GT3A-3AF20
GT3A-3AF20
    IDEC(日本和泉)
    可编程(多功能) 延时继电器 DPDT(2 Form C) 0.1 秒 ~ 180 小时 延时 5A @ 240VAC/24VDC 可插
GT3A-3AF20 数据手册
Timers Timer (Selection Guide) GT3 Series Multi-function Timers Classification Part No. (Rated voltage code in ) Multi-mode (Analog Setting) With Inputs 8-pin (11-pin) (4) GT3A-4 (5) GT3A-5 (6) GT3A-6 (1) GT3A-1 (2) GT3A-2 (3) GT3A-3 OFF Delay (8-pin Terminal) Star-Delta (8-pin Terminal) Twin-Timer (8-pin Terminal) (1) GT3F-1 (2) GT3F-2 (1) GT3S-1 (2) GT3S-2 (1) GT3W-A Shape Operation System Operation Mode Solid-state CMOS circuitry ON Delay Interval ON Cycle Cycle ON (4) ON Delay, Cycle, Signal ON/OFF Delay, Signal OFF Delay (5) Interval ON, One Shot Cycle, Signal ON/ OFF Delay, Signal OFF Delay (6) One Shot, One Shot ON Delay, One Shot, Signal ON/OFF Delay Solid-state CMOS circuitry (1) Power OFF Delay (with reset input) (2) Power OFF Delay Star-Delta (1) Sequential Start, Coarse/Fine Adjustment, Instantaneous Cycle, Cycle, Cycle Inversion, Interval ON, Interval ON Delay, Sequential Interval 0.1 sec to 600 sec Star: 0.05 to 100 sec Star-Delta: 0.05 sec 0.1 sec 0.25 sec 0.5 sec 0.1 sec to 6 hours 0.1 sec to 300 hours (1) Delayed = Star:1NO, Delta:1NO (2) Delayed = Star:1NO, Delta:1NO Instantaneous = 1NO Delayed SPDT + Delayed SPDT Time Ranges 0.1 sec to 180 hours Contact (1) Delayed SPDT (2) Delayed SPDT + Instantaneous SPDT (3) Delayed DPDT Delayed DPDT (11-pin) (1) Delayed SPDT (2) Delayed DPDT Output (1)(2) 240V AC, 3A 120V AC/30V DC, 5A (resistive load) (3)(4)(5)(6) 240V AC/24V DC, 5A (resistive load) (1) 250V AC/24V DC, 5A (resistive load) (2) 250V AC/24V DC, 3A (resistive load) Repeat Error Setting Error Voltage Error Temperature Error Reset Time Timing Accuracy ±0.2%, ±10 ms (Note) ±10% ±0.2%, ±10 ms (Note) ±0.2%, ±10 ms (Note) ±10% ±0.2%, ±10 ms (Note) 250V AC/30V DC, 5A (resistive load) 250V AC, 1.5A/30V DC, 2A (inductive load) ±0.2%, ±10 ms (Note) ±10% ±0.2%, ±30 ms (Note) ±0.2%, ±10 ms (Note) ±0.2%, ±10 ms (Note) ±0.2%, ±10 ms (Note) 60 ms maximum – 500 ms maximum 100 to 240V AC 100 to 240V AC (50/60Hz) (50/60Hz) 24V AC (50/60Hz)/24V DC Rated Voltage 100 to 240V AC (50/60Hz) 24V AC (50/60Hz)/24V DC External Connection • Pin Terminals Socket (DIN rail mount screw terminal, panel mount screw terminal, solder terminal) Snap Mounting Adapter Mechanical 20,000,000 operations minimum Electrical 100,000 operations minimum Life Input – No-voltage contact inputs/Transistor inputs 24V DC, 1 mA maximum 3,000,000 operations minimum 100,000 operations minimum 20,000,000 operations minimum 100,000 operations minimum (1) No-voltage contact inputs/Transistor 6V DC, 0.6 mA maximum 240V AC, 3A 120V AC/30V DC, 5A (resistive load) ±0.2%, ±10 ms (Note) ±10% ±0.2%, ±10 ms (Note) ±0.2%, ±10 ms (Note) 60 ms maximum 100 to 240V AC (50/60Hz) 24V AC (50/60Hz)/24V DC 20,000,000 operations minimum 100,000 operations minimum – Power Consumption (Approx.) 4.0VA (Delayed DPDT, 200V AC, 60Hz) 0.7W (Delayed DPDT, 24V DC) 2.3VA (100V AC, 60Hz) 0.2W (24V DC) 4.0VA (200V AC, 60Hz) 5.1VA (200V AC, 60Hz) 0.9W (24V DC) Operating Temperature Operating Humidity Storage Temperature Storage Humidity Dimensions (Body)(mm) Weight (Approx.) Standards Page –10 to +50°C (no freezing) 35 to 85% RH (no condensation) –30 to +70°C (no freezing) 35 to 85% RH (no condensation) 40H × 36W × 72.2D (1)63g (2)73g (3)79g 80g UL, c-UL, CE UL, c-UL, CE 5 7 40H × 36W × 72.2D (1)77g (2)79g UL, c-UL, CE 11 40H × 36W × 72.2D (1)68g (2)75g UL, c-UL, CE 13 40H × 36W × 70D 73g UL, c-UL, CE 15 Note: The largest value becomes the error against a preset value depending on the time range. 2 Timer (Selection Guide) GT5 Series Miniature Electronic Timers GT5Y (Solder Terminal) GE1A Series Electronic Timers GE1A-B GT5P (8-pin Terminal) (1) GT5Y-2S * (2) GT5Y-4S * Operation mode, time range, and rated voltage code in * (1) GT5P * Operation mode, time range, and rated voltage code in * RC oscillator 4 different time ranges GE1A➀➁➂ GE1A➀➁➂ ➀Contact code ➁Time range code ➂Rated voltage code ➀Contact code ➁Time range code ➂Rated voltage code RC oscillator ON Delay, Cycle, or One Shot available ON delay (Instantaneous contact) • On Delay: 0.1 sec to 60 min • Interval: 0.1 sec to 10 min • Cycle: 0.1 sec to 10 min • On Delay: 0.1 sec to 10 min • Cycle: 0.1 sec to 10 sec • One Shot: 0.1 sec to 10 sec 10H (0.1 min to 10 hours) 30H (0.3 min to 30 hours) (1) Delayed DPDT (2) Delayed 4PDT Delayed SPDT Delayed + Instantaneous (1) 220V AC/30V DC, 5A (resistive load) (2) 220V AC/30V DC, 3A (resistive load) 240V AC, 3A 120V AC/30V DC, 5A (resistive load) 240V AC/5A, 24V DC/5A (resistive load) ±0.2%, ±20 ms (Note) ±10% maximum ±0.5%, ±20 ms (Note) ±0.2%, ±10 ms (Note) ±10% maximum ±0.5%, ±20 ms (Note) ±0.2% ±10 ms maximum ±10% maximum ±0.5% ±10 ms maximum ±3% maximum ±3% maximum ±3% maximum 100 ms maximum 100 to 120V AC, 200 to 240V AC (50/60Hz), 12/24V DC • Solder Terminal 100 ms maximum 100 to 120V AC, 200 to 240V AC (50/60Hz), 12V DC, 24V AC (50/60Hz) • Pin Terminal 100 ms minimum DIN Rail Mount Screw Terminal Panel Mount Solder PC Board Terminal 50,000,000 operations minimum (1) 500,000 operations minimum (2) 200,000 operations minimum – Socket (1)(2) ON Delay, Interval, or Cycle available on both types Socket GE1A-C DIN Rail Mount Screw Terminal Panel Mount Solder Wrapping Terminal ON delay Delayed 100 to 110V AC, 200 to 200V AC, 220 to 240V AC, 24V AC/DC • Octal Pin Terminal Socket (Din rail mount socket, Panel mount socket, PC board mount socket) 20,000,000 operations minimum GE1A-B: 10,000,000 operations minimum GE1A-C: 5,000,000 operations minimum 100,000 operations minimum 100,000 operations minimum – 1.6VA (100V AC, 60Hz) 1.4VA (200V AC, 60Hz) 1.0W (24V DC) • Excluding One Shot 2.3VA (100V AC, 60Hz) 3.9VA (200V AC, 60Hz) 0.5W (24V DC) –10 to +50°C (no freezing) 35 to 85% RH (no condensation) –30 to +80°C (no freezing) 35 to 85% RH(no condensation) 27.5H × 21W × 58.6D 50g UL, c-UL, CE 23 –10 to +50°C (no freezing) 35 to 85% RH (no condensation) –30 to +70°C (no freezing) 35 to 85% RH (no condensation) 36H × 29W × 69D 49g UL, CSA, CE 25 – 7.7 VA, 6.6 VA (220V AC, 60/50Hz) 7.0 VA, 6.0 VA (200V AC, 60/50Hz) 3.8 VA, 3.3 VA (110V AC, 60/50Hz) 3.5 VA, 3.0 VA (100V AC, 60/50Hz) 1.6 VA/1.0W (24V AC/DC) 8.0 VA, 7.0 VA (220V AC, 60/50Hz) 8.0 VA, 7.0 VA (200V AC, 60/50Hz) 3.5 VA, 3.0 VA (110V AC, 60/50Hz) 3.5 VA, 3.0 VA (100V AC, 60/50Hz) 2.0 VA/ 0.8W (24V AC/DC) – – – – 48H × 48W × 95.2D 101g 95g UL, c-UL, TÜV, CE 30 3 GT3 Series Multi-function Timers Wide Variety Including OFF Delay and StarDelta ••Universal AC power voltage 100 to 240V AC ••Solid-state CMOS circuitry ensures high accuracy ••Easy-to-view operation indicator ••DIN 48mm square panel mount adapter for snap mounting   ••Complies with safety standards. UL/c-UL listed. ••Complies with EN standard Applicable Standards Mark File No. or Organization UL508 CSA C22.2 No.14 UL/c-UL Listed File No. E55996 EN61812-1 EU Low Voltage Directive [Multi-mode] ••Instantaneous operation at zero setting ••Multi-mode, and universal AC power voltage cover 96 types by one timer Multi-Mode (Analog Setting) Operation Mode On Delay Interval ON Cycle OFF Cycle ON For details, see pages 5 to 10. Model GT3A-1 Contact Delayed SPDT GT3A-2 Delayed SPDT + Instantaneous SPDT GT3A-3 Delayed DPDT ON Delay Cycle Signal ON/OFF Delay Signal OFF Delay With Input GT3A-4 Interval ON One Shot Cycle Signal ON/OFF Delay Signal OFF Delay With Input GT3A-5 One Shot One Shot ON Delay One Shot Signal ON/OFF Delay With Input GT3A-6 Time Range Delayed DPDT (11P) Output 240V AC, 3A 120V AC/ 30V DC, 5A 0.1 sec to 180 hours 240V AC/ 24V DC, 5A 0.1 sec to 180 hours 240V AC/ 24V DC, 5A OFF Delay Model Contact GT3F-1 Delayed SPDT GT3F-2 Delayed DPDT Time Range Output 250V AC/ 24V DC, 5A Star-Delta GT3S-2 0.1 sec to 600 sec 250V AC/ 24V DC, 3A Contact Delayed Star: SPST-NO Delta: SPST-NO Delayed Star: SPST-NO Delta: SPST-NO Instantaneous: SPST-NO Time Range Star: 0.05 to 100 sec Star-Delta: 0.05 sec 0.1 sec 0.25 sec 0.5 sec Output 24V AC/24V DC GT3A-4AD24 100 to 240V AC GT3A-5AF20 24V AC/24V DC GT3A-5AD24 100 to 240V AC GT3A-6AF20 24V AC/24V DC GT3A-6AD24 Operating Voltage Part No. GT3F-1AF20 GT3F-1AD24 GT3F-2AF20 GT3F-2AD24 Part No. GT3S-1AF20 250V AC/ 30V DC, 5A Twin-Timer 4 GT3A-4AF20 For details, see pages 13 to 14. Model GT3S-1 Serial Activation Coarse/Fine Adjustment Setting Instantaneous Cycle Cycle Cycle Inversion Interval ON Interval ON Delay Serial Interval ON 100 to 240V AC Operating Voltage 100 to 240V AC 24V AC/24V DC 100 to 240V AC 24V AC/24V DC Star-Delta Operation Mode Part No. GT3A-1AF20 GT3A-2AF20 GT3A-2AD24 GT3A-3AF20 GT3A-3AD24 For details, see pages 11 to 12. Operation Mode With Reset Input Power OFF Delay Without Reset Input Operation Mode Operating Voltage 100 to 240V AC 100 to 240V AC 24V AC/24V DC 100 to 240V AC 24V AC/24V DC 100 to 240V AC GT3S-2AF20 For details, see pages 15 to 16. Model Contact Time Range Output T1: 0.1 sec to 6 hours T2: 0.1 sec to 6 hours GT3W-A Delayed SPDT + Delayed SPDT T1: 0.1 sec to 6 hours T2: 0.1 sec to 300 hours 240V AC, 3A T1: 0.1 sec to 300 hours T2: 0.1 sec to 6 hours 120V AC/ 30V DC, 5A T1: 0.1 sec to 300 hours T2: 0.1 sec to 300 hours Operating Voltage 100 to 240V AC GT3W-A11AF20N 24V AC/24V DC GT3W-A11AD24N Part No. 100 to 240V AC GT3W-A13AF20N 24V AC/24V DC GT3W-A13AD24N 100 to 240V AC GT3W-A31AF20N 24V AC/24V DC GT3W-A31AD24N 100 to 240V AC GT3W-A33AF20N 24V AC/24V DC GT3W-A33AD24N GT3 Series Multi-Mode (Analog Setting) GT3A-1, -2, -3 (8-Pin) Four Selectable Operation Modes in One Timer: ON Delay, Interval ON, Cycle, Cycle ON POWER Indicator (flashes during time delay period) OUT Indicator Setting Knob (2) Time Range Selector 1S, 10S, 10M, 10H (1) Operation Mode Selector A, B, C, D (1) Operation Mode Rated Voltage 100 to 240V AC 100 to 240V AC 24V AC/24V DC 100 to 240V AC 24V AC/24V DC A: ON Delay B: Interval ON C: Cycle OFF D: Cycle ON Time Ranges 0.1 sec to 180 hours See Time Ranges for details. Time Ranges 1S 10S 10M 10H Rated Load Maximum Switching Power Maximum Switching Voltage Maximum Switching Current Maximum Switching Frequency Minimum Applicable Load External Protection Element Electrical Life Mechanical 240V AC/24V DC, 5A (resistive load) Contact Delayed SPDT Delayed SPDT + Instantaneous SPDT Delayed DPDT Part No. GT3A-1AF20 GT3A-2AF20 GT3A-2AD24 GT3A-3AF20 GT3A-3AD24 General Specifications 0-1 0-3 0-6 0 - 18 0.1 sec to 1 sec 0.1 sec to 10 sec 6 sec to 10 min 6 min to 10 hours 0.1 sec to 3 sec 0.3 sec to 30 sec 18 sec to 30 min 18 min to 30 hours 0.1 sec to 6 sec 0.6 sec to 60 sec 36 sec to 60 min 36 min to 60 hours 0.2 sec to 18 sec 1.8 sec to 180 sec 108 sec to 180 min 108 min to 180 hours Contact Ratings Model Output 240V AC, 3A 120V AC/30V DC, 5A (resistive load) GT3A-1, GT3A-2 240V AC, 3A (resistive load) 120V AC/30V DC, 5A (resistive load) AC: 960VA DC: 120W GT3A-3 240V AC/24V DC, 5A (resistive load) AC: 1200VA DC: 120W 250V AC/150V DC 5A 600 operations/hour Model Operation System Operation Time Range Pollution Degree Overvoltage Category AF20 Rated Voltage AD24 AF20 Voltage Range AD24 Reset Voltage Operating Temperature Storage Temperature Operating Humidity Storage Humidity Altitude Reset Time Repeat Error Voltage Error Temperature Error Setting Error Insulation Resistance 600 operations/hour 5V DC, 10 mA (reference value) Dielectric Strength Fuse 250V, 5A 100,000 operations minimum (rated load) 20,000,000 operations minimum Vibration Resistance Shock Resistance Degree of Protection Power Consumption (approx.) (2) Range (3) Dial (3) Dial Selector 0-1, 0-3, 0-6, 0-18 AF20 GT3A-1 GT3A-2 GT3A-3 Solid-state CMOS circuitry Multi-Mode 0.1 sec to 180 hours 2 (IEC60664-1) III (IEC60664-1) 100 to 240V AC (50/60Hz) 24V AC (50/60Hz)/24V DC 85 to 264V AC (50/60Hz) 20.4 to 26.4V AC (50/60Hz)/21.6 to 26.4V DC Rated voltage × 10% minimum -10 to +50°C (no freezing) -30 to +70°C (no freezing) 35 to 85% RH (no condensation) 35 to 85% RH (no condensation) 0 to 2000m (operation) 0 to 3000m (transportation) 60 ms maximum ±0.2%, ±10 ms maximum (Note) ±0.2%, ±10 ms maximum (Note) ±0.2%, ±10 ms maximum (Note) ±10% maximum 100 MΩ minimum (500V DC megger) Between power and output terminals: 2000V AC, 1 minute Between contacts of different poles: 2000V AC, 1 minute Between contacts of the same pole: 750V AC, 1 minute (GT3A-1, 2) 1000V AC, 1 minute (GT3A-3) GT3A-1/-2/-3: Damage limits: 10 to 55 Hz, amplitude 0.75mm, 2 hours each in 3 directions GT3A-1/-2: Operating extremes: 10 to 55 Hz, amplitude 0.75mm, 2 hours each in 3 directions GT3A-3: Operating extremes: 10 to 55 Hz, amplitude 0.41mm, 2 hours each in 3 directions Operating extremes: 98 m/s2, Damage limits: 490 m/s2, 3 shocks each in 6 directions IP40 (timer), IP20 (socket) (IEC60529) 100V AC 60Hz 2.9VA 2.5VA 2.2VA 200V AC 60Hz 4.7VA 4.3VA 4.0VA AD24 (AC/DC) Dimensions Weight (approx.) 1.3VA/0.5W 2.0VA/0.8W 40H × 36W × 72.2D mm 63g 73g 1.8VA/0.7W 79g Note: The largest value becomes the error against a preset value depending on the time range. 5 GT3 Series Multi-Mode (Analog Setting) Operation Chart Part No. Contact GT3A-1 Delayed SPDT Internal Connection 6 Operation Mode Selection On Delay MODE A 5 8 Item Terminal No. Power 2-7 7(~)/(+) 3 4 6 2(~)/(-) 1 8 Operation Set Time Interval ON MODE B Indicator Cycle OFF (OFF start) MODE C Cycle ON (ON start) MODE D OUT 6 2-7 2(~)/(-) 1 8 Operation Set Time Item Terminal No. Power 2-7 5 7(~)/(+) 2(~)/(-) Operation Set Time 5-8,4-1 Delayed (NC) Contact 6-8,3-1 (NO) POWER Indicator (NO) Indicator OUT POWER OUT Item Terminal No. Power 2-7 Operation Set Time 5-8 Delayed (NC) Contact 6-8 (NO) Indicator Item Power Terminal No. 2-7 Operation Set Time Instantaneous Contact Indicator Item Terminal No. Power 2-7 Operation Set Time 5-8,4-1 Delayed (NC) Contact 6-8,3-1 (NO) 5-8 Delayed (NC) Contact 6-8 (NO) OUT 4-1 (NC) POWER Indicator 3-1 (NO) OUT POWER OUT Item Terminal No. Power 2-7 Set Time Operation Indicator Item Terminal No. Power 2-7 Set Time Operation 5-8 Delayed (NC) Contact 6-8 (NO) 5-8 Delayed (NC) Contact 6-8 (NO) Instantaneous Contact OUT Indicator Item Terminal No. Power 2-7 Set Time Operation 5-8,4-1 Delayed (NC) Contact 6-8,3-1 (NO) 4-1 (NC) POWER Indicator 3-1 (NO) OUT POWER OUT Item Terminal No. Power 2-7 5-8 Delayed (NC) Contact 6-8 (NO) POWER Functions in same manner as Mode C, with the exception that first transfer of contacts occurs as soon as power is applied. The ratio is 1:1. Time Off = Time On Power 4 6 4-1 POWER Set timer for desired delay, apply power to coil. First transfer of contacts occurs after preset delay has elapsed, after the next elapse of preset delay contacts return to original position. The timer now cycles between on and off as long as power is applied. The ratio is 1:1. Time Off = Time On Terminal No. 3 Instan- (NC) taneous Contact 3-1 POWER Set timer for desired delay, apply power to coil. Contacts transfer immediately, and return to original position after preset time has elapsed. Reset occurs with removal of power. Item GT3A-3 Delayed DPDT 7(~)/(+) 5 5-8 Delayed (NC) Contact 6-8 (NO) 5-8 Delayed (NC) Contact 6-8 (NO) POWER Set timer for desired delay, apply power to coil. Contacts transfer after preset time has elapsed, and remain in transferred position until timer is reset. Reset occurs with removal of power. Operation Chart GT3A-2 Delayed SPDT + Instantaneous SPDT Indicator OUT Set Time Operation Item Terminal No. Power 2-7 5-8 Delayed (NC) Contact 6-8 (NO) Instantaneous Contact Indicator 4-1 (NC) 3-1 (NO) POWER OUT Set Time Operation Item Terminal No. Power 2-7 5-8,4-1 Delayed (NC) Contact 6-8,3-1 (NO) POWER Indicator OUT Set Time Operation GT3 Series Multi-Mode (Analog Setting) GT3A-4, -5, -6 (11-Pin) Four Selectable Operation Modes with Start, Gate, and Reset Inputs for External Control POWER Indicator (flashes during time delay period) OUT Indicator Setting Knob (2) Time Range Selector 1S, 10S, 10M, 10H (1) Operation Mode Selector A, B, C, D (1) Operation Mode A: ON Delay C: Signal ON Delay 1S 10S 10M 10H B: One-Shot Cycle, D: Signal OFF Delay B: One-Shot ON Delay D: Signal ON/OFF Delay 100 to 240V AC 24V AC/24V DC GT3A-4AD24 0.1 sec to 180 hours See Time Ranges for details 240V AC, 5A 24V DC, 5A (resistive load) Delayed DPDT Start Reset Gate GT3A-5AF20 GT3A-5AD24 GT3A-6AF20 GT3A-6AD24 0-3 0-6 0 - 18 0.1 sec to 1 sec 0.1 sec to 10 sec 6 sec to 10 min 6 min to 10 hours 0.1 sec to 3 sec 0.3 sec to 30 sec 18 sec to 30 min 18 min to 30 hours 0.1 sec to 6 sec 0.6 sec to 60 sec 36 sec to 60 min 36 min to 60 hours 0.2 sec to 18 sec 1.8 sec to 180 sec 108 sec to 180 min 108 min to 180 hours Maximum Switching Voltage Maximum Switching Current Maximum Switching Frequency Minimum Applicable Load External Protection Element Electrical Mechanical 240V AC/24V DC, 5A (resistive load) AC: 1200VA DC: 120W 250V AC/150V DC 5A 600 operations/hour 5V DC, 10 mA (reference value) Fuse 250V, 5A 100,000 operations minimum (rated load) 20,000,000 operations minimum Operation System Operation Time Range Pollution Degree Overvoltage Category AF20 Rated Voltage AD24 AF20 Voltage Range AD24 Reset Voltage Operating Temperature Storage Temperature Operating Humidity Storage Humidity Altitude Reset Time Repeat Error Voltage Error Temperature Error Setting Error Insulation Resistance Dielectric Strength Input Specifications Gate Input Part No. GT3A-4AF20 24V AC/24V DC 0-1 Maximum Switching Power Reset Input Input General Specifications (3) Dial Rated Load Start Input Contact 100 to 240V AC Contact Ratings Life Output 24V AC/24V DC Time Ranges (2) Range Time Ranges 100 to 240V AC B: Cycle OFF D: Signal OFF Delay A: Interval ON C: Signal ON/OFF Delay A: One-Shot C: One-Shot Rated Voltage Code (3) Dial Selector 0-1, 0-3, 0-6, 0-18 The start input initiates delayed operation and controls output status. When the reset input goes on (L level), the timer is reset to the original time (time at power-on). The time delay operation is suspended while the gate input is on (L level). No-voltage contact inputs and NPN open collector transistor inputs are applicable. 24V DC, 1 mA maximum Input response time: 50 ms maximum Vibration Resistance Shock Resistance Degree of Protection Power Consumption (Approx.) Dimensions Weight (approx.) AF20 AD24 Solid-state CMOS circuitry Multi-mode with inputs (11 pins) 0.1 sec to 180 hours 2 (IEC60664-1) III (IEC60664-1) 100 to 240V AC (50/60Hz) 24V AC (50/60Hz)/24V DC 85 to 264V AC (50/60Hz) 20.4 to 26.4V AC (50/60Hz)/21.6 to 26.4V DC Rated voltage × 10% minimum -10 to +50°C (no freezing) -30 to +70°C (no freezing) 35 to 85% RH (no condensation) 35 to 85% RH (no condensation) 0 to 2000m (operation) 0 to 3000m (transportation) 60 ms maximum ±0.2%, ±10 ms (Note) ±0.2%, ±10 ms (Note) ±0.2%, ±10 ms (Note) ±10% maximum 100MΩ minimum (500V DC megger) Between power and output terminals: 2000V AC, 1 minute Between contacts of different poles: 2000V AC, 1 minute Between contacts of the same pole: 1000V AC, 1 minute Damage Limits: 10 to 55 Hz, amplitude 0.75 mm, 2 hours each in 3 directions Operating extremes: 10 to 55 Hz, amplitude 0.41mm, 2 hour each in 3 directions Operating extremes: 98 m/s2 Damage limits: 490 m/s2 3 shocks each in 6 directions IP40 (timer), IP20 (socket) (IEC60529) 2.2VA (100V AC/60Hz), 4.1VA (200V AC/60Hz) 1.8VA (AC)/0.7W (DC) 40H × 36W × 72.2D mm 80g Note: The largest value becomes the error against a preset value depending on the time range. 7 GT3 Series Multi-Mode (Analog Setting) Operation Chart GT3A-4 Note: While the gate input is on during time delay operation, the POWER indicator flashing slows down. Operation Chart Delayed DPDT Contact Internal Connection 3 Operation Mode Selection 4 9 11 1 On Delay Item A Power is applied to timer at all times. Set time for desired delay. When start input is supplied time delay starts, contacts transfer after preset time has elapsed. Contacts remain in transferred position until timer is reset. Input MODE Power Reset 7-2 ON or L Gate 5-2 ON or L Item B Power is applied to timer at all times. Set timer for desired delay, initiate start input. Contacts transfer after preset time has elapsed and remain in transferred position until preset time elapses a second time. The timer will now continue to cycle in above manner until reset applied. Input MODE Power 4-1 8-11 3-1 9-11 Note: While the gate input is on during time-delay operation, the POWER indicator flashing slows down. POWER OUT C For this mode a maintained pushbutton is required for start input. Power is applied to timer at all times. Set timer for desired delay, initiate start input. Contacts will transfer immediately. After preset time (with start input still present) contacts will transfer back to original position. Remove start signal, at this time contacts will again transfer. Contacts will transfer to original position after preset time. Timer is reset by initiation of reset input. 8 (NO) OUT T Gate 5-2 ON or L 4-1 8-11 3-1 9-11 T T T Ta T T T T' T" T T T T T Operation (NO) POWER OUT T T Ta T Terminal No. Ta Ta T T' T" Ta Operation 2-10 Start 6-2 ON or L 7-2 ON or L Set Time T (NC) Reset Indicator T Terminal No. 7-2 ON or L Delayed Contact T 2-10 Reset Item Operation POWER 6-2 ON or L Power T" (NC) Start Gate Power is applied to timer at all times. Set timer for desired delay, initiate start input. Contacts immediately transfer. When start input is removed time delay starts. After preset time contacts transfer back to original position. Timer is reset by initiation of reset input. 4-1 8-11 3-1 9-11 Set Time Input D 5-2 ON or L Indicator Signal OFF Delay MODE 7-2 ON or L Delayed Contact T' Terminal No. Gate Item Ta 2-10 Reset Power Input MODE T Set Time Signal ON/OFF Delay 2(~)/(-) (NO) 6-2 ON or L Indicator Gate Note: T = Set time Ta = Shorter than set time T = T’ + T’’ (NC) Start Delayed Contact Reset Start Operation Set Time Cycle 7 6 5 Terminal No. 6-2 ON or L Indicator (~)/(+) 10 2-10 Start Delayed Contact 8 5-2 ON or L 4-1 8-11 3-1 9-11 (NC) (NO) POWER OUT T Ta Ta T T' T" GT3 Series Multi-Mode (Analog Setting) GT3A-5 Operation Chart Delayed DPDT Contact Internal Connection 3 Operation Mode Selection 4 9 Item A Power is applied to timer at all times. Set timer for desired delay, initiate start input. Contacts immediately transfer. After preset delay contacts return to original position. Timer is reset by initiation of reset input. Input MODE Power Reset 7-2 ON or L Gate 5-2 ON or L B Power is applied to timer at all times. Set timer for desired delay, initiate start input. After preset time has elapsed contacts will transfer. Contacts will transfer to their original position after preset time elapses a second time. Timer is reset by initiation of reset input. Power Input MODE Item 4-1 8-11 3-1 9-11 (NO) POWER OUT For this mode a maintained pushbutton is required for start input. Power is applied to timer at all times. Set timer for desired delay, initiate start input. Contacts will transfer immediately. After preset time (with start input still present) contacts will transfer back to original position. Remove start signal, at this time contacts will again transfer. Contacts will transfer to original position after preset time. Timer is reset by initiation of reset input. Input C Power is applied to timer at all times. Set timer for desired delay, initiate start input. Contacts immediately transfer. When start input is removed time delay starts. After preset time contacts transfer back to original position. Timer is reset by initiation of reset input. 4-1 8-11 3-1 9-11 Operation (NC) POWER OUT T 7-2 ON or L Gate 5-2 ON or L 4-1 8-11 3-1 9-11 T" T Operation POWER OUT T T Ta T Terminal No. Ta Ta T T' T" Ta Operation 2-10 6-2 ON or L Reset 7-2 ON or L Gate 5-2 ON or L Set Time T' (NC) Start Indicator Ta (NO) Set Time Delayed Contact T 2-10 Reset Item T Terminal No. 6-2 ON or L Power T" (NO) Start Indicator Input D 5-2 ON or L Delayed Contact Signal OFF Delay MODE 7-2 ON or L Gate Power T' 2-10 Reset Item Ta Terminal No. Set Time Signal ON/OFF Delay MODE T 6-2 ON or L Indicator 2(~)/(-) (NC) Start Delayed Contact Gate Operation Set Time One-Shot Cycle Note: T = Set time Ta = Shorter than set time T = T’ + T’’ Start Terminal No. 6-2 ON or L Indicator Reset 7 6 5 2-10 Start Delayed Contact (~)/(+) 10 11 1 Interval ON 8 4-1 8-11 3-1 9-11 (NC) (NO) POWER OUT T Ta Ta T T' T" 9 GT3 Series Multi-Mode (Analog Setting) GT3A-6 Operation Chart Delayed DPDT Contact Internal Connection 3 Operation Mode Selection 4 9 11 1 One Shot Item A Power is applied to timer at all times. Set timer for desired delay, initiate start input. Contacts immediately transfer. After preset time has elapsed contacts transfer back to original position. Reset occurs with initiation of reset input. Input MODE Power Reset 7-2 ON or L Gate 5-2 ON or L MODE Item Power Input B Set timer for desired delay. When power is applied preset time begins and contacts transfer after preset time has elapsed (no start input needed at this time). Start input is now supplied, this causes the contacts to transfer back to original position. Contacts will remain in this position for preset time, after which they will transfer again. Contacts will now remain in this position until: reset, start input is applied again or power is removed. 4-1 8-11 3-1 9-11 OUT C Power is applied to timer at all times. Set timer for desired delay, initiate start input. Contacts immediately transfer. After preset time has elapsed contacts transfer back to original position. Reset occurs with initiation of reset input. 5-2 ON or L 4-1 8-11 3-1 9-11 POWER OUT T T MODE Input D For this mode a maintained pushbutton is required for start input. Power is applied to timer at all times. Set timer for desired delay, initiate start input. Contacts will transfer immediately. After preset time (with start input still present) contacts will transfer back to original position. Remove start signal, at this time contacts will again transfer. Contacts will transfer to original position after preset time. Timer is reset by initiation of reset input. 7-2 ON or L 5-2 ON or L 4-1 8-11 3-1 9-11 10 T" Operation (NC) POWER OUT T Ta T Terminal No. T' T" Operation 2-10 6-2 ON or L Reset 7-2 ON or L Gate 5-2 ON or L Set Time T' (NO) Start Indicator T 2-10 Gate Delayed Contact Ta Terminal No. Reset Item T" (NC) 6-2 ON or L Power T' Operation Set Time Signal ON/OFF Delay Ta (NO) Start Indicator T 2-10 7-2 ON or L Delayed Contact Ta Terminal No. Gate Power Input MODE Ta Reset Item 2(~)/(-) (NO) Set Time One Shot Gate POWER 6-2 ON or L Indicator Note: T = Set time Ta = Shorter than set time T = T’ + T’’ (NC) Start Delayed Contact Reset Start Operation Set Time One Shot ON Delay 7 6 5 Terminal No. 6-2 ON or L Indicator (~)/(+) 10 2-10 Start Delayed Contact 8 4-1 8-11 3-1 9-11 (NC) (NO) POWER OUT T T Ta T' T" Ta Ta T GT3 Series Power OFF Delay GT3F-1/GT3F-2 (8-Pin) Specifically designed for Power OFF Delay. Reset Inputs are available. GT3F-1 GT3F-2 POWER Indicator Setting Knob (1) Dial Selector 0-1, 0-3, 0-18, 0-60 (1) Operation Mode Rated Voltage Code 100 to 240V AC 24V AC/24V DC 100 to 240V AC 24V AC/24V DC Power OFF Delay Time Ranges 10S (3) Dial 0-1 0-3 0 - 18 0 - 60 0.1 sec to 1 sec 0.1 sec to 10 sec 0.1 sec to 3 sec 0.3 sec to 30 sec 0.2 sec to 18 sec 1.8 sec to 180 sec 0.6 sec to 60 sec 6 sec to 600 sec Timeout Repeat Cycle Reset Input Repeat Cycle 3 sec minimum 3 sec minimum Contact Ratings Model Rated Load Minimum Switching Power Minimum Switching Voltage Minimum Switching Current Maximum Switching Frequency Minimum Applicable Load External Protection Element Life Contact Electrical Mechanical 250V AC/24V DC, 5A Delayed SPDT Reset 250V AC/24V DC, 3A Delayed DPDT Without GT3F-1 GT3F-2 250V AC/24V DC, 250V AC/24V DC, 5A (resistive load) 3A (resistive load) AC: 1250VA AC: 750VA DC: 150W DC: 90W 250V AC/125V DC 5A 3A 1800 operations/hour 5V DC, 10 mA 5V DC, 100 mA Fuse 250V, 5A Fuse 250V, 3A 100,000 operations minimum (rated load) 3,000,000 operations minimum Operation System Operation Time Range Pollution Degree Overvoltage Category AF20 Rated Voltage AD24 AF20 Voltage Range AD24 Time Delay Operation Start Voltage Minimum Power Application Time (Note 1) Operating Temperature Storage Temperature Operating Humidity Storage Humidity Altitude Repeat Error Voltage Error Temperature Error Setting Error Insulation Resistance Dielectric Strength Input Specifications Reset Input Input Part No. GT3F-1AF20 GT3F-1AD24 GT3F-2AF20 GT3F-2AD24 General Specifications GT3F-1/GT3F-2 1S Output 0.1 sec to 600 sec Time Ranges (2) Range (2) Time Range Selector 1s, 10s The contact is reset by turning the reset input on (L level). No-voltage contact input and NPN open collector transistor input are applicable. 6V DC, 0.6 mA maximum Input Response Time (AC): ON: 50 ms maximum OFF: 1 sec maximum Vibration Resistance Shock Resistance Degree of Protection AF20 Power Consumption (approx.) AD24 Dimensions Weight (approx.) Solid-state CMOS circuitry Power OFF delay 0.1 sec to 600 hours 2 (IEC60664-1) III (IEC60664-1) 100 to 240V AC (50/60Hz) 24V AC (50/60Hz)/24V DC 85 to 264V AC (50/60Hz) 20.4 to 26.4V AC (50/60Hz)/21.6 to 26.4V DC Rated Voltage × 10% minimum 0.4 sec (time range: 180 sec or less) 1 sec (time range: 600 sec) -10 to +50°C (no freezing) -30 to +70°C (no freezing) 35 to 85% RH (no condensation) 35 to 85% RH (no condensation) 0 to 2000m (operation) 0 to 3000m (transportation) ±0.2%, ±10 ms (Note 2) ±0.2%, ±10 ms (Note 2) ±0.2%, ±10 ms (Note 2) ±10% 100 MΩ min. (500V DC megger) Between power and output terminals: 2000V AC, 1 minute Between contacts of different poles: 2000V AC, 1 minute Between contacts of the same pole: 1000V AC, 1 minute Damage limits/operating extremes: 10 to 55Hz, amplitude 0.75 mm, 2 hours each in 3 directions Operating extremes: 98 m/s2, Damage limits: 490 m/s2, 3 shocks each in 6 directions IP40 (timer), IP20 (socket) (IEC60529) 1.1 VA (100V AC/60Hz), 2.3 VA (200V AC/60Hz) 0.7 VA (AC)/0.2W (DC) 40H × 36W × 72.2D mm GT3F-1 GT3F-2 77g 79g Note 1: An inrush current flows during minimum power application time. AF20: Approx. 0.4A, AD24: Approx. 1.2A Note 2: The largest value becomes the error against a preset value depending on the time range. 11 GT3 Series Power OFF Delay Operation Chart Contact Internal Connection Operation Chart Item 6 5 7 GT3F-1 4 Delayed SPDT Output with Reset Input 1 8 Power 2-7 Reset Input 4-1 ON Delayed Contact (~)/(+) Reset Indicator 6-8 (NO) POWER Tr T Ta Ts T T = Set time Ta = Shorter than set time Ts = 1 sec Tr = Minimum power application time • 0.4 sec (time range: 180 sec or less) • 1 sec (time range: 600 sec or less) • When power turns on, the NO output contact goes on. When a preset time has elapsed after the power has been turned off, the NO output contact goes off. • The contact is reset by turning the reset input on. Item Power 4 6 Operation 5-8 (NC) Set Time 2 (~)/(-) 3 Terminal No. (~)/(+) 5 7 GT3F-2 Delayed Contact Indicator Terminal No. Operation 2-7 5-8, 4-1 (NC) 6-8, 3-1 (NO) POWER Delayed DPDT Output 1 12 8 2 (~)/(-) Set Time T Tr T T = Set time Tr = Minimum power application time • 0.4 sec (time range: 180 sec or less) • 1 sec (time range: 600 sec or less) • When power turns on, the NO output contact goes on. When a preset time has elapsed after the power has been turned off, the NO output contact goes off. GT3 Series Star-Delta GT3S-1/GT3S-2 (8-Pin) Star-Delta Output Mode Star Output Indicator Delta Output Indicator Star Setting Knob (2) Star-Delta Switching Time Selector 0.05 sec, 0.1 sec, 0.25 sec, 0.5 sec (1) Star Dial Selector 0-5, 0-10, 0-50, 0-100 (1) Operation Mode Star-Delta Rated Voltage 100 to 240V AC Time Range Star: 0.05 to 100 sec Star-Delta switching time 0.05 sec 0.10 sec 0.25 sec 0.50 sec Time Ranges 1 Star Dial Selector Dial 0 -- 5 0 -- 10 0 -- 50 0 -- 100 Time Range 0.05 sec -- 5 sec 0.1 sec -- 10 sec 0.5 sec -- 50 sec 1 sec -- 100 sec Maximum Switching Power Maximum Switching Voltage Maximum Switching Current Maximum Switching Frequency Minimum Applicable Load External Protection Element Life Electrical Mechanical 250V AC/ 30V DC, 5A (resistive load) Contact Star: Delayed SPST-NO Delta: Delayed SPST-NO Star: Delayed SPST-NO Delta: Delayed SPST-NO Instantaneous SPST-NO Part No. GT3S-1AF20 GT3S-2AF20 General Specifications 2 Star-Delta Switching Time Selector Indication Time 0.05 0.05 sec 0.1 0.1 sec 0.25 0.25 sec 0.5 0.5 sec Contact Ratings Rated Load Output 250V AC/30V DC, 5A (resistive load) 250V AC, 1.5A/30V DC, 2A (inductive load) AC: 1250VA DC: 150W 250V AC/125V DC 5A 600 operations/hour 5V DC, 100mA (reference value) Fuse 250V, 5A 100,000 operations minimum (rated load) 20,000,000 operations minimum Operation System Operation Time Range Pollution Degree Overvoltage Category Rated Voltage Voltage Range Reset Voltage Operating Temperature Storage Temperature Operating Humidity Storage Humidity Altitude Reset Time Repeat Error Voltage Error Temperature Error Setting Error Insulation Resistance Dielectric Strength Vibration Resistance Shock Resistance Degree of Protection Solid-state CMOS circuitry Star-delta Star side: 0.05 sec to 100 sec Star delta switching time: 0.05, 0.1, 0.25, 0.5 sec 2 (IEC60664-1) III (IEC60664-1) 100 to 240V AC (50/60Hz) 85 to 264V AC (50/60Hz) Rated Voltage × 10% minimum --10 to +50°C (no freezing) --30 to +70°C (no freezing) 35 to 85% RH (no condensation) 35 to 85% RH (no condensation) 0 to 2000m (operation) 0 to 3000m (transportation) 500 ms maximum ±0.2%, ±10 ms (Note) ±0.2%, ±30 ms (Note) ±0.2%, ±10 ms (Note) ±10% maximum 100 MΩ minimum (500V DC megger) Between power and output terminals: 2000V AC, 1 minute Between contacts of different poles: 2000V AC, 1 minute Between contacts of the same pole: 1000V AC, 1 minute Damage limits/operating extremes: 10 to 55 Hz, amplitude 0.75 mm, 2 hours each in 3 directions Operating extremes: 98 m/s2, Damage limits: 490 m/s2, 3 shocks each in 6 directions IP40 (timer), IP20 (socket) (IEC60529) GT3S-1AF20 Power Consumption (approx.) Dimensions Weight (approx.) GT3S-2AF20 2.3VA 2.3VA (100V AC/60Hz) (100V AC/60Hz) 4.0VA 3.8VA (200V AC/60Hz) (200V AC/60Hz) 40H × 36W × 72.2D mm GT3S-1AF20 GT3S-2AF20 68g 75g Note: The largest value becomes the error against a preset value depending on the time range. 13 GT3 Series Star-Delta Operation Chart Contact Internal Connection (~) 5 7 6 GT3S-1 Star : Delayed SPST-NO Delta: Delayed SPST-NO Operation Chart Item Terminal No. Power 2-7 Star Delayed Contact Delta Delayed Contact 8-5 (NO) Operation 8-6 (NO) Star Indicator Delta 2 8 Set Time (~) T1 T2 T3 The star delayed contact goes on when power is turned on and goes off after a set time for the star contact (T1). The delta contact goes on after star-delta switching time (T2) and goes off when power is turned off. • T1 = Star ON time (Set Time), T2 = Star-delta swithing time, T3 = Star ON time (~) GT3S-2 Star : Delayed SPST-NO Delta: Delayed SPSTNO Instantaneous SPST-NO 3 5 6 7 Item Terminal No. Power 2-7 Star Delayed Contact Delta Delayed Contact 8-5 (NO) Instantaneous contact 3-1 (NO) Operation 8-6 (NO) Star Indicator Delta 1 8 2 (~) Set Time T1 T2 T3 • The star delayed contact goes on when power is turned on and goes off after a set time for the star contact (T1). The delta contact goes on after star-delta switching time (T2) and goes off when power is turned off. • Instantaneous contact goes on when power is turned on and goes off when power is turned off. • T1 = Star ON time (Set Time), T2 = Star-delta swithing time, T3 = Star ON time 14 GT3 Series Twin-Timer GT3W-A11, -A13, -A31, A33 Multi-range Twin-Timer with 8 operation modes OUT Indicators POWER Indicator Setting Knob (T2) Time Range Selector Mode Selector Setting Knob (T1) (1) Operation Mode 100 to 240V AC 24V AC/24V DC 100 to 240V AC 24V AC/24V DC 100 to 240V AC 24V AC/24V DC 100 to 240V AC 24V AC/24V DC Sequential Start Coarse/Fine Adjustment Instantaneous Cycle Cycle Cycle Inversion Interval ON Interval ON Delay Sequential Interval Time Ranges 0.1 sec to 6 hours Time Range Time Scale Selector Range 0.1 sec to 1S 1 sec 0.3 sec to 10S 0-1 10 sec 15 sec to 10M 10 min 0.1 sec to 1S 6 sec 1.3 sec to 10S 60 sec 7.5 sec to 1M 0-6 1 min 75 sec to 10M 60 min 7.5 min to 1H 6 hours Maximum Switching Power Maximum Switching Voltage Maximum Switching Current Maximum Switching Frequency Minimum Applicable Load External Protection Element Life Electrical Mechanical T1 T2 0.1 sec to 6 hours 0.1 sec to 6 hours 0.1 sec to 300 hours 0.1 sec to 6 hours 0.1 sec to 300 hours 0.1 sec to 300 hours Part No. GT3W-A11AF20N GT3W-A11AD24N GT3W-A13AF20N GT3W-A13AD24N GT3W-A31AF20N GT3W-A31AD24N GT3W-A33AF20N GT3W-A33AD24N General Specifications 0.1 sec to 300 hours Time Range Time Scale Selector Range 0.1 sec to 1S 3 sec 3.8 sec to 1M 0-3 3 min 3.8 min to 1H 3 hours 0.6 sec to 1S 30 sec 38 sec to 1M 30 min 38 min to 0 - 30 1H 30 hours 10H 6.3 hours to 300 hours Contact Ratings Rated Load Time Ranges Rated Voltage 240V AC, 3A (resistive load) 120V AC/ 30V DC, 5A (resistive load) AC: 960VA DC: 120W 250V AC/150V DC 5A 600 operations/hour 5V DC, 10mA (reference value) Fuse 250V, 5A 100,000 operations minimum (rated load) 20,000,000 operations minimum Operation System Operation Time Range Pollution Degree Overvoltage Category AF20 Rated Range AD24 AF20 Voltage Range AD24 Reset Voltage Operating Temperature Storage Temperature Operating Humidity Storage Humidity Altitude Reset Time Repeat Error Voltage Error Temperature Error Setting Error Insulation Resistance Dielectric Strength Vibration Resistance Shock Resistance Degree of Protection Power Consumption (approx.) Dimensions Weight (approx.) AF20 AD24 Solid-state CMOS circuitry Multi-Mode 0.1 sec to 300 hours 2 (IEC60664-1) III (IEC60664-1) 100 to 240V AC (50/60Hz) 24V AC (50/60Hz)/ 24V DC 85 to 264V AC (50/60Hz) 20.4 to 26.4V AC (50/60Hz)/21.6 to 26.4V DC Rated voltage × 10% minimum -10 to +50°C (no freezing) -30 to +70°C (no freezing) 35 to 85% RH (no condensation) 35 to 85% RH (no condensation) 0 to 2000m (operation) 0 to 3000m (transportation) 60 ms maximum ±0.2%, ±10 ms (Note) ±0.2%, ±10 ms (Note) ±0.6%, ±10 ms (Note) ±10% 100 MΩ minimum (500V DC megger) Between power and output terminals: 2000V AC, 1 minute Between contacts of different poles: 2000V AC, 1 minute Between contacts of the same pole: 750V AC, 1 minute Damage limits/operating extremes: 10 to 55Hz, amplitude 0.75 mm, 2 hours each in 3 directions Operating extremes: 98 m/s2 Damage limits: 490 m/s2 3 shocks each in 6 directions IP40 (timer), IP20 (socket) (IEC60529) 2.6VA (100V AC /60Hz) 5.1VA (200V AC /60Hz) 1.8VA (AC)/0.9W (DC) 40H × 36W × 70.0D mm 73g Note: The largest value becomes the error against a preset value depending on the time range. 15 GT3 Series Twin-Timer Operation Chart Operation Chart Delayed SPDT + Delayed SPDT Contact Internal Connection 4 6 3 Operation Mode Selection 5 7(~)/(+) 8 1 Operation Mode Selection 2(~)/(-) Sequential Start Item Terminal No. Power 2-7 Delayed Contact Ry2 Indicator Operation 1-4 (NC) 1-3 (NO) 5-8 (NC) 6-8 (NO) ON after T1 + T2 Terminal No. Power 2-7 Delayed Contact Ry2 Terminal No. Power 2-7 Delayed Contact Ry2 Indicator 8 7(~)/(+) 2(~)/(-) T1 T2 Operation 1-4 (NC) 1-3 (NO) 5-8 (NC) 6-8 (NO) Description ON during T1 OFF during T2 ON during T1 OFF during T2 OUT1 OUT2 Set Time Operation 1-4 (NC) 1-3 (NO) 5-8 (NC) 6-8 (NO) Description ON after T1 + T2 ON after T1 + T2 Item Terminal No. Power 2-7 Delayed Contact Ry1 F OUT1 Delayed Contact Ry2 Indicator OUT2 Item Terminal No. Power 2-7 Delayed Contact Ry2 Indicator T1 T1 T2 Operation 1-4 (NC) 1-3 (NO) 5-8 (NC) 6-8 (NO) Description ON during T1 ON after T1, during T2 OUT1 OUT2 Set Time T2 Operation 1-4 (NC) 1-3 (NO) 5-8 (NC) 6-8 (NO) Description Instantaneous ON OFF during T1 ON during T2 Item Terminal No. Power 2-7 Delayed Contact Ry1 G OUT1 Delayed Contact Ry2 Indicator OUT2 Set Time T1 T2 T1 T1 T2 Operation 1-4 (NC) 1-3 (NO) 5-8 (NC) 6-8 (NO) Description ON during T1 ON after T1 + T2 OUT1 OUT2 Set Time T2 Cycle T1 T2 Sequential Interval Item Terminal No. Power 2-7 Delayed Contact Ry1 Delayed Contact Ry2 Indicator Operation 1-4 (NC) 1-3 (NO) 5-8 (NC) 6-8 (NO) Description OFF during T1 ON during T2 Item Terminal No. Power 2-7 Delayed Contact Ry1 OFF during T1 ON during T2 OUT1 H Delayed Contact Ry2 Indicator OUT2 Set Time 16 1 5 Interval ON Delay Delayed Contact Ry1 D E OUT2 Set Time C Item Delayed Contact Ry1 OUT1 Item Indicator Instantaneous Cycle 4 6 Interval ON Delayed Contact Ry1 B Description ON after T1 Set Time Coarse/ Fine Adjustment 3 Cycle Inversion Delayed Contact Ry1 A Operation Chart Delayed SPDT + Delayed SPDT Contact Internal Connection T1 T2 T1 T2 Operation 1-4 (NC) 1-3 (NO) 5-8 (NC) 6-8 (NO) ON during T1 + T2 ON after T1, during T2 OUT1 OUT2 Set Time Description T1 T2 GT3 Series Accessories Applicable Sockets & Hold-Down Springs (Optional) DIN Rail Mount Socket Item 8-Pin Screw Terminal Socket 11-Pin Screw Terminal Hold-Down Spring Part No. Ordering No. Applicable Timer GT3A-1/2/3, GT3F, GT3S, GT3W Package Quantity SR2P-06A SR2P-06A SR3P-05A SR3P-05A SR3P-06A SR3P-06A SR3P-05C SR3P-05C SFA-202 SFA-202PN20 — 10 sets (20 pcs) SFA-203 SFA-203PN20 — 10 sets (20 pcs) 1 1 GT3A-4/5/6 1 1 Note: All are UL recognized, CSA certified, and TÜV approved. SR2P-06A SR3P-05A SR3P-06A SFA-202 (2 pcs/set) Remarks Hold-down spring: SFA-202 (2 pcs.) Hold-down spring: SFA-203 (2 pcs.) Hold-down spring: SFA-202 (2 pcs.) Finger-safe For SR2P-06A/SR3P-06A (2 pcs/set) For SR3P-05A (2 pcs/set) SFA-203 (2 pcs/set) Panel Mount Socket Item Socket Part No. Ordering No. Applicable Timer Package Quantity Remarks 1 — — For SR2P-511/ SR3P-511 8-Pin Solder Terminal SR2P-511 SR2P-511 GT3A-1/2/3, GT3F, GT3S, GT3W 11-Pin Solder Terminal SR3P-511 SR3P-511 GT3A-4/5/6 1 SFA-402 SFA-402PN10 — 10 Hold-Down Spring Note: SR2P-511 and SR3P-511 are UL recognized and CSA certified. SR2P-511 SR3P-511 SFA-402 Panel Mount Adapter and wiring Socket Adapter Package Quantity: 1 Item DIN 48mm Square Panel Mount Adapter Wiring Socket Adapter Part No. Color: Gray RTB-G01 Color: Beige RTB-M01 Color: Black RTB-B01 8-Pin Solder Terminal 8-Pin Screw Terminal 11-Pin Solder Terminal 11-Pin Screw Terminal SR6P-S08 SR6P-M08G SR6P-S11 SR6P-M11G (8-pin Wiring Socket Adapter) SR6P-S08 (11-pin Wiring Socket Adapter) SR6P-S11 (8-pin Screw Wiring Socket Adapter) SR6P-M08G (11-pin Screw Wiring Socket Adapter) SR6P-M11G • Finger-safe 11-pin screw wiring socket adapter (Part No.: SR6P-C11) is also available. Installation of Hold-Down Springs (DIN Rail Mount Socket) Insert the springs into the outer slots with the projections facing inside. Socket SR2P-06A Hold-Down Spring (optional) SFA-202 (2 pcs/set) (Panel Mount Socket) Hold-Down Spring Insert the springs into the slots. Socket Hold-Down Spring (optional) SR3P-05A SFA-203 (2 pcs/set) SFA-402 Insert 8-Pin Socket SR2P-511 SR2P-70 Note: Once installed into the socket, the hold-down springs cannot be removed. 17 GT3 Series Multi-function Timers Dimensions GT3A-4, -5, -6 (11-pin) (SR3P-05A Socket) When Using DIN Rail Mount Socket (SR2P-06A Socket) GT3A-1, -2, -3/GT3F/GT3S (8-pin) (When using DIN rail) BAA, BAP: 105.5 max. 101.5 max. 36 40 60 64.2 8 52 Hold-Down Spring (SFA-203) 13 16.5 20 28.5 3 1.7 31.7 40 95 max. 33 ø27 (When using DIN rail) BAA, BAP: 99 max. DIN Rail (BAA, BAP, BADA) DIN Rail 8 64.2 (SR3P-05C Socket) 1 18 22 (When using DIN rail) BAA, BAP: 105 max. 103.5 max. GT3W 40 (When using DIN rail) BAA, BAP: 96.6 max. 31.7 36 40 60 1.7 92.6 max. 64.2 5.6 DIN Rail Hold-Down Spring 13 (SFA-202) 18 8 64.2 21.5 30 13 (SR3P-06A Socket) 1 36 DIN Rail (BAA, BAP) 22 (When using DIN rail) BAA, BAP: 99 max. 95 max. 3 7(~)/(+) 4 6 DIN Rail GT3A-3 5 4 6 3 7(~)/(+) 5 7(~)/(+) 36 8 Hold-Down Spring 13 (SFA-202) 64.2 18 1 5 60 40 [Internal Connections] GT3A-1 GT3A-2 6 1.7 • Calculate the dimensions for mounting, referring to the diagrams of SR2P06A on Relay Sockets catalog. 31.7 36 Hold-Down Spring 13 (SFA-202) 22 • Calculate the dimensions for mounting, referring to the diagrams in Relay Sockets catalog for SR3P-05A, SR3P-05C, and SR3P-06A. Gate 11 1 (~)/(+) 10 7 6 5 6 Reset 5 7 8 2(~)/(-) 4 3 Reset 5 4 6 8 1 2 Hold-Down Spring (SFA-402) (~)/(-) 4.2 GT3W 6 7 2 (~) 18 1 8 2 (~) 10 11 2.5 1 8 38 0 6 7 (BOTTOM VIEW) 3 4 6 1 8 2-ø3.5 Mounting Hole (or M3 Tapped Hole) (Terminal Arrangement) 4 3 2 5 7(~)/(+) 34 8 2.5 4 5 ø3 3 2 34 (~)/(+) 5 7 (~) 3 2-ø3.5 Mounting Hole (or M3 Tapped Hole) (Terminal Arrangement) GT3A-4, -5, -6 (SR3P-511 Socket) 2 (~)/(-) GT3S-2 7 4.2 Gate 1 Gate (~) 6 Hold-Down Spring (SFA-402) Start GT3F-2 (~)/(+) Start Reset 7 6 5 2(~)/(-) GT3F-1 GT3S-1 5 11 1 2(~)/(-) 8 (~)/(+) 10 2(~)/(-) 2.5 10 11 2.5 5 6 7 1 11 8 9 10 38 4 9 8 Start GT3A-6 3 4 9 0 7 6 5 3 Reset ø3 11 1 (~)/(+) 10 Panel Surface 8 When Using Panel Mount Socket GT3A-1, -2, -3/GT3F/GT3S/GT3W (8-pin) (SR2P-511 Socket) 6 4 9 GT3A-5 6 3 2(~)/(-) 50 38 GT3A-4 8 1 2(~)/(-) Panel Surface 8 1 2(~)/(-) 50 38 8 (BOTTOM VIEW) All dimensions in mm. GT3 Series Multi-function Timers All GT3 Series When using DIN 48mm-square Panel Mount Adapter (For 8-pin solder wiring socket adapter: SR6P-S08 and 11-pin solder wiring socket adapter: SR6P-S11) 98 max. 48 42.5 1.7 Panel Thickness: 0.8 to 5 mm 48 Wiring Socket Adapter 61.2 11 (8-pin Screw Terminal Wiring Socket Adapter: SR6P-M08G) 8-M3.5 Terminal Screw Panel Thickness: 0.8 to 5 mm 44.6 30.4 44.6 3 4 5 6 2 1 8 7 7 3.5 max. 5.6 min. ø3.6 min. 6.9 max. 9.8×3 80.5 (11-pin Screw Terminal Wiring Socket Adapter: SR6P-M11G) 45 34 11-M3.5 Terminal Screw 45 16.7 4 92 30.5 3.5 max. 2 1 11 7 6 5 3 8 9 10 7 5.8 min. ø3.6 min. 6.9 max. 8.5×4 (Finger-safe 11-pin Screw Terminal Wiring Socket Adapter: SR6P-C11) 11-M3.5 Terminal Screw 45 16.7 2 1 11 7 6 45 34 A1 15 25 Finger-safe structure complies with VDE 0106 T.100. 5 16 18 26 28 A2 4 3 8 9 10 33.5 95 1.5 7 8.5×4 45 (Mounting Hole Layout) Single Mounting 45 45 Horizontal Close Mounting 48N--3 Tolerance: +0.5 to 0 N: No. of timers mounted All dimensions in mm. 19 GT3 Series Instructions Safety Precautions ••Be sure to turn off power before mounting, removal, wiring, maintenance and inspection. Otherwise, electric shock or fire may occur. ••Be sure to use timers within rated specification values. Otherwise electric shock or fire may occur. ••Be sure to use wires to meet voltage and current requirements and tighten M3.5 terminal screws to a torque of 1.0 to 1.3 N·m. Be sure to solder the terminals correctly. Loose terminal screws or incomplete soldering may cause abnormal heat and fire. Instructions Mode Setting The set time is selected by turning the setting knob. GT3A only [Setting Examples] •• When the setting knob is set at 1.5, with dial 0-3 and time range 10S selected, then the set time is 15 sec (1.5 × 10S). •• When the setting knob is set at 0.2, with dial 0-1 and time range 10H selected, then the set time is 2 hours (0.2 × 10H). The operation mode can be selected from A, B, C, and D modes using the Operation Mode Selector. The operation mode is changed from A to B, C, and D in turn by turning the Operation Mode Selector clockwise using a flat screwdriver 4 mm wide maximum and the selected mode is displayed in the window. Since this selector does not turn infinitely, turn the selector clockwise when Mode A is displayed and counterclockwise when Mode D is displayed. Setting Knob The time range of GT3F-1 and GT3F-2 can be selected between 1S and 10S with the Time Range Selector by using a flat screw driver. The selected time range (0-1, 0-3, 0-18, or 0-60) is displayed in the six windows of the Setting Knob by turning Dial Selector which allows to set the scale. Note that the switches do not turn infinitely. Time Range Determined by Time Range Selector and Dial Selector Time Range Selector Operation Mode Selector 2. GT3F (OFF Delay) Dial Selector (1) Dial (2) Range 1S Mode Code and Operation Mode Part No. MODE Code GT3A-1, -2, -3 10S GT3A-4 A ON Delay ON Delay B Interval ON Cycle C Cycle D Cycle ON Signal ON/ OFF Delay Signal OFF Delay GT3A-5 GT3A-6 Interval ON One-Shot One Shot Cycle Signal ON/ OFF Delay Signal OFF Delay One-Shot ON Delay One-Shot 0-1 0-3 0 - 18 0 - 60 0.1 sec to 1 sec 0.1 sec to 10 sec 0.1 sec to 3 sec 0.3 sec to 30 sec 0.2 sec to 18 sec 1.8 sec to 180 sec 0.6 sec to 60 sec 6 sec to 600 sec The set time is selected by turning the Setting Knob. [Setting Examples] ••When the setting knob is set at 2.5, with dial 0-3 and range 1S selected, then the set time is 2.5 sec (2.5 × 1S). ••When the setting knob is set at 15, with dial 0-18 and range 10S selected, then the set time is 150 sec (15 × 10S). 3. GT3S (Star-Delta) Signal ON/ OFF Delay Time Range Setting The time range is calibrated at its maximum time scale, therefore, it is desirable to use the timer at a setting as close to its maximum time scale as possible for accurate time delay. For a more accurate time delay, adjust the setting knob by measuring the operating time before application. Time range can be selected from 1S, 10S, 10M, and 10H by turning the Time Range Selector with a flat screwdriver 4 mm wide maximum. The four different ranges of 0 to 1, 0 to 3, 0 to 6, and 0 to 18 are displayed in the six windows by turning the Dial Selector, allowing for selecting the best suited scale. Since the selectors do not turn infinitely, turn the selectors clockwise when 1S or 0-1 is displayed and counterclockwise when 10H or 0-18 is displayed. Time Range Determined by Time Range Selector and Dial Selector Time Range 1S 10S 10M 10H 20 Star-Delta Switching Time Selector Star Dial Selector 1. GT3A (Multi-Mode Analog Setting) Dial Selector Setting Knob 0-1 0-3 0-6 0 - 18 0.1 sec to 1 sec 0.1 sec to 10 sec 6 sec to 10 min 6 min to 10 hours 0.1 sec to 3 sec 0.3 sec to 30 sec 18 sec to 30 min 18 min to 30 hours 0.1 sec to 6 sec 0.6 sec to 60 sec 36 sec to 60 min 36 min to 60 hours 0.2 sec to 18 sec 1.8 sec to 180 sec 108 sec to 180 min 108 min to 180 hours The scale range on the star side can be selected from four different ranges of 0 to 5, 0 to 10, 0 to 50, and 0 to 100 displayed in the six windows by turning the Star Dial Selector. Note that the selectors does not turn infinitely. Time Range Determined by Time Range Selector and Dial Selector Star Dial Selector Dial 0 -- 5 0 -- 10 0 -- 50 0 -- 100 Time Range 0.05 sec -- 5 sec 0.1 sec -- 10 sec 0.3 sec -- 50 sec 1 sec -- 100 sec Star-Delta Switching Time Selector Indication Time 0.05 0.05 sec 0.1 0.1 sec 0.25 0.25 sec 0.5 0.5 sec The Star ON time is selected by turning the Setting Knob. [Setting Examples] •• If the setting knob is set at 8, with Star Dial Selector 0-10 and Star- Delta switching time 0.1S selected, the Star ON time (T1) is 8 sec and the Star-Delta switching time (T2) is 0.1 sec. GT3 Series Instructions 4. GT3W [Twin-Timer] Inputs of GT3A and GT3F Time Range Determined by Time Range Selector and Dial Selector To avoid electric shock, do not touch the input signal terminal during power voltage application. •• When connecting the input signal terminals of two or more GT3A timers to the same contact or transistor, the input terminals of the same number should be connected. (Connect Terminals No. 2 in common.) •• Never apply the input signals to two or more GT3F timers using the same contact or transistor. Use a flat screwdriver with a diameter of 4 mm maximum to turn Time Range Selector and gain time range as shown in the table below. Note that the selectors do not turn infinitely. 0.1 sec to 6 hours Time Range Scale Time Range Selector 0.1 sec to 1S 1 sec 0.3 sec to 10S 0-1 10 sec 15 sec to 10M 10 min 0.1 sec to 1S 6 sec 1.3 sec to 10S 60 sec 7.5 sec to 1M 0-6 1 min 75 sec to 10M 60 min 7.5 min to 1H 6 hours 0.1 sec to 300 hours Time Range Scale Time Range Selector 0.1 sec to 1S 3 sec 3.8 sec to 1M 0-3 3 min 3.8 min to 1H 3 hours 0.6 sec to 1S 30 sec 38 sec to 1M 30 min 38 min to 0 - 30 1H 30 hours 10H 6.3 hours to 300 hours Note: No blank time range can be set. [Incorrect] GT3 Series Timer Input Contact or Transistor Input Terminal 2 10 Power Input Terminal 2 10 [correct] Input Terminal 2 10 Power Input Terminal 2 10 •• In a transistor circuit for controlling input signals with its primary and secondary power circuits isolated, do not ground the secondary circuit. GT3 Series Timer Input Terminal Rectifier Circuit Power Circuit Insulating Transformer •• Do not connect input signal terminals of the GT3A timer to other terminals than No. 2. Never apply voltage to input signal terminals. Otherwise, the internal circuit may be damaged. Selector Setting 10 Gate Input •• Do not connect input signal terminals of the GT3F timer to other terminals than No. 2. Never apply voltage to input signal terminals. Otherwise, the internal circuit may be damaged. •• Input signal lines must be made as short as possible and installed away from power cables and power lines. Shielded wires or a separate conduit should be used for input wiring. •• For contact input, use reliable gold-plated contacts to make sure that the residual voltage is less than 1V when the contacts are closed. Start Input 6 5 7 4 8 3 9 2 10 1 11 Power ••For transistor input, use transistors with following specifications; VCE = 40V, VCES = 1V or less, IC = 50mA or more, ICBO = 50μA or less. The resistance should be less than 1kΩ when the transistor is on. When the output transistor switches on, a signal is inputted to the timer. Gate Input The GT3F, consisting of a high-impedance circuit, may not be reset due to the influence of an inductive voltage or residual voltage caused by a leakage current. In not reset, connect an RC filter or bleeder resistor between power terminals so that the voltage between power terminals can be reduced to less than 15% of the rated voltage. RY Power Start Input Wiring 2 Reset Input Power •• Since DC types have a polarity in their power supply connection, connect the power according to wiring diagram. •• Since AC type GT3A, GT3S, and GT3W comprise a capacitive load, the SSR dielectric strength should be two or more times as large as the power voltage when switching the timer power using an SSR. 5, 6, and 7 Input Terminal Reset Input •• Use a flat screwdriver with a diameter of 4 mm maximum to turn the selector. Turn the selector until it clicks. Otherwise, malfunction may occur. Also, do not rotate the selector forcibly since the selector does not turn infinitely. •• Since changing the setting during operation may cause malfunction, turn power off before changing the setting. 6 5 7 4 8 3 9 2 10 1 11 Power 21 GT3 Series Instructions Contact Protection GT3A Transistor output equipment such as proximity switches and photoelectric switches can input signals if they are voltage/current output type, power voltage ranges from 18 to 30V, and residual voltage is 1V. When the signal voltage switches from H to L, a signal is inputted to the timer. Transistor Output Circuit Transistor 5, 6, 7 Input Terminal 2 GT3F Do not input signals using transistor output equipment of a voltage/current output type. Otherwise, the internal circuit may be damaged. Minimum Power Application Time If the power application time to the GT3F is shorter than the minimum power application time, the output relay may not operate or the timer may operate faster than the preset time. Time Range Setting Repeat error is calibrated at its maximum time scale, therefore, it is desirable to use the timer at a setting as close to its maximum time scale as possible for accurate time delay. For a more accurate time delay, adjust the setting knob by measuring the operating time before application. Time Accuracy Repeat Error This indicates variance of operation time when operation is repeated under the same conditions. The variance is calculated from the following formula and the measurements should be done 5 times at least. 1 Max. measured value - Min. measured value × 100 (%) =± × 2 Maximum scale value Voltage Error This indicates the variance of operation time when the voltage at operation current varies within allowable voltage variance. =± Tv - Tr × 100 (%) Tr Tv: Average of measured operation time values at voltage V Tr: Average of measured operation time values at the raged voltage Temperature Error This indicates the influence caused by the change in temperature during operation within operating temperature. This is shown with the variance of operation time. =± Tt - T20 × 100 (%) T20 Tt: Average of operation times at temperature t T20: Average of operation times at reference temperature (20°C) Setting Error This indicates the deviation, range, and gap between actual operation time and that on scale. =± Average of measured values - Set value × 100 (%) Maximum scale value Ex.) GT3 setting error: ±10% When the maximum scale value is 10 sec. and setting time is 1 to 3 sec., the setting error ia ±1 sec. and operating time is 1 to 3 sec. When setting a value near the lower limit, be sure to confirm the actual operating time. Load Current The rated current of the contact (or control output) should not be exceeded. Especially for inductive, capacitive, and incandescent lamp loads, the inrush current as large as a few to several tens times the rated current may cause welded contacts and other troubles. The amount of inrush current as well as steady-state current must be taken into consideration. 22 Switching an inductive load generates a counter-electromotive force in the coil. The counter emf will cause arcing, which may shorten the contact life. Application of a protection circuit is recommended for contact protection. Rest Time When turning power off after time-out or during operation, allow a rest time longer than the reset time to restart. (Each model has a different reset time.) Continuous Energizing Continuous energizing for a long period of time may damage the electrical characteristics of the timer because of internal heating. Use an additional relay to the output circuit and refrain from continuous energizing of the timer. Dielectric Strength Test When performing an insulation resistance or dielectric-strength test on control panels containing timers, make sure that the dielectric strength of the timer is not exceeded. In case the dielectric strength is exceeded, remove the timers from the panels. Operating Environment Temperature and Humidity Use the timer within the operating temperature and operating humidity ranges and prevent freezing and condensation. After storing below the operation temperature, leave the timer at room temperature for a sufficient period of time before use. Environment Prevent a corrosive gas such as sulfurous or ammonia gas, organic solvents (alcohol, benzine, thinner, etc.), strong alkaline substances or strong acids from touching to the timer, and do not use the timer in such an environment. Keep the timer from water splashes or steam. Vibration and Shock Since excessive vibrations or shocks cause the output contacts to open, the timer should be used within the operating extremes of vibration and shock resistance. Use of hold-down springs is recommended for secure mounting on sockets. Noise and Static Charge Check the operation of the timer before using in an environment with a lot of noise. Install the input signal source, input signal wiring and timer away from noise source and high-voltage wire with noise as much as possible. Also, in case of using the timer under the environment with multiple static charge (pipe transportation of molding material, power/liquid material, etc.), place the timer away from such static charge source as well. Others • The GT3F does not read the preset values of each selector after power is turned off. Note that minimizing the preset time does not shorten the delay time after power is turned off. • To make a sequence circuit by connecting timers and relays, check the timer operation sufficiently in consideration of the reset time of the timer. • Storage temperature should range from -30°C to +70°C. If the product has been stored at a temperature below -10°C, leave the product at room temperatures for more than 3 hours before using. • Do not remove the housing. • In the GT3 timers, latching relay is used for output relay. Shocks such as dropping during transportation or handling may cause the output to be different from the initial value. Be sure to check the output status using a tester. GT5Y Miniature Electronic Timers Four Selectable Time Ranges Delayed Output 4PDT/3A or DPDT/5A • Three operation modes: ON Delay, Interval ON, and Cycle • Repeat error: ±0.2% ±20 ms maximum • Miniature size • LED indicators for output and power • Complies with safety standards. UL/c-UL listed. EN compliant. Applicable Mark File No. or Organization Standards UL508 UL/c-UL Listed CSA C22.2 No.14 File No. E55996 EU Low Voltage Directive Package Quantity: 1 Output 220V AC/ 30V DC, 5A DPDT ON Delay 220V AC/ 30V DC, 3A 4PDT 220V AC/ 30V DC, 5A DPDT Interval ON 4PDT 220V AC/ 30V DC, 3A DPDT 220V AC/ 30V DC, 5A 4PDT 220V AC/ 30V DC, 3A Cycle 1S/10S/1M/10M 1S/10S/1M/10M Operating Voltage Part No. 100 to 120V AC 12V DC 24V DC 100 to 120V AC 24V DC GT5Y-2SN1A100 GT5Y-2SN3A100 GT5Y-2SN6A100 GT5Y-2SN1A200 GT5Y-2SN3A200 GT5Y-2SN6A200 GT5Y-2SN1D12 GT5Y-2SN3D12 GT5Y-2SN6D12 GT5Y-2SN1D24 GT5Y-2SN3D24 GT5Y-2SN6D24 GT5Y-4SN1A100 GT5Y-4SN3A100 GT5Y-4SN6A100 GT5Y-4SN1A200 GT5Y-4SN3A200 GT5Y-4SN6A200 GT5Y-4SN3D12 GT5Y-4SN1D24 GT5Y-4SN3D24 GT5Y-4SN6D24 GT5Y-2SV1A100 GT5Y-2SV1D12 GT5Y-2SV1D24 GT5Y-4SV1A100 GT5Y-4SV1D24 100 to 120V AC GT5Y-2SF1A100 200 to 240V AC 24V DC GT5Y-4SF1A200 GT5Y-4SF1D24 100 to 120V AC 200 to 240V AC 12V DC 24V DC 100 to 120V AC 200 to 240V AC 12V DC 24V DC Note: S and M of the time range indicate second, and minute respectively. Both SY4S-05C and SM2S-05C are UL recognized, CSA certified, and TÜV approved. Others are UL recognized and CSA certified, except for SY4S-05A and SM2S-05A. When ordering, specify the Ordering No. DIN Rail Mount Socket Socket HoldDown Spring Panel/ PC Board Mount Socket Socket Hold-Down Spring Code Scale 1S 10S 1M 10M 3S 30S 3M 30M 6S 60S 6M 60M 0 to 10 0 to 10 0 to 10 0 to 10 0 to 3 0 to 3 0 to 3 0 to 3 0 to 6 0 to 6 0 to 6 0 to 6 Package Quantity 1 1 1 1 1 1 1 1 1 1 10 sets (20 pcs) Part No. Ordering No. SY4S-05A SY4S-05C SY4S-05D SY4S-05DF SU2S-11L SU4S-11L SM2S-05A SM2S-05C SM2S-05D SM2S-05DF SY4S-05A SY4S-05C SY4S-05D SY4S-05DF SU2S-11L SU4S-11L SM2S-05A SM2S-05C SM2S-05D SM2S-05DF SFA-202 SFA-202PN20 SFA-511 SFA-511PN20 20 SY4S-51 SY4S-61 SM2S-51 SY4S-51 SY4S-61 SM2S-51 1 1 1 SM2S-61 SM2S-61 1 SFA-302 SFA-302PN20 10 sets (20 pcs) Remarks For 4PDT contact For 4PDT contact For 4PDT contact For 4PDT contact For DPDT contact For 4PDT contact For DPDT contact For DPDT contact For DPDT contact For DPDT contact For SY4S-05A, SM2S-05A (2 pcs/set) For SY4S-05D, SY4S-05DF, SM2S-05D, SM2S-05DF For 4DPT contact, Solder Terminal For 4DPT contact, PC Board Terminal For DPDT contact, Solder Terminal For DPDT contact, PC Board Terminal For SY4S-51, SY4S-61, SM2S-51, SM2S-61 (2 pcs/set) Time Range Indication × 0.1 S ×1 S × 0.1 M ×1 M ×1 S × 10 S ×1 M × 10 M ×1 S × 10 S ×1 M × 10 M Time Range 0.1 sec to 1 sec 0.2 sec to 10 sec 1.2 sec to 1 min 12 sec to 10 min 0.1 sec to 3 sec 0.5 sec to 30 sec 3 sec to 3 min 30 sec to 30 min 0.1 sec to 6 sec 1 sec to 60 sec 6 sec to 6 min 1 min to 60 min Contact Ratings Part No. Contact Configuration Resistive Load Inductive Load cosø=0.3 L/R=7ms Maximum Switching Voltage Maximum Switching Current Maximum Switching Frequency Resistive Load Inductive Load cosø= 0.3 L/R=7ms Minimum Applicable Load External Protection Element Accessories Item Time Ranges Electrical Mechanical GT5Y-4 GT5Y-2 4PDT DPDT 220V AC, 3A 30V DC, 3A 220V AC, 5A 30V DC, 5A 220V AC, 0.8A 30V DC, 1.5A 220V AC, 2A 30V DC, 2.5A 250V AC/125V DC 250V AC/125V DC 3A 5A (Note) 1800 operations/ hour AC: 660VA DC: 90W 1800 operations/ hour AC: 1100VA DC: 150W AC: 176VA DC: 45W AC: 440VA DC: 75W 5V DC, 10mA (reference value) 24V DC, 5mA (reference value) 5V DC, 20mA (reference value) 24V DC, 10mA (reference value) Fuse 250V 3A Fuse 250V 5A 200,000 operations minimum (220V AC, 3A) 50 million operations minimum 500,000 operations minimum (220V AC, 5A) 50 million operations minimum Note: See Operating Temperature - Maximum Switching Current Characteristics. Operating Temperature Maximum Switching Current Characteristics Check the derating curve described below when mounting more than two GT5Y-2 timers and SM2S05* sockets. Mounting Direction Derating Curve Switching Current Contact Time Ranges (4 ranges selectable) 1S/10S/1M/10M 3S/30S/3M/30M 6S/60S/6M/60M 1S/10S/1M/10M 3S/30S/3M/30M 6S/60S/6M/60M 1S/10S/1M/10M 3S/30S/3M/30M 6S/60S/6M/60M 1S/10S/1M/10M 3S/30S/3M/30M 6S/60S/6M/60M 1S/10S/1M/10M 3S/30S/3M/30M 6S/60S/6M/60M 1S/10S/1M/10M 3S/30S/3M/30M 6S/60S/6M/60M 3S/30S/3M/30M 1S/10S/1M/10M 3S/30S/3M/30M 6S/60S/6M/60M Life Operation Mode Rated Load  Allowable Contact Power EN61812-1 SM2S-05A, C Sockets 5A SM2S-05D, DF Sockets 2.5A 40°C 50°C Operating Temperature 23 GT5Y Miniature Electronic Timers General Specifications Operation Charts and Internal Connections GT5Y-oSN GT5Y-oSV GT5Y-oSF ON Delay Interval Cycle 2 (IEC60664-1) III (IEC60664-1) 200 to 240V AC (50/60Hz) 100 to 120V AC (50/60Hz) 24V DC 12V DC 170 to 264V AC (50/60Hz) 85 to 132V AC (50/60Hz) 21.6 to 26.4V DC 10.8 to 13.2V DC Rated Voltage × 20% minimum -10 to +50°C (no freezing and condensation) Note: See Operating Temperature – Maximum Switching Current Characteristics. Electrical Life Curves 110V AC Resis. Load 220V AC Resis. Load 110V AC Induc. Load 220V AC Induc. Load 100 50 1 2 3 1-9, 3-11, 2-10, 4-12 (NC) ON Delay 5-9, 7-11, 6-10, 8-12 (NO) POWER Indicator OUT Indicator 4 Set Time Terminal No. 13-14 (POWER) 1-9, 3-11, 2-10, 4-12 (NC) Interval ON 5-9, 7-11, 6-10, 8-12 (NO) POWER Indicator OUT Indicator Set Time T T Terminal No. 13-14 (POWER) 1-9, 3-11, 2-10, 4-12 (NC) Cycle 5-9, 7-11, 6-10, 8-12 (NO) POWER Indicator OUT Indicator (Internal Connections) GT5Y-4 5 1 6 2 7 3 8 4 GT5Y-2 13 5 1 8 4 13 (~/–) (~/–) (~/+) (~/+) 9 10 11 12 9 14 12 14 500 83.6 max. (Note 3) 100 50 10 5 (When using DIN rail) BAA, BAP: 87.6 max. (Note 4) 30V DC Resis. Load 30V DC Induc. Load 100V DC Resis. Load 100V DC Induc. Load 1000 0 1 2 3 4 27.5 Life (×10,000 operations) Life (× 10,000 operations) 1000 0 Set Time Terminal No. 13-14 (POWER) See Relay Sockets catalog for SM2S-05A, SM2S-05C, SM2S05D, SM2S-05DF. DC Load GT5Y-2 GT5Y-4 GT5Y-2 GT5Y-4 10 Operation GT5Y-2 5000 AC Load 500 Item -30 to +80°C (no freezing and condensation) 35 to 85% RH (no condensation) 35 to 85% RH (no condensation) 0 to 2000m (operation) Altitude 0 to 3000m (transportation) Reset Time 100 ms maximum Repeat Error ±0.2%, ±20 ms Voltage Error ±0.5%, ±20 ms Temperature Error ±3% Setting Error ±10% Insulation Resistance 100 MΩ minimum (500V DC megger) Between power and output terminals: 2000V AC, 1 minute Between contacts of different poles: 2000V AC, 1 minute Dielectric Strength Between contacts of the same pole: 1000V AC, 1 minute Vibration Resis10 to 55 Hz, amplitude 0.75 mm, 2 hours each in 3 directance tions Operating extremes: 98 m/s2, Shock Resistance Damage limits: 490 m/s2, 3 shocks each in 6 directions Degree of Protection IP40 (timer), IP20 (socket) (IEC60529) A200 1.6 VA (200V AC/60Hz) Power A100 1.4 VA (100V AC/60Hz) Consumption D24 1.0W (approx.) D12 0.9W Dimensions 27.5H × 21.0W × 58.6D mm Weight (approx.) 50g 5000 Operation Mode 5 Load Current (A) Load Current (A) 21 Dimensions 6 52.6 6.4 58.6 (When using DIN Rail Mount Socket) HoldDown Spring DIN Rail 18.5 25 GT5Y-4 See Relay Sockets catalog for SY4S-05A, SY4S-05C, SY4S-05D, SY4S-05DF. (When using DIN rail) BAA, BAP: 87.6 max. (Note 2) 83.6 max. (Note 1) Note 3: SM2S-05A: 83.6 max., SM2S-05C: 83.6 max., SM2S-05D: 88.6 max., SM2S-05DF: 88.6 max. Note 4: SM2S-05A: 87.8 max., SM2S-05C: 87.8 max., SM2S-05DN: 92.8 max., SY4S-05DF: 92.8 max. GT5Y-4 and SU4S-11L, GT5Y-2 and SU2S-11L 27.5 (When using DIN rail) BAA, BAP: 94.1 max. 90.6 max. 52.6 58.6 6.4 HoldDown Spring DIN Rail 27.5 6 18.5 25 3 21 Note 1: SY4S-05A: 83.6 max., SY4S-05C: 83.6 max., SY4S-05D: 88.6 max., SY4S-05DF: 88.6 max. Note 2: SY4S-05A: 87.8 max., SY4S-05C: 87.8 max., SY4S-05D: 92.8 max., SY4S-05DF: 92.8 max. 24 3 Model Operation Pollution Degree Overvoltage Category A200 Rated A100 Operational D24 Voltage D12 A200 A100 Voltage Range D24 D12 Reset Voltage Operating Temperature Storage/Transportation Temperature Operating Humidity Storage Humidity 21 6 52.6 58.6 6.4 32 35.5 Applicable hold-down spring: SFA-202 GT5P Miniature Electronic Timers Economic Efficiency Focused Delayed Output SPDT/5A ••Three operation modes: ON Delay, Cycle, and One Shot ••Repeat error: ±0.2% ±10 ms maximum ••Complies with safety standards UL recognized, CSA certified, TÜV approved, EN compliant File No. or Organization UL508 UL/c-UL recognized File No. E55996 CSA C22.2 No.14 CSA File No. LR66809 EN61812-1 EU Low Voltage Directive Package Quantity: 1 Operation Mode ON Delay Cycle One Shot Contact SPDT SPDT SPDT Output 24V DC/ 120V AC, 5A 240V AC, 3A 24V DC/ 120V AC, 5A 240V AC, 3A 24V DC/ 120V AC, 5A 240V AC, 3A Time Range 3S 10S 30S 60S 3M 6M 10M 1S 6S 10S 30S 60S 3M 6M 10M 1S 6S 10S 60S 6M 10M 10S 30S 60S 10M 3S 10S 3S 10S 3S 10S 3S 10S 3S 3S 10S 3S 10S Operating Voltage 100 to 120V AC 200 to 240V AC 24V AC/DC 12V DC 100 to 120V AC 200 to 240V AC 24V AC/DC 12V DC 100 to 120V AC 200 to 240V AC 24V AC/DC Part No. (Ordering No.) GT5P-N3SA100 GT5P-N10SA100 GT5P-N30SA100 GT5P-N60SA100 GT5P-N3MA100 GT5P-N6MA100 GT5P-N10MA100 GT5P-N1SA200 GT5P-N6SA200 GT5P-N10SA200 GT5P-N30SA200 GT5P-N60SA200 GT5P-N3MA200 GT5P-N6MA200 GT5P-N10MA200 GT5P-N1SAD24 GT5P-N6SAD24 GT5P-N10SAD24 GT5P-N60SAD24 GT5P-N6MAD24 GT5P-N10MAD24 GT5P-N10SD12 GT5P-N30SD12 GT5P-N60SD12 GT5P-N10MD12 GT5P-F3SA100 GT5P-F10SA100 GT5P-F3SA200 GT5P-F10SA200 GT5P-F3SAD24 GT5P-F10SAD24 GT5P-F3SD12 GT5P-F10SD12 GT5P-P3SA100 GT5P-P3SA200 GT5P-P10SA200 GT5P-P3SAD24 GT5P-P10SAD24 Time Ranges Code 1S 3S 6S 10S 30S 60S 3M 6M 10M Time Range 0.1 sec to 1 sec 0.1 sec to 3 sec 0.1 sec to 6 sec 0.2 sec to 10 sec 0.5 sec to 30 sec 1 sec to 60 sec 3 sec to 3 min 6 sec to 6 min 10 sec to 10 min Contact Ratings Contact Configuration Maximum Switching Voltage Maximum Switching Current Maximum Switching Power Rated Load Mark Life Applicable Standards Resistive Load Inductive Load cosø = 0.3 - 0.4 L/R = 15 ms Electrical Mechanical SPDT 250V AC, 150V DC 5A AC: 960VA DC: 120W 120V AC / 24V DC, 5A 240V AC, 3A 240V AC, 0.8A 120V AC, 1.4A 24V DC, 1.7A 100,000 operations minimum (rated resistive load) 20,000,000 operations minimum Minimum Applicable Load: 5V DC 10 mA (reference value) Note: S and M of time range indicate second and minute respectively. Accessories Item DIN Rail Mount Socket Socket Hold-Down Spring Panel Mount Socket w/Solder Terminals w/Wire Wrap Terminals Part No. SR2P-06A SR2P-05A SR2P-05C SFA-202 SFA-203 SR2P-511 SR2P-70 Ordering No. SR2P-06A SR2P-05A SR2P-05C SFA-202PN20 SFA-203PN20 SR2P-511 SR2P-70 Package Quantity 1 1 1 10 sets (20 pcs) 10 sets (20 pcs) 1 1 Remarks UL/CSA/TÜV For SR2P-06A (2 pcs/set) For SR2P-05A (2 pcs/set) UL/CSA 25 GT5P Miniature Electronic Timers General Specifications Model Operation Pollution Degree A200 Rated A100 Operational AD24 Voltage D12 A200 A100 Voltage Range AD24 D12 Operating Temperature Storage Temperature Operating Humidity Storage Humidity Operation Charts and Internal Connections GT5P-N GT5P-F GT5P-P ON Delay Cycle One Shot 2 (IEC60664-1) 200 to 240V AC (50/60Hz) 100 to 120V AC (50/60Hz) 24V AC (50Hz/60Hz)/24V DC 12V DC 170 to 264V AC (50/60Hz) 85 to 132V AC (50/60Hz) 20.4 to 26.4V AC (50/60Hz)/21.6 to 26.4V DC 10.8 to 13.2V DC Operation Mode Life ( ×10,000 operations) 6-8 (NO) POWER Indicator OUT Indicator 6-8 (NO) POWER Indicator OUT Indicator Terminal No. 13-14 (POWER) 5-8 (NC) One Shot 6-8 (NO) POWER Indicator OUT Indicator (Internal Connections) ON Delay (GT5P-N) 4 7 5 3 2 1 1 2 3 4 Load Current (A) Dimensions (When using DIN Rail Mount Socket) SR2P-05A For SR2P-05C, see Relay Sockets catalog. Note 1: SR2P-05C: 99.5 max. Note 2: SR2P-05C: 103.5 max. 5 Cycle (GT5P-F) 4 5 5 3 6 3 6 2 7 2 7 1 8 (~/+) POWER 24V DC R esis. load 120V AC R esis. 240V load AC R esis . loa d 24V DC 120 24 τ VA =1 0V 5m Cc AC os s ø= co sø 0.4 =0 .4 50ms minimum 3-4 (Start Input) (~/–) 10 0 5-8 (NC) Cycle 1 20 Set Time T T Terminal No. 2-7 (POWER) Electrical Life Curves 30 Set Time 5-8 (NC) On Delay –30 to +70°C (no freezing) 100 70 50 Operation Terminal No. 2-7 (POWER) –10 to +50°C (no freezing) 35 to 85% RH (no condensation) 30 to 85% RH (no condensation) 0 to 2000m (operation) Altitude 0 to 3000m (transportation) Reset Time 100 ms maximum Repeat Error ±0.2%, ±10 ms Voltage Error ±0.5%, ±20 ms Temperature Error ±3% Setting Error ±10% Insulation Resistance 100 MΩ minimum (500V DC megger) Between power and output terminals: 2000V AC, 1 minute Between contacts of different poles: 2000V AC, 1 minDielectric Strength ute Between contacts of the same pole: 750V AC, 1 minute 10 to 55Hz, amplitude 0.75 mm, 2 hours each in 3 Vibration Resistance directions Operating extremes: 98 m/s2, Shock Resistance Damage limits: 490 m/s2 A200 3.9 VA (60Hz) 5.6 VA (60Hz) A100 2.3 VA (60Hz) 2.9 VA (60Hz) Power Consump1.2 VA (60Hz)/ tion (approx.) AD24 1.3 VA (60Hz)/0.5W 0.5W D12 0.6W 0.6W Dimensions 36H × 29W × 81.5D mm Weight (approx.) 49g 26 Item SR2P-06B START EXTERNAL CONTROL SIGNAL 8 (~/–) (~/+) POWER One Shot (GT5P-P) 4 5 1 8 6 3 2 7 (~/–) (~/+) POWER GT5Y/GT5P Miniature Electronic Timers Dimensions / Mounting Hole Layout (for Panel/PC Board Mount Socket) 1. GT5Y-4 Panel Mount Socket (SY4S-51) 2. GT5Y-2 Panel Mount Socket (SM2S-51) PC Board Mount Socket (SY4S-61) PC Board Mount Socket (SM2S-61) 3. GT5P Solder Terminal (SR2P-511) Wire Wrap Terminal (SR2P-70) Installation of Hold-Down Springs DIN Rail Mount Socket Panel/PC Board Mount Socket The SFA-302 Hold-Down Springs can be installed to the SY4S-51, SY4S-61, SM2S-51, and SM2S-61 sockets. Recommended Tightening Torque and Terminal Screw Timer Applicable Socket Terminal Screw Recommended Tightening Torque GT5Y SY4S-05 SM2S-05 M3 0.6 to 1.0 N·m Hold-down springs cannot be installed to SR2P-511 and SR2P-70 panel mount sockets. Note: Once installed into sockets, the hold-down springs cannot be removed. Recommended Tightening Torque and Terminal Screw Timer Applicable Socket Terminal Screw Recommended Tightening Torque GT5P SR2P-05 SR2P-06 M3 1.0 to 1.3 N·m 27 GT5Y/GT5P Miniature Electronic Timers Installation/Removal of Hold-Down Springs 28 Installation/Removal of Hold-Down Springs GT5Y/GT5P Miniature Electronic Timers Safety Precautions ••Be sure to turn off power before mounting, removal, wiring, maintenance and inspection. Otherwise, electric shock or fire could occur. ••Be sure to use timers within rated specification values. Otherwise, electric shock or fire may occur. ••Be sure to use wires to meet voltage and current requirements and tighten M3.5 terminal screws to a tightening torque of 1.0 to 1.3 N·m. Be sure to solder the terminals correctly. Loose terminal screws or incomplete soldering may cause abnormal heat and fire. Instructions Time Range Setting Contact Protection The time range is calibrated at its maximum time scale, therefore it is desirable to use the timer at a setting as close to its maximum time scale as possible for accurate time delay. For a more accurate time delay, adjust the control knob by measuring the operating time with a watch before application. On the GT5Y timers, a desired time range can be selected using the time range selectors on the side surface. Turn the multiplier and time unit selectors using a flat screwdriver until they click. Switching an inductive load generates a counter-electromotive force in the coil. The counter emf will cause arcing, which may shorten the contact life. Application of a protection circuit is recommended for contact protection. Rest Time When turning power off after time-out, allow a rest time of 0.1 sec, and during operation, 1 sec at least. Control knob Power Time range indication window Since DC types are designed to operate on DC power containing 10% or less ripple, insert a smoothing circuit when using a rectified AC power to operate DC type timers. Time range selector Continuous Energizing Continuous energizing for a long period of time may damage the electrical characteristics of the timer because of internal heating. Use an additional relay to the output circuit and refrain from continuous energizing of the timer. Timing Accuracy Timing accuracies are calculated from the following formulas: Repeat Error =± 1 Max. measured value - Min. measured value × 100 (%) × 2 Maximum scale value Voltage Error =± Tv - Tr Tv: Average of measured values at voltage V × 100 (%) Tr Tr: Average of measured values at the raged voltage Temperature Error =± Tt - T20 Tt: Average of measured values at t°C × 100 (%) T20 T20: Average of measured values at 20°C Setting Error = Average of measured values - Set value × 100 (%) Maximum scale value Use of External Input (GT5P-P Only) 1. Do not apply voltage to external input terminals 3 and 4. Be sure not to connect external inputs to other terminals because the internal circuit may be damaged. 2. Use reliable mechanical contacts capable of switching approximately 22V DC, 1 mA to close input terminals 3 and 4. (Closed: 1 kΩ maximum, Open: 100 kΩ minimum) The input terminals should not be connected to a ground wire of other devices. 3. Do not install input lines in parallel with high-voltage or motor lines. Use shielded wires or separate conduit for input lines, and make the input lines as short as possible. Load Current The rated current of the contact (or control output) should not be exceeded. Especially for inductive, capacitive, and incandescent lamp loads, the inrush current as large as a few to several tens times the rated current may cause welded contacts and other troubles. The amount of inrush current as well as steady-state current must be taken into consideration. Dielectric Strength Test When performing an insulation resistance or dielectric strength test on control panels containing timers, make sure that the dielectric strength of the timer is not exceeded. In case the dielectric strength is exceeded, remove the timers from the panels. Operating Environment Temperature and Humidity Use the timer within the operating temperature and operating humidity ranges and prevent freezing and condensation. After storing below the operation temperature, leave the timer at room temperature for a sufficient period of time before use. Environment Prevent a corrosive gas such as sulfurous or ammonia gas, organic solvents (alcohol, benzine, thinner, etc.), strong alkaline substances or strong acids from touching to the timer, and do not use the timer in such an environment. Keep the timer from water splashes or steam. Vibration and Shock Since excessive vibrations or shocks cause the output contacts to open, the timer should be used within the operating extremes of vibration and shock resistance. Use of hold-down springs is recommended for secure mounting on sockets. Others •• Use a mechanical-contact switch or relay to supply power to the time. •• When driving the timer using a solid-state output device such as two-wire proximity switch, photoelectric switch or solidstate relay directly, malfunction may be caused by a leakage current from the solid-state device. Be sure to check thoroughly before using. •• Since AC types (such as A100 and A200) comprise a capacitive load, the SSR dielectric strength should be two or more times as large as the power voltage when switching the timer power using an SSR. •• To make a sequence circuit by connecting timer and relay, check the timer operation sufficiently in consideration of the reset time of the timer. 29 GE1A Series Electronic Timers Two different time ranges to cover a wide time range ••Large clear knob for easy time range setting ••ON Delay function ••Highly precise time control ••Instant monitoring of operation status by LED indicators. Applicable Standards UL508 CSA C22.2 No. 14 Mark File No. or Organization UL/c-UL Listed File No. E204716 EU Low Voltage Directive EN61812-1 TÜV Product Service Contact Ratings Contact Ratings Electrical Life Mechanical Life Time Ranges Time Range Code 240V AC/5A, 24V DC/5A (resistive load) 100,000 operations minimum (resistive load) GE1A-B: 10,00,000 operations minimum GE1A-C: 5,000,000 operations minimum 10H 10H 30H 30H Time Range 10H (0.1 sec. to 10 hours) 30H (0.3 sec. to 30 hours) Rated Voltage 220 to 240V AC 200 to 220V AC 110 to 120V AC 100 to 110V AC 24V AC/DC 220 to 240V AC 200 to 220V AC 110 to 120V AC 100 to 110V AC 24V AC/DC Magnification 1S 10S 1M 10M 1H 10H 1S 10S 1M 10M 1H 10H Time Range 0.1 sec. to 1 sec. 1 sec. to 10 sec. 0.1 min. to 1 min. 1 min. to 10 min. 0.1 hour to 1 hour 1 hour to 10 hours 0.3 sec. to 3 sec. 3 sec. to 30 sec. 0.3 min. to 3 min. 3 min. to 30 min. 0.3 hour to 3 hour 3 hour to 30 hours Part No. Contact Delayed SPDT + Instantaneous SPDT GE1A-B10HA220 GE1A-B10HA200 GE1A-B10HA110 GE1A-B10HA100 GE1A-B10HAD24 GE1A-B30HA220 GE1A-B30HA200 GE1A-B30HA110 GE1A-B30HA100 GE1A-B30HAD24 Delayed DPDT GE1A-C10HA220 GE1A-C10HA200 GE1A-C10HA110 GE1A-C10HA100 GE1A-C10HAD24 GE1A-C30HA220 GE1A-C30HA200 GE1A-C30HA110 GE1A-C30HA100 GE1A-C30HAD24 Part No. Development GE1A Rated Voltage Code Time Range Code Contact Code 30 A220: 220 to 240V AC A200: 200 to 220V AC A110: 110 to 120V AC A100: 100 to 110V AC AD24: 24V AC/24V DC 10H: 0.1S to 10H 30H: 0.3S to 30H B: Instantenous SPDT + Delayed SPDT C: Delayed DPDT GE1A Series Electronic Timers Specifications Model Operation Mode Time Range Rated Operational Voltage Voltage Tolerance Operating Temperature Storage Temperature Operating Humidity Repeat Error Voltage Error Temperature Error Setting Error Insulation Resistance Between power and output terminals Dielectric Strength Between contact circuits Between contact circuits (opposite pole) Vibration Resistance Damage limits Shock Resistance Operating extremes 220V AC 200V AC 110V AC 100V AC 24V AC 24V DC Power Consumption Weight (Approx.) GE1A-B GE1A-C ON Delay 0.1 second to 30 hours 220V to 240V AC, 200 to 220V AC, 110V to 120V AC, 100 to 110V AC, 24V AC/DC AC: 85 to 110%, DC: 90 to 110% –10 to +55°C (without freezing) –30 to +70°C (without freezing) 35 to 85% RH (without condensation) ±0.2% ±10 ms maximum ±0.5% ±10 ms maximum ±3% maximum ±10% maximum 100 MΩ minimum (500V DC megger) 2,000V AC, 1 minute 750V AC, 1 minute 2,000V AC, 1 minute Damage limits: Amplitude 0.75 mm, 10 to 55 Hz Operating extremes: Amplitude 0.5 mm, 10 to 55 Hz Panel mount: 490 m/s2 (approx. 50G) Surface mount: 249 m/s2 (approx. 25G) 98 m/s2 (approx. 10G) 7.7 VA (60 Hz), 6.6 VA (50 Hz) 8.0 VA (60 Hz), 7.0 VA (50 Hz) 7.0 VA (60 Hz), 6.0 VA (50 Hz) 8.0 VA (60 Hz), 7.0 VA (50 Hz) 3.8 VA (60 Hz), 3.3 VA (50 Hz) 3.5 VA (60 Hz), 3.0 VA (50 Hz) 3.5 VA (60 Hz), 3.0 VA (50 Hz) 3.5 VA (60 Hz), 3.0 VA (50 Hz) 1.6 VA 2.0 VA 1.0W 0.8W 101g 95g GE1A-B Item Power Delayed Contact Instantaneous Contact LED Indicator GE1A-C Terminal No. Operation Item Preset Time 2-7 (Power) Power 5-8 (NC) Delayed Contact 6-8 (NO) 1-4 (NC) LED Indicator 1-3 (NO) Terminal No. Operation Preset Time 2-7 (Power) 1-4, 5-8 (NC) 1-3, 6-8 (NO) POWER OUT POWER OUT Internal Connections GE1A-B 3 2 4 1 5 8 GE1A-C 6 3 7 2 (~/+) (~/−) 4 5 1 8 (~/–) 7 (~/+) Panel Cut-out 35 48 10.2 6 14.2 10.9 +0.5 45 –0 +0.5 63.8 48 45 –0 Dimensions 6 31 GE1A Series Electronic Timers Applicable Sockets SR2P-05A (not UL/c-UL listed) When using BAA/BAP: 113 max. 63.8 29 4.5 max. ø4.2 hole 3 16.5 29 DIN Rail (BAA/BAP) 8 20 2-ø4.2 Mounting Holes (or M4 Tapped Holes) M3.5 Terminal Screw 52 109 max. Terminal Arrangement 36 8 DIN Rail (BAA/BAP) 5 min. 5 4 6 3 7 2 8 1 (Top View) 7.9 max. ø3.6 min. 28.5 SR2P-06A When using BAA/BAP: 107 max. 40 Terminal Arrangement M3.5 Terminal Screw 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 60 103 max. 63.8 ø4.2 hole 33 1 5.0 max. 8 1 2 44.6 30.4 44.6 17 3 4 5 6 2 1 8 7 3.5 max. 5.6 min. ø3.6 min. 6.9 max. 7 9.8×3 All dimensions in mm. Shape Part No. GE9Z-AD Dust Cover GE9Z-C48 www.idec.com Head Office 6-64, Nishi-Miyahara-2-Chome, Yodogawa-ku, Osaka 532-0004, Japan Tel: +1-408-747-0550 Tel: +49-40-25 30 54 - 0 Tel: +65-6746-1155 Tel: +66-2-392-9765 Tel: +61-3-8523-5900 Tel: +886-2-2698-3929 opencontact@idec.com service@eu.idec.com info@sg.idec.com sales@th.idec.com sales@au.idec.com service@tw.idec.com Specifications and other descriptions in this brochure are subject to change without notice. 2018 IDEC Corporation, All Rights Reserved. EP1428-8 AUGUST 2018 7 7.9 max. Panel Mount Adapter IDEC Corporation APEM GmbH IDEC Izumi Asia Pte. Ltd. IDEC Asia (Thailand) Co., Ltd IDEC Australia Pty. Ltd. IDEC Taiwan Corporation 5 min. (Top View) Accessories USA Germany Singapore Thailand Australia Taiwan 3 8-M3.5 Terminal Screws Panel Thickness: 0.8 to 5 Name 4 ø3.6 min. SR6P-M08G 81 max. 5 33 18 22 6 Hong Kong China/Shanghai China/Shenzhen China/Beijing Japan IDEC Izumi (H.K.) Co., Ltd. IDEC (Shanghai) Corporation IDEC (Shenzhen) Corporation IDEC (Beijing) Corporation IDEC Corporation Tel: +852-2803-8989 Tel: +86-21-6135-1515 Tel: +86-755-8356-2977 Tel: +86-10-6581-6131 Tel: +81-6-6398-2527 info@hk.idec.com idec@cn.idec.com idec@cn.idec.com idec@cn.idec.com marketing@idec.co.jp
GT3A-3AF20 价格&库存
很抱歉,暂时无法提供与“GT3A-3AF20”相匹配的价格&库存,您可以联系我们找货
