MicroSmart FC6A Plus PLC
Expansion Interface Module
KEY FEATURES
SLAVE MODULE
MASTER MODULE
ClassI Div2
Hazardous
Location
FC6A PLUS EXPANSION INTERFACE MODULE
(MASTER MODULE) SPECIFICATIONS
Part No.
FC6A-EXM1M
No. of Connectable CPU
Plus: 1
No. of Connectable Slaves
10
Connector
RJ45
Cable
CAT 5. STP
Maximum Cable Length
100m
Isolation from Internal Circuit
Pulse transformer isolation
Power Consumption inside Module
DC5V: 75mA
Weight (approx.)
80g
Easily expand FC6A digital and analog
I/O
Supports 1 master and up to 10 slave
modules
Uses standard RJ45 Ethernet cable
Note: When using an expansion interface module (separate master type), the no. of connectable expansion modules to the Plus CPU module is 5 maximum.
(13 max. modules when using an expansion interface (unibody type)
(SLAVE MODULE) SPECIFICATIONS
Part No.
8 maximum (256 I/Os maximum)
24V DC
Allowable Voltage Range
20.4 to 28.8V DC
Maximum Power Consumption (*1) (External Power)
24.5W
Allowable Momentary Power Interruption
10ms minimum (24V DC)
Connectable Expansion Modules
Digital I/O Module
Analog I/O Module
Connector
Communication
Between internal circuits and power
supply
Not isolated
Between input circuits and
communication
Insertion/Removal Durability
100 times minimum
Applicable Ferrules
1-wire: AI 0.5-10 (Phoenix Contact)
2-wire: AI-TWIN 2×0.5-10 (Phoenix Contact)
Connector
RJ45
Cable
CAT 5. STP
100m
Weight (approx.)
165g
5.1
Beyond the expansion interface module:
Connectable I/O modules
15.2
73.0
FC6A-EXM1M
3.8
23.6
90.0
7 maximum (224 I/Os maximum)
90.0
47.3
Between CPU module and expansion
interface module: Connectable I/O
modules
Rated Power Voltage
Isolation from
Internal Circuit
FC6A-EXM1S
FC6A-EXM1S
5.1
I/O Expansion
DIMENSIONS (mm)
*1: Power consumption by the expansion interface module and seven I/O modules.
73.0
IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.IDEC.com/usa
©2017 IDEC Corporation. All Rights Reserved. FC9Y-DS300-0f 10/17 PDF Only
很抱歉,暂时无法提供与“FC6A-EXM1S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2713.156291+352.70154
- 10+2264.2653310+294.34717
- 25+2124.9120425+276.23169
