FC6A-D32K3CEE
FC6A-D32K3CEE
    IDEC(日本和泉)
    PLC 32IO 24VDC TRANS. SINK
FC6A-D32K3CEE 数据手册
MicroSmart FC6A Plus PLC CPU Module Specifications PRODUCT DESCRIPTION This next-generation IDEC MicroSmart FC6A Plus PLC performs beyond micro PLC limits. With its 2,060 I/O capacity, it can control large machines or entire small-scale manufacturing facilities, providing more capabilities for the most demanding applications. KEY FEATURES • Dual Ethernet ports FC6A PLUS CPU MODULES High-speed Counter & Pulse Output Part No. • iOS and Android WindEDIT app Power Input FC6A-D16K1CEE FC6A-D32P3CEE Interface I/O Points Relay Output 2A (240V AC-2A, 30V DC-2A) FC6A-D16R1CEE FC6A-D16P1CEE Output • High-speed counter Maximum input frequency: 100kHz • Pulse output (*1) Maximum output frequency: 100kHz 24V DC FC6A-D32K3CEE 24V DC (Sink/ Source) Port 1 (USB) Transistor Sink Output 0.5A Port 2 (Ethernet) Transistor Source Output 0.1A Port 3 (Ethernet) 16 points (8/8) ClassI Div2 Hazardous Location Part No. FC6A-D16R1CEE FC6A-D16P1CEE FC6A-D16K1CEE Rated Power Voltage 24V DC Allowable Voltage Range 20.4 to 28.8V DC (including ripple) Maximum Power Consumption (CPU module) FC6A-D16R1CEE: 2.88W (24V DC) FC6A-D16P1CEE: 2.88W (24V DC) FC6A-D16K1CEE: 2.88W (24V DC) FC6A-D32P3CEE: 3.36W (24V DC) FC6A-D32K3CEE: 3.36W (24V DC) FC6A-D32P3CEE FC6A-D32K3CEE 35A maximum 10ms (at rated voltage) Storage Temperature –25 to +65ºC (no freezing) –25 to +­70ºC (no freezing) Relative Humidity Level RH1 (IEC 61131-2) 10 to 95% (no condensation) Altitude Operation: 0 to 2,000m, 795 to 1,013hPa, Transport: 0 to 3,000m, 701 to 1,013hPa Pollution Degree 2 (IEC 60664-1) Corrosion Immunity Free from corrosive gases Between power and FE terminals: 500V AC, 1 minute Between transistor output and FE terminals: 500V AC, 1 minute Between power and input terminals: 500V AC, 1 minute Between power and relay output terminals: 2,300V AC, 1 minute Between input and relay output terminals: 2,300V AC, 1 minute Dielectric Strength • BACnet/IP and Modbus TCP 32 points (16/16) SPECIFICATIONS Inrush Current Allowable Momentary Power Interruption Operating Temperature • -25 to 65 degree C operating temperature • Bluetooth communication Transistor Source Output 0.5A Transistor Sink Output 0.1A • Maximum 2,060 digital I/O Between input and FE terminals: 500V AC, 1 minute Between relay output and FE terminals: 2,300V AC, 1 minute Between power and transistor output terminals: 500V AC, 1 minute Between input and transistor output terminals: 500V AC, 1 minute 1 SPECIFICATIONS CONT. Insulation Resistance Noise Resistance USB PORT SPECIFICATIONS Between power and FE terminals: 100MΩ or higher (500V DC megger) Between transistor output and FE terminals: 100MΩ or higher (500V DC megger) Between power and input terminals: 100MΩ or higher (500V DC megger) Between power and relay output terminals: 100 MΩ or higher (500V DC megger) Between input and relay output terminals: 100MΩ or higher (500V DC megger) Between input and FE terminals: 100MΩ or higher (500V DC megger) Between relay output and FE terminals: 100MΩ or higher (500V DC megger) Between power and transistor output terminals: 100 MΩ or higher (500V DC megger) Between input and transistor output terminals: 100 MΩ or higher (500V DC megger) USB mini-B USB Standard USB 2.0 Isolation Not isolated from the internal circuit Maintenance communication to PC Communication Function ETHERNET PORT 1 SPECIFICATIONS AC/DC power terminals: 1kV, 50ns to 1μs I/O terminals (coupling clamp): 1.5kV, 50ns to 1μs coupling adapter Shock Resistance 5 to 8.4Hz amplitude 3.5mm 8.4 to 150Hz acceleration 9.8m/s2 (1G), 2 hours per axis on each of three mutually perpendicular axes (IEC 61131-2) 147m/s2 (15G), 11ms duration, 3 shocks per axis on three mutually perpendicular axes Degree of Protection IP20 (IEC 60529) Power Supply Wire UL1007 AWG24-16, UL2464 AWG24-16, UL1015 AWG20-16 Grounding Wire UL1007 AWG16 Ground D-type ground (Class 3 ground) Mounting DIN rail or panel mounting Weight (approx.) FC6A-D16R1CEE: 290g FC6A-D16P1CEE: 275g FC6A-D16K1CEE: 275g Vibration Resistance USB Type Communication Type IEEE802.3 compliant Communication Speed 10BASE-T, 100BASE-TX Connector RJ45 Cable CAT.5STP Maximum Cable Length 100m Isolation Pulse transformer isolation Communication Function Maintenance communication (server), user communication (server/client), user communication UDP, Modbus TCP (server/client), Email, Web Server, PING, SNTP, FTP server/client, BACnet/IP server FC6A-D32P3CEE: 255g FC6A-D32K3CEE: 255g ETHERNET PORT 2 SPECIFICATIONS FUNCTION SPECIFICATIONS FC6A-D16R1CEE FC6A-D16P1CEE (*4) FC6A-D16K1CEE (*4) Part No. Control System Instruction Words Basic Stored program system 42 Advanced 130 Program Capacity (*1) 800KB (100,000 steps) User Program Storage Processing Time I/O Points FC6A-D32P3CEE (*4) FC6A-D32K3CEE (*4) Serial Flash Memory (100,000 times rewritable) Basic Instruction 21μs/1,000 steps END Processing (*2) 1ms maximum Input 8 points 16 points Output 8 points 16 points Expandable Modules 7 modules (*3) Expandable I/O Points with Expansion Modules 224 points Expandable Modules with Unibody Type Expansion 8 modules Modules Expandable I/O Points with Unibody Type Expansion 256 points Modules Expandable Modules with Separate Type Expansion 63 modules (separate type master: 1 module maximum, separate type slave: 10 Modules (*5) modules maximum) Expandable I/O Points with Separate Type Expansion 2,016 points Modules (*5) Internal Relay 15,400 points Special Internal Relay 1,600 points Shift Register 256 points Data Register 60,000 points Non-Retentive Data Register 200,000 points Special Data Register 900 points Counter 512 points Timer (1ms, 10ms, 100ms,1s) 2,000 points Clock Battery Clock accuracy: ±30 sec/month (typical) at 25°C Internal relay, shift register, counter, data register, timer, special data register, special internal relay, clock data Lithium primary battery (BR2032) Battery Life Approx. 4 years Replaceability Possible Keep data, user program sum check (serial flash memory), user program sum check (RAM), timer/counter preset value sum check, user program syntax check, user program execution check, WDT check, user program write check, power failure, clock error, data ink connection check, I/O bus initialization check 0 ms (without filter), 3 to 15ms (selectable in increments of 1ms) I14, I15, I16, I17: 3ms Six inputs I0, I1, I3, I4, I6, I7 (Minimum turn on pulse width: 5μs max./Minimum turn off pulse width: 5μs max.) Backup Data RAM Backup Self-diagnostic Function Input Filter Catch Input/Interrupt Input 2 Communication Type IEEE802.3 compliant Communication Speed 10BASE-T, 100BASE-TX Connector RJ45 Cable CAT.5STP Maximum Cable Length 100m Isolation Pulse transformer isolation Maintenance communication (server), user communication (server/client), Communication Function user communication UDP, Modbus TCP (server/client), PING FUNCTION SPECIFICATIONS CONT. High-speed Counter Analog Potentiometer Analog Voltage Input Pulse Output (transistor output model only) Maximum Counting Frequency and Highspeed Counter Points Counting Range Total 6 points Single/two-phase selectable: 100kHz (single-phase: 6 points, two-phase: 3 points) 0 to 4,294,967,295 (32 bits) Operation Mode Rotary encoder mode, adding counter mode, frequency measurement mode Quantity 1 point Data Range 0 to 1,000 Quantity 1 point Input Voltage Range 0 to 10V Input Impedance Approx. 100KΩ Digital Resolution Approx. 4,000 steps (12 bits) Quantity Maximum Output Pulse Frequency Reversible Control 4 points PWM Output Duty cycle 0.1 to 100.0% (increments of 0.1%), Output pulse frequency 15 to 5,000 Hz (increments of 1 Hz): 4 points (Q0, Q2, Q4, Q6) (Adjust 5µs minimum as ON time and 15µs minimum as OFF time.) Q0, Q2, Q4, Q6: 100kHz Single-pulse output mode: 4 axis (Q0-Q7), Dual-pulse output mode: 4 axis (Q0-Q7) USB Port USB mini-B (maintenance communication) Ethernet Port 1 Maintenance communication (server), user communication TCP (server/client), user communication UDP, Modbus TCP (server/client), Email, Web Server, PING, SNTP, FTP server/client Ethernet Port 2 Maintenance communication (server), user communication TCP (server/client), user communication UDP, Modbus TCP (server/client), PING Cartridge (option) Two cartridges can be added (when using FC6A–HPH1)/One cartridge can be added (when using FC6A–PH1) SD Card Slot Embedded HMI Module (option) Yes *1: 1 step equals 8 bytes. *2: Not including expansion I/O service time, counter timer processing time, data link processing time, and interrupt processing time. *3: A maximum of 5 modules can be connected when using the expansion interface module separate type master. *4: Transistor output model *5: Communication module cannot be connected. INPUT SPECIFICATIONS FC6A-D16R1CEE FC6A-D16P1CEE FC6A-D16K1CEE Part No. Input Points Rated Input Voltage Input Voltage Range Rated Input Current Input Impedance Turn ON Time Input Delay Turn OFF Time Isolation Input Type External Load for I/O Interconnection Signal Determination Method Effect of Improper Input Connection Cable Length Connector FC6A-D32P3CEE FC6A-D32K3CEE 8 (8/1 common) 24V DC: 24V DC sink/source input signal 0 to 28.8V DC High speed input port 5mA/pt, middle/normal speed input port 7mA/pt High speed input port 4.9kΩ, middle/normal speed input port: 3.4kΩ High speed input port: 5μs + filter value Middle speed input port: 35μs + filter value Normal speed input port: 35μs + filter value High speed input port: 5μs + filter value Middle speed input port: 35μs + filter value Normal speed input port: 100μs + filter value Between input terminals: Not isolated Internal circuit: Optocoupler-isolated Type1 (IEC 61131-2) Not needed Static Both sinking and sourcing input signals can be connected, therefore reverse connection does not cause damage. If any input exceeding the rated value is applied, permanent damage may be caused. 3m in compliance with electromagnetic immunity Insertion Durability 100 times minimum Applicable Ferrule 1-wire: AI 0.5-8 WH (Phoenix Contact) 2-wire: AI-TWIN 2×0.5-8 WH (Phoenix Contact) RELAY OUTPUT SPECIFICATIONS Part No. FC6A-D16R1CEE Relay Output Points Output Points per Common Line 8 COM1 4 COM2 4 Output Type Maximum Load Current 16 (16/1 common) 1NO Per Point 2A Per Common COM1: 7A COM2: 7A Minimum Switching Load 1mA/5V DC (reference value) Initial Contact Resistance 30mΩ maximum 3 RELAY OUTPUT SPECIFICATIONS CONT. Electrical Life 100,000 operations minimum (rated resistive load 1,800 operations/hour) Mechanical Life 20,000,000 operations minimum (no load 18,000 operations/hour) Rated Load Resistive load: 240V AC 2A, 30V DC 2A Inductive load: 240V AC 2A (cos ø = 0.4), 30V DC 2A (L/R =7 ms) Connector Insertion/Removal Durability 100 times minimum Applicable Ferrule 1-wire: AI 0.5-8 WH (Phoenix Contact) 2-wire: AI-TWIN 2×0.5-8 WH (Phoenix Contact) TRANSISTOR OUTPUT SPECIFICATIONS Part No. Transistor Output Points Output Type FC6A-C16P1CEE FC6A-C16K1CEE FC6A-D32P3CEE FC6A-D32K3CEE 8 (8/1 common) 16 (16/1 common) Transistor Sink FC6A-D16K1CEE/FC6A-D32K3CEE Transistor Source FC6A-D16P1CEE/FC6A-D32P3CEE Rated Load Voltage 24V DC Voltage Tolerance 19.2 to 28.8V DC Per Point 0.5A 0.1A Per Common 4.0A 1.6A Turn ON Time Isolation High speed input port: 5μs Normal speed input port: 300μs High speed input port: 5μs Normal speed input port: 300μs Between output terminal and Internal circuit: Optocoupler-isolated Between output terminals: Not isolated Voltage Drop (ON Voltage) 1V max (voltage between COM and output terminal when output is on.) Inrush Current 1A Leakage Current 0.1mA maximum Clamping Voltage 39V ±1V Maximum Lamp Load 12W Inductive Load L/R=10ms (28.8V DC, 1Hz) Overcurrent Protection Transistor Sink Output: No Transistor Source Output: Overcurrent is detected by current limit resistance. (*1) External Current Draw 100mA maximum, 24V DC (power voltage at the +V terminal, -V terminal at source) Rated Load Current Output Delay Connector Turn OFF Time 0.2A 2.4W Insertion Durability 100 times minimum Applicable Ferrule 1-wire: AI 0.5-8 WH (Phoenix Contact) 2-wire: AI-TWIN 2×0.5-8 WH (Phoenix Contact) — *1: This overcurrent signals consist of one signal per 4 point outputs. When microprocessor gets this overcurrent signal by interrupt input, microprocessor turns off 4pt outputs of this category at fixed time (approx. 1sec). DIMENSIONS (mm) FC6A-D32K3CEE FC6A-D32P3CEE 70.0 12.6 73.0 45.4 130.9 114.3 130.9 114.3 70.0 8.2 73.0 4.0 4.0 IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.IDEC.com/usa ©2018 IDEC Corporation. All Rights Reserved. FC9Y-DS400-1 9/18 7.5K 15.4 13.3 15.4 13.3 90.0 90.0 45.4 FC6A-D16R1CEE FC6A-D16K1CEE FC6A-D16P1CEE
FC6A-D32K3CEE 价格&库存
很抱歉,暂时无法提供与“FC6A-D32K3CEE”相匹配的价格&库存,您可以联系我们找货
FC6A-D32K3CEE
  • 1+6620.952331+856.59692
  • 10+5994.6616010+775.56950
库存:7
