FC6A-F2MR1
FC6A-F2MR1
    IDEC(日本和泉)
    PID 控制模块 DIN 轨道 24VDC
FC6A-F2MR1 数据手册
MicroSmart FC6A PLC PID Module Specifications KEY FEATURES • Configure up to 15 modules • Maximum 30 PID loops • 2 analog inputs and 2 relay or 4-20mA Non-contact voltage output for SSR drive SPECIFICATIONS Input Range FC6A-F2MR1 FC6A-F2M1 K Input Range (Digital Resolution) Input Value of LSB -200 to 1,370°C -328 to 2,498°F 1°C (°F) -200.0 to 400.0°C -328.0 to 752.0°F 0.1°C (°F) J -200 to 1,000°C -328 to 1,832°F 1°C (°F) R 0 to 1,760°C 32 to 3,200°F 1°C (°F) S 0 to 1,760°C 32 to 3,200°F 1°C (°F) B 0 to 1,820°C 32 to 3,308°F 1°C (°F) E -200 to 800°C -328 to 1,472°F 1°C (°F) T -200.0 to 400.0°C -328.0 to 752.0°F 0.1°C (°F) N -200 to 1,300°C -328 to 2,372°F 1°C (°F) PL-II 0 to 1,390°C 32 to 2,534°F 1°C (°F) C (W/Re5-26) 0 to 2,315°C 32 to 4,199°F 1°C (°F) -200 to 850°C -328 to 1,562°F 1°C (°F) -200.0 to 850.0°C -328.0 to 1,562.0°F 0.1°C (°F) -200 to 500°C -328 to 932°F 1°C (°F) -200.0 to 500.0°C -328.0 to 932.0°F 0.1°C (°F) Pt100 JPt100 DC 4 to 20mA -2,000 to 10,000 (12,000 increments) 1 1.333μA DC 0 to 20mA -2,000 to 10,000 (12,000 increments) 1 1.666μA DC 0 to 1V -2,000 to 10,000 (12,000 increments) 1 0.083mA DC 0 to 5V -2,000 to 10,000 (12,000 increments) 1 0.416mA DC 1 to 5V -2,000 to 10,000 (12,000 increments) 1 0.333mA DC 0 to 10V -2,000 to 10,000 (12,000 increments) 1 0.833mA FC6A-M24BR1/FC6A-F2M1 FC6A-F2MR1 3.8 39.2 4.0 90.0 Input DIMENSIONS ∗ 5.0 Part Number 11.4 73. 0 ∗ 9.3 mm when the clamp is pulled out. Note 1: Linear-conversion is possible. 1 RATINGS Part Number Control Mode FC6A-F2MR1 Possible Heating/Cooling Control Possible (overwrapping deadband settings available) 1 Difference Input Temperature Control Possible 1 Cascade Control Possible 1 2ch Input Points Input Type Input Range FC6A-F2M1 Independent PID Control Thermocouple K, J, R, S, B, E, T, N, PL-II, C (W/Re5-26) External resistance: 100Ω maximum Resistance Thermometer Pt100, JPt100, 3-wire type Current Input 0 to 20 mA DC, 4 to 20 mA DC Input impedance: 50Ω Voltage Input 0 to 1V DC Input impedance: 1MΩ minimum 0 to 5V DC, 1 to 5V DC, 0 to 10V DC Input impedance: 100kΩ minimum 100 ms Sampling Duration Time 100 ms Sampling Repetition Time AD Conversion Sampling time + sampling interval + 1 scan time Total Input System Transfer Time Differential input Type of Input ∑ ∆ type ADC Conversion Method Maximum Error at 25°C Thermocouple Input ±0.2% of full scale or ±2°C (4°F), whichever is greater However, R, S inputs: 0 to 200°C (0 to 400°F): ±6°C (12°F) B input: 0 to 300°C (0 to 600°F) Accuracy is not guaranteed. K, J, E, T, N inputs: Less than 0°C (32°F): ±0.4% of full scale ±0.1% of full scale or ±1°C (2°F), whichever is greater Resistance Thermometer Input ±0.2% of full scale Voltage/Current Inputs ±1°C at 0 to 55°C Cold Junction Temperature Compensation Accuracy ±0.005%/°C of full scale Temperature Coefficient Yes Input Filter Noise Resistance Recommended Cable for Noise Immunity Twisted pair shielded cable (current/voltage) / Twisted pair cable (temperature input) None Cross Talk Isolation Between input and power circuit Transformer-isolated Between input and internal circuit Photocoupler-isolated 2ch Output Points Relay output 1NO Rated load 5A 250V AC/30V DC (resistive load) 3A 250V AC (inductive load cos ø=0.4) 3A 30V DC (resistive load VR=7ms) Minimum open/closed load: 10 mA 5V DC (reference value) Electrical life: 100,000 cycles (at the maximum rating of resistive load) Output Noise Resistance Non-contact voltage output (for SSR drive) 12V DC±15% Maximum 40 mA (short circuit protected) Recommended Cable for Noise Immunity Cross Talk Analog current output 4 to 20 mA DC Load resistance: 550Ω maximum Analog output digital resolution: 1,000 LSB input value: 0.016 mA — Twisted pair shielded cable — None Between input and power circuit: Transformer-isolated Between input/output and internal circuits: Photocoupler-isolated Between input circuits: Photocoupler-isolated Isolation 24V DC (External power), 5V DC (Internal power) Power Voltage Allowable Voltage Range Maximum Power Consumption Internal Power Consumption 20.4 to 28.8V DC 3.6W 65mA (5V DC) 140g Weight (approx.) Note 1: Dual channel input is required for one loop control. IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.IDEC.com/usa ©2016 IDEC Corporation. All Rights Reserved. FC9Y-DS100-0d PDF only 1603091339
FC6A-F2MR1 价格&库存
很抱歉,暂时无法提供与“FC6A-F2MR1”相匹配的价格&库存,您可以联系我们找货
