FC6A-PC3
FC6A-PC3
    IDEC(日本和泉)
    RS485 COMMUNICATION ADAPTER
FC6A-PC3 数据手册
MicroSmart FC6A PLC HMI and Communication Adapter Specifications KEY FEATURES • Add 2nd Ethernet port • Add additional serial port • HMI module supports User Web Page • HMI module supports Web Server Functions • HMI module supports Email and Text Message notifications HMI MODULE SPECIFICATIONS General Specifications Operation Specifications Part Number FC6A-PH1 Power Consumption Inside Module (without connection cartridge) 100mA (5V) 1.5mA (24V) Cartridge (option) One analog cartridge can be added Weight (approx.) 170g Part Number FC6A-PH1 Operation Method Rubber Switch Operating Force 2.0N minimum Mechanical Life 10,000 operations Multiple Operation Possible HMI Ethernet Port Specifications Display Specifications Part Number FC6A-PH1 Complies with IEEE802.3 FC6A-PH1 Display TFT Monochrome LCD Transmission speed 10BASE-T, 100BASE-TX Color/Shade Monochrome Effective Display Area 47.98W × 8.22H mm Protocol Datalink layer: IP/ARP Network layer: TCP/UDP, ICMP Application layer: DHCP, DNS, HTTP, SMTP Display Resolution 192W × 64H pixels Connector RJ45 View Angle Right and left 30°,up 20°, down 40° Cable CAT 5. STP Contrast adjustment Impossible Maximum Cable Length 100m Backlight LED (green) Brightness 45 cd/m2 Isolation from Internal Circuit Pulse transformer isolation Brightness Adjustment Impossible Backlight Control ON/OFF Backlight Replacement Impossible Display Character Size 1/2 size 8 × 16 pixels (JIS 8-bit code, Western European language ISO 88591, Cyrillic ANSI1251) Full size 16 × 16 pixels (Japanese JIS first level characters, simplified Chinese) Quantity of Characters 1/2 size 24 characters × 4 lines Full size 12 characters × 4 lines Major Functions Part Number Communication Remote Maintenance Uploading, downloading and monitoring using WindLDR Number of connections: 8 Web Server Page data of 5MB maximum (total of system web page and user web page) can be stored. (System web page: approx. 450 KB) Number of connections: 8 maximum Authentic method: digest authentication Send E-mail Sends preregistered e-mails. Up to 255 types of e-mails can be sent. Authentic method: SMTP-Auth (login), SMTP-Auth (CRAM-MD5), SMTPs Encoding method: BASE64 E-mail Size The maximum size of texts for To or Cc is 512 bytes. 1 E-mail subject: 255 bytes maximum E-mail body: 4096 bytes maximum Attached CSV file: 4096 bytes maximum (includes spaces, separator characters, and newlines) Blink, reverse, Character Attribute Communication Adapter FC6A-PC3 EIA RS232C EIA RS485 Maximum Baud Rate 115,200bps Maintenance Communication Possible Possible User Communication Possible Possible Data Link Communication — Possible Half-duplex Communication — Possible Maximum Cable Length 5m 200m Quantity of Slave Stations — 31 Note 1: Comma (,) is inserted as a separating character between e-mail addresses. DIMENSIONS FC6A-PH1 66.5 FC6A-PC1 Standards 3. 9 Part Number 74.5 7. 3 73. 0 Isolation between Internal Circuit Not isolated and Communication Port — Conductor Resistance Shield Resistance 3-core shielded cable with a minimum core wire of 0.3 mm2 90.0 Cable 85 Ω/km maximum 20 Ω/km maximum ∗ 5. 0 RS485 Cable 4.0 119.5 148.7 IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.IDEC.com/usa ©2016 IDEC Corporation. All Rights Reserved. FC9Y-DS100-0e PDF only 1603091339
FC6A-PC3 价格&库存
很抱歉,暂时无法提供与“FC6A-PC3”相匹配的价格&库存,您可以联系我们找货
