DPRI-01
DPRI-01
    IDEC(日本和泉)
    模块
    SENSOR PROX 4MM MODULE
DPRI-01 数据手册
Sensors Magnetic: DPRI Magnetic: DPRI Magnetic Proximity Switches PLCs Operator Interfaces • Lightweight, compact design reduces mounting space requirements • Compact size allows units to be mounted in close proximity to each other • Sealed reed contact can be used in dusty locations • Long life and high reliability Automation Software The DPRI magnetic proximity switch incorporates a sealed reed switch and four magnets inside a compact housing. This self-contained proximity switch requires no external power supply and can detect the presence of magnetic objects without contact. Dimensions 0.7" (5mm) (18mm) Single Mounting 0.39" Power Supplies 0.39" (10mm) 0.2" (10mm) 0.73" (18.5mm) M3 or 3, 2-3, 6 dia 1.46" 39.37" Close Mounting of 2 units (28.5mm) 0.35" 0.39" 0.39" Sensors 0.24" (6mm) 0.47" (12mm) (1000mm) (37mm) 1.12" (9mm) (10mm) (10mm) P ‰ ‰ P = 0.75" (19mm) Communication & Networking USA: 800-262-IDEC Canada: 888-317-IDEC 227 Sensors Magnetic: DPRI Specifications Operator Interfaces PLCs DPRI-01 Normal Switching Distance 5mm ±10% √ Operating Distance 0 to 4mm √ Release Distance Over switching distance, 9mm (maximum) √ Repeat Error ON 0.05mm (maximum) √ Repeat Error OFF 0.15mm (maximum) √ Temperature Error (–10 to 50˚C) ±0.5mm or less (20˚C as standard) √ Response Speed Output 300Hz or less (bounce 0.4ms or less) √ Contact Configuration 1NO √ Switching Capacity AC: 10VA (maximum) DC: 10W (maximum) √ Operating Voltage AC: 100V (maximum) DC: 100V (maximum) √ Operating Current AC: 0.25A (maximum) DC: 0.25A (maximum) √ Power Supplies Automation Software Initial Contact Resistance √ 20G or less √ Ambient Temperature Range –10 to +50˚C √ Sensing Object Magnetic materials: Fe, Ni, Cu, Ferrite, etc. √ Standard Sensing Object Life Expectancy Electrical Mechanical 30 x 20 x 1mm, Ferromagnetic soft iron plate √ 20,000,000 operations √ 1,000,000,000 operations √ Lead Wire Cable type: 5mm 2-core vinyl cabtyre cable, 3-1/3’ (1m) long √ Weight Approximately 40g √ Part Number Description Part Number Magnetic Proximity Switch DPRI-01 For information on accessories, see page 229. Operation Principle The DPRI magnetic proximity switch incorporates a sealed reed switch and four magnets inside a compact housing. This self-contained proximity switch requires no external power supply and can detect the presence of magnetic objects without contact. Communication & Networking Sensors 0.35Ω (maximum) Shock Resistance 228 www.idec.com
DPRI-01 价格&库存
很抱歉,暂时无法提供与“DPRI-01”相匹配的价格&库存,您可以联系我们找货
DPRI-01
    • 1+238.994331+31.06849
    • 5+218.725585+28.43362
    • 10+211.1903410+27.45406
    • 25+202.1823625+26.28306
    • 50+196.0152150+25.48135
    • 100+190.35946100+24.74612
    库存:1063
