FC6A-EXM2
FC6A-EXM2
    IDEC(日本和泉)
    接口模块 DIN 轨道 24VDC
FC6A-EXM2 数据手册
MicroSmart FC6A PLC Expansion Interface Module Specifications KEY FEATURES • Required when expanding to more than 7 expansion modules • Allows FC6A to expand an additional 8 expansion modules Expansion Interface Module Specifications Part Number FC6A-EXM2 Rated Power Voltage 24V DC Allowable Voltage Range 20.4 to 28.8V DC Power Consumption Internal power (supplied from CPU module): 20 mA (5V DC), 0 mA (24V DC) External power: With I/O modules 1 750 mA (26.4V DC) Maximum Power Consumption (External Power) 1 0.5W (24V DC) Allowable Momentary Power Interruption 10ms minimum (24V DC) I/O Expansion Between CPU module and expansion interface module Connectable I/O modules: 7 maximum (224 I/Os maximum) Beyond the expansion interface module Connectable I/O modules: 8 maximum (256 I/Os maximum) Not isolated Isolation from Internal Circuit Connector Insertion/Removal Durability 100 times minimum Applicable Ferrules 1-wire: AI 0.5-10 (Phoenix Contact) 2-wire: AI-TWIN 2×0.5-10 (Phoenix Contact) 150g Weight (approx.) Note 1: Power consumption by the expansion interface module and eight I/O modules. DIMENSIONS (all dimensions are in mm) FC6A-EXM2 39.2 90.0 4.0 ∗ 5.0 3.8 15.2 73. 0 IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.IDEC.com/usa ©2016 IDEC Corporation. All Rights Reserved. FC9Y-DS100-0f PDF only 1603091339
FC6A-EXM2 价格&库存
很抱歉,暂时无法提供与“FC6A-EXM2”相匹配的价格&库存,您可以联系我们找货
FC6A-EXM2
    • 1+2447.585601+316.81445
