Timers
GE1A
Switches & Pilot Lights
GE1A Series — ON Delay Timers
Single Function
Key features:
• DPDT or SPDT + instantaneous SPDT
• 8-pin, octal base
• Repeat error ±0.2% maximum
• Large, clear knob for easy setting
• Instant monitoring of operational status by LED indicators
Signaling Lights
UL, c-UL Listed
File No. E55996
Relays & Sockets
Specifications
Voltage Tolerance
AC: 85 to 110%
DC: 90 to 110%
Contact Rating
240V AC/5A
24V DC/5A
Contact Form
DPDT or SPDT+ instantaneous SPDT
Repeat Error
±0.2% ±10msec maximum
Voltage Error
±0.5% ±10msec maximum
Temperature Error
±3% maximum
Setting Error
±10% maximum
Reset Time
0.1 sec maximum
Insulation Resistance
100MΩ minimum (500V DC megger)
Dielectric Strength
Between power and output terminals: 2,000V AC, 1 minute
Between contact circuits: 750V AC, 1 minute
Vibration Resistance
Damage limits: Amplitude 0.75mm, 10 to 55 Hz
Operating extremes: Amplitude 0.5mm, 10 to 55 Hz
Shock Resistance
Damage limits: 500m/s2 (Approx. 50G)
Contactors
24V AC/DC
110 to 120V AC
220 to 240V AC
Timers
Rated Operating Voltage
24V AC type: 1.6 VA
GE1A-B
24V DC type: 1.0W
110V AC type: 3.8 VA
220V AC type: 7.7 VA
Power
Consumption
GE1A-C
Terminal Blocks
24V AC type: 2.0 VA
24V DC type: 0.8W
110V AC type: 3.5 VA
220V AC type: 8.0 VA
100,000 operations minimum (at full rated load)
Mechanical Life
B type: 10,000,000 operations minimum, C type: 5,000,0000
operations minimum
Operating Temperature
–10 to +55°C (without freezing)
Operating Humidity
35 to 85% RH (without freezing)
1705151136
800-262-IDEC (4332) • USA & Canada
Circuit Breakers
Electrical Life
973
Timers
GE1A
Part Numbering List
Mode of Operation
Contact
Output
Rated Voltage
Time Range
220-240V AC
GE1A-B10HA220
110-120V AC
0.1s - 10h
24V AC/DC
Delayed SPDT +
Instantaneous SPDT
220-240V AC
Signaling Lights
24V DC/120V AC, 5A
240V AC, 5A
GE1A-B30HA220
0.3s - 30h
24V AC/DC
GE1A-B30HAD24
GE1A-C10HA220
0.1s - 10h
GE1A-C10HA110
24V AC/DC
GE1A-C10HAD24
220-240V AC
GE1A-C30HA220
110-120V AC
0.3s - 30h
24V AC/DC
Relays & Sockets
GE1A-B30HA110
220-240V AC
110-120V AC
Delayed DPDT
GE1A-B10HA110
GE1A-B10HAD24
110-120V AC
ON-Delay
Complete Part Number
GE1A-C30HA110
GE1A-C30HAD24
Timing Diagrams/Schematics
GE1A-B
GE1A-C
Delayed SPDT + Instantaneous SPDT
Delayed DPDT
Timers
Operation
Mode Selection
ON-Delay 1
MODE
A
Item
Set Time
Power
Delayed
Contact
Terminal Number
2 - 7 (8p)
Contactors
Item
Set Time
Power
5 - 8 (8p)
(NC)
6 - 8 (8p)
(NO)
Instantaneous
Contact
Indicator
Operation
1-4
(NC)
1-3
(NO)
Delayed
Contact
Indicator
Terminal Number
Operation
2 - 7 (8p)
5 - 8 (8p)
(NC)
6 - 8 (8p)
(NO)
POWER
OUT
POWER
OUT
Circuit Breakers
Terminal Blocks
Note: Terminals 1, 3, and 4 are for the instantaneous contact
974
www.IDEC.com
1705151136
Timers
GE1A
Accessories
Mounting Accessories & Sockets
Item
Appearance
Part No.
SR2P-05
8-Pin Fingersafe Socket
SR2P-05C
8-Pin Screw Terminal
SR2P-06
Signaling Lights
8-Pin Screw Terminal (dual tier)
DIN Rail/Surface
BNDN1000
SR2P-51
Screw Terminal Socket
SR6P-M08G
Panel Mount Adapter
GE9Z-AD
Contactors
8-Pin Solder Terminal
Timers
Panel Mounting
Accessories
Relays & Sockets
DIN Mounting Rail Length 1000mm
Terminal Blocks
Other Accessories
Item
Appearance
Dust Cover
Part No.
GE9Z-C48
Circuit Breakers
1705151136
975
Timers
GE1A
GE1A Timer
63.8
Ø35.0
48
10.2
6
14.2
44.8
10.9
10.2
.4
Dimensions
0.6
5
44.8
6.0
35
6
7
48
4
8
4.2
1
X10
69.8
OUT
48.0
10.9
Relays & Sockets
GE1A Timer Panel Cutout
45.0 (+0.6, –0)
45.0 (+0.6, –0)
14.2
Signaling Lights
3
X1
GE1A
2
48.0
0.8
Panel Cut-out
Timers
8-Pin SR2P-05
40
8
25.5 when
using BAA
2-ø4.2 Mounting Hole
(M4 screw hole)
6
ø25
M3.5 Screw
1 0
Contactors
Mounting
Hole
5min.
ø3.6min.
18
22
5
4
7
8
1
3
2
(TOP VIEW )
7.9max.
8-Pin SR2P-06
40
8
25.5 when
using BAA
ø25
6
1 0
5
4
7
8
1
3
22
5min.
ø3.6min.
18
2
(TOP VIEW )
7.9max.
Circuit Breakers
Mounting
Hole
6
33
4.9max.
ø4.2
33
Terminal
Arrangement
DIN Rail (BAA)
(M4 screw hole)
M3.5 Screw
Terminal Blocks
6
33
4.9max.
ø4.2
33
Terminal
Arrangement
DIN Rail (BAA)
976
www.IDEC.com
1705151136
很抱歉,暂时无法提供与“GE1A-C10HA110”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+368.187101+47.86313
- 国内价格 香港价格
- 1+432.887701+56.27400
- 50+408.6355650+53.12130
