FS1A-C11S
FS1A-C11S
    IDEC(日本和泉)
    控制器 - 机械安全 通用 24VDC 电源 DIN 轨道
FS1A-C11S 数据手册
FS1A Safety Controller New 24-logic model. 24 more safety circuits.  Safety circuit logics compliant with international standards  ISO 13849-1 PLe International Standard Compliant Cost Saving No Programming Required 24 Compact 8 Logics Logics FS1A-C01S discontinued as of February 28, 2015. Replaced by FS1A-C11S. FS1A-C01S FS1A-C11S (15/03/05) This is evolution. The FS1A-C11S safety controller with 24 new logics make it possible to control more types of safety systems. International Standards Compliant FS1A-C11S 24 logics FS1A-C01S 8 logics FS1A-C01S discontinued as of February 28, 2015. Replaced by FS1A-C11S. Complies with key safety standards! The SafetyOne satisfies: EN 954-1 IEC 61508 ISO 13849-1 ISO13849-1 PLe Category 4 SIL3 Performance level e ISO IEC EN ANSI/RIA ANSI SEMI NFPA With 8 (FS1A-C01S) or 24 (FS1A-C11S) pre-programmed safety circuit logics in a compact housing, the FS1A SafetyOne safety controller allows you to build a safety circuit by just sliding a DIP switch. Because the programs are tested and approved for compliance with key safety standards, labor, cost, and time for safety system certification can be reduced greatly. Note: The eight logic programs of FS1A-C01S are not included in the 24 logic programs of FS1A-C11S. Cost Saving Reduces overall cost. Simple wiring! One SafetyOne can replace more than seven safety relay modules. When configuring mode change system Emergency Stop Switch When using safety modules · 7 safety relay modules · 14 safety contactors Before The system is complicated, and the interlocking of mode selector switch cannot be determined. Results in a risk of not satisfying the required safety performance. When using SafetyOne (FS1A-C11S, logic 104) · One FS1A · 8 safety contactors Enabling Switch Selector Switch Interlock Switch After Interlock Switch The system and wiring are much simpler, and the required safety level is satisfied. No Selecting a logic­—that’s all you need! Programming SafetyOne lets you configure a system without any programming. Just select one logic from 8 (FS1A-C01S) or 24 (FS1A-C11S) to configure a Required safety system. After Before Logic selection only! • Safety PLC • Third-party certification for • Programming tools programs • Creating and de(time and cost) bugging a program Safety PLC or Safety Controller Software (programs, function blocks) Simple DIP switch selection No tools required No programming or debugging No program certification required 2 (15/03/05) Building a safety system has never been so easy, cost effective, or worry-free! FS1A Safety Controller Large functionality in a compact housing! Small & Compact Replaces more than seven safety relay modules -ONE ALL-IN Two-hand Control Emergency Stop Switch FS1A-C11S Logic 12A Interlock Switch Safety Output 1 Light Curtain (PNP) Monitor Output Safety Output 2 Safety Outputs PLC Two-hand Control Monitor signals Mode selection Error signals 72 mm Emergency Stop Switch Muting function of light curtains 114.5 mm Light curtains Hazardous area Muting sensors FS1A-C11S Logic 103 Light Curtain Safety Output 1 Enabling Switch Safety Output 2 Selector Switch Object 113.5 mm Muting lamp Interlock Switch Four safety output lines Emergency Stop Switch Solenoid drive output FS1A-C11S Logic 104 Safety Output 2 Enabling Switch Safety Input Safety Output 1-1 Selector Switch Total Solution Safety Output 3 Various safety products can be connected easily using the SafetyOne. Safety Relay Barrier EB3N Two-hand control Safety Output 1-2 Interlock Switch Solenoid drive output Emergency Stop Switch XA1E, XW1E, XN1E, HA1B, HA1E, HW1B, HW1E Interlock Switch HS6B, HS5B, HS5D Interlock Switch with Solenoid (spring lock) HS6E, HS5E, HS1E, HS1L Pilot Light (for muting) HW1P-5Q7 LED SignaLight Towers LD6A Safety Relay Module HR1S Laser Scanner (PNP) SE1L Non-contact Interlock Switch HS7A (15/03/05) Enabling/Grip Switches HE1B, HE2B, HE3B, HE5B, HE1G, HE1G-L, HE2G Light Curtain (PNP) SE4D Sensor (for muting) (PNP) SA1E Safety Controller FS1A 3 FS1A logic selection chart 1 Output Lines Input Device 1 1 line Mode select necessary (Two dual safety outputs of the same operation) Mode select unnecessary Input Device 2 Input Device 3 Light curtain Using the muting function of FS1A 004 FS1A-C01S Not using the muting function of FS1A 003 FS1A-C01S NO/NC contact device 002 FS1A-C01S 001 FS1A-C01S Other devices (Two dual safety outputs of different operations) Mode select necessary FS1A 006 FS1A-C01S FS1A-C01S discontinued as of February 28, 2015. Replaced by FS1A-C11S. 2 lines Logic No. Light curtain 005 FS1A-C01S Not using the muting function of FS1A 103 FS1A-C11S 13b FS1A-C11S 13C FS1A-C11S 13d FS1A-C11S 103 FS1A-C11S 13A FS1A-C11S 13b FS1A-C11S Other devices 13C FS1A-C11S START 13d FS1A-C11S Mode select unnecessary 12A FS1A-C11S Two-hand control Using the muting function of FS1A 11d FS1A-C11S 11A FS1A-C11S Light curtain Not using the muting function of FS1A C a t e g o r y 4 11C FS1A-C11S 102 FS1A-C11S 12C FS1A-C11S NO/NC contact device 11b FS1A-C11S 007 FS1A-C01S 008 FS1A-C01S 101 FS1A-C11S 11A FS1A-C11S Other devices 11C FS1A-C11S 102 FS1A-C11S 12b FS1A-C11S 12C FS1A-C11S 4 lines (Four single safety outputs of different operations) Mode select necessary Light curtain Not using the muting function of FS1A 14d FS1A-C11S 108 FS1A-C11S 104 FS1A-C11S 14A FS1A-C11S 14b FS1A-C11S Other devices 14C FS1A-C11S 14b FS1A-C11S 108 FS1A-C11S Mode select unnecessary Light curtain Not using the muting function of FS1A 105 FS1A-C11S 106 FS1A-C11S C a t e g o r y 3 105 FS1A-C11S Other devices 106 FS1A-C11S 107 FS1A-C11S 4 (15/03/05) FS1A-C01S General-purpose logic for various apparatus 001 002 General-purpose logic for apparatus with openings 003 Muting function logic for apparatus with openings FS1A-C01S discontinued as of February 28, 2015.004  General-purpose logic for NO/NC contact inputs  General-purpose for devices for which sync time Replaced bylogic FS1A-C11S. between contacts cannot be specified 005   The logic applicable for selection of active safety input devices 006 007 008    The logic applicable for selection of active safety input devices 101 11A 11b 11C 11d 102 12A 12b 12C 12d 103 13A The logic constructing an OR circuit applicable for selection of active safety input devices Partial stop logic applicable for selection of active safety input devices Partial stop 1 logic for various apparatus Partial stop 2 logic for various apparatus Output 4 Lines Output put 2 Lines Output 1 Line Two-hand Control NO/NC Contact Inputs Muting Llight Curtain Mode Selection Page  6 6 7 7  8           8 9 9       10 10 11 11 11 12 12 13 13 13 14 14   15        15 15     16        Partial stop logic applicable for selection of active safety input devices 14A 14b 14C      16 17 17 Partial stop logic applicable for selection of active safety input devices for apparatus with openings 14d      17 Partial stop logic for apparatus with openings       Partial stop logic for various apparatus 105 106 107  18 18 19 Partial stop logic applicable for selection of active safety input devices in apparatus with openings 108   19 The logic for various apparatus The logic for apparatus with openings The logic for apparatus with NO/NC contact inputs The logic for apparatus with openings Muting function logic for apparatus with openings Partial stop logic for apparatus with openings The logic for apparatus with a two-hand control device The logic constructing an OR circuit for various apparatus The logic constructing an OR circuit for apparatus with openings FS1A-C11S Logic No. Enabling/Grip Switch Logic Type Interlock/Emergency Stop Switch FS1A logic selection chart 2 Partial control logic for apparatus with openings                         13b     The logic applicable for selection of active safety input devices 13C 13d   Partial stop logic applicable for selection of active safety input devices 104 Partial stop logic applicable for selection of active safety input devices Partial stop logic applicable for selection of active safety input devices Partial stop logic for apparatus with openings                  Partial stop logic applicable for selection of active safety input devices    Compliant with key safety standards Applicable Standards ISO 13849-1, 10218-1, 13851 (FS1A-C11S) IEC 61508, 62061, 61496-1, 60204-1, 61131-2, 61000-6-2, 61000-6-4 EN 954-1, 13849-1, 62061, 61496-1, 60204-1, 61131-2, 61000-6-2, 61000-6-4 ANSI/RIA R15.06 ANSI B11.19 SEMI S2 NFPA 79 UL (15/03/05) UL508, CSA22.2 No.142 The SafetyOne satisfies the requirements of SIL3 (IEC 61508), performance level e (ISO 13849-1), and safety category 3 or 4 (EN 954-1). 5 FS1A-C01S discontinued as of February 28, 2015. Replaced by FS1A-C11S. FS1A Safety Controller FS1A-C01S FS1A-C01S General-purpose logic for Logic 001 various apparatus Category Output Line: 1 2 dual safety outputs of the same operation 4 Logic 001 is used for safeguarding measures of machine tools and robots. It can be used with dual direct-opening components such as emergency stop switches and interlock switches. • Wiring Example (PHUJHQF\ 6WRS6ZLWFK • Logic Chart /RJLF 6DIHW\ 2XWSXW ,QWHUORFN 6ZLWFK 6DIHW\ 2XWSXW ,QWHUORFN 6ZLWFK Z6ROHQRLG VSULQJORFN W\SH • DIP Switch and LED Display 6DIHW\,QSXW 7;7; 'XDO&KDQQHO 'LUHFW2SHQLQJ 6DIHW\,QSXW 7;7; 'XDO&KDQQHO 'LUHFW2SHQLQJ 6DIHW\,QSXW 7;7; 'XDO&KDQQHO 'LUHFW2SHQLQJ 6DIHW\,QSXW 7;7; 'XDO&KDQQHO 'LUHFW2SHQLQJ 6DIHW\,QSXW 7;7; 'XDO&KDQQHO 'LUHFW2SHQLQJ 6DIHW\,QSXW 7;7; 'XDO&KDQQHO 'LUHFW2SHQLQJ 6WDUW,QSXW ; 0RQLWRU,QSXW 6WDUW,QSXW ; 0RQLWRU,QSXW ([WHUQDO'HYLFH0RQLWRU 7; ('0 ([WHUQDO 'HYLFH 0RQLWRU ([WHUQDO'HYLFH0RQLWRU 7; ('0 ([WHUQDO 'HYLFH 0RQLWRU 8 Logics +ROG +ROG 6HOIKROG IXQFWLRQ
FS1A-C11S 价格&库存
很抱歉,暂时无法提供与“FS1A-C11S”相匹配的价格&库存,您可以联系我们找货
FS1A-C11S
    • 1+7692.106591+999.94897
