MicroSmart FC6A PLC
HMI and Communication Adapter Specifications
KEY FEATURES
• Add 2nd Ethernet port
• Add additional serial port
• HMI module supports User Web Page
• HMI module supports Web Server Functions
• HMI module supports Email and Text Message notifications
HMI MODULE SPECIFICATIONS
General Specifications
Operation Specifications
Part Number
FC6A-PH1
Power Consumption Inside
Module (without connection
cartridge)
100mA (5V)
1.5mA (24V)
Cartridge (option)
One analog cartridge can be added
Weight (approx.)
170g
Part Number
FC6A-PH1
Operation Method
Rubber Switch
Operating Force
2.0N minimum
Mechanical Life
10,000 operations
Multiple Operation
Possible
HMI Ethernet Port Specifications
Display Specifications
Part Number
FC6A-PH1
Complies with IEEE802.3
FC6A-PH1
Display
TFT Monochrome LCD
Transmission speed
10BASE-T, 100BASE-TX
Color/Shade
Monochrome
Effective Display Area
47.98W × 8.22H mm
Protocol
Datalink layer: IP/ARP
Network layer: TCP/UDP, ICMP
Application layer: DHCP, DNS, HTTP, SMTP
Display Resolution
192W × 64H pixels
Connector
RJ45
View Angle
Right and left 30°,up 20°, down 40°
Cable
CAT 5. STP
Contrast adjustment
Impossible
Maximum Cable Length
100m
Backlight
LED (green)
Brightness
45 cd/m2
Isolation from
Internal Circuit
Pulse transformer isolation
Brightness Adjustment
Impossible
Backlight Control
ON/OFF
Backlight Replacement
Impossible
Display
Character
Size
1/2 size
8 × 16 pixels (JIS 8-bit code, Western European language ISO 88591, Cyrillic ANSI1251)
Full size
16 × 16 pixels (Japanese JIS first level characters, simplified
Chinese)
Quantity of
Characters
1/2 size
24 characters × 4 lines
Full size
12 characters × 4 lines
Major Functions
Part Number
Communication
Remote
Maintenance
Uploading, downloading and monitoring using WindLDR
Number of connections: 8
Web Server
Page data of 5MB maximum (total of system web page and user web
page) can be stored. (System web page: approx. 450 KB)
Number of connections: 8 maximum
Authentic method: digest authentication
Send E-mail
Sends preregistered e-mails.
Up to 255 types of e-mails can be sent.
Authentic method: SMTP-Auth (login),
SMTP-Auth (CRAM-MD5), SMTPs
Encoding method: BASE64
E-mail Size
The maximum size of texts for To or Cc is 512 bytes. 1
E-mail subject: 255 bytes maximum
E-mail body: 4096 bytes maximum
Attached CSV file: 4096 bytes maximum
(includes spaces, separator characters, and newlines)
Blink, reverse,
Character Attribute
FC6A-PC3
EIA RS232C
EIA RS485
Maximum Baud Rate
115,200bps
Maintenance Communication
Possible
Possible
User Communication
Possible
Possible
Data Link Communication
Possible
Half-duplex Communication
Possible
5m
200m
Quantity of Slave Stations
31
Note 1: Comma (,) is inserted as a separating character between e-mail addresses.
DIMENSIONS
FC6A-PH1
66.5
FC6A-PC1
Standards
3. 9
Part Number
74.5
7. 3
73. 0
Isolation between Internal Circuit
Not isolated
and Communication Port
Conductor Resistance
Shield Resistance
3-core shielded cable with a minimum
core wire of 0.3 mm2
90.0
Cable
85 Ω/km maximum
20 Ω/km maximum
5. 0
RS485
Cable
4.0
119.5
148.7
IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.IDEC.com/usa
©2016 IDEC Corporation. All Rights Reserved. FC9Y-DS100-0e PDF only
1603091339
很抱歉,暂时无法提供与“FC6A-PC1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+710.358551+92.19158
- 10+643.2871710+83.48694
- 25+618.3610225+80.25198
- 50+600.1482850+77.88830
- 100+582.46272100+75.59303
