FC6A-EXM1M
FC6A-EXM1M
    IDEC(日本和泉)
    接口模块 DIN 轨道 5VDC
FC6A-EXM1M 数据手册
MicroSmart FC6A Plus PLC Expansion Interface Module KEY FEATURES • • • SLAVE MODULE MASTER MODULE ClassI Div2 Hazardous Location FC6A PLUS EXPANSION INTERFACE MODULE (MASTER MODULE) SPECIFICATIONS Part No. FC6A-EXM1M No. of Connectable CPU Plus: 1 No. of Connectable Slaves 10 Connector RJ45 Cable CAT 5. STP Maximum Cable Length 100m Isolation from Internal Circuit Pulse transformer isolation Power Consumption inside Module DC5V: 75mA Weight (approx.) 80g Easily expand FC6A digital and analog I/O Supports 1 master and up to 10 slave modules Uses standard RJ45 Ethernet cable Note: When using an expansion interface module (separate master type), the no. of connectable expansion modules to the Plus CPU module is 5 maximum. (13 max. modules when using an expansion interface (unibody type) FC6A PLUS EXPANSION INTERFACE MODULE (SLAVE MODULE) SPECIFICATIONS Part No. 8 maximum (256 I/Os maximum) 24V DC Allowable Voltage Range 20.4 to 28.8V DC Maximum Power Consumption (*1) (External Power) 24.5W Allowable Momentary Power Interruption 10ms minimum (24V DC) Connectable Expansion Modules Digital I/O Module Analog I/O Module Connector Communication Between internal circuits and power supply Not isolated Between input circuits and communication Pulse transformer isolation Insertion/Removal Durability 100 times minimum Applicable Ferrules 1-wire: AI 0.5-10 (Phoenix Contact) 2-wire: AI-TWIN 2×0.5-10 (Phoenix Contact) Connector RJ45 Cable CAT 5. STP Maximum Cable Length 100m Weight (approx.) 165g 5.1 Beyond the expansion interface module: Connectable I/O modules 15.2 73.0 FC6A-EXM1M 3.8 23.6 90.0 7 maximum (224 I/Os maximum) 90.0 47.3 Between CPU module and expansion interface module: Connectable I/O modules Rated Power Voltage Isolation from Internal Circuit FC6A-EXM1S FC6A-EXM1S 5.1 I/O Expansion DIMENSIONS (mm) *1: Power consumption by the expansion interface module and seven I/O modules. 73.0 IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.IDEC.com/usa ©2017 IDEC Corporation. All Rights Reserved. FC9Y-DS300-0f 10/17 PDF Only
FC6A-EXM1M 价格&库存
很抱歉,暂时无法提供与“FC6A-EXM1M”相匹配的价格&库存,您可以联系我们找货
FC6A-EXM1M
    • 1+2216.757511+286.93616
