HG1P-ST32ZBFH-B0
HG1P-ST32ZBFH-B0
    IDEC(日本和泉)
    人机接口 (HMI) 操作面板 4.3" 颜色
HG1P-ST32ZBFH-B0 数据手册
Operator Interface Hand-held Model HG1P Lightweight and robust For optimal usability Functional and user-friendly New solution from IDEC 1 2 Lightweight and compact, weighs only 500g Robust design Lightweight hand-held structure enables stress-free operation even when the worker needs to move around. Designed to withstand a drop test from a predictable height during hand-held operation or storage. Prevents damage even when dropped accidentally. * Not including cable. * Not resistant to excessive shock. ht Lightweig 1.5m Heavy 3 4 Ergonomic design ideal for long and fatigue-free operation Starts up in only 1.5 seconds! Designed to fit comfortably in the hand by its ergonomic design. Reduces wait time at start-up. 5 Wall mount bracket available when the HG1P is not used 6 Low power consumption, only 3W! The size of the power source can be reduced, achieving a more compact system. Approx. –25% 4W max. (Conventional product) 2 3W max. (HG1P) HG1P Operator Interface Hand-held Model 7 8 Clear and high resolution 4.3 inch display Multilingual Equipped with a high resolution 4.3 inch TFT color LCD touch panel. Clear and informative display enables intuitive operation. Several languages can be selected and changed easily with a button. START 9 開始 10 Easy maintenance with a USB memory Removable cable Project data can be saved on a USB memory inserted in the device. No need to use a PC as data inside the HG1P can be updated via USB. Also, teaching parameter data can be saved on USB memory and imported. If damaged, the connection cable can easily be detached and repaired. Saves downtime and cost. USB 11 Flexible software enables easy designing of the screen Programming Software Included in Automation Organizer The easy-to-use work space enables the structure of the project to be easily understood and configuration of operating settings simple, allowing a comfortable working environment. 3 Solves on-site problems Case 1 Case 2 High resolution and clear display makes robot teaching simple Before Only experts with know-how can understand an operating screen full of text Screens showing indirect values make it difficult to imagine the actual movement and memorize values. Even skilled operators have to refer to manuals during operation. Before Several touch panels are located in different places on the line Although touch panels are needed to operate control panels, some are not used frequently. After After User-friendly screens enable standardization of operations The high resolution 4.3 inch display achieves an impressive operating screen. Machine operating experience is not required, reducing time required to train staff and enabling quick start-up of a manufacturing site. Also, the operating screen can be easily designed using programming software. High Resolution 4.3 inch 4 Flexible installation. A single touch panel can be used in various locations Easy design Touchscreen display Saves cost and space Touch panels do not need to be always installed as cables can be detached from the hand-held operator interface and can be connected with external devices when necessary. Lightweight 500g makes the operator interface easy to carry around. Saves cost and helps downsize control panels. 500g Lightweight Flexible Use HG1P Operator Interface Hand-held Model Case 3 Case 4 Labor-saving operation on large machines Before Several operators are needed for startup operation On large equipment, several operators had to check with each other to confirm processing work. Safety ensured during maintenance Before Maintenance using PCs may lead to human error When checking a PLC setting on a PC, knowledge of ladder software is required to determine the changes needed. Also, parameters that do not require changes might be adjusted, leading to failure. Furthermore, the worker may have to work in an uncomfortable position for long hours. After After Portable design helps reduce manpower The hand-held operator interface is light-weight, and easy to carry around, enabling process work to be checked visually. The ergonomic design reduces fatigue caused by long working hours. Also, the drop resistance is 1.5m, so there is no need to worry about the hand-held operator interface slipping from the hands. Portable Ergonomic Design Drop Resistance 1.5m Display only the required data on customized screens By showing only required data, safe and efficient maintenance is achieved. Data can be saved on a USB memory, making it easy for troubleshooting and maintenance. Easy maintenance USB memory 5 HG1P Operator Interface Hand-held Model Easily readable and functional. Designed for optimal usability. (2) (1) (4) (3) (8) (5) (9) (10) (7) (6) (11) (13) (14) (12) USB port cover - closed No. Name (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) Emergency stop switch Selector switch Function key Display Touchscreen Power LED Connector Hole for mounting bracket Enabling switch Hole for hand strap USB port cover Fixed screw for USB port cover USB interface (USB 2) USB interface (USB 1) USB port cover - open HG1P Display Screen 4.3-inch TFT color LCD 65,536 colors Operation Style Touch switch (analog resistive) Function switch Communication Interface Part No. Approvals RS422 / RS485 HG1P-ST32YBFH-B0 UL61010-1 UL61010-2-201 Ethernet HG1P-ST32ZBFH-B0 CSA C22.2 No.61010-1 (c-UL) CSA C22.2 No.61010-2-201 (c-UL) * For models without IDEC logo, contact IDEC. Cable Item HG1P Option cable 6 Communication Method RS422 / RS485 / Ethernet Length Weight Part No. 3m 600g HG9Z-XCP13 5m 1,000g HG9Z-XCP15 7m 1,300g HG9Z-XCP17 Remarks [Connector for HG1P unit] CA-19S1N128007S (Phoneix Contact) [External device connection] D-sub 25 pin (Plug / fixed screw M2.6) HG1P Operator Interface Hand-held Model General Specifications Power Voltage Range 24V DC Display 20.4 to 28.8V DC Color/Shade 65,536 colors Effective Display Area 95.04 W × 53.856 H mm TFT Color LCD Dielectric Withstand Voltage 500V AC, 10mA (1 minute) Display Resolution 480 W × 272 H pixels Power Consumption 3W max. (2W max. when not using USB interface (USB2)) View Angle Left / right: 80°, top: 65°, bottom: 55° Backlight White LED 10 ms max. Backlight Life 30,000 hours minimum (*1) Inrush Current 20A max. Brightness 400 cd/m2 (*2) Operating Temperature 0 to +45°C (no freezing) Brightness Adjustment 32 levels Operating Humidity 10 to 90% RH (no condensation) Backlight Replacement Not possible Storage Temperature –10 to +60°C (no freezing) 10 to 90% RH (no condensation) Altitude 2,000m max. (during operation) 750 hPa to 1,060 hPa Pollution Degree 2 Vibration Resistance 5 to 8.4 Hz amplitude 3.5 mm 8.4 to 150 Hz acceleration 9.8 m/s2 10 cycles (100 minutes) on each of three mutually perpendicular axes Shock Resistance 147 m/s2, 11 ms 5 shocks on each of three mutually perpendicular axes Drop Test 1/2 size 8 × 8 pixels (Western European language: ISO 8859-1, Central European language: ANSI 1250, Baltic: ANSI 1257, Cyrillic: ANSI1251, Japanese katakana and symbols: JIS 8-bit code) 8 × 16 pixels (Western European language ISO 8859-1, Central European language: ANSI 1250, Baltic: ANSI 1257, Cyrillic: ANSI1251, Japanese katakana and symbols: JIS 8-bit code) 16 × 32 pixels, 24 × 48 pixels, 32 × 64 pixels (Western European language: ISO 8859-1) Full size 16 × 16 pixels (Japanese JIS first and second level characters, simplified Chinese, traditional Chinese, Korean) 1.5m drop in six directions Double size Connector Insertion Life HG1P Optional Cable: 100 times USB1: 5000 times, USB2: 1500 times 32 × 32 pixels (Japanese JIS first level characters, Mincho font) 1/4 size 60 characters × 34 lines 1/2 size 60 characters × 17 lines Noise Immunity Fast transient/burst test, Power terminals: ±2 kV, Communication line: ±1 kV (IEC/EN61131-2) Quantity of Characters Storage Humidity 1/4 size Display Character Size Allowable Momentary Power Interruption Full size 30 characters × 17 lines 15 characters × 8 lines (Mincho font) Lighting surge Power unit : ±500 V (between power - 0V) : ±1 kV (between power - FE, between 0-FE) (IEC/EN61131-2) Double size Character Magnification 0.5, 1 to 8 vertically and horizontally (except for scalable fonts) Character Attribute Blink (1 or 0.5 sec period), reverse, bold, shadowed Electrostatic Discharge Air: 8 kV  Contact: 4 kV (IEC/EN61131-2) Atmosphere No corrosive gas Graphics Straight line, polyline, rectangle, arc, pie,circle/ ellipse, equilateral polygons (3, 4, 5, 6, 8), picture, fill Degree of Protection IP54F (not including the cable connector) (IEC60529) Dimensions 191.0 W × 168.9 H × 56.0 D mm Weight (approx.) 500g (except HG1P option cable) • Do not use the HG1P in an environment subject to strong ultraviolet rays, otherwise the LCD quality will deteriorate. • Specifications include the use of HG1P option cable designated by IDEC. Function Specifications Screen Types Base screen, popup screen, system screen No. of Screens Base screen: 3,000 max. Popup screen: 3,015 max. Parts Bit Button, Word Button, Goto Screen, Print Button, Key Button, Multi Button, Keypad, Selector Switch, Potentiometer, Numerical Input, Character Input, Pilot Lamp, Multi-State Lamp, Picture Display, Message Display, Message Switching Display, Alarm List Display, Alarm Log Display, Numerical Display, Bar Graph, Trend Chart, Pie Chart, Meter, Calendar, Bit Write Command, Word Write Command, Goto Screen Command, Print Command, Timer, Screen Script Command, Multi Command, Video Display Calendar (*1) Year, Month, Day, Hour, Min., Sec., Day of Week ±90 sec per month (at 25°C) Window Display Touch Panel Construction Specifications Environmental Specifications Electrical Specifications Rated Power Voltage Display Specifications 3 popup screens + 1 system screen Switching Element Analog resistive membrane Operating Force 3N maximum Mechanical Life 1,000,000 operations Buzzer Single tone (sound length adjustable) User Memory Capacity 12 MB approx. (including extension font) • Also see operating instructions on the back page. *1) The backlight life is not guaranteed and refers to the time until the brightness reduces by half after use at 25°C. The actual life depends on operating environments and conditions. *2) Brightness of the LCD only at 25°C. *1) Calendar data is deleted when power is off if a battery for backup is not installed. 7 HG1P Operator Interface Hand-held Model Mechanical Specifications Interface Specifications Emergency Stop Switch HG1P-ST32YBFH-B0 Electrical Characteristics Part No. AB6E-3BV02PRM Quantity 1 Contact Configuration 2NC (External wiring) Contact Rating 30V DC, 1A (resistive load / inductive load) Durability Electrical: 100,000 operations minimum Mechanical: 100,000 operations minimum Reset Pull or turn reset Serial Interface (COM) Transmission Distance Synchronization USB Interface (USB1) Enabling Switch USB Interface (USB2) (*2) Part No. Quantity Contact Configuration HE6B-M200Y 1 2C (External wiring) Contact Rating 30V DC, 1A (resistive load) 30V DC, 0.7A (inductive load) Monitor Contact N/A Durability Mechanical: Position 1  2  1 1000,000 operations minimum 1  2  3  1 100,000 operations minimum Electrical Life: 100,000 operations minimum Transmission RS422/485 Speed Interface Connector Interface Connector EIA RS422/485 compliant 187,500/115,200/57,600/ 38,400/19,200/9,600/ 4,800/2,400/1,200 bps (*1) 20m max. Asynchronous USB 2.0 (device) USB Type Mini-B connector USB 2.0 (host) USB Type A connector • The above specification applies only when a optional cable specified for HG1P is used. *1) 187,500 bps is available only with SIEMENS SIMATIC S7-300/400 series (MPI port direct connection). *2) USB memory only HG1P-ST32ZBFH-B0 Ethernet Interface (LAN) Selector Switch USB Interface (USB1) Interface Communication Speed Interface Connector Interface Connector IEEE802.3i (10BASE-T) compliant 10M bps USB 2.0 (device) USB Type Mini-B connector USB 2.0 (host) USB Type A connector Part No. LB6S-2T1 Quantity 1 Contact Configuration SPDT (external wiring) Contact Rating 30V DC, 0.1A (resistive Load) LED Non-illuminated • The above specification applies only when a optional cable specified for HG1P is used. Durability Electrical: 250,000 operations minimum Mechanical: 100,000 operations minimum *1) USB memory only Angle 90° 2-position Operation Maintained (manual) USB Interface (USB2) (*1) Function key Method Tactile switch Quantity 12 Contact Configuration NO contact (internal wiring) External Interface Connecter Pin Arrangement Removable 19-pin connector (socket): CA-19P1N126Y00 (Phoneix Contact) 11 10 9 12 17 1 18 13 19 2 3 16 8 7 4 14 15 6 5 Connector pin layout diagram 8 No. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 Name C_NC1 C_NO1 B_C1 B_C2 B_NO2 FG RDA+/TPI+ RDB-/TPISDB-/TPOA_NC21 A_NC22 DC24VC_C1 B_NO1 SG SDA+/TPO+ A_NC11 A_NC12 DC24V+ Function Selector switch contact 1 (NC) Selector switch contact 1 (NO) Enabling switch contact 1 (COM) Enabling switch contact 2 (COM) Enabling switch contact 2 (NO) Frame ground Receive data (+) Receive data (–) Send data (–) Emergency stop switch contact 2 (NC) Emergency stop switch contact 2 (NC) Power supply 24V DC (–) Selector switch contact 1 (COM) Enabling switch contact 1 (NO) Communication signal ground Send data (+) Emergency stop switch contact 1 (NC) Emergency stop switch contact 1 (NC) Power supply 24V DC (+) HG1P Operator Interface Hand-held Model Dimensions All dimensions in mm. Optional cable (HG9Z-XCP13 / -XCP15 / -XCP17) 56 51 70.6 169 191 Option Cable Connector Terminal Arrangement No. Cable Length 3m, 5m, 7m External device side connection 1 14 13 25 Connector pin layout diagram Name Function Conductor color 1 FG Frame ground Brown 2 RDB–/TPI– Receive data (–) Orange 3 RDA+/TPI+ Receive data (+) Orange (White) 4 SDB–/TPO– Send data (–) Green 5 SDA+/TPO+ Send data (+) Green (White) 6 SG Communication signal ground 7 NC 8 NC 9 B_NO1 Enabling switch contact 1 (NO) Pink (White) 10 B_C1 Enabling switch contact 1 (COM) Pink 11 A_NC11 Emergency stop switch contact 1 (NC) Yellow 12 A_NC12 Emergency stop switch contact 1 (NC) Yellow (White) 13 DC24V– Power supply 24V DC (–) Black 14 NC — — 15 NC — — 16 NC — — 17 NC — 18 C_NC1 Selector switch contact 1 (NC) Light blue (White) 19 C_NO1 Selector switch contact 1 (NO) Light blue 20 C_C1 Selector switch contact 1 (COM) Gray 21 B_NO2 Enabling switch contact 2 (NO) Blue (White) 22 B_C2 Enabling switch contact 2 (COM) Blue 23 A_NC21 Emergency stop switch contact 2 (NC) Purple 24 A_NC22 Emergency stop switch contact 2 (NC) Purple (White) 25 DC24V+ Power supply 24V DC (+) Red Gray (White) — — — — — 9 HG1P Operator Interface Hand-held Model Accessories (optional) Name Part No. (Ordering No.) Description Application Software SW1A-W1C User’s Manual (English) HG9Y-B1701 Automation Organizer (includes WindO/I NV4) • Includes digital manual Hand Strap HG9Z-PS4 Strap for wrists. Wall Mount Bracket HG9Z-PK3 Install on the back of the pendant to enable wall mount USB Maintenance Cable HG9Z-XCM42 • Length: 2m • Communication method: USB • Connector (main unit side): USB-miniB • Connector (external device connection side): USB type A Debug Cable (*1) HG9Z-PX12 • Length: 2m • Connector (main unit side): CA-19S1N128007S (Phoenix Contact) • Connector (external device connection side): loose wire *1) Use the Debug Cable only for debugging. Dimensions All dimensions in mm. Wall Mount Bracket (HG9Z-PK3) Hand Strap (HG9Z-PS4) Length adjustment part (black) 21 16 1.5 39.6 50 205 9 35 54.5 48 44.1 1.2 6.5 68 Debug Cable (HG9Z-PX12) Stripped wires Cable length: 2m Shielded Cross Section View Wiring Table Double 2 Single 5 White Black Orange Single 4 Single 3 10 Yellow Black Red Name Function Conductor color 1 RDA+/TPI+ Receive data (+) Double 1: Black Sheath 2 RDB-/TPI– Receive data (–) Double 1: Red 3 SDA+/TPO+ Send data (+) Double 2: Black 4 SDB-/TPO– Send data (–) Double 2: White 5 FG Frame ground Single 1: Green 6 SG Communication signal ground Single 2: Yellow 7 DC24V+ Power supply 24V DC (+) Single 3: Brown 8 NC 9 DC24V– Green Blue Brown No. Shield Single 1 Single 2 Double 1 — Power supply 24V DC (–) Single 4: Blue Single 5: Orange HG1P Operator Interface Hand-held Model Compatible PLCs Manufacturer Series Manufacturer MICROSmart FC6A (Ethernet) IDEC SmartAXIS FT1A Pro/Lite (Ethernet) MICROSmart FC6A / FC5A / FC4A Modbus RTU Slave (*2) Modicon SmartAXIS FT1A Pro/Lite Modbus TCP Server (*2) MELSEC-QnA (link unit) Schneider Electric Twido MELSEC-Q (link unit) Panasonic FP Series MELSEC-Q (Ethernet) MELSEC-FX Yaskawa Electric DirectLOGIC 05 DirectLOGIC 06 SYSMAC-CJ1 Koyo KOSTAC SU KOSTAC SU (Ethernet) MicroLogix (Full Duplex) Fanuc Yokogawa Electric ControlLogix (Full Duplex) CompactLogix (Full Duplex) FlexLogix (Full Duplex) Fuji Electric PLC-5 (Ethernet) MICREX-F MICREX-SX LS Industrial Systems PROSEC T Series V Series MASTER-K VB MicroLogix (Ethernet) Emerson FloBoss Hitachi Industrial Equipment Systems EH S7-300 (link unit) S7-400 S7-1200 (Ethernet) KV-700/1000/3000/5000 KV Nano KZ KV KV (Ethernet) GE Fanuc Automation FA-M3 (Ethernet) VIGOR S7-300 (connects to CPU) Toshiba Machine Works FA-M3 SLC 500 (Ethernet) S7-200 JTEKT Series MICREX-SX (Ethernet) ControlLogix (Ethernet/IP, Ethernet/IP (Logix Native Tag)) CompactLogix (Ethernet/IP, Ethernet/IP (Logix Native Tag)) Power Mate FREX-PC Toshiba Hitachi KOSTAC SZ SYSMAC-CP1 SLC-500 (Half Duplex) Keyence DirectLOGIC 205 SYSMAC-CJ2 PLC-5 (Half Duplex) SIEMENS MP (Ethernet) SYSMAC-C SYSMAC (Ethernet) Allen-Bradley MP MELSEC-FX (Ethernet) SYSMAC-CS OMRON Modbus ASCII Master (*1) Modbus TCP Client (*1) MELSEC-A (link unit) Mitsubishi Series Modbus RTU Master (*1) S10mini S10V VH EH (Ethernet) • The compatible PLC information is for reference only (except for IDEC PLCs), and IDEC does not guarantee the operation of any other manufacturers’ PLC. When using other manufacturers’ PLCs, read their specifications and instruction manual carefully. The PLC must be operated correctly under the user’s responsibility. • The company names and product names are registered trademarks or brand names. *1) H  G series can be connected as a master to the slave/server device. *2) H  G series is connected as a slave to the master/client device. An updated listing of compatible PLCs can be found at the following website. http://www.idec.com/oi/drivers TOYOPUC-PC2J TOYOPUC-PC3J TC200 TCmini Series90-30 VersaMax 11 HG1P Operator Interface Hand-held Model Operating Instructions Be sure to read this manual carefully before performing installation, wiring, or maintenance work. • When using the HG1P in applications which require high level of safety, add a fail-safe or backup functionality, and verify an adequate level of safety using the product specifications. • Turn off the power to the HG1P before installation, removal, wiring, maintenance, and inspection of the HG1P. Failure to turn power off may cause electrical shock or fire hazard. • Special expertise is required to install, wire, configure, and operate the HG1P. Users without such expertise must not use the HG1P. • Emergency stop circuit must be configured outside of the HG1P. • Do not use touch switches and the function keys for an emergency stop circuit or an interlocking circuit. If the HG1P fails, equipment connected to the HG1P will no longer be protected, and serious injury to operators and equipment damage may be caused. • Be sure to build the system to ensure safety in an event of a loss of communication between HG1P and connected device. • Connect the emergency stop switch and the enabling switch on the HG1P to function as either a category 0 or category 1 stop in accordance with IEC/EN60204-1. • Do not under any circumstances, hold the enabling switch on the HG1P in position 2 with tape, string, or deform the rubber cover. The intrinsic function of the enabling switch will be lost, and the enabling switch may not work in an emergency. • When using the HG1P, place your finger firmly on the enabling switch. • Perform regular checks to confirm that the emergency stop switch and enabling switch work properly. It is extremely dangerous if a foreign object gets stuck in between causing the enabling switch to remain in position 2 even when the hands are released. • Stop using the HG1P if it is accidentally dropped or exposed to significant shocks, check the HG1P for damage, and confirm that its various functions work safely and correctly. • Connect the FG wire to grounding resistance of 100 Ω or less. Otherwise there is a risk of electric shock or mistaken operation. • When more than one button is pressed at the same time, due to the detection characteristics of an analog type touch panel, only the center of the pressed area is sensed and the unit assumes that only one button is pressed. Do not operate the HG1P by pressing more than one button simultaneously because there is a risk of accident. • The screen will not be visible if the backlight burns out, but the touch panel and the function key will remain functional. In this case, stop using the HG1P as damage may occur if a touch panel or function key is operated mistakenly with the backlight burned out. • The HG1P is designed for indoor use only (Not for outdoor use) • Use HG1P optional cable for wiring. The D-sub connector on the end of the HG1P optional cable is not water- or dust-proof. If protection against water or dust is required, the user must replace the D-sub connector with water-proof characteristics. • Use the product within the environmental limits given in the catalog and manual. Use of the product in high temperature or high-humidity environments, or in locations where it is exposed to condensation, corrosive gas or large shock may cause electrical shock, fire, or malfunction. • The HG1P is designed for use in pollution degree 2. Use the HG1P in pollution degree 2 environment. (according to IEC60664-1) • Prevent metal fragments or wire chips from dropping inside the HG1P housing. Ingress of such fragments and chips may cause fire hazard, damage, or malfunction. • Use a power supply of the rated value. Using a wrong power supply or wiring in reverse polarity may cause fire hazard or damage. • Make sure of safety before starting and stopping the HG1P. Incorrect operation of the HG1P may cause mechanical damage or accidents. • Use the HG1P in a local area network if you download, upload or monitor the project data via the Ethernet port. • The touch panel of the HG1P is made of glass, and will break if exposed to excessive shock. Be sure to handle with care. • Do not push or scratch the touch panel and protection sheet with a hard object such as a tool, because they can be easily damaged. • When used under temperatures over the rated operating temperature, the clock accuracy is affected. Adjust the clock before use or regularly. • Do not install the HG1P in areas subjected to strong ultraviolet rays, since ultraviolet rays may impair the quality of the LCD. • Do not attempt to disassemble, repair or modify the HG1P. This can create the risk of fire or electrical shock. • Do not switch off the power or pull out the USB flash drive while it is being accessed, as this may result in destruction of the stored data. If the data on the USB flash drive is corrupted, reformat the USB flash drive. • Install the HG1P according to the instructions. Improper installation may result in, failure, electrical shock, fire hazard, or malfunction of the HG1P. • If the HG1P is used in a way incompatible with the its original purpose, the function of the HG1P may be impaired. • Note that small black and bright dots may show up on LCD Screen: this is not a failure or malfunction. www.idec.com Head Office 6-64, Nishi-Miyahara-2-Chome, Yodogawa-ku, Osaka 532-0004, Japan USA Germany Singapore Thailand Australia India IDEC Corporation APEM GmbH IDEC Izumi Asia Pte. Ltd. IDEC Asia (Thailand) Co., Ltd IDEC Australia Pty. Ltd. IDEC Controls India Private Limited Tel: +1-408-747-0550 Tel: +49-40-25 30 54-0 Tel: +65-6746-1155 Tel: +66-2-392-9765 Tel: +61-3-8523-5900 Tel: +91-80679-35328 opencontact@idec.com service@eu.idec.com info@sg.idec.com sales@th.idec.com sales@au.idec.com info_india@idec.com Specifications and other descriptions in this brochure are subject to change without notice. Information in this brochure is current as of March, 2020. 2020 IDEC Corporation, All Rights Reserved. EP1699-1 Taiwan Hong Kong China/Shanghai China/Shenzhen China/Beijing Japan IDEC Taiwan Corporation IDEC Izumi (H.K.) Co., Ltd. IDEC (Shanghai) Corporation IDEC (Shenzhen) Corporation IDEC (Beijing) Corporation IDEC Corporation Tel: +886-2-2577-6938 Tel: +852-2803-8989 Tel: +86-21-6135-1515 Tel: +86-755-8356-2977 Tel: +86-10-6581-6131 Tel: +81-6-6398-2527 service@tw.idec.com info@hk.idec.com idec@cn.idec.com idec@cn.idec.com idec@cn.idec.com marketing@idec.co.jp
HG1P-ST32ZBFH-B0 价格&库存
很抱歉,暂时无法提供与“HG1P-ST32ZBFH-B0”相匹配的价格&库存,您可以联系我们找货
