GE1A-C10HAD24
GE1A-C10HAD24
    IDEC(日本和泉)
    开 - 延迟 延时继电器 DPDT(2 Form C) 0.1 秒 ~ 10 小时 延时 5A @ 240VAC/24VDC 可插
GE1A-C10HAD24 数据手册
Timers GE1A Switches & Pilot Lights GE1A Series — ON Delay Timers Single Function Key features: • DPDT or SPDT + instantaneous SPDT • 8-pin, octal base • Repeat error ±0.2% maximum • Large, clear knob for easy setting • Instant monitoring of operational status by LED indicators Signaling Lights UL, c-UL Listed File No. E55996 Relays & Sockets Specifications Voltage Tolerance AC: 85 to 110% DC: 90 to 110% Contact Rating 240V AC/5A 24V DC/5A Contact Form DPDT or SPDT+ instantaneous SPDT Repeat Error ±0.2% ±10msec maximum Voltage Error ±0.5% ±10msec maximum Temperature Error ±3% maximum Setting Error ±10% maximum Reset Time 0.1 sec maximum Insulation Resistance 100MΩ minimum (500V DC megger) Dielectric Strength Between power and output terminals: 2,000V AC, 1 minute Between contact circuits: 750V AC, 1 minute Vibration Resistance Damage limits: Amplitude 0.75mm, 10 to 55 Hz Operating extremes: Amplitude 0.5mm, 10 to 55 Hz Shock Resistance Damage limits: 500m/s2 (Approx. 50G) Contactors 24V AC/DC 110 to 120V AC 220 to 240V AC Timers Rated Operating Voltage 24V AC type: 1.6 VA GE1A-B 24V DC type: 1.0W 110V AC type: 3.8 VA 220V AC type: 7.7 VA Power Consumption GE1A-C Terminal Blocks 24V AC type: 2.0 VA 24V DC type: 0.8W 110V AC type: 3.5 VA 220V AC type: 8.0 VA 100,000 operations minimum (at full rated load) Mechanical Life B type: 10,000,000 operations minimum, C type: 5,000,0000 operations minimum Operating Temperature –10 to +55°C (without freezing) Operating Humidity 35 to 85% RH (without freezing) 1705151136 800-262-IDEC (4332) • USA & Canada Circuit Breakers Electrical Life 973 Timers Switches & Pilot Lights GE1A Part Numbering List Mode of Operation Contact Output Rated Voltage Time Range 220-240V AC GE1A-B10HA220 110-120V AC 0.1s - 10h 24V AC/DC Delayed SPDT + Instantaneous SPDT 220-240V AC Signaling Lights 24V DC/120V AC, 5A 240V AC, 5A GE1A-B30HA220 0.3s - 30h 24V AC/DC GE1A-B30HAD24 GE1A-C10HA220 0.1s - 10h GE1A-C10HA110 24V AC/DC GE1A-C10HAD24 220-240V AC GE1A-C30HA220 110-120V AC 0.3s - 30h 24V AC/DC Relays & Sockets GE1A-B30HA110 220-240V AC 110-120V AC Delayed DPDT GE1A-B10HA110 GE1A-B10HAD24 110-120V AC ON-Delay Complete Part Number GE1A-C30HA110 GE1A-C30HAD24 Timing Diagrams/Schematics GE1A-B GE1A-C Delayed SPDT + Instantaneous SPDT Delayed DPDT Timers Operation Mode Selection ON-Delay 1 MODE A Item Set Time Power Delayed Contact Terminal Number 2 - 7 (8p) Contactors Item Set Time Power 5 - 8 (8p) (NC) 6 - 8 (8p) (NO) Instantaneous Contact Indicator Operation 1-4 (NC) 1-3 (NO) Delayed Contact Indicator Terminal Number Operation 2 - 7 (8p) 5 - 8 (8p) (NC) 6 - 8 (8p) (NO) POWER OUT POWER OUT Circuit Breakers Terminal Blocks Note: Terminals 1, 3, and 4 are for the instantaneous contact 974 www.IDEC.com 1705151136 Timers GE1A Switches & Pilot Lights Accessories Mounting Accessories & Sockets Item Appearance Part No. SR2P-05 8-Pin Fingersafe Socket SR2P-05C 8-Pin Screw Terminal SR2P-06 Signaling Lights 8-Pin Screw Terminal (dual tier) DIN Rail/Surface Mounting Accessories BNDN1000 SR2P-51 Screw Terminal Socket SR6P-M08G Panel Mount Adapter GE9Z-AD Contactors 8-Pin Solder Terminal Timers Panel Mounting Accessories Relays & Sockets DIN Mounting Rail Length 1000mm Terminal Blocks Other Accessories Item Appearance Dust Cover Part No. GE9Z-C48 Circuit Breakers 1705151136 800-262-IDEC (4332) • USA & Canada 975 Timers GE1A Switches & Pilot Lights GE1A Timer 63.8 Ø35.0 48 10.2 6 14.2 44.8 10.9 10.2 .4 Dimensions 0.6 5 44.8 6.0 35 6 7 48 4 8 4.2 1 X10 69.8 OUT 48.0 10.9 Relays & Sockets GE1A Timer Panel Cutout 45.0 (+0.6, –0) 45.0 (+0.6, –0) 14.2 Signaling Lights 3 X1 GE1A 2 48.0 0.8 Panel Cut-out Timers 8-Pin SR2P-05 40 8 25.5 when using BAA 2-ø4.2 Mounting Hole (M4 screw hole) 6 ø25 M3.5 Screw 1 0 Contactors Mounting Hole 5min. ø3.6min. 18 22 5 4 7 8 1 3 2 (TOP VIEW ) 7.9max. 8-Pin SR2P-06 40 8 25.5 when using BAA ø25 6 1 0 5 4 7 8 1 3 22 5min. ø3.6min. 18 2 (TOP VIEW ) 7.9max. Circuit Breakers Mounting Hole 6 33 4.9max. ø4.2 33 Terminal Arrangement DIN Rail (BAA) 2-ø4.2 Mounting Hole (M4 screw hole) M3.5 Screw Terminal Blocks 6 33 4.9max. ø4.2 33 Terminal Arrangement DIN Rail (BAA) 976 www.IDEC.com 1705151136
GE1A-C10HAD24 价格&库存
很抱歉,暂时无法提供与“GE1A-C10HAD24”相匹配的价格&库存,您可以联系我们找货
