GT5Y-2SN3D24
GT5Y-2SN3D24
    IDEC(日本和泉)
    开 - 延迟 延时继电器 DPDT(2 Form C) 0.1 秒 ~ 30 分 延时 5A @ 220VAC/30VDC 可插
GT5Y-2SN3D24 数据手册
Timers GT5P Switches & Pilot Lights GT5P Series — ON Delay Timers Key features: UL Recognized File No. E55996 CSA Certified File No. LR66809 Signaling Lights • SPDT, 5A contacts • 8-pin, octal base • 9 time ranges • Repeat error ±0.2% maximum • Control settings by hand or screwdriver • Power ON and timing out LED indicators • Uses the same sockets and hold down clips as IDEC’s RR2P 8-pin relays Specifications Voltage Tolerance AC type: ±15% DC type: ±10% (ripple 10% maximum) Resistive load 120V AC/24V DC, 5A 240V AC, 3A Inductive load 240V AC, 0.8A 120V AC, 1.4A 24V DC, 1.7A Contact Rating 960VA AC 120W DC Contact Form SPDT Voltage 250V AC, 150V DC Repeat Error ±0.2% ±10msec Voltage Error ±0.5% ±10msec Temperature Error ±3% maximum (over –10 to 50°C, reference temperature 20°C) Setting Error ±10% maximum Reset Time When turning power off after time up: 0.1 sec maximum When turning power off before time up: 1 sec maximum Insulation Resistance 100MΩ minimum Dielectric Strength 2000V AC, 1 minute (except between contacts of the same pole) Vibration Resistance 100N (approximate 10G) Shock Resistance Operating extremes: 100N (approximate 10G) Damage limits: 500N (approximate 50G) Power Consumption 100V AC type: 1.5VA (at 50Hz) 200V AC type: 1.6VA (at 50Hz) 24V DC type: 0.9W Electrical Life 100,000 operations minimum (at rated load) Mechanical Life 20,000,000 operations minimum Operating Temperature –10 to +50°C Operating Humidity 45 to 85% RH Timers Allowable Contact Power (resistive load) Relays & Sockets Rated Operating Voltage 100 to 120V AC (50/60Hz) 200 to 240V AC (50/60Hz) 24V AC/DC 12V DC Contactors Terminal Blocks Circuit Breakers 1. Inductive load (reference), cos ø =0.3 to 0.4 or L/R=15msec. 2. Minimum applicable load: 5VDC/10mA (reference). 1705151136 800-262-IDEC (4332) • USA & Canada 977 Timers Part Numbering List Mode of Operation Contact Output Rated Voltage 100 to 120V AC Relays & Sockets Signaling Lights Switches & Pilot Lights GT5P 200 to 240V AC SPDT Timers ON-Delay 24V DC/120V AC, 5A 240V AC, 3A Contactors 24V AC/DC Complete Part No. 1S — 3S GT5P-N3SA100 6S — 10S GT5P-N10SA100 30S GT5P-N30SA100 60S GT5P-N60SA100 3M GT5P-N3MA100 6M GT5P-N6MA100 10M GT5P-N10MA100 1S GT5P-N1SA200 3S — 6S GT5P-N6SA200 10S GT5P-N10SA200 30S GT5P-N30SA200 60S GT5P-N60SA200 3M GT5P-N3MA200 6M GT5P-N6MA200 10M GT5P-N10MA200 1S GT5P-N1SAD24 3S — 6S GT5P-N6SAD24 10S GT5P-N10SAD24 30S — 60S GT5P-N60SAD24 3M — 6M GT5P-N6MAD24 10M GT5P-N10MAD24 1S — 3S — 6S — 10S GT5P-N10SD12 30S GT5P-N30SD12 60S GT5P-N60SD12 3M — 6M — 10M GT5P-N10MD12 For sockets and accessories, see page 941. Circuit Breakers Terminal Blocks 12V DC Time Range 978 www.IDEC.com 1705151136 Timers GT5P Switches & Pilot Lights Timing Diagram/Schematic/Electrical Life Curves SPDT Operation Mode Signaling Lights Do not apply voltage to terminals 1, 3, and 4. Item Set Time Power ON-Delay Delayed Contact Indicator Terminal Number Operation 2 - 7 (8p) 5 - 8 (8p) (NC) 6 - 8 (8p) (NO) POWER Relays & Sockets OUT Electrical Life Curves Timers Contactors Terminal Blocks Circuit Breakers 1705151136 800-262-IDEC (4332) • USA & Canada 979 Timers GT5P Switches & Pilot Lights Accessories Mounting Mounting Accessories and Sockets Style Signaling Lights 8-Pin Screw Terminal (dual tier) Use with Timers Part No. GT5P SR2P-05 Appearance 8-Pin Fingersafe Socket GT5P SR2P-05C 8-Pin Screw Terminal GT5P SR2P-06 — BNDN1000 DIN Rail/ Surface Mounting Accessories DIN Mounting Rail Length 1000mm SFA-202 Contactors Part Numbers: Mounting Accessories and Sockets Terminal Blocks Part No. SFA-203 Timers Relays & Sockets Appearance Applicable Hold-Down Springs Mounting Accessories 8-Pin Solder Terminal SR2P-51 Installation of Hold-Down Springs DIN Rail Mount Socket Insert the springs into the outer slots with the projections facing inside. Insert the springs into the slots. Socket SR2P-05 Applicable Hold-Down Springs SFA-402 Panel Mount Socket Hold-down Spring SFA-402 Insert 8-pin Socket SR2P-51 Hold-down Spring (sold separately) SFA-203 (use two springs) Hold-down Spring (sold separately) SFA-202 (use two springs) Circuit Breakers Socket SR2P-06 980 www.IDEC.com 1705151136 Timers GT5P Switches & Pilot Lights Dimensions GT5P Timer, 8-Pin with SR2P-05 Signaling Lights GT5P Timer, 8-Pin with SR2P-06 Relays & Sockets Timers Contactors Terminal Blocks Circuit Breakers 1705151136 800-262-IDEC (4332) • USA & Canada 981 Timers Signaling Lights Switches & Pilot Lights GT5Y GT5Y Series — ON Delay Timers Key features: • 4PDT, 3A or DPDT, 5A contacts • 4 time ranges • Repeat error ±0.2% maximum • Control settings by hand or screwdriver • Power ON and timing out LED indicators • Uses the same sockets and hold-down clips as IDEC’s RY4S and RU series relays UL, c-UL Listed File No. E55996 Specifications Relays & Sockets GT5Y-2 100 to 120V AC (50/60Hz) 200 to 240V AC (50/60Hz) 24V DC 24V AC 12V DC Rated Operating Voltage Contact Form DPDT 4PDT Resistive Load 220V AC, 5A 30V DC, 5A 220V AC, 3A 30V DC, 3A Inductive Load 220V AC, 2A 30V DC, 2.5A 220V AC, 0.8A 30V DC, 1.5A Resistive Load 1100VA AC 150W DC 660VA AC 90W DC Inductive Load Cos ø = 0.3 L/R = 7msec 440VA AC 75W DC 176VA AC 45W DC Timers Rated Load Allowable Contact Power Allowable Voltage Allowable Current Temperature Error GT5Y-4 250V AC, 125V DC 5A 3A ±3% maximum (over –10 to 50°C, reference temperature 20°C) Contactors Setting Error Reset Time Vibration Resistance Shock Resistance Terminal Blocks When turning power off after time up: 0.1 second maximum When turning power off before time up: 1 second maximum Insulation Resistance Dielectric Strength Power Consumption Electrical Life Mechanical Life Circuit Breakers ±10% maximum 100MΩ minimum 2,000V AC, 1 minute (except between contacts of the same pole) 100N (approximate 10G) Operating extremes: 100N (approximate 10G) Damage limits: 500N (approximate 50G) 100V AC type: 1.5VA (at 50Hz) 200V AC type: 1.6VA (at 50Hz) 24V DC type: 0.9W 500,000 operations minimum (220V AC, 5A) 200,000 operations minimum (110V AC, 3A) 50,000,000 operations minimum Operating Temperature –10 to +50°C Operating Humidity 45 to 85% RH 1. Minimum applicable load: GT5Y-2: 5V DC, 20mA (reference value); GT5Y-4: 5V DC, 10mA (reference value). 2. Inductive load: cos ø =0.3, L/R=7msec. 982 www.IDEC.com 1705151136 Timers GT5Y Mode of Operation Contact Output Rated Voltage 100 to 120V AC 200 to 240V AC 12V DC 24V DC ON-Delay 100 to 120V AC 200 to 240V AC 220V AC/30V DC, 3A 12V DC 24V DC GT5Y-2SN3A100 6S/60S/6M/60M GT5Y-2SN6A100 1S/10S/1M/10M GT5Y-2SN1A200 3S/30S/3M/30M GT5Y-2SN3A200 6S/60S/6M/60M GT5Y-2SN6A200 1S/10S/1M/10M GT5Y-2SN1D12 3S/30S/3M/30M GT5Y-2SN3D12 6S/60S/6M/60M GT5Y-2SN6D12 1S/10S/1M/10M GT5Y-2SN1D24 3S/30S/3M/30M GT5Y-2SN3D24 6S/60S/6M/60M GT5Y-2SN6D24 1S/10S/1M/10M GT5Y-2SN1A24 3S/30S/3M/30M GT5Y-2SN3A24 6S/60S/6M/60M GT5Y-2SN6A24 1S/10S/1M/10M GT5Y-4SN1A100 3S/30S/3M/30M GT5Y-4SN3A100 6S/60S/6M/60M GT5Y-4SN6A100 1S/10S/1M/10M GT5Y-4SN1A200 3S/30S/3M/30M GT5Y-4SN3A200 6S/60S/6M/60M GT5Y-4SN6A200 1S/10S/1M/10M — 3S/30S/3M/30M GT5Y-4SN3D12 6S/60S/6M/60M — 1S/10S/1M/10M GT5Y-4SN1D24 3S/30S/3M/30M GT5Y-4SN3D24 6S/60S/6M/60M GT5Y-4SN6D24 1S/10S/1M/10M GT5Y-4SN1A24 3S/30S/3M/30M GT5Y-4SN3A24 6S/60S/6M/60M GT5Y-4SN6A24 Contactors 24V AC 3S/30S/3M/30M Timers 4PDT GT5Y-2SN1A100 Relays & Sockets 24V AC Complete Part No. Signaling Lights DPDT 220V AC/ 30V DC, 5A Time Range 1S/10S/1M/10M Switches & Pilot Lights Part Numbering List For sockets and accessories, see page 941. Timing Ranges Code Scale Time Range S 0.1 second to 1 second x1 S 0.2 second to 10 seconds x 0.1 M 1.2 seconds to 1 minute 10M x1 M 12 seconds to 10 minutes 3S x1 S 0.1 second to 3 seconds x 10 S 0.5 second to 30 seconds x1 M 3 seconds to 3 minutes 30M x 10 M 30 seconds to 30 minutes 6S x1 S 0.1 second to 6 seconds 60S x 10 S 1 second to 60 seconds x1 M 6 seconds to 6 minutes x 10 M 1 minute to 60 minutes 10S 1M 30S 3M 6M 60M 1705151136 0 to 10 0 to 3 0 to 6 800-262-IDEC (4332) • USA & Canada Circuit Breakers x 0.1 Terminal Blocks 1S Time Range Indication 983 Timers Signaling Lights Switches & Pilot Lights GT5Y Timing Diagram/Schematics/Electrical Life Curves GT5Y-2 GT5Y-4 DPDT 4PDT Internal Connections (bottom view) Relays & Sockets Item Set Time Operation Mode: ON-Delay Terminal Number Power 13 - 14 Delayed Contact 1 - 9, 2 - 10 3 - 11, 4 - 12 5 - 9, 6 - 10 7 - 11, 8 - 12 Operation (NC) (NO) POWER Indicator OUT For an explanation of timing modes, see page page 940. Electrical Life Curves Timers 5000 AC Load Contactors Life (× 10,000 operations) GT5Y-2 GT5Y-4 1000 110V AC Resis. Load 220V AC Resis. Load 110V AC Induc. Load 220V AC Induc. Load 500 100 50 10 1 0 2 3 4 5 Load Current (A) Terminal Blocks Life (× 10,000 operations) 5000 DC Load GT5Y-2 GT5Y-4 30V DC Resis. Load 30V DC Induc. Load 100V DC Resis. Load 100V DC Induc. Load 1000 500 100 50 10 0 1 2 3 4 5 Circuit Breakers Load Current (A) 984 www.IDEC.com 1705151136 Timers GT5Y Switches & Pilot Lights Accessories2 DIN Rail Mounting Accessories DIN Rail/Surface Mount Sockets and Hold-Down Springs DIN Rail Mount Socket Style Appearance 14-Blade Screw Terminal Applicable Hold-Down Springs Part No. Appearance Part No. SY4S-05 Signaling Lights SFA-202 SY4S-05C DIN Mounting Rail Length 1000mm BNDN1000 Relays & Sockets 14-Blade Screw Terminal (fingersafe) Panel Mounting Accessories Part Numbers: Panel Mount Socket and Hold-Down Springs Panel Mount Socket Appearance 14-Blade Solder Terminal Applicable Hold-Down Springs Part No. Appearance SY4S-51 Part No. Timers Style SFA-302 PCB Mount Socket Style Appearance Contactors PCB Mounting Accessories Part Numbers: PCB Mount Sockets with Applicable Hold-Down Springs Applicable Hold-Down Springs Part No. Appearance Part No. SY4S-61 SFA-302 14 Blade, PCB Terminal SY4S-62 SY4S-02F1 Terminal Blocks 14 Blade, PCB Terminal Circuit Breakers 1705151136 800-262-IDEC (4332) • USA & Canada 985
GT5Y-2SN3D24
PDF文件内容分析如下: 1. 物料型号:型号为“TP4056”,属于升压式线性充电IC。
2. 器件简介:TP4056是一款用于单节锂离子/锂聚合物电池的充电管理IC,具有充电电流可调、充电状态指示、输入防反接、温度监控等特性。
3. 引脚分配:共有5个引脚,分别是输入、输出、地、充电状态指示和充电电流设定。
4. 参数特性:包括输入电压范围、输出电压范围、充电电流、最大输入电流等详细参数。
5. 功能详解:包括充电控制、输入电流限制、温度监控和充电状态指示等功能的详细说明。
6. 应用信息:适用于便携式电子设备,如手机、蓝牙耳机、移动电源等。
7. 封装信息:通常采用SOT89-5封装。
GT5Y-2SN3D24 价格&库存
很抱歉,暂时无法提供与“GT5Y-2SN3D24”相匹配的价格&库存,您可以联系我们找货
GT5Y-2SN3D24
  • 1+448.570171+58.03453
  • 10+369.5559710+47.81193
  • 25+348.3696525+45.07092
  • 50+335.1732650+43.36361
  • 100+324.01688100+41.92024
  • 250+311.87390250+40.34922
库存:75
