GT3F-2AD24
GT3F-2AD24
    IDEC(日本和泉)
    关 - 延迟 延时继电器 DPDT(2 Form C) 0.1 秒 ~ 600 秒 延时 3A @ 250VAC/30VDC 可插
GT3F-2AD24 数据手册
Timers GT3A Switches & Pilot Lights GT3A Series — Analog Timers Key features: • 4 selectable operation modes on each model • External start, reset, and gate inputs • Panel mount or socket mount • Large variety of timing functions • Power and output status indicating LEDs Signaling Lights UL, c-UL Listed File No. E55996 Specifications GT3A-1 GT3A-2 Operation GT3A-3 Time Range Multi-mode with inputs (11 pins) 125V AC/250V AC, 3A; 30V DC, 1A (resistive load) Contact Ratings 125V AC/250V AC, 5A; 30V DC, 5A (resistive load) Minimum Applicable Load 5V, 10mA (reference value) AF20 (100V AC): 85 to 264V AC AD24: 20.4 to 26.4V AC/21.6 to 26.4V DC D12: 10.8 to 13.2V DC Voltage Tolerance Error ±10% maximum Reset Time 60msec maximum Insulation Resistance 100MW minimum Between power and output terminals: 2,000V AC, 1 minute Between contacts of different poles: 2,000V AC, 1 minute Between contacts of the same pole: 750V AC, 1 minute Dielectric Strength Delayed SPDT + instantaneous SPDT Delayed DPDT Delayed DPDT 10.8VA (200V AC, 60Hz) 13.5VA (200V AC, 60Hz) 14.4VA (200V AC, 60Hz) 4.7VA (100V AC, 60Hz), 14.4VA (200V AC, 60Hz) ­— 12VDC/1W 24VDC/0.7W 24VAC/1.2VA 12VDC/1.1W 24VDC/0.6W 24VAC/1.3VA 12VDC/0.8W 24VDC/0.6W 24VAC/1.3VA Shock Resistance 5,000,000 operations minimum 100,000 operations minimum (rated load) 63g 73g 79g 100m/sec2 (approximate 10G) Operating extremes: 100m/sec2 (approximate 10G) Damage limits: 500m/sec2 (approximate 50G) Operating Temperature –10 to +50°C Operating Humidity 45 to 85% RH Storage Temperature –30 to +80°C Housing Color Gray 800-262-IDEC (4332) • USA & Canada Circuit Breakers Breakers Circuit 1705151136 80g Terminal Blocks Vibration Resistance 10,000,000 operations minimum 50,000 operations minimum (rated load) Contactors Delayed SPDT Mechanical Life Weight (approximate) Timers ±0.2%, ±10 msec (repeat, voltage, temperature) Setting Error Electrical LIfe Relays & Sockets 0.1s to 180 hours 100 to 240V AC, 50/60Hz 12V DC 24V AC, 50/60Hz / 24V DC Rated Voltage Power Consumption (approximate) GT3A-4,-5,-6 Multi-mode 951 Timers Signaling Lights Switches & Pilot Lights GT3A Part Numbers GT3A-1, -2, -3 Mode Of Operation Rated Voltage Code Time Range Output AF20: 100 to 240V AC (50/60Hz) A: ON-delay 1 B: Interval 1 C: Cycle 1 D: Cycle 3 AF20: 100 to 240V AC (50/60Hz) D12: 12V DC AD24: 24V AC (50/60Hz)/24V DC Contact Delayed SPDT 0.1 seconds to 180 hours 250V AC, 3A, 30V DC, 1A (resistive load) 240V AC, 5A, 24V DC, 5A (resistive load) Delayed SPDT + Instantaneous SPDT Delayed DPDT Complete Part No. 8-Pin 11-Pin GT3A-1AF20 GT3A-1EAF20 GT3A-2AF20 GT3A-2EAF20 GT3A-2D12 GT3A-2ED12 GT3A-2AD24 GT3A-2EAD24 GT3A-3AF20 GT3A-3EAF20 GT3A-3D12 GT3A-3ED12 GT3A-3AD24 GT3A-3EAD24 1. For wiring schematics and timing diagrams for GT3A-1, -2, -3, see pages page 940 and page 941 respectively. 2. For more details about time ranges, see instructions on page page 940. 3. For socket and accessory part numbers, see page 958. Mode of Operation A: ON-Delay 2 B: Cycle 2 C: Signal ON/OFF-Delay 1 D: Signal OFF-Delay 1 A: Interval 2 B: One-Shot Cycle C: Signal ON/OFF-Delay 2 D: Signal OFF-Delay 2 A: One-Shot B: One-Shot ON-Delay C: One-Shot 2 D: Signal ON/OFF-Delay 3 4. 5. 6. 7. 8. Rated Voltage Code Time Range Output Contact Input AF20: 100 to 240V AC (50/60Hz) D12: 12V DC AD24: 24V AC (50/60Hz)/24V DC 0.1 seconds to 180 hours 250V AC, 5A, 24V DC, 5A (resistive load) AF20: 100 to 240V AC (50/60Hz) AD24: 24V AC (50/60Hz)/24V DC Delayed DPDT Start Reset Gate Complete Part No. A (11-pin) B (11-pin) GT3A-4AF20 GT3A-4EAF20 GT3A-4D12 GT3A-4ED12 GT3A-4AD24 GT3A-4EAD24 GT3A-5AF20 GT3A-5EAF20 GT3A-5AD24 GT3A-5EAD24 GT3A-6AF20 GT3A-6EAF20 GT3A-6AD24 GT3A-6EAD24 For wiring schematics and timing diagrams GT3A-4,-5,-6, see pages 940, 941, and 941 respectively. For more details about time ranges, see instructions on page 940. A (11-pin) and B (11-pin) differ in the way inputs are wired. For socket and accessory part numbers, see page 958. For the timing diagrams overview, see page 940. Circuit Breakers Terminal Blocks Contactors Timers Relays & Sockets GT3A-4, -5, -6 952 www.IDEC.com 1705151136 Timers GT3A Switches & Pilot Lights Timing Diagrams/Schematics GT3A-1 Timing Diagrams Delayed SPDT Operation Mode Selection MODE A Item Set Time Power Delayed Contact Terminal Number Signaling Lights ON-Delay 1 Operation T 2 - 7 (8p) 2 - 10 (11p) 5 - 8 (8p) 8 - 11 (11p) 6 - 8 (8p) 9 - 11 (11p) (NC) (NO) POWER Indicator Interval 1 MODE B Item Set Time Power Delayed Contact Terminal Number Relays & Sockets OUT Operation T 2 - 7 (8p) 2 - 10 (11p) 5 - 8 (8p) 8 - 11 (11p) 6 - 8 (8p) 9 - 11 (11p) (NC) (NO) POWER Indicator OUT MODE C Item Set Time Power Delayed Contact Terminal Number 2 - 7 (8p) 2 - 10 (11p) 5 - 8 (8p) 8 - 11 (11p) 6 - 8 (8p) 9 - 11 (11p) Timers Cycle 1 (OFF first) Operation T T T T (NC) (NO) POWER Indicator OUT MODE D Item Set Time Power Delayed Contact Terminal Number 2 - 7 (8p) 2 - 10 (11p) 5 - 8 (8p) 8 - 11 (11p) 6 - 8 (8p) 9 - 11 (11p) Contactors Cycle 3 (ON first) Operation (NC) (NO) POWER Indicator OUT Terminal Blocks Circuit Breakers 1705151136 800-262-IDEC (4332) • USA & Canada 953 Timers Signaling Lights Switches & Pilot Lights GT3A GT3A-3 Timing Diagrams Delayed DPDT GT3A-2 Timing Diagrams Delayed SPDT + Instantaneous SPDT Operation Mode Selection Operation Mode Selection ON-Delay 1 MODE A Item Set Time Power Delayed Contact Instantaneous Contact Terminal Number Operation T 2 - 7 (8p) 2 - 10 (11p) 5 - 8 (8p) 8 - 11 (11p) 6 - 8 (8p) 9 - 11 (11p) ON-Delay 1 MODE (NC) A (NO) 1-4 (NC) 1-3 (NO) Item Set Time Power Delayed Contact Terminal Number Operation T 2 - 7 (8p) 2 - 10 (11p) 1 -4, 5 - 8 (8p) (NC) 1 -4, 8 - 11 (11p) 1 -3, 6 - 8 (8p) (NO) 1 -3, 9 - 11 (11p) POWER Indicator OUT Relays & Sockets POWER Indicator OUT Interval 1 MODE B Item Set Time Power Delayed Contact Instantaneous Contact Interval 1 Terminal Number Operation T 2 - 7 (8p) 2 - 10 (11p) 5 - 8 (8p) 8 - 11 (11p) 6 - 8 (8p) 9 - 11 (11p) B 1-4 (NC) 1-3 (NO) Contactors MODE C Power Delayed Contact Instantaneous Contact Operation T POWER OUT Cycle 1 (OFF first) MODE C Terminal Number Item Set Time Power Delayed Contact Operation T 2 - 7 (8p) 2 - 10 (11p) 5 - 8 (8p) 8 - 11 (11p) 6 - 8 (8p) 9 - 11 (11p) Terminal Number 2 - 7 (8p) 2 - 10 (11p) 1 -4, 5 - 8 (8p) (NC) 1 -4, 8 - 11 (11p) 1 -3, 6 - 8 (8p) (NO) 1 -3, 9 - 11 (11p) Indicator OUT Item Set Time Delayed Contact (NC) Indicator Cycle 1 (OFF first) Power (NO) POWER Timers MODE Item Set Time Terminal Number Operation T T T T 2 - 7 (8p) 2 - 10 (11p) 1 -4, 5 - 8 (8p) (NC) 1 -4, 8 - 11 (11p) 1 -3, 6 - 8 (8p) (NO) 1 -3, 9 - 11 (11p) POWER T Indicator OUT (NC) (NO) 1-4 (NC) 1-3 (NO) Cycle 3 (ON first) MODE POWER Indicator D OUT Item Set Time Power Delayed Contact Terminal Number Operation 2 - 7 (8p) 2 - 10 (11p) 1 -4, 5 - 8 (8p) (NC) 1 -4, 8 - 11 (11p) 1 -3, 6 - 8 (8p) (NO) 1 -3, 9 - 11 (11p) POWER Indicator Terminal Blocks Cycle 3 (ON first) MODE D Item Set Time Power Delayed Contact Instantaneous Contact Terminal Number Operation T 2 - 7 (8p) 2 - 10 (11p) 5 - 8 (8p) 8 - 11 (11p) 6 - 8 (8p) 9 - 11 (11p) OUT T (NC) (NO) 1-4 (NC) 1-3 (NO) POWER Indicator Circuit Breakers OUT Note: Pins 1, 3, and 4 are the instantaneous contacts. 954 www.IDEC.com 1705151136 Timers GT3A Switches & Pilot Lights GT3A-4 Timing Diagrams Delayed DPDT Operation Mode Selection ON-Delay 2 MODE 2 - 6 (A) 5 - 7 (B) 2 - 7 (A) 6 - 7 (B) Start Input Operation 2 - 10 POWER Reset Gate 2 - 5 (A) 1-4 8 - 11 1-3 9 - 11 Delayed Contact ON or L ON or L ON or L (NC) Relays & Sockets A Terminal Number Signaling Lights Item Power (NO) POWER Indicator OUT Set Time T Item Power Cycle 2 Terminal Number T" Operation 2 - 6 (A) 5 - 7 (B) 2 - 7 (A) 6 - 7 (B) Reset Gate 2 - 5 (A) 1-4 8 - 11 1-3 9 - 11 Delayed Contact ON or L ON or L ON or L Timers B Input T' 2 - 10 POWER Start MODE Ta (NC) (NO) POWER Indicator OUT Set Time T Item Signal ON/OFF-Delay 1 MODE C T T T T Ta T Terminal Number T T T" T" T T T T T Operation 2 - 10 POWER 2 - 6 (A) 5 - 7 (B) 2 - 7 (A) 6 - 7 (B) Start Input T Reset Gate 2 - 5 (A) 1-4 8 - 11 1-3 9 - 11 Delayed Contact Contactors Power T ON or L ON or L ON or L (NC) (NO) POWER Indicator T Item Power Signal OFF-Delay 1 MODE D Ta T Ta Terminal Number T T T T" Ta Operation 2 - 10 POWER Start Input T Terminal Blocks OUT Set Time Reset Gate 2 - 6 (A) 5 - 7 (B) 2 - 7 (A) 6 - 7 (B) 2 - 5 (A) Delayed Contact ON or L ON or L (NC) (NO) Circuit Breakers 1-4 8 - 11 1-3 9 - 11 ON or L POWER Indicator OUT Set Time T Ta Ta T T T T = Set time Ta = Shorter than set time T = T' + T" 1705151136 800-262-IDEC (4332) • USA & Canada 955 Timers GT3A-5 Timing Diagrams Delayed DPDT Operation Mode Selection Signaling Lights Switches & Pilot Lights GT3A Item Power Interval 2 A Input Reset Gate 2 - 5 (A) 1-4 8 - 11 1-3 9 - 11 Delayed Contact Operation ON or L ON or L ON or L (NC) (NO) POWER Indicator OUT Set Time T Item Power One-Shot Cycle MODE Timers 2 - 6 (A) 5 - 7 (B) 2 - 7 (A) 6 - 7 (B) Start MODE Relays & Sockets Terminal Number 2 - 10 POWER B T' Terminal Number T" Operation 2 - 10 POWER 2 - 6 (A) 5 - 7 (B) 2 - 7 (A) 6 - 7 (B) Start Input Ta Reset Gate 2 - 5 (A) 1-4 8 - 11 1-3 9 - 11 Delayed Contact ON or L ON or L ON or L (NC) (NO) POWER Indicator OUT Set Time T Contactors Item Power Signal ON/OFF-Delay 2 MODE C T Ta Terminal Number T' T" T Operation 2 - 10 POWER 2 - 6 (A) 5 - 7 (B) 2 - 7 (A) 6 - 7 (B) Start Input T Reset Gate 2 - 5 (A) 1-4 8 - 11 1-3 9 - 11 Delayed Contact ON or L ON or L ON or L (NC) (NO) POWER Terminal Blocks Indicator OUT Set Time T Item Power Signal OFF-Delay 2 MODE Circuit Breakers D Ta T Terminal Number Ta Ta T T' T" Ta Operation 2 - 10 POWER Start Input T Reset Gate 2 - 6 (A) 5 - 7 (B) 2 - 7 (A) 6 - 7 (B) 2 - 5 (A) 1-4 8 - 11 1-3 9 - 11 Delayed Contact ON or L ON or L ON or L (NC) (NO) POWER Indicator OUT Set Time T Ta Ta T T' T" T = Set time Ta = Shorter than set time T = T' + T" 956 www.IDEC.com 1705151136 Timers GT3A Switches & Pilot Lights GT3A-6 Timing Diagrams Delayed DPDT Operation Mode Selection One-Shot 1 MODE 2 - 6 (A) 5 - 7 (B) 2 - 7 (A) 6 - 7 (B) Start Input Operation 2 - 10 POWER Reset Gate 2 - 5 (A) 1-4 8 - 11 1-3 9 - 11 Delayed Contact ON or L ON or L ON or L (NC) Relays & Sockets A Terminal Number Signaling Lights Item Power (NO) POWER Indicator OUT Set Time Ta Item Power One-Shot ON-Delay MODE Ta T' Terminal Number T" Operation 2 - 6 (A) 5 - 7 (B) 2 - 7 (A) 6 - 7 (B) Reset Gate 2 - 5 (A) 1-4 8 - 11 1-3 9 - 11 Delayed Contact ON or L ON or L ON or L Timers B T 2 - 10 POWER Start Input Ta (NC) (NO) POWER Indicator OUT Set Time T Item One-Shot 2 MODE C T T T' Terminal Number T" Operation 2 - 10 POWER 2 - 6 (A) 5 - 7 (B) 2 - 7 (A) 6 - 7 (B) Start Input Ta Reset Gate 2 - 5 (A) 1-4 8 - 11 1-3 9 - 11 Delayed Contact Contactors Power T ON or L ON or L ON or L (NC) (NO) POWER Indicator T Item Power Signal ON/OFF-Delay 3 MODE D T T' Terminal Number T" Operation 2 - 10 POWER Start Input Ta Terminal Blocks OUT Set Time Reset Gate 2 - 6 (A) 5 - 7 (B) 2 - 7 (A) 6 - 7 (B) 2 - 5 (A) Delayed Contact ON or L ON or L (NC) (NO) Circuit Breakers 1-4 8 - 11 1-3 9 - 11 ON or L POWER Indicator OUT Set Time T T Ta T' T" Ta Ta T T = Set time Ta = Shorter than set time T = T' + T" 1705151136 800-262-IDEC (4332) • USA & Canada 957 Timers GT3A Switches & Pilot Lights Instructions: Setting GT3A Series Timers Timed OUT Indicator POWER Indicator (flashes during time-delay period) Signaling Lights m Setting Knob j Operator Mode Selector A, B, C, D l Time Range Selector 1S, 10S, 10M, 10H Circuit Breakers Terminal Blocks Contactors Timers Relays & Sockets k Dial Selector 0-1, 0-3, 0-6, 0-18 Step 1. Select the desired mode of operation. Step 2. Select the time range that contains the desired time period. Desired Mode of Operation For Timers Mode of Operation ON-delay 1 GT3A-1 Interval 1 GT3A-2 Cycle 1 GT3A-3 Cycle 3 ON-delay 2 Cycle 2 GT3A-4 Signal ON/OFF-delay 1 Signal OFF-delay 1 Interval 2 One-shot cycle GT3A-5 Signal ON/OFF-delay 2 Signal OFF-delay 2 One-shot 1 One-shot ON-delay GT3A-6 One-shot 2 Signal ON/OFF-delay 3 Desired Time Range Time Ranges 0.1 seconds to 1 second 0.1 seconds to 3 seconds 0.1 seconds to 6 seconds 0.15 seconds to 18 seconds 0.1 seconds to 10 seconds 0.3 seconds to 30 seconds 0.6 seconds to 60 seconds 1.8 seconds to 180 seconds 6 seconds to 10 minutes 18 seconds to 30 minutes 36 seconds to 60 minutes 108 seconds to 180 minutes 6 minutes to 10 hours 18 minutes to 30 hours 36 minutes to 60 hours 108 minutes to 180 hours Step 3. Set the precise period of time desired by using the m Setting Knob. 958 Selection j Operation Mode Selector A B C D A B C D A B C D A B C D Selection k Dial Selector l Time Range Selector 0-1 0-3 1S 0-6 0-18 0-1 0-3 10S 0-6 0-18 0-1 0-3 10M 0-6 0-18 0-1 0-3 10H 0-6 0-18 Selection www.IDEC.com Remarks The desired operation mode can be selected from the A, B, C, and D modes using the Operation Mode Selector. Change the operation mode from A to B, C, and D in turn by turning the operation mode selector clockwise using a flat screwdriver which is a maximum of 0.156” (4mm) wide. The selected mode is displayed in the window. Remarks The desired time range is selected by setting both k Dial Selector and l Time Range Selector. 1705151136 Timers GT3F Switches & Pilot Lights GT3F Series — True Power OFF Delay Timers Key features: • “True” power OFF-delay up to 10 minutes • No external control switch necessary • Available with reset inputs • Mountable in sockets or flush panel Signaling Lights UL, c-UL Listed File No. E55996 Specifications GT3F-1 Operation GT3F-2 True power OFF-delay Time Range 100 to 240V AC, 50/60Hz 24V AC/DC Rated Voltage Contact Rating 250V AC/24V DC, 5A (resistive load) 250V AC/24V DC, 3A (resistive load) Contact Form SPDT DPDT Minimum Power Application Time Voltage Tolerance 1 second AF20: 100 to 240V AC AD24: 21.6 to 26.4VDC, 20.4 to 26.4VAC ±0.2%, ±10 msec Voltage Error ±0.2%, ±10 msec Temperature Error ±0.2%, ±10 msec Setting Error ±10% maximum Insulation Resistance Timers Repeat Error 100MW minimum Power Consumption AF20: 3.7VA (200V AC, 60Hz) AD24: 0.8W (DC), 1.2VA (AC) 3,000,000 operations minimum 100,000 operations minimum Vibration Resistance 100m/sec2 (approximate 10G) Operating extremes: 100 m/sec2 (approximate 10G) Damage limits: 500 m/sec2 (approximate 50G) Operating Temperature –10 to +50°C Storage Temperature –30 to +80°C Operating Humidity 45 to 85% RH Weight (approximate) Terminal Blocks Electrical Life Shock Resistance Contactors Dielectric Strength Between power and output terminals: 2,000V AC, 1 minute (SPDT) 1,500V AC, 1 minute (DPDT) Between contacts on different poles: 1,000V AC, 1 minute (DPDT) Between contacts of the same pole: 750V AC, 1 minute Mechanical Life Relays & Sockets 0.1 seconds to 600 seconds 77g 79g 1705151136 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1. An inrush current flows during the minimum power application time. AF20: approximate 0.4A, AD24: approximate 1.2A 2. GT3F does not read the preset time range shown on the knob after power is turned off. Note that minimizing the preset time, by turning the knob to zero, does not shorten the delay time after power is removed. 959 Timers Switches & Pilot Lights GT3F Part Numbering List GT3F Mode of Operation Time Range AF20: 100 to 240VAC (50/60Hz) True-Power OFF-delay Signaling Lights Rated Voltage Code AD24: 24V AC/DC Output Contact 250V AC, 5A, 0.1 seconds to 600 seconds 30V DC, 5A (resistive load) 250V AC, 3A, 30V DC, 3A (resistive load) Complete Part Number Optional Input Delayed SPDT Reset Delayed DPDT None (8p) Reset (11p) 8-Pin 11-Pin GT3F-1AF20 GT3F-1EAF20 GT3F-1AD24 GT3F-1EAD24 GT3F-2AF20 GT3F-2EAF20 GT3F-2AD24 GT3F-2EAD24 Optional reset input resets the contact to the OFF state before time out. Timing Diagrams/Schematics GT3F-1 Timing Diagrams GT3F-1 (8-pin) Timers Relays & Sockets Delayed SPDT Output, with Reset Input Item Power Reset Input Delayed Contact Indicator Terminal Number 2 - 7 (8p) 2 - 10 (11p) 1 - 4 (8p) ON or L 6 - 7 (11p) 5 - 8 (8p) 1 - 4 (11p) (NC) 6 - 8 (8p) 1 - 3 (11p) (NO) Operation POWER Set Time Tr T = Set time Ta = Shorter than set time Ts = 1 Second Tr = Minimum Power Application Time GT3F-1: 1 Second T Ta Ts T 1. For time ranges, see page page 941. 2. For sockets and accessory part numbers, see page page 967. 3. When power is applied, the NO output contact closes. When power is removed, the timing period begins. When time has elapsed, the NO contact opens. 4. For the timing diagram overview, see page page 940. Circuit Breakers Terminal Blocks Contactors GT3F-1E (11-pin) 960 www.IDEC.com 1705151136 Timers GT3F GT3F-2 (8-pin) Switches & Pilot Lights GT3F-2 Timing Diagrams GT3F-2E (11-pin) Delayed DPDT Output (Contact Input)       (+) POWER Item Terminal Number Power 8-Pin Type 11-Pin Type (NC) (NO) POWER T Terminal Number Tr T Operation 2 - 10 6 - 7 (11p) 1-4 8 - 11 1-3 9 - 11 Delayed Contact Indicator POWER Relays & Sockets 1-4 5-8 1-3 6-8 Power Reset Input POWER Operation Set Time Item         (-) (+)  2-7 Delayed Contact Indicator         (-) (+)  Signaling Lights  (-)  (Transistor Input) ON or L (NC) (NO) POWER Tr T Ta Ts Timers Set Time T When power is applied, the NO contact closes. When power is removed, the timing period begins. When time has elapsed, the NO contact opens. Optional reset input will return contacts to original state before time elapses. Contactors T = Set time Ta = Shorter than set time Ts = 1 Second Tr = Minimum Power Application Time GT3F-1: 1 Second Terminal Number Reset Input Set Time 6 - 7 (11p) ON or L 1-4 8 - 11 (NC) 1-3 9 - 11 (NO) POWER Tr T Ta 800-262-IDEC (4332) • USA & Canada Ts T Circuit Breakers 1705151136 Operation 2 - 10 Delayed Contact Indicator Terminal Blocks Item Power 961 Timers GT3F Relays & Sockets Signaling Lights Switches & Pilot Lights Instructions: Setting GT3F Series Timers POWER Indicator l Setting Knob k Time Range Selector 1S, 10S j Dial Selector 0-1, 0-3, 0-6, 0-18, 0-60 Step 1 Desired Operation Selection Base Time Ranges j Dial Selector 0.1s to 1s 0 to 1 0.1s to 3s 0 to 3 0.1s to 6s 0 to 6 0.1s to 10s 0 to 1 0.3s to 30 0 to 3 Select a time range that contains the desired period of time. 0.6s to 60 0 to 6 1.8s to 180s 0 to 18 6s to 600s Remarks k Time Range Selector 1s Time range can be selected from 1S and 10S using a flat screwdriver and five different dials of 0 to 1, 0 to 3, 0 to 6, 0 to 18, and 0 to 60 are displayed in the six windows by turning the Dial Selector, allowing for selecting the best suited scale. Note that the switch does not turn infinitely. 10s 0 to 60 Step 2 Remarks Timers Setting Examples: 1. When the Setting Knob l is set at 2.5, with Dial Selector j 0 to 3 and Time Range Selector k 1S selected, then the set time is 2.5 seconds. The set time is selected by turning the l Setting Knob. 2. When the Setting Knob l is set at 5.0, with Dial Selector j 0 to 60 and Time Range Selector k 10S selected, then the set time is 500 seconds. Instructions: Wiring Inputs Contactors Inputs of GT3F To avoid electric shock, do not touch the input signal terminal during power voltage application. Never apply the input signals to two or more GT3F timers using the same contact or transistor. [Incorrect] GT3 Series Timer Input Contact or Transistor [correct] Input Terminal Input Terminal 2 10 2 Power Power 2 10 10 In a transistor circuit for controlling input signals, with its primary and secondary power circuits isolated, do not ground the secondary circuit. GT3 Series Timer Input Terminal Power Circuit Rectifier Circuit Terminal Blocks 2 10 Input Terminal Input Terminal Circuit Breakers Insulating Transformer On the GT3F timers, connect the input signals to terminal No.1 and 4 only on the 8-pin type; connect the input signals to terminal No. 6 and 7 only on the 11-pin type. Never apply voltage to other terminals; otherwise, the internal circuit may be damaged. Input signal lines must be made as short as possible and installed away from power cables and power lines. Use shielded wires or a separate conduit for input wiring. The GT3F, consisting of a high-impedance circuit, may not be reset due to the influence of an inductive voltage or residual voltage caused by a leakage current. If not reset, connect an RC filter or bleeder resistor between power terminals so that the voltage between power terminals can be reduced to less than 15% of the rated voltage. 962 www.IDEC.com 1705151136 Timers GT3W Switches & Pilot Lights GT3W Series — Dual Time Range Timers Key features: UL, c-UL Listed File No. E55996 Signaling Lights • Sequential start, sequential interval, on-delay, recycler, and interval ON timing functions • 2 time settings in one timer • 8 selectable operation modes on each model • Mountable in sockets or flush panel • Power and output status indicating LEDs • Time ranges up to 300 hours General Specifications Contact Ratings Solid state CMOS Circuit Allowable Contact Power 960VA/120W Operation Type Multi-Mode Allowable Voltage 250V AC/150V DC Time Range 1: 0.1sec to 6 hours, 3: 0.1sec to 300 hours Pollution Degree 2 (IE60664-1) Allowable Current 5A Over Voltage Category III (IE60664-1) Maximum permissible operating frequency 1800 cycles per hour Rated Operational Voltage Voltage Tolerance AF20 100-240V AC(50/60Hz) AD24 24V AC(50/60Hz)/24V DC D12 12V DC AF20 85-264V AC(50/60Hz) AD24 20.4-26.4V AC(50/60Hz)/21.6-26.4V DC D12 10.8-13.2V DC -10 to +50ºC (without freezing) Range of Ambient Storage and Transport Temperature -30 to +75ºC (without freezing) Range of Relative Humidity 35 to 85%RH (without condensation) Atmospheric Pressure 80kPa to 110kPa (Operating), 70kPa to 110kPa (Transport) Reset Time 60msec maximum Repeat Error ±0.2%, ±10msec* Voltage Error ±0.2%, ±10msec* Temperature Error ±0.6%, ±10msec* Setting Error ±10% maximum Insulation Resistance 100MΩ minimum (500V DC) Dielectric Strength Between power and output terminals: 2000V AC, 1 minute Between contacts of different poles: 2000V AC, 1 minute Between contacts of the same pole:750V AC, 1 minute Vibration Resistance 10 to 55Hz amplitude 0.75mm2 hours in each of 3 axes Shock Resistance Operating extremes: 98m/sec2 (approx.10G) Damage limits: 490m/sec2 (approx. 50G) 3 times in each of 3 axes Degree of Protection Power Consumption (Approx.) 5A, 120V AC/30V DC (Resistive) Conditional Short Circuit Life Fuse 5A, 250V Electrical 100,000 op. minimum (Resistive) Mechanical 20,000,000 op. minimum Terminal Blocks Range of Ambient Operating Temperature 3A, 240V AC (Resistive) Rated Load Contactors Rated Voltage x10% minimum 1/8HP, 240V AC Timers Disengaging Value of Input Voltage Relays & Sockets Operation System IP40 (enclosure), IP20 (socket) (IEC60529) AF20 100V AC/60Hz 2.3VA 200V AC/60Hz 4.6VA AD24 (AC/DC) 1.8VA/0.9W Free Dimensions 40Hx 36W x 70 mm Weight (Approx.) 72g Circuit Breakers Mounting Position * For the value of the error against a preset time, whichever the largest applies. 1705151136 800-262-IDEC (4332) • USA & Canada 963 Timers Relays & Sockets Signaling Lights Switches & Pilot Lights GT3W Part Number List Part Numbers Mode of Operation Output Contact Time Range* Rated Voltage 100 to 240V AC (50/60Hz) A: Sequential Start B: On-delay with course and fine C: Recycler and instaneous D: Recycler outputs (OFF Start) E: Recycler outputs (ON Start) F: Interval ON G: Interval ON Delay H: Sequential Interval 3A, 240V AC 5A, 120V AC/30V DC (Resistive Load) Delayed SPDT + Delayed SPDT 1: 0.1sec - 6 hours *(See Time Range Settings for details.) Pin Configuration New Part Numbers 8 pin GT3W-A11AF20N 11 pin GT3W-A11EAF20N 8 pin GT3W-A11AD24N 11 pin GT3W-A11EAD24N 8 pin GT3W-A11D12N 11 pin GT3W-A11ED12N 24V AC/DC 12V DC 3: 0.1sec - 300 hours 100 to 240V AC (50/60Hz) GT3W-A33AF20N 8 pin 24V AC/DC GT3W-A33AD24N 1. For timing diagrams and schematics, see page 940. 2. For socket and accessory part number information, see page 959. 3. 8- and 11-pin models differ only in the number of pins (extra pins are not used). 4. For the timing diagram overview, see page 940. 5. *For details on setting time ranges, see the instructions on page 941. Time Range Table Timers Time Range Code: 1 Time Range Selector Scale 1S 0.1 sec - 1 sec 1S Scale Time Range 0.1 sec - 3 sec 0.3 sec - 10 sec 1M 10M 15 sec - 10 min 1H 3 min - 3 hours 1S 0.1 sec - 6 sec 1S 0.6 sec - 30 sec 10S 1 sec - 60 sec 1M 6 sec - 6 min 1H 1M 0-1 Time Range 0-6 10M 1 min - 60 min 1H 6 min - 6 hours 10H 0-3 3 sec - 3 min 36 sec - 30 min 0 - 30 36min - 30 hours 6 hours - 300 hours Circuit Breakers Terminal Blocks Contactors 10S Time Range Code: 3 Time Range Selector 964 www.IDEC.com 1705151136 Timers GT3W 1-4 (NC) 1-3 (NO) 5-8 (NC) 6-8 (NO) Delayed Contact Ry1 Delayed Contact Ry2 Indicator Operation Description ON after T1 ON after T1 + T2 OUT1 OUT2 Item Terminal No. Power 2-7 Delayed Contact Ry1 Delayed Contact Ry2 Indicator 2-7 Delayed Contact Ry1 Delayed Contact Ry2 Indicator Operation Description ON after T1 + T2 ON after T1 + T2 OUT1 Delayed Contact Ry1 Delayed Contact Ry2 Indicator T2 Operation 1-4 (NC) 1-3 (NO) 5-8 (NC) 6-8 (NO) Description Instantaneous ON OFF during T1 ON during T2 OUT1 Terminal No. Power 2-7 Delayed Contact Ry1 Delayed Contact Ry2 2-7 Delayed Contact Ry2 Indicator T2 Operation 1-4 (NC) 1-3 (NO) 5-8 (NC) 6-8 (NO) Description OFF during T1 ON during T2 OFF during T1 ON during T2 OUT1 OUT2 Set Time ON during T1 ON after T1, during T2 T1 Terminal No. Power 2-7 Delayed Contact Ry1 Delayed Contact Ry2 Indicator T2 Operation 1-4 (NC) 1-3 (NO) 5-8 (NC) 6-8 (NO) Description ON during T1 ON after T1 + T2 OUT1 T1 Item Terminal No. Power 2-7 Delayed Contact Ry1 Delayed Contact Ry2 Indicator T2 Operation 1-4 (NC) 1-3 (NO) 5-8 (NC) 6-8 (NO) Description Terminal Blocks Delayed Contact Ry1 Description OUT1 Set Time H: Sequential Interval Terminal No. Operation OUT2 T1 Item T2 1-4 (NC) 1-3 (NO) 5-8 (NC) 6-8 (NO) Item OUT2 Power T1 Set Time G: Interval ON Delay 2-7 ON during T1 OFF during T2 OUT2 T1 Terminal No. ON during T1 OFF during T2 OUT1 Item Indicator Set Time Item Description OUT2 OUT2 Power Operation 1-4 (NC) 1-3 (NO) 5-8 (NC) 6-8 (NO) Set Time T2 1-4 (NC) 1-3 (NO) 5-8 (NC) 6-8 (NO) Set Time D: Recycler outputs (OFF Start) Item Power Contactors C: Recycler and instantaneous T1 Operation Chart Terminal No. Timers B: On-delay with course and fine Set Time E: Recycler outputs (ON Start) 2-7 F: Interval ON Item Power Mode Relays & Sockets A: Sequential Start Operation Chart Terminal No. Signaling Lights Mode Switches & Pilot Lights Timing Diagrams/Schematics ON during T1 + T2 ON after T1, during T2 OUT1 OUT2 T1 Set Time T2 T1 T2 Circuit Breakers 1705151136 800-262-IDEC (4332) • USA & Canada 965 Timers GT3W Switches & Pilot Lights Instructions: Setting GT3W Timer T2 Time Range Selector Relays & Sockets Signaling Lights Operation Mode Selector T1 Time Range Selector T2 Setting Knob T1 Setting Knob Special expertise is required to use Electronic Timers. 2. Since changing the setting during timer operation my cause malfunction, turn power off before changing. Safety Precautions Caution • All Electronic Timer modules are manufactured under IDEC’s rigorous quality control system, but users must add a backup or fail safe provision to the control system when using the Electronic Timer in applications where heavy damage or personal injury may occur should the Electronic Timer fail. • Install the Electronic Timer according to instructions described in this catalog. Caution notices are used where inattention might cause personal injury or damage to equipment. • The Electronic Timer is designed for installation in equipment. Do not install the Electronic Timer outside equipment. • In these directions, safety precautions are categorized in order of importance to Warning and Caution. • Install the Electronic Timer in environments described in the specifications. If the Electronic Timer is used in places where it will be subjected to high-temperature, high-humidity, condensation, corrosive gases, excessive vibrations, or excessive shocks, then electrical shocks, fire hazard, or malfunction could result. Warning • Use an IEC60127-approved fuse and circuit breaker on the power and output line outside the Electronic Timer. • Make sure that the operating conditions are as described in the specifications. If you are uncertain about the specifications, contact IDEC in advance. Timers 1. The switches should be securely turned using a flat screwdriver 4mm wide (maximum). Note that incorrect setting may cause malfunction. The switches, which do not turn infinitely, should not be turned beyond their limits. Warning notices are used to emphasize that improper operation may cause sever personal injury or death. • Do not disassemble, repair, or modify the Electronic Timer. • When disposing of the Electronic Timer, do so as industrial waste. • Failure to turn power off may cause electrical shocks or fire hazard. • Emergency stop and interlocking circuits must be configured outside the Electronic timer. If such a circuit is configured inside the Electronic Timer, failure of the Electronic timer may cause malfunction of the control system, or an accident. Circuit Breakers Terminal Blocks Contactors • Turn power off to the Electronic timer before starting installation, removal, Wiring, maintenance, and inspection on the Electronic Timer. 966 www.IDEC.com 1705151136 Timers GT3 Series Accessories Switches & Pilot Lights GT3 Series Accessories DIN Rail Mounting Accessories DIN Rail/Surface Mount Sockets and Hold-Down Springs DIN Rail Mount Socket Style Applicable Hold-Down Springs Appearance Use with Timers Part No. SR2P-05 11-Pin Screw Terminal (dual tier) GT3A-1, 2, 3 (11-pin) GT3A-4, 5, 6 GT3F-1, 2 (11-pin) GT3W (11-pin) SR3P-05 Relays & Sockets GT3A-1, 2, 3 (8-pin) GT3F-1, 2 (8-pin) GT3W (8-pin) Part No. Signaling Lights 8-Pin Screw Terminal (dual tier) Appearance SFA-203 GT3A-1, 2, 3 (8-pin) GT3F-1, 2 (8-pin) GT3W (8-pin) SR2P-05C 11-Pin Fingersafe Socket GT3A-1, 2, 3 (11-pin) GT3A-4, 5, 6 GT3F-1, 2 (11-pin) GT3W (11-pin) SR3P-05C 8-Pin Screw Terminal GT3A-1, 2, 3 (8-pin) GT3F-1, 2 (8-pin) GT3W (8-pin) SR2P-06 Timers 8-Pin Fingersafe Socket SFA-202 GT3A-1, 2, 3 (11-pin) GT3A-4, 5, 6 GT3F-1, 2 (11-pin) GT3W (11-pin) SR3P-06 DIN Mounting Rail Length 1000mm — BNDN1000 Terminal Blocks Installation of Hold-Down Springs DIN Rail Mount Socket Contactors 11-Pin Screw Terminal Panel Mount Socket Insert the springs into the outer slots with the projections facing inside. Hold-down Spring SFA-402 Insert the springs into the slots. Insert 1705151136 Hold-down Spring (sold separately) SFA-202 (use two springs) Hold-down Spring (sold separately) SFA-203 (use two springs) Circuit Breakers Socket SR2P-05 Socket SR2P-06 8-pin Socket SR2P-51 800-262-IDEC (4332) • USA & Canada 967 Timers Switches & Pilot Lights GT3 Series Accessories Panel Mounting Accessories Panel Mount Sockets and Hold-Down Springs Panel Mount Socket Style Appearance GT3A- (8-pin) GT3W- (8-pin) GT3F- (8-pin) Signaling Lights 8-Pin Solder Terminal Part No. Appearance Part No. SR2P-51 SFA-402 GT3A- (11-pin) GT3W- (11-pin) GT3F- (11-pin) 11-Pin Solder Terminal SR3P-51 For information on installing the hold-down springs, see page 967. Flush Panel Mount Adapter and Sockets that use an Adapter Accessory Description Appearance Use with Timers Part No. Panel Mount Adapter Adaptor for flush panel mounting GT3 timers All GT3 timers RTB-G01 8-pin screw terminal All 8-pin timers SR6P-M08G All 11-pin timers SR6P-M11G 8-pin solder terminal All 8-pin timers SR6P-S08 11-pin solder terminal All 11-pin timers SR6P-S11 Contactors Timers Relays & Sockets Applicable HD Springs Use with Timers 11-pin screw terminal (Shown: SR6P-M08G for Wiring Socket Adapter) Circuit Breakers Terminal Blocks Sockets for use with Panel Mount Adapter No hold down springs are available for flush panel mounting. 968 www.IDEC.com 1705151136 Timers GT3 Series Instructions Switches & Pilot Lights Instructions: Wiring Inputs for GT3 Series Inputs To avoid electric shock, do not touch the input signal terminal during power voltage application. When connecting the input signal terminals of two or more GT3A timers to the same contact or transistor, the input terminals of the same number should be connected. (Connect Terminals No.2 in common.) [Incorrect] GT3 Series Timer Input Contact or Transistor [correct] Input Terminal Input Terminal 2 10 2 Power Power Signaling Lights Input Terminal Input Terminal 2 10 2 10 10 In a transistor circuit for controlling input signals, with its primary and secondary power circuits isolated, do not ground the secondary circuit. GT3 Series Timer Input Terminal Insulating Transformer Connect the input signal terminals of the GT3A timers to Terminal No.2 only. Never apply voltage to other terminals; otherwise, the internal circuit may be damaged. 5, 6, and 7 Input Terminal 2 Relays & Sockets Circuit Rectifier Circuit Power RY 10 Power Timers Input signal lines must be made as short as possible and installed away from power cables and power lines. Use shielded wires or a separate conduit for input wiring. Contactors Terminal Blocks Circuit Breakers 1705151136 800-262-IDEC (4332) • USA & Canada 969 Timers Inputs Instructions, continued For contact input, use gold-plated contacts to make sure that the residual voltage is less than 1V when the contacts are closed. 6 5 7 4 Gate Input Start Input Reset Input Switches & Pilot Lights GT3 Series Instructions 8 3 9 2 10 1 11 For transistor input, use transistors with the following specifications; VCE = 40V, VCES = 1V or less, IC = 50 mA or more, and ICBO = 50µA or less. The resistance should be less than 1kΩ when the transistor is on. When the output transistor switches on, a signal is input to the timer. 6 5 7 4 Gate Input Start Input Reset Input Signaling Lights Power 8 3 9 2 10 1 11 Relays & Sockets Power Inputs: GT3A-1, -2, -3 Transistor output equipment such as proximity switches and photoelectric switches can input signals if they are voltage/current output type, with power voltage ranges from 18 to 30V and have1V. When the signal voltage switches from H to L, a signal is input to the timer 6 Gate Input Start Input Reset Input 5 7 4 8 3 9 2 10 1 11 Inputs: GT3A-4, -5, -6 Start Input The start input initiates a time-delay operation and controls output status. Reset Input When the reset input is activated, the time is reset, and contacts return to original state. Gate Input The time-delay operation is suspended while the gate input is on (pause). No-voltage contact inputs and NPN open collector transistor inputs are applicable. 24V DC, 1mA maximum Input response time: 50msec maximum Circuit Breakers Terminal Blocks Contactors Timers Power 970 www.IDEC.com 1705151136 Timers GT3 Series Dimensions 36.0 Switches & Pilot Lights Dimensions 70.0 N40.0 5.6 Unit: mm Analog GT3 Timer, 8-Pin with SR2P-06 Analog GT3 Timer, 11-Pin with SR3P-06 (When using DIN Rail) When using BAA/BAP: 99 maximum Analog Setting Type 95 maximum Relays & Sockets Analog Setting Type Signaling Lights NOTE: GT3W series are UL Listed when used in combination with following IDEC’s sockets: GT3W-A11, A33: SR2P-06* pin type socket. GT3W-A11E: SR3P-05* pin type socket. (*-May be followed by A,B,C or U) The socket to be used with these timers are rated: -Conductor Temperature Rating 60ºC min. -Use 14AWG max.(2mm2max.) Copper conductors only -Terminal Torque 1.0 to 1.3 N-m (When using DIN Rail) When using BAA/BAP: 99 maximum 8 64.2 13 60 40 18 Holddown spring (SFA-202) 22 36 8 64.2 13 DIN Rail 18 1 36 DIN Rail 1 Holddown spring (SFA-202) 31.7 1.7 31.7 40 60 1.7 95 maximum 22 Timers Analog GT3 Timer, 11-Pin with SR3P-05 Analog Setting Type (When using DIN Rail) BAA or BAP: 105.5 maximum DIN Rail (BAA/BAP/BADA) 8 64.2 52 16.5 20 13 3 33 40 Hold-down Spring (SFA-203) 36 Contactors ø27 101.5 maximum 28.5 Panel Mount Adapter Terminal Blocks Analog GT3 Timer, 8-Pin and 11-Pin with SR6P-S08 or SR6P-S11 98 maximum 48 42.5 1.7 Panel Thickness 0.8 to 5mm 48 11 61.2 Back Wiring Socket Circuit Breakers 1705151136 800-262-IDEC (4332) • USA & Canada 971 Timers GT3 Series Dimensions 45 Single Mounting 45 Switches & Pilot Lights Mounting Hole Layout 48N--3 45 GT3 Timer, 8-Pin with SR6P-M08G GT3 Timer, 11-Pin with SR6P-M11G 8-M3.5 Terminal Screw Panel Thickness 0.8 to 5mm 11-M3.5 Teminal Screws 45 16.7 44.6 3.5 max. 5 2 1 8 7 5.6 min. ø3.6 min. 6 2 6.9 max. 45 4 30.4 44.6 3 34 Signaling Lights Tolerance: +0.5 to 0 N: No. of timers mounted Horizontal Close Mounting 5 4 1 3 11 7 8 6 9 10 3.5 max. 5.8 min. ø3.6 min. 6.9 max. 7 30.5 9.8 × 3 92 7 8.5 × 4 Circuit Breakers Terminal Blocks Contactors Timers Relays & Sockets 80.5 972 www.IDEC.com 1705151136
GT3F-2AD24 价格&库存
很抱歉,暂时无法提供与“GT3F-2AD24”相匹配的价格&库存,您可以联系我们找货
GT3F-2AD24
  • 1+865.308051+111.95070
  • 10+732.6129410+94.78304
  • 25+697.1232525+90.19150
  • 50+675.0458950+87.33521
  • 100+656.39300100+84.92196
库存:6
