
BNJ62 (2 pole)
BNJ26
BNJ26FW
2. Marking strips are available in 1 meter lengths.
3. Most jumpers are six poles (except for BNJ62 which is 2 poles only).
4. Remove the “H” in the terminal block part number for standard screw type (ex. BNH50W becomes BN50W).
Circuit Breakers
Terminal Blocks
Contactors
BNH50W
1008
www.IDEC.com
1705151137
Terminal Blocks
BNF Fuse Blocks
Model
BNF10SW
BNF10NW
BNF10DW
0.591” (15mm)
0.591” (15mm)
0.591” (15mm)
None
Neon (100–300VAC)
LED (24V DC)
UL, CSA
UL, CSA
UL, CSA
Appearance
Blown Fuse Indicator
Approvals
No. of Poles
1
1
1
Wire Sizes
18 to 10 AWG
18 to 10 AWG
18 to 10 AWG
Voltage/Current
600V/10A maximum
600V/10A maximum
M4
M4
M4
Type
Standard screw
Standard screw
Standard screw
35mm DIN rail
35mm DIN rail
35mm DIN rail
Mounting
(N-m)
1.4 - 2.0
1.4 - 2.0
1.4 - 2.0
(in-lbs.)
12.4 - 17.8
12.4 - 17.8
12.4 - 17.8
End Plate
BNE20
BNE20
BNE20
DIN Rail Stop
BNL-5
BNL-5
BNL-5
Terminal
Torque
Dust Cover
Marking Strip
BNM7
BNM7
1/4” x 1-1/4”
(6.35 x 31.8mm)
1/4” x 1-1/4”
(6.35 x 31.8mm)
Timers
Applicable Fuse Size
BNM7
1/4” x 1-1/4”
(6.35 x 31.8mm)
Relays & Sockets
Terminals
600V/10A maximum
Size
Signaling Lights
Width
2. Fuses not included.
Contactors
Terminal Blocks
Circuit Breakers
1705151137
Canada: 888-317-4332 • USA: 800-262-4332
1009
Terminal Blocks
Dimensions
BNH Series
Part No.
6.7
11.3
8
BNH30W
29.5
23.5
5 max.
48
24.4
4 min.
29.5
23.5
5 max.
3.3 min.
15.8
12
9.6
ø4.2 min.
9.5 max.
6 max.
31.4
25.4
ø3.6 min.
8.5 max.
38
19.4
When using C Rail: 44
36.5
14.3
10.5
8.5
When using DIN Rail: 38
38
18
3.3 min.
When using
C Rail: 41
33.5
29.5
23.5
5 max.
6.6 max.
4.5 min.
18
15.5
13
When using C Rail: 50
ø5.2 min.
42.5
12.8 max.
34.3
28.3
6.5 max.
4.5 min.
BN Series
Part No.
Diagrams
BN150W
31.7
25.7
8.5 max.
6 min.
Part No.
11 max.
10 min.
BND15W
17.5
15
13
62
38
18
12
8
6.7
ø3.2 min.
5 min.
59.5
6.6 max.
5 max.
55.5
49.5
5.2 max.
When using
35-mm DIN Rai: 61
Whem using
C Rail: 67
ø4.2 min.
11.3 max.
33
27
When using C Rail: 59.5
52
63
43
3.3 min.
8
Circuit Breakers
BNDH15W
ø8.5 min.
22.8 max.
Diagrams
BNF10SW/BNF10NW/BNF10DW
When using DIN Rail: 53.5
BNF10SW
BNF10NW
BNW10DW
29.8
26
23
29
42.5
16.8 max.
74
63
33
35
22.5
ø6.2 min.
When using DIN Rail: 44
Contactors
BN75W
BN150W
53
26
When using DIN Rail: 52
50.5
BN75W
Terminal Blocks
38
18
ø3.2 min.
When using
35-mmD IN Rail: 35
33.5
5.8 max.
33.5
When using DIN Rail: 35
Relays & Sockets
BNH50W
BNH50W
5.9
BNH15MW
10.3
7
ø3.2 min.
When using C Rail: 41
BNH15LW
BNH15LW
BNH30W
38
18
Signaling Lights
BNH10W
BNH15MW
Timers
Diagrams
BNH10W
BNH/BN
1010
www.IDEC.com
1705151137
很抱歉,暂时无法提供与“BNE30W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+12.490761+1.62067
