FC6A-C40K1DEJ
FC6A-C40K1DEJ
    IDEC(日本和泉)
    控制器 - 可编程逻辑(PLC) DIN 轨道 12VDC
FC6A-C40K1DEJ 数据手册
MicroSmart FC6A PLC Digital I/O Specifications KEY FEATURES • 16 modules to choose from • Screw or MIL type terminal block • 8/16/32 points I/O module SPECIFICATIONS Input Module Specifications Part Number FC6A-N08B1 Input Points 8 (8/1 common) Rated Input Voltage Input Voltage Range Rated Input Current Input Impedance OFF Voltage ON Voltage OFF Current ON Current Input Delay Time (24V DC) FC6A-N16B1 FC6A-N16B3 16 (16/1 common) 32 (16/1 common) 8 (4/1 common) 24V DC sink/source input signal 0 to 28.8V DC 7 mA/point (24V DC) 5 mA/point (24V DC) 3.4 kΩ 4.4 kΩ 5V maximum 15V minimum 1.2 mA maximum 0.9 mA maximum 4.2 mA minimum (at 15V DC) 3.2 mA minimum (at 15V DC) Turn ON: 4.1ms, Turn OFF: 4.1ms Signal Determination Method Effect of Improper Input Connection Cable Length Turn ON: 25ms, Turn OFF: 30ms Not needed Static Both sink and source input signals can be connected. If any input exceeding the rated value is applied, permanent damage may be caused. 3m in compliance with electromagnetic immunity Connector Insertion/ Removal Durability Applicable Ferrule 100 to 120V AC 0 to 132V AC (50/60 Hz) 17 mA/point (120V AC, 60 Hz) 0.8 kΩ (60 Hz) 20V maximum 79V minimum — Between input terminals in the same common: Not isolated Between input terminals in different commons: Isolated Between input terminals and internal circuits: Photocoupler-isolated External Load for I/O Interconnection If any input exceeding the rated value is applied, permanent damage may be caused. — 100 times minimum 1-wire: AI 0.5-8 WH (Phoenix Contact) 2-wire: AI-TWIN 2×0.5-10 (Phoenix Contact) — All Inputs ON 30mA (5V DC) 0mA (24V DC) 40mA (5V DC) 0mA (24V DC) 40mA (5V DC) 0mA (24V DC) 65mA (5V DC) 0mA (24V DC) 40mA (5V DC) 0mA (24V DC) All Inputs OFF 17mA (5V DC) 0mA (24V DC) 17mA (5V DC) 0mA (24V DC) 17mA (5V DC) 0mA (24V DC) 17mA (5V DC) 0mA (24V DC) 17mA (5V DC) 0mA (24V DC) Internal Power Consumption (at 24V DC while all inputs ON) Weight (approx.) FC6A-N08A11 Between input terminals: Not isolated Internal circuit: Photocoupler-isolated Isolation Internal Current Draw FC6A-N32B3 0.20W 0.27W 0.27W 0.44W 0.27W 110g 105g 75g 110g 110g 1 Relay Output Module Specifications Part Number Transistor Output Module Specifications FC6A-R081 FC6A-R161 Output Points 8 (4/1 common) 16 (8/1 common) Output Type 1NO 2A per point 7A per common 8A per common Maximum Load Current Minimum Switching Load Initial Contact Resistance Electrical Life Mechanical Life Rated Load Dielectric Strength Connector Insertion/ Removal Durability Applicable Ferrule All outputs Internal ON Current All Draw outputs OFF Internal Power Consumption (at 24V DC while all outputs ON) Weight (approx.) FC6A-T08K1 FC6A-T08P1 Part Number Output Type Rated Load Voltage Operating Load Voltage Range 30 mΩ maximum Maximum Load Current 100,000 operations minimum (rated load 1,800 operations/hour) 20,000,000 operations minimum (no load 18,000 operations/hour) Resistive load: 240V AC 2A, 30V DC 2A Inductive load: 240V AC 2A (cos ø = 0.4) 30V DC 2A (L/R =7 ms) Between output and ground terminals: 1,500V AC, 1 minute Between output terminal and internal circuit: 1,500V AC, 1 minute Between output terminals (COMs): 1,500V AC, 1 minute Voltage Drop (ON Voltage) Inrush Current Leakage Current Clamping Voltage Maximum Lamp Load Inductive Load External Current Draw Overcurrent Protection Isolation 100 times minimum Connector Insertion/ Removal Durability 1-wire: AI 0.5-10 (Phoenix Contact) 2-wire: AI-TWIN 2×0.5-10 (Phoenix Contact) 35mA (5V DC) 50mA (24V DC) 50mA (5V DC) 100mA (24V DC) 17mA (5V DC) 0mA (24V DC) 17mA (5V DC) 0mA (24V DC) 1.44W 2.74W 130g 140g Applicable Ferrule All outputs ON Internal Current Draw FC6A-T16K3 FC6A-T16P3 FC6A-T32K3 FC6A-T32P3 8 (8/1 common) Output Points 1 mA/ 5V DC (reference value) FC6A-T16K1 FC6A-T16P1 All outputs OFF Internal Power Consumption (at 24V DC while all outputs ON) Turn ON Time Output Delay Turn OFF Time Weight (approx) 16 (16/1 common) 32 (16/1 common) FC6A-TK: Transistor sink output FC6A-TP: Transistor source output 24V DC 19.2 to 28.8V DC 0.5A per point 0.1A per point 3A per common 1A per common 1V maximum (voltage between COM and output terminals when output is on) 1A maximum 0.1mA maximum Approx. 50V 12W 2.4W L/R = 10ms (28.8V DC 1Hz) FC6A-TK: 100 mA maximum, 24V DC (power voltage at the +V terminal) FC6A-TP: 100 mA maximum, 24V DC (power voltage at the -V terminal) Transistor Sink Output: No Transistor Source Output: Yes Between output terminal and internal circuit: Photocoupler-isolated Between output terminals: Not isolated 100 times minimum 1-wire: AI 0.5-10 (Phoenix Contact) 2-wire: AI-TWIN 2×0.5-10 (Phoenix Contact) 25mA (5V DC) 30mA (5V DC) 45mA (5V DC) 15mA (24V DC) 25mA (24V DC) 50mA (24V DC) 17mA (5V DC) 17mA (5V DC) 17mA (5V DC) 17mA (5V DC) 0mA (24V DC) 0mA (24V DC) 0mA (24V DC) 0mA (24V DC) 0.53W 0.80W 1.50W 110g 400 μs maximum 450 μs maximum 105g 75g 115g Mixed I/O Module Specifications Part Number Input Points FC6A-M08BR1 FC6A-M24BR1 4 (4/1 common) 16 (16/1 common) 24V DC sink/source input signal Rated Input Voltage Input Voltage Range 0 to 28.8V DC Rated Input Current 7 mA/point (24V DC) 3.4 kΩ Input Specification Input Impedance 5V maximum OFF Voltage ON Voltage 15V minimum OFF Current 1.2 mA maximum 4.2 mA minimum (at 15V DC) ON Current Turn ON Time: 4.1ms, Turn OFF Time: 4.1ms Input Delay Time (24V DC) Between input terminals: Not isolated Internal circuit: Photocoupler-isolated Isolation Not needed External Load for I/O Interconnection Static Signal Determination Method Effect of Improper Input Connection Both sinking and sourcing input signals can be connected. If any input exceeding the rated value is applied, permanent damage may be caused. 3m in compliance with electromagnetic immunity Cable Length 4 (4/1 common) Output Points 8 (4/1 common) 1NO 2A per point 7A per common 1 mA/ 5V DC (reference value) Output Type Maximum Load Current Minimum Switching Load 30 mΩ maximum Output Specifications Initial Contact Resistance 100,000 operations minimum (rated load 1,800 operations/hour) Electrical Life Mechanical Life Rated Load Dielectric Strength Connector Insertion/Removal Durability 20,000,000 operations minimum (no load 18,000 operations/hour) Resistive load: 240V AC 2A, 30V DC 2A Inductive load: 240V AC 2A (cos ø = 0.4), 30V DC 2A (L/R =7 ms) Between output and PE terminals: 1,500V AC, 1 minute Between output terminal and internal circuit: 1,500V AC, 1 minute Between output terminals (COMs): 1,500V AC, 1 minute 100 times minimum 1-wire: AI 0.5-10 (Phoenix Contact), 2-wire: AI-TWIN 2×0.5-10 (Phoenix Contact) Applicable Ferrule Internal Current Draw All I/Os ON 30mA (5V DC), 25mA (24V DC) 55mA (5V DC), 25mA (24V DC) All I/Os OFF 17mA (5V DC), 0mA (24V DC) 17mA (5V DC), 0mA (24V DC) 0.80W 0.97W 120g 165g Internal Power Consumption (at 24V DC while all I/Os are ON) Weight (approx.) 2 Temperature derating curves: Input voltage vs. I/O Simultaneous ON Ratio (%) FC6A-N08B1 FC6A-N16B1 Ambient Temp. 55 ºC Input Voltage 28.8V 26.4V 24.0V 0V 0% 100% I/O Simultaneous ON Ration (%) FC6A-N08A11 Input Voltage 0V 28.8V 26.4V 24.0V 0% 100% I/O Simultaneous ON Ration (%) Input Voltage 0V 28.8V 26.4V 24.0V 0V 0% FC6A-T08P1/FC6A-T16P1 FC6A-T16P3/FC6A-T32P3 V (+) Internal Circuit Internal Circuit COM (+ ) Output 50% 70% 90% 100% Logic COM (− ) I/O Simultaneous ON Ration (%) Input Voltage Ambient Temp. 45 ºC Ambient Temp. 55 ºC 28.8V 26.4V 24.0V 0V 100% I/O Simultaneous ON Ration (%) 0% 70% 100% I/O Simultaneous ON Ration (%) Input Internal Circuit 4.3KΩ Input COM Input 3.3KΩ FC6A-N08A11 COM Input 2.21 kΩ COM Internal Circuit COM FC6A-M08BR1/FC6A-M24BR1 Internal Circuit Internal Circuit 3.3KΩ Input FC6A-N16B3/FC6A-N32B3 Internal Circuit FC6A-N08B1/FC6A-N16B1 DIMENSIONS (all dimensions are in mm) FC6A-N16B1/FC6A-R161 FC6A-T16K1/FC6A-T16P1 FC6A-J4A1/FC6A-J8A1 FC6A-J4CN1/FC6A-J8CU1 FC6A-L06A1 FC6A-N08B1/FC6A-N08A11/FC6A-R081 FC6A-T08K1/FC6A-T08P1/FC6A-M08BR1 FC6A-J2C1/FC6A-K4A1/FC6A-L03CN1 3.8 23.6 3.8 FC6A-N16B3/FC6A-T16K3 FC6A-T16P3 3.8 23.6 90.0 73.0 ∗ 5.0 11.7 10.1 73.0 FC6A-M24BR1/FC6A-F2M1 FC6A-F2MR1 30.2 3.8 39.2 4.0 10.1 73. 0 ∗ 5.0 90.0 90.0 4.0 ∗ 5.0 4.0 90.0 ∗ 5.0 90.0 ∗ 5.0 73.0 FC6A-N32B3/FC6A-T32K3 FC6A-T32P3 3.8 17.6 4.0 4.0 15.8 11.4 Output V (− ) Overcurrent Protection Element FC6A-M24BR1 Ambient Temp. 55 ºC 0% Ambient Temp. 30 ºC Ambient Temp. 55 ºC Input Voltage 0V 70% 100% 0% I/O Simultaneous ON Ration (%) 28.8V 26.4V 24.0V FC6A-T08K1/FC6A-T16K1 FC6A-T16K3/FC6A-T32K3 FC6A-N16B3/FC6A-N32B3 Ambient Temp. 45 ºC Ambient Temp. 55 ºC FC6A-M08BR1 Ambient Temp. 55 ºC 132V 120V 102V Input Voltage Output Internal Circuit 73. 0 ∗ 9.3 mm when the clamp is pulled out. IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.IDEC.com/usa ©2016 IDEC Corporation. All Rights Reserved. FC9Y-DS100-0b PDF only 1603091339
FC6A-C40K1DEJ
物料型号: - 输入模块型号包括FC6A-N08B1, FC6A-N16B1, FC6A-N16B3, FC6A-N32B3, FC6A-N08A11等。 - 输出模块型号包括FC6A-R081, FC6A-R161等。 - 晶体管输出模块型号包括FC6A-T08K1, FC6A-T08P1, FC6A-T16K1, FC6A-T16P1等。 - 混合I/O模块型号包括FC6A-M08BR1, FC6A-M24BR1等。
器件简介: - 提供16种模块选择,支持螺钉或MIL型端子台,8/16/32点I/O模块。
引脚分配: - 各模块的输入/输出点数不同,例如8点输入模块具有8个输入点,16点输入模块具有16个输入点等。
参数特性: - 输入模块的额定输入电压、输入电压范围、额定输入电流、输入阻抗、关断电压、导通电压、关断电流、导通电流、输入延迟时间等参数均有详细说明。 - 输出模块的最大负载电流、初始接触电阻、机械寿命、电气寿命、额定负载、介质强度等参数也进行了描述。
功能详解: - 包括输入信号的确定方法、不当输入连接的影响、电缆长度、端子的插入/拔出耐久性、适用的端子等。
应用信息: - 适用于电磁兼容性、内部电路功耗、重量等应用场景。
封装信息: - 提供了不同模块的尺寸信息。
FC6A-C40K1DEJ 价格&库存
很抱歉,暂时无法提供与“FC6A-C40K1DEJ”相匹配的价格&库存,您可以联系我们找货
FC6A-C40K1DEJ
  • 1+8743.335571+1131.08393
