FC6A-L06A1
FC6A-L06A1
    IDEC(日本和泉)
    输入,输出(I/O)模块 DIN 轨道 24VDC
FC6A-L06A1 数据手册
MicroSmart FC6A PLC Analog I/O Module Specifications KEY FEATURES • 8 modules to choose from • Up to 16-bit resolution • Fast sampling rate • Wide range of signals: • 0/4-20mA, 0-10V DC, -10 to 10V DC, Type K, J, R, S, B, E, T, N, C thermocouple and RTD SPECIFICATIONS Analog I/O Module Specifications Part Number Input Points Input Signal Type FC6A-J2C1 2 FC6A-J4A1 FC6A-J8A1 4 8 FC6A-L03CN1 4 2 FC6A-J4CN1 4 Voltage (0 to 10V) Voltage (-10 to +10V) Current (0 to 20mA) Current (4 to 20mA) Thermocouple Resistance Thermometer Voltage (0 to 10V) Voltage (-10 to +10V) Current (0 to 20mA) Current (4 to 20mA) Output Points − − − Output Signal Style − − − 2 1 Voltage (0 to 10V) Voltage (-10 to +10V) Current (0 to 20mA) Current (4 to 20mA) FC6A-J8CU1 8 Thermocouple Thermistor (NTC, PTC) − − − − FC6A-K4A1 − − 4 Voltage (0 to 10V) Voltage (−10 to +10V) Current (0 to 20mA) Current (4 to 20mA) Rated Power Voltage 24V DC, Allowable Voltage Range 20.4 to 28.8V DC External Power Supply External Current Draw (24V DC) 1 FC6A-L06A1 25mA 30mA 40mA 100mA Connector Insertion/ Removal Durability 80mA 40mA 30mA 125mA 100 times minimum 1-wire: AI 0.5-10 (Phoenix Contact), 2-wire: AI-TWIN 2×0.5-10 (Phoenix Contact) Applicable Ferrule Internal Power Consumption (5V DC) 40mA max. 45mA max. 40mA max. 55mA max. 55mA max. 50mA max. 45mA max. 50mA max. Internal Power Consumption (at 24V DC while all I/Os are ON) 0.27W 0.30W 0.27W 0.37W 0.37W 0.34W 0.30W 0.34W 115g 110g 110g 110g 115g 110g 110g 115g Weight (approx.) Note 1: The external current draw is the value when all the analog inputs are used and the analog output value is at 100%. 1 Analog Input Specifications (1) Part Number Input Signal Type Input Range Input Impedance Input Detection Current Sampling Duration Time Sampling Repetition Time AD Conversion Total Input System Transfer Time Type of Input Operating Mode Conversion Method Maximum Error at 25°C Input Error Cold Junction Compensation Error Temperature Coefficient Digital Resolution Input per Resolution Data Data Type in Application Program Monotonicity Input Data Out of Range Input Filter Noise Resistance FC6A-J2C1 Voltage Input 0 to 10V -10 to +10V 1MΩ maximum − FC6A-J4A1/FC6A-J8A1/FC6A-L06A1 Current Input 0 to 20mA 4 to 20mA 50Ω maximum − Voltage Input Current Input 0 to 10V 0 to 20mA -10 to +10V 4 to 20mA 1MΩ maximum 50Ω maximum − − 1ms 1ms or 10ms (selectable with application software) Sampling time × valid input channels Sampling time + sampling interval + 1 scan time Single-ended input Self-scan ∑ ∆ type ADC ±0.1% of full scale ±0.2% of full scale − − − − ±0.006% of full scale/°C ±0.01% of full scale/°C 65,536 increments (16 bits) 4,096 increments (12 bits) 0 to 10V: 0.15mV 0 to 20mA: 0.30μA 0 to 10V: 2.44mV 0 to 20mA: 4.88μA -10 to +10V: 0.30mV 4 to 20mA: 0.244μA -10 to +10V: 4.88mV 4 to 20mA: 3.91μA Optional: -32,768 to 32,767 (selectable for each channel) 1 Yes Detectable 2 Soft filter (0 to 10 s, selectable in increments of 0.1 s) Recommended Cable for Noise Immunity Twisted pair shielded cable 1LSB maximum Between input and power circuit: Transformer-isolated Between input and internal circuit: Photocoupler-isolated No damage Crosstalk Isolation Effect of Improper Input Connection Maximum Permanent Allowed Overload (No Damage) 13V DC 40mA 13V DC 40mA Using programming software Selection of Analog Input Signal Type Calibration or Verification to Maintain Rated Accuracy Not possible Note 1: The data processed in the analog I/O module can be linear-converted to a value between -32,768 and 32,767. The optional range designation, and analog I/O data minimum and maximum values can be selected using data registers allocated to analog I/O modules. Note 2: When an error is detected, a corresponding error code is stored to a data register allocated to analog I/O operating status. 2 Analog Input Specifications (2) Part Number Input Signal Type FC6A-L03CN1/FC6A-J4CN1 Voltage Input Current Input Resistance Thermometer FC6A-J8CU1 Thermocouple Thermocouple Type K (-200 to +1,300°C) Type J (-200 to +1,000°C) Pt100, Pt1000 3-wire Type R (0 to 1,760°C) type (-200 to 850°C) Type S (0 to 1,760°C) 0 to 10V DC 0 to 20mA Input Range Ni100, Ni1000 3-wire Type B (0 to 1,820°C) -10 to +10V 4 to 20mA type Type E (-200 to +800°C) (-60 to 180°C) Type T (-200 to +400°C) Type N (-200 to +1,300°C) Type C (0 to 2,315°C) Input Impedance 1 MΩ minimum 50Ω maximum 1 MΩ minimum 1 MΩ minimum Input Detection Current — — 0.1mA maximum 0.1mA maximum Sampling Duration Time 10ms, 100ms or 104ms (selectable using application software) AD Conversion Sampling Repetition Time Total Input System Transfer Time Type of Input Data Noise Resistance Cold Junction Compensation Error Isolation Effect of Improper Input Connection Maximum Permanent Allowed Overload (No Damage) Selection of Input Signal Type and Input Range Calibration or Verification to Maintain Rated Accuracy -90 to +150°C 100 to 10,000Ω 1 MΩ minimum 0.1mA maximum 104ms ±0.2% of full scale — — Single-ended input Self-scan ∑ ∆ type ADC FC6A-L03CN1: ±0.1% of full scale + cold junction compensation error FC6A-J4CN1: ±0.2% of full scale + cold junction compensation error 3 ±0.2% of full scale + cold junction compensation error 3 ±4°C maximum ±4°C maximum FC6A-L03CN1: 0.006%/°C of full scale Temperature Coefficient FC6A-J4CN1: 0.01%/°C of full scale Type K: approx. 15,000 increments (14 bits) Type J: approx. 12,000 increments (14 bits) Type R: approx. 17,600 Pt100: approx. 10,500 increments (15 bits) increments (14 bits) Type S: approx. 17,600 Pt1,000: approx. 8,000 increments (15 bits) increments (13 bits) Type B: approx. 18,200 Digital Resolution 65,536 increments (16 bits) Ni100: approx. 2,400 increments (15 bits) increments (12 bits) Type E: approx. 10,000 Ni1,000: approx. 2,400 increments (14 bits) increments (12 bits) Type T: approx. 6,000 increments (13 bits) Type N: approx. 15,000 increments (14 bits) Type C: approx. 23,150 increments (15 bits) 0 to 20mA: 0 to 10V: 0.15mV 0.30μA Input Value of LSB -10 to +10V: 0.1°C 0.1°C 4 to 20mA: 0.30mV 0.244μA Data Type in Application Program Monotonicity Input Data Out of Range Input Filter Recommended Cable for Noise Immunity Crosstalk PTC Thermistor Sampling time + sampling interval + 1 scan time Conversion Method Input Error NTC Thermistor Sampling time × valid input channels Operating Mode Maximum Error at 25°C Type K (-200 to +1,300°C) Type J (-200 to +1,000°C) Type R (0 to 1,760°C) Type S (0 to 1,760°C) Type B (0 to 1,820°C) Type E (-200 to +800°C) Type T (-200 to +400°C) Type N (-200 to +1,300°C) Type C (0 to 2,315°C) 1 MΩ minimum 0.1mA maximum 0.01%/°C of full scale Type K: approx. 15,000 increments (14 bits) Type J: approx. 12,000 increments (14 bits) Type R: approx. 17,600 increments (15 bits) Type S: approx. 17,600 increments (15 bits) Type B: approx. 18,200 increments (15 bits) Type E: approx. 10,000 increments (14 bits) Type T: approx. 6,000 increments (13 bits) Type N: approx. 15,000 increments (14 bits) Type C: approx. 23,150 increments (15 bits) 0.1°C NTC: approx. 2,400 increments (12 bits) PTC: approx. 9,900 increments (14 bits) 0.1°C 1Ω Optional: selectable for each channel from -32,768 to 32,767 1 Yes Detectable 2 Software Twisted pair shielded cable Twisted pair cable 1 LSB maximum Between input and power circuit: Transformer-isolated Between input and internal circuit: Photocoupler-isolated No damage 13V DC 40mA Using programming software Not possible Note 1: The data processed in the analog I/O module can be linear-converted to a value between -32,768 and 32,767. The optional range designation, and analog I/O data minimum and maximum values can be selected using data registers allocated to analog I/O modules. Note 2: When an error is detected, a corresponding error code is stored to a data register allocated to analog I/O operating status. Note 3: R, S: ±6 (0 to 200°C) B: no compensation K, J, E, T, N: ±0.4% of full scale (0°C maximum) 3 Analog Output Specifications Part Number FC6A-K4A1 FC6A-L06A1 0 to 10V DC -10 to +10V DC 0 to 20mA 4 to 20mA Voltage output: 1 kΩ minimum Current output: 300Ω maximum Resistive load 1ms 1ms DA Conversion Time +Output Update Interval + 1 scan time ±0.1% of full scale ±0.006%/°C of full scale ±0.4% of full scale No damage ±0.01%/°C of full scale 20mV maximum 0% ±1% of full scale 4,096 increments (12 bits) 0 to 10V DC: 2.44mV -10 to +10V DC: 4.88mV 0 to 20mA: 4.88μA 4 to 20mA: 3.91μA Optional: -32,768 to 32,767 (selected for each channel) Yes Undetectable Voltage Output Signal Style/Output Range Current Impedance Load Load Type DA Conversion Time DA Conversion Output Update Interval Total Output System Transfer Time ±0.2% of full scale ±0.01%/°C of full scale Maximum Error at 25°C Temperature Coefficient Repeatability after Stabilization Time Output Voltage Drop Output Error ±0.2% of full scale Non-lineality Output Ripple Overshoot Total Error Digital Resolution Voltage Output Value of LSB Current Data Data Type in Application Program Monotonicity Current Loop Open Recommended Cable for Noise Immunity Noise Resistance ±0.2% of full scale ±0.01%/°C of full scale ±0.2% of full scale Twisted pair shielded cable 1LSB Transformer-isolated Photocoupler-isolated No damage Using software programming Crosstalk Between output and power circuit Isolation FC6A-L03CN1 Between output and internal circuit Effect of Improper Output Connection Selection of Analog Output Signal Type Calibration or Verification to Maintain Rated Accuracy Impossible DIMENSIONS (all dimensions are in mm) 23.6 3.8 3.8 23.6 17.6 3.8 73.0 ∗ 5.0 11.7 30.2 4.0 90.0 90.0 73.0 ∗ 5.0 90.0 15.8 FC6A-N32B3/FC6A-T32K3 FC6A-T32P3 4.0 4.0 ∗ 5.0 3.8 FC6A-N16B3/FC6A-T16K3 FC6A-T16P3 4.0 90.0 FC6A-N08B1/FC6A-N08A11/FC6A-R081 FC6A-T08K1/FC6A-T08P1/FC6A-M08BR1 FC6A-J2C1/FC6A-K4A1/FC6A-L03CN1 10.1 73.0 ∗ 5.0 FC6A-N16B1/FC6A-R161 FC6A-T16K1/FC6A-T16P1 FC6A-J4A1/FC6A-J8A1 FC6A-J4CN1/FC6A-J8CU1 FC6A-L06A1 10.1 IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.IDEC.com/usa ©2016 IDEC Corporation. All Rights Reserved. FC9Y-DS100-0c PDF only 1603091339 73. 0
FC6A-L06A1 价格&库存
很抱歉,暂时无法提供与“FC6A-L06A1”相匹配的价格&库存,您可以联系我们找货
