LB-T60
LB-T60
    IDEC(日本和泉)
    可配置开关元件 - 触点块 DPDT 5A @ 125VAC/30VDC
LB-T60 数据手册
Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø16mm - LB Series LB Flush Mount & 16mm Miniature Switches & Pilot Lights Flush bezel projects only 2mm from front of panel. Standard bezel has a depth of only 27.9mm! Removable contact blocks are ideal for single board mounting. Key Features • Pushbuttons, lever switches, selector switches, and key selector switches with up to 3PDT contacts. • Key selectors with keys that are difficult to duplicate. Seven different key numbers to choose from. • Pilot lights with flat or dome lenses. • Buzzers with 80dB steady sound. • Black or metallic flush bezels available. • Bright and clear LED illuminated face. • Choice of either gold-clad or silver contacts. • Degree of protection: IP65 (from the front of the panel). Relays & Sockets Applicable Standards Mark Contact Ratings File No. or Organization UL508 UL Recognition No.E55996 CSA 22.2 No.14 CSA File No. LR 21451 Gold Contact (switch base color: blue) Rated Insulation Voltage Rated Thermal Current Rated Operating Voltage Rated Operating Current (resistive load) Contact Material TÜV Rheinland EN60947-5-1 Minimum applicable load (reference value): 5V AC/DC, 1 mA EU Low Voltage Directive Timers GB14048.5 Specifications Contactors Operating Temperature Storage Temperature Operating Humidity Contact Resistance Insulation Resistance Dielectric Strength Switch Terminal Blocks Shock Resistance Circuit Breakers –25 to +60°C (no freezing), Illuminated units: –25 to +55°C –30 to +80°C (no freezing) 45 to 85% RH (no condensation) 50 mW maximum (initial value) 100 MW minimum (500V DC megger) Between live part and ground: 2,000V AC, 1 min. Between terminals of different poles: 2,000V AC, 1 min. Between terminals of the same poles: 1,000V AC, 1 min. Illumination Between live part and ground: 2,000V AC, 1 min. Vibration Resistance Mechanical Life (minimum operations) Electrical Life (minimum operations) Degree of Protection Terminal Style Bezel Weight (approx.) 250V 3A 30V DC 125V AC 0.1A 0.1A Gold-clad silver Operating extremes/Damage limits: 5 to 55 Hz, amplitude 0.5mm Operating extremes: 100 m/s2 Damage limits: 1,000 m/s2 Momentary: 2,000,000 Maintained: 250,000 Selector switches: 250,000 Key selector switches: 250,000 Momentary: 50,000 / 100,000 1 Maintained: 50,000 / 100,000 2 Selector switches: 50,000 / 100,000 2 Key selector switches: 50,000 / 100,000 2 IP65 (IEC 60529) Solder/tab terminal #110, PC board terminal Black plastic or metallic 11g (lever switch) 13g (pilot light, pushbutton) 14g (illuminated pushbutton, pushbutton with guard, buzzer) 15g (selector switch, illuminated pushbutton with guard) 27g (key selector switch) Silver Contact (switch base color: gray) Rated Insulation Voltage Rated Operating Voltage Resistive load AC 50/60Hz Inductive load Resistive load DC Inductive load Rated Operating Current Resistive load AC 50/60Hz Inductive load DC 250V 30V — — 5A 2.5A — — 125V 5A 3A 1.1A 0.55A 5A 3A 250V 5A 1.5A — — 3A 1.5A Resistive load 3A 0.6A — Inductive load 1A 5A Silver 0.22A — Rated Thermal Current Contact Material AC inductive load: PF=0.6 to 0.7 DC inductive load: L/R=7 ms max. LED Ratings Rated Voltage Voltage Range 5V DC 5V DC±5% LED Part No. LB9Z-LED5➁ LB9Z-LED1➁ LB9Z-LED2➁ A, R: 22 mA G, PW, S: 16 mA Marked on the side of the LED unit Approx. 30,000 hours (until the brightness reduces to 50% of the initial value) A, PW, R A, PW, R Rated Current Voltage Rating LED Life (reference value) 12V AC/DC 12V AC/DC±10% 24V AC/DC 24V AC/DC ±10% X1 X1 (+) Internal Circuit X2 (–) X2 G, S G, S X1 X1 (+) LED Chip X2 (–) Protection Diode Zener Diode Resistor X2 1. Switching frequency 1,800 operations/h. 2. Switching frequency 1,200 operations/h. 506 Varistor 1. For ➁ (color code): A (amber), G (green), PW (white), R (red), S (blue) 2. Use the white LED for yellow illumination. 3. LED lamp contains a current-limiting resistor. www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - LB Series Style Operation Operating Voltage Contact Standard Bezel Flush Bezel Solder/Tab Terminal PC Board Terminal Solder/Tab Terminal PC Board Terminal (silver contacts) (gold contacts) (silver contacts) (gold contacts) SPDT LBjL-M1T51k LBjL-M1T11Vk LBlmL-M1T51k LBlmL-M1T11Vk DPDT LBjL-M1T61k LBjL-M1T21Vk LBlmL-M1T61k LBlmL-M1T21Vk SPDT LBjL-M1T53k LBjL-M1T13Vk LBlmL-M1T53k LBlmL-M1T13Vk DPDT LBjL-M1T63k LBjL-M1T23Vk LBlmL-M1T63k LBlmL-M1T23Vk SPDT LBjL-M1T54k LBjL-M1T14Vk LBlmL-M1T54k LBlmL-M1T14Vk Switches & Pilot Devices Illuminated Pushbuttons (Assembled) ➁ Color Code Standard Bezel (black) 12V AC/DC DPDT LBjL-M1T64k LBjL-M1T24Vk LBlmL-M1T64k LBlmL-M1T24Vk SPDT LBjL-A1T51k LBjL-A1T11Vk LBlmL-A1T51k LBlmL-A1T11Vk DPDT LBjL-A1T61k LBjL-A1T21Vk LBlmL-A1T61k LBlmL-A1T21Vk SPDT LBjL-A1T53k LBjL-A1T13Vk LBlmL-A1T53k LBlmL-A1T13Vk DPDT LBjL-A1T63k LBjL-A1T23Vk LBlmL-A1T63k LBlmL-A1T23Vk SPDT LBjL-A1T54k LBjL-A1T14Vk LBlmL-A1T54k LBlmL-A1T14Vk DPDT LBjL-A1T64k LBjL-A1T24Vk LBlmL-A1T64k LBlmL-A1T24Vk 5V DC Relays & Sockets 24V AC/DC Flush Bezel (metallic or black) Signaling Lights Momentary 5V DC Specify the color code in place of k in the Part Number: A: amber G: green R: red S: blue PW: white Y: yellow Maintained Timers 12V AC/DC Contactors Black Bezel with Guard 24V AC/DC Terminal Blocks 1. For Standard Bezel part numbers specify: - Bezel shape in place of j. 1 (round), 2 (square), 3 (rectangular) - Lens/LED color in place of k. A (amber), G (green), PW (white), R (red), S (blue), Y (yellow) 2. For Flush Bezel part numbers specify: - Lens/LED in place of k. A (amber), G (green), PW (white), R (red), S (blue), Y (yellow) - Bezel shape in place of l. 6 (round), 7 (square), 8 (rectangular) - Bezel material in place of m. M (metallic), Blank (black), G (black with guard) 3. Solder/Tab terminals have silver contacts and PC Board Terminals have gold contacts. 4. Illuminated pushbuttons contain an LED unit. 5. See page page 524 for dimensions. 6. See page page 539 for replacement LED units. 7. Illuminated pushbuttons can be used with legend markings. Engraving can be done on a marking plate which is placed in the lens, or a clear film can be printed and placed in the lens. See page page 539 for details on the marking plate and film. Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 507 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø16mm - LB Series Illuminated Pushbuttons (Sub-assembled) Contact Block + Terminal Style LED Module + Contact Block Lens + Operator Material Contact Part Number Silver SPDT LB-T50 Solder/Tab Gold PCB DPDT LB-T60 SPDT LB-T10V DPDT LB-T20V Style Style Monmontary Maintained Round LB1L-M0 LB1L-A0 Square LB2L-M0 LB2L-A0 Rectangular LB3L-M0 LB3L-A0 Round LB6L-M0 LB6L-A0 Flush Mount Square (Plastic) LB7L-M0 LB7L-A0 Part Number Amber 5V LB9Z-LED5A Rectangular LB8L-M0 LB8L-A0 12V LB9Z-LED1A Round LB6ML-M0 LB6ML-A0 24V LB9Z-LED2A 5V LB9Z-LED5G Flush Mount Square (Metallic) LB7ML-M0 LB7ML-A0 12V LB9Z-LED1G Rectangular LB8ML-M0 LB8ML-A0 24V LB9Z-LED2G LB6GL-A0 LB9Z-LED5R 12V LB9Z-LED1R LB7GL-M0 LB7GL-A0 24V LB9Z-LED2R Round Flush Mount (Built-in Square switch guard) Rectangular LB6GL-M0 5V LB8GL-M0 LB8GL-A0 5V LB9Z-LED5S 12V LB9Z-LED1S 24V LB9Z-LED2S 5V LB9Z-LED5PW 12V LB9Z-LED1PW 24V LB9Z-LED2PW 5V LB9Z-LED5PW 12V LB9Z-LED1PW 24V LB9Z-LED2PW Blue Contactors Shape Voltage Red White Yellow Terminal Blocks Mounting Style Color Green Lens Shape Round Square Circuit Breakers Rectangular 508 Completed Unit = Standard (Plastic) LED Module Timers Relays & Sockets Operator www.IDEC.com Color Part Number Amber Green Red Blue White Yellow Amber Green Red Blue White Yellow Amber Green Red Blue White Yellow LB1A-L1A LB1A-L1G LB1A-L1R LB1A-L1S LB1A-L1W LB1A-L1Y LB2A-L1A LB2A-L1G LB2A-L1R LB2A-L1S LB2A-L1W LB2A-L1Y LB3A-L1A LB3A-L1G LB3A-L1R LB3A-L1S LB3A-L1W LB3A-L1Y 1705151131 Switches & Pilot Devices ø16mm - LB Series Switches & Pilot Devices Pilot Lights (Assembled) Standard Bezel Operating Voltage Style Flush Bezel Solder/Tab Terminal (silver contacts) PC Board Terminal Solder/Tab Terminal PC Board Terminal (gold contacts) (silver contacts) (gold contacts) LBjP-nT01k LBjP-nT01Vk k Color Code Standard Bezel (black) LBlmP-nT01k Signaling Lights 5V DC LBlmP-nT01Vk Relays & Sockets Specify the color code in place of k in the Part Number.: Flush Bezel (metallic or black) LBjP-nT03Vk LBlmP-nT03k LBlmP-nT03Vk 24V AC/DC LBjP-nT04k LBjP-nT04Vk LBlmP-nT04k LBlmP-nT04Vk A: amber G: green PW: white R: red S: blue Y: yellow Contactors LBjP-nT03k Timers 12V AC/DC Terminal Blocks 1705151131 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1. For Standard Bezel part numbers specify: - bezel shape in place of j. 1 (round), 2 (square), 3 (rectangular) - lens/LED color in place of k. A (amber), G (green), PW (white), R (red), S (blue), Y (yellow) - lens type code in place of n. 1 (flat), 2 (dome with round lens) 2. For Flush Bezel part numbers specify: - lens/LED in place of k. A (amber), G (green), PW (white), R (red), S (blue), Y (yellow) - bezel shape in place of l. 6 (round), 7 (square), 8 (rectangular) - bezel material in place of m. M (metallic), Blank (black) - lens type code in place of n. 1 (flat), 2 (dome with round lens) 3. Pilot lights contain an LED unit. 4. See page page 524 for dimensions. 5. See page page 539 for replacement LED unit. 509 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø16mm - LB Series Pilot Lights (Sub-assembled) Contact Block + LED Module + Contact Block Lens + Operator Terminal Style Part Number Solder Tab Style LB-T00 Mounting Style Standard (Plastic) Flush Mount (Plastic) LED Module Style Color Amber Timers Green Red Blue Contactors White Yellow Voltage 5V 12V 24V 5V 12V 24V 5V 12V 24V 5V 12V 24V 5V 12V 24V 5V 12V 24V Part Number LB9Z-LED5A LB9Z-LED1A LB9Z-LED2A LB9Z-LED5G LB9Z-LED1G LB9Z-LED2G LB9Z-LED5R LB9Z-LED1R LB9Z-LED2R LB9Z-LED5S LB9Z-LED1S LB9Z-LED2S LB9Z-LED5PW LB9Z-LED1PW LB9Z-LED2PW LB9Z-LED5PW LB9Z-LED1PW LB9Z-LED2PW Flush Mount (Metallic) Lens Shape Round Dome Terminal Blocks Square Shape Part Number Round LB1P-0 Square LB2P-0 Rectangular LB3P-0 Round LB6P-0 Square LB7P-0 Rectangular LB8P-0 Round LB6MP-0 Square LB7MP-0 Rectangular LB8MP-0 Color Part Number Amber Green Red Blue White LB1A-P1A LB1A-P1G LB1A-P1R LB1A-P1S LB1A-P1W Yellow LB1A-P1Y Amber LB1A-P2A Green LB1A-P2G Red LB1A-P2R Blue LB1A-P2S White LB1A-P2W Yellow LB1A-P2Y Amber Green Red Blue White Yellow Amber Green Red Blue White Yellow LB2A-P1A LB2A-P1G LB2A-P1R LB2A-P1S LB2A-P1W LB2A-P1Y LB3A-P1A LB3A-P1G LB3A-P1R LB3A-P1S LB3A-P1W LB3A-P1Y Circuit Breakers Rectangular Completed Unit = LB-T00V PCB Relays & Sockets Operator 510 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - LB Series Switches & Pilot Devices Non-Illuminated Pushbuttons (Assembled) Style Operation Contact Standard Bezel Flush Bezel Solder/Tab Terminal PC Board Terminal Solder/Tab Terminal PC Board Terminal (silver contacts) (gold contacts) (silver contacts) (gold contacts) SPDT LBjB-M1T5k LBjB-M1T1Vk LBlmB-M1T5k LBlmB-M1T1Vk DPDT LBjB-M1T6k LBjB-M1T2Vk LBlmB-M1T6k LBlmB-M1T2Vk 3PDT LBjB-M1T7k LBjB-M1T3Vk LBlmB-M1T7k LBlmB-M1T3Vk k Color Code LBjB-A1T5k LBjB-A1T1Vk LBlmB-A1T5k LBlmB-A1T1Vk DPDT LBjB-A1T6k LBjB-A1T2Vk LBlmB-A1T6k LBlmB-A1T2Vk 3PDT LBjB-A1T7k LBjB-A1T3Vk LBlmB-A1T7k LBlmB-A1T3Vk Specify the color code in place of k in the Part Number: B: black G: green R: red S: blue W: white Y: yellow Maintained Timers SPDT Relays & Sockets Flush Bezel (metallic or black) Signaling Lights Momentary Standard Bezel (black) Black Bezel with Guard Contactors Terminal Blocks 1. For Standard Bezel part numbers specify: - bezel shape in place of j. 1 (round), 2 (square), 3 (rectangular) - lens/LED in place of k. B (black), G (green), R (red), S (blue), W (white), Y (yellow) 2. For Flush Bezel part numbers specify: - lens/LED in place of k. B (black), G (green), R (red), S (blue), W (white), Y (yellow) - bezel shape in place of l. 6 (round), 7 (square), 8 (rectangular) - bezel material in place of m. M (metallic), Blank (black) 3. See page page 526 for dimensions. 4. Lens can be used with legend markings. Engraving can be done on a marking plate which is placed into the lens, or a clear film can be printed and placed under the lens. For details on the marking plate and film, see page page 539. Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 511 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø16mm - LB Series Non-Illuminated Pushbuttons (Sub-assembled) Contact Block Operator + Completed Unit + Contact Block = Operator Terminal Style Material Solder/Tab Relays & Sockets Button PCB Silver Gold Contact Part Number SPDT LB-T5 DPDT LB-T6 3PDT LB-T7 SPDT LB-T1V DPDT LB-T2V 3PDT LB-T3V Style Mounting style Standard (Plastic) Flush Mount (Plastic) Button Timers Style Contactors Round Terminal Blocks Square Part Number Black LB1A-B1B Green LB1A-B1G Red LB1A-B1R Blue LB1A-B1S White LB1A-B1W Yellow LB1A-B1Y Black LB2A-B1B Green LB2A-B1G Red LB2A-B1R Blue LB2A-B1S White LB2A-B1W Yellow LB2A-B1Y Black LB3A-B1B Green LB3A-B1G Red LB3A-B1R Blue LB3A-B1S White LB3A-B1W Yellow LB3A-B1Y Flush Mount (Metallic) Flush Mount (Built-in switch guard) Momentary Maintained Round LB1L-M0 LB1L-A0 Square LB2L-M0 LB2L-A0 Rectangular LB3L-M0 LB3L-A0 Round LB6L-M0 LB6L-A0 Square LB7L-M0 LB7L-A0 Rectangular LB8L-M0 LB8L-A0 Round LB6ML-M0 LB6ML-A0 Square LB7ML-M0 LB7ML-A0 Rectangular LB8ML-M0 LB8ML-A0 Round LB6GL-M0 LB6GL-A0 Square LB7GL-M0 LB7GL-A0 Rectangular LB8GL-M0 LB8GL-A0 Circuit Breakers Rectangular Color Shape 512 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - LB Series Switches & Pilot Devices Selector Switches (Assembled) Style Standard Bezel Flush Bezel Contact Solder/Tab Terminal PC Board Terminal Solder/Tab Terminal PC Board Terminal (silver contacts) (gold contacts) (silver contacts) (gold contacts) Operator Position Standard Bezel (black) Maintained L Spring return from right R L Maintained L C R Flush Bezel (metallic or black) Spring return from right L R Spring return from left L C R lever shown Spring return two-way L C R LBjS-2nT1V LBlmS-2nT5 LBlmS-2nT1V DPDT LBjS-2nT6 LBjS-2nT2V LBlmS-2nT6 LBlmS-2nT2V 3PDT LBjS-2nT7 LBjS-2nT3V LBlmS-2nT7 LBlmS-2nT3V SPDT LBjS-21nT5 LBjS-21nT1V LBlmS-21nT5 LBlmS-21nT1V DPDT LBjS-21nT6 LBjS-21nT2V LBlmS-21nT6 LBlmS-21nT2V 3PDT LBjS-21nT7 LBjS-21nT3V LBlmS-21nT7 LBlmS-21nT3V DPDT LBjS-3nT6 LBjS-3nT2V LBlmS-3nT6 LBlmS-3nT2V 3PDT LBjS-3nT7 LBjS-3nT3V LBlmS-3nT7 LBlmS-3nT3V DPDT LBjS-31nT6 LBjS-31nT2V LBlmS-31nT6 LBlmS-31nT2V 3PDT LBjS-31nT7 LBjS-31nT3V LBlmS-31nT7 LBlmS-31nT3V DPDT LBjS-32nT6 LBjS-32nT2V LBlmS-32nT6 LBlmS-32nT2V 3PDT LBjS-32nT7 LBjS-32nT3V LBlmS-32nT7 LBlmS-32nT3V DPDT LBjS-33nT6 LBjS-33nT2V LBlmS-33nT6 LBlmS-33nT2V 3PDT LBjS-33nT7 LBjS-33nT3V LBlmS-33nT7 LBlmS-33nT3V Timers 45° 3-position C LBjS-2nT5 Relays & Sockets lever shown SPDT Signaling Lights 90° 2-position R Contactors Terminal Blocks Knob models shown above unless otherwise indicated. 5. For Standard Bezel part numbers specify: - bezel shape in place of j. 1 (round), 2 (square), 3 (rectangular) - operator shape in place of n. blank (knob), L (lever). 6. For Flush Bezel part numbers specify: - bezel shape in place of l. 6 (round), 7 (square), 8 (rectangular) - bezel material in place of m. M (metallic), Blank (black) - operator shape in place of n. blank (knob), L (lever). 7. See page page 522 for contact operation . 8. See page page 528 for dimensions. Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 513 Switches & Pilot Devices Selector Switches (Sub-assembled) Contact Block Completed Unit + + Contact Block Solder/Tab PCB Silver Gold SPDT LB-T5 DPDT LB-T6 3PDT LB-T7 SPDT LB-T1V DPDT LB-T2V 3PDT LB-T3V Shape Position Flush Mount (Plastic) Round SPDT contacts applicable for 2-position switches only. Operator Round Contactors Rectangular Square 2 3 3 Lever Maintained LB1S-2Y LB1S-2L Spring from right LB1S-21Y LB1S-21L Maintained LB1S-3Y LB1S-3L Spring from right LB1S-31Y LB1S-31L Spring from left LB1S-32Y LB1S-32L Spring from both LB1S-33Y LB1S-33L Maintained LB2S-2Y LB2S-2L Spring from right LB2S-21Y LB2S-21L Maintained LB2S-3Y LB2S-3L Spring from right LB2S-31Y LB2S-31L Spring from left LB2S-32Y LB2S-32L Spring from both LB2S-33Y LB2S-33L Maintained LB3S-2Y LB3S-2L Spring from right LB3S-21Y LB3S-21L Maintained LB3S-3Y LB3S-3L Spring from right LB3S-31Y LB3S-31L Spring from left LB3S-32Y LB3S-32L Spring from both LB3S-33Y LB3S-33L 2 3 2 Flush Mount (Metallic) Round 3 2 3 Square 2 3 Function Part Number Knob Lever Maintained Spring from right Maintained Spring from right Spring from left Spring from both Maintained Spring from right Maintained Spring from right Spring from left Spring from both Maintained Spring from right Maintained Spring from right Spring from left Spring from both Maintained Spring from right Maintained Spring from right Spring from left Spring from both Maintained Spring from right Maintained LB6S-2Y LB6S-21Y LB6S-3Y LB6S-31Y LB6S-32Y LB6S-33Y LB7S-2Y LB7S-21Y LB7S-3Y LB7S-31Y LB7S-32Y LB7S-33Y LB8S-2Y LB8S-21Y LB8S-3Y LB8S-31Y LB8S-32Y LB8S-33Y LB6MS-2Y LB6MS-21Y LB6MS-3Y LB6MS-31Y LB6MS-32Y LB6MS-33Y LB7MS-2Y LB7MS-21Y LB7MS-3Y LB6S-2L LB6S-21L LB6S-3L LB6S-31L LB6S-32L LB6S-33L LB7S-2L LB7S-21L LB7S-3L LB7S-31L LB7S-32L LB7S-33L LB8S-2L LB8S-21L LB8S-3L LB8S-31L LB8S-32L LB8S-33L LB6MS-2L LB6MS-21L LB6MS-3L LB6MS-31L LB6MS-32L LB6MS-33L LB7MS-2L LB7MS-21L LB7MS-3L Spring from right Spring from left Spring from both Maintained Spring from right Maintained Spring from right Spring from left Spring from both LB7MS-31Y LB7MS-32Y LB7MS-33Y LB8MS-2Y LB8MS-21Y LB8MS-3Y LB8MS-31Y LB8MS-32Y LB8MS-33Y LB7MS-31L LB7MS-32L LB7MS-33L LB8MS-2L LB8MS-21L LB8MS-3L LB8MS-31L LB8MS-32L LB8MS-33L Circuit Breakers Terminal Blocks Rectangular 2 Square Knob Rectangular Round 3 3 Part Number Round 2 Standard (Plastic) Function 3 2 Square Shape Position 2 Round Material Contact Style Part Number Square Terminal Style Style Timers Operator Rectangular Relays & Sockets Signaling Lights Switches & Pilot Devices ø16mm - LB Series 514 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - LB Series Switches & Pilot Devices Illuminated Selector Switches (Assembled) Style Operating Voltage Standard Bezel Flush Bezel Contact Solder/Tab Terminal PC Board Terminal Solder/Tab Terminal PC Board Terminal (silver contacts) (gold contacts) (silver contacts) (gold contacts) Operator Position Standard Bezel (black) Maintained 90° 2-position L SPDT LBjF-2T51k LBjF-2T11Vk LB6lF-2T51k LB6lF-2T11Vk DPDT LBjF-2T61k LBjF-2T21Vk LB6lF-2T61k LB6lF-2T21Vk DPDT LBjF-3T61k LBjF-3T21Vk LB6lF-3T61k LB6lF-3T21Vk SPDT LBjF-2T53k LBjF-2T13Vk LB6lF-2T53k LB6lF-2T13Vk DPDT LBjF-2T63k LBjF-2T23Vk LB6lF-2T63k LB6lF-2T23Vk DPDT LBjF-3T63k LBjF-3T23Vk LB6lF-3T63k LB6lF-3T23Vk SPDT LBjF-2T54k LBjF-2T14Vk LB6lF-2T54k LB6lF-2T14Vk DPDT LBjF-2T64k LBjF-2T24Vk LB6lF-2T64k LB6lF-2T24Vk DPDT LBjF-3T64k LBjF-3T24Vk LB6lF-3T64k LB6lF-3T24Vk R Signaling Lights 5V DC Maintained 45° 3-position L C R Maintained L R 12V AC/DC Flush Bezel (metallic or black) Relays & Sockets 90° 2-position Maintained 45° 3-position L C R Maintained R 24V AC/DC Timers 90° 2-position L Maintained 45° 3-position L C R Contactors Flush bezel only available with round operator. 9. For Standard Bezel part numbers specify: - bezel shape in place of j. 1 (round), 2 (square), 3 (rectangular) - color code in place of k. A (amber), G (green), R (red), S (blue), PW (white), Y (yellow) 10. For Flush Bezel part numbers specify: - color code in place of k. A (amber), G (green), R (red), S (blue), PW (white), Y (yellow) - bezel material in place of l. M (metallic), Blank (black) 11. See page page 522 for contact operation. 12. See page page 530 for dimensions. Terminal Blocks Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 515 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø16mm - LB Series Illuminated Selector Switches (Sub-assembled) Contact Block Operator + + Contact Block Lens Handle + Material Solder/Tab Silver Gold PCB Gold Contact Part Number SPDT LB-T50 DPDT LB-T60 SPDT LB-T10 DPDT LB-T20 SPDT LB-T10V DPDT LB-T20V Style = Color Amber Green Red Blue SPDT contacts applicable for 2-position switches only. Operator Style Shape Contactors Rectangular Square Round Timers Standard (Plastic) Round Flush Mount (Plastic) Round Flush Mount (Metallic) Position Function Part Number 2 Maintained LB1F-2 White Yellow 3 Maintained LB1F-3 2 Maintained LB2F-2 3 Maintained LB2F-3 2 Maintained LB3F-2 Maintained LB3F-3 2 Maintained LB6F-2 3 Maintained LB6F-3 2 Maintained LB6MF-2 3 Maintained LB6MF-3 Part Number LB9Z-LED5A LB9Z-LED1A LB9Z-LED2A LB9Z-LED5G LB9Z-LED1G LB9Z-LED2G LB9Z-LED5R LB9Z-LED1R LB9Z-LED2R LB9Z-LED5S LB9Z-LED1S LB9Z-LED2S LB9Z-LED5PW LB9Z-LED1PW LB9Z-LED2PW LB9Z-LED5PW LB9Z-LED1PW LB9Z-LED2PW Lens Handle Style 3 Voltage 5V 12V 24V 5V 12V 24V 5V 12V 24V 5V 12V 24V 5V 12V 24V 5V 12V 24V Color Part Number Amber LA1A-FA Green LA1A-FG Red LA1A-FR Blue LA1A-FS White LA1A-FW Yellow LA1A-FY Circuit Breakers Terminal Blocks Completed Unit LED Module Terminal Style Relays & Sockets LED Module 516 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - LB Series Switches & Pilot Devices Key Selector Switches (Assembled) Style Operator Position Key retained at j 90° 2-position B B A L R L R L L R C R Flush Bezel (metallic or black) Maintained D E G L L L L C C C C C R R R R R R LBlmK-2T5A LBlmK-2T1VA DPDT LBjK-2T6A LBjK-2T2VA LBlmK-2T6A LBlmK-2T2VA 3PDT LBjK-2T7A LBjK-2T3VA LBlmK-2T7A LBlmK-2T3VA SPDT LBjK-2T5B LBjK-2T1VB LBlmK-2T5B LBlmK-2T1VB DPDT LBjK-2T6B LBjK-2T2VB LBlmK-2T6B LBlmK-2T2VB 3PDT LBjK-2T7B LBjK-2T3VB LBlmK-2T7B LBlmK-2T3VB SPDT LBjK-2T5C LBjK-2T1VC LBlmK-2T5C LBlmK-2T1VC DPDT LBjK-2T6C LBjK-2T2VC LBlmK-2T6C LBlmK-2T2VC 3PDT LBjK-2T7C LBjK-2T3VC LBlmK-2T7C LBlmK-2T3VC SPDT LBjK-21T5B LBjK-21T1VB LBlmK-21T5B LBlmK-21T1VB DPDT LBjK-21T6B LBjK-21T2VB LBlmK-21T6B LBlmK-21T2VB 3PDT LBjK-21T7B LBjK-21T3VB LBlmK-21T7B LBlmK-21T3VB DPDT LBjK-3T6A LBjK-3T2VA LBlmK-3T6A LBlmK-3T2VA 3PDT LBjK-3T7A LBjK-3T3VA LBlmK-3T7A LBlmK-3T3VA DPDT LBjK-3T6B LBjK-3T2VB LBlmK-3T6B LBlmK-3T2VB 3PDT LBjK-3T7B LBjK-3T3VB LBlmK-3T7B LBlmK-3T3VB DPDT LBjK-3T6C LBjK-3T2VC LBlmK-3T6C LBlmK-3T2VC 3PDT LBjK-3T7C LBjK-3T3VC LBlmK-3T7C LBlmK-3T3VC DPDT LBjK-3T6D LBjK-3T2VD LBlmK-3T6D LBlmK-3T2VD 3PDT LBjK-3T7D LBjK-3T3VD LBlmK-3T7D LBlmK-3T3VD DPDT LBjK-3T6E LBjK-3T2VE LBlmK-3T6E LBlmK-3T2VE 3PDT LBjK-3T7E LBjK-3T3VE LBlmK-3T7E LBlmK-3T3VE DPDT LBjK-3T6G LBjK-3T2VG LBlmK-3T6G LBlmK-3T2VG 3PDT LBjK-3T7G LBjK-3T3VG LBlmK-3T7G LBlmK-3T3VG DPDT LBjK-3T6H LBjK-3T2VH LBlmK-3T6H LBlmK-3T2VH 3PDT LBjK-3T7H LBjK-3T3VH LBlmK-3T7H LBlmK-3T3VH Terminal Blocks H L C LBjK-2T1VA Contactors 45° 3-position C L LBjK-2T5A Timers B SPDT Relays & Sockets Spring return from right C R Standard Bezel Flush Bezel Solder/Tab Terminal PC Board Terminal Solder/Tab Terminal PC Board Terminal (silver contacts) (gold contacts) (silver contacts) (gold contacts) Signaling Lights Standard Bezel (black) Maintained A L Contact Assembled Key Selector Switches con’t on next page. Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 517 Switches & Pilot Devices Assembled Key Selector Switches con’t on next page. Style Operator Position Key retained at j Standard Bezel (black) L C R Contact Standard Bezel Flush Bezel Solder/Tab Terminal PC Board Terminal Solder/Tab Terminal PC Board Terminal (silver contacts) (gold contacts) (silver contacts) (gold contacts) DPDT LBjK-31T6B LBjK-31T2VB LBlmK-31T6B LBlmK-31T2VB 3PDT LBjK-31T7B LBjK-31T3VB LBlmK-31T7B LBlmK-31T3VB DPDT LBjK-31T6D LBjK-31T2VD LBlmK-31T6D LBlmK-31T2VD 3PDT LBjK-31T7D LBjK-31T3VD LBlmK-31T7D LBlmK-31T3VD DPDT LBjK-31T6G LBjK-31T2VG LBlmK-31T6G LBlmK-31T2VG 3PDT LBjK-31T7G LBjK-31T3VG LBlmK-31T7G LBlmK-31T3VG DPDT LBjK-32T6C LBjK-32T2VC LBlmK-32T6C LBlmK-32T2VC 3PDT LBjK-32T7C LBjK-32T3VC LBlmK-32T7C LBlmK-32T3VC DPDT LBjK-32T6D LBjK-32T2VD LBlmK-32T6D LBlmK-32T2VD 3PDT LBjK-32T7D LBjK-32T3VD LBlmK-32T7D LBlmK-32T3VD DPDT LBjK-32T6H LBjK-32T2VH LBlmK-32T6H LBlmK-32T2VH 3PDT LBjK-32T7H LBjK-32T3VH LBlmK-32T7H LBlmK-32T3VH DPDT LBjK-33T6D LBjK-33T2VD LBlmK-33T6D LBlmK-33T2VD 3PDT LBjK-33T7D LBjK-33T3VD LBlmK-33T7D LBlmK-33T3VD Spring return from right B Signaling Lights Switches & Pilot Devices ø16mm - LB Series L C R D L C R 45° 3-position L C R C Spring return from left Flush Bezel (metallic or black) Timers Relays & Sockets G L C R D L C R Terminal Blocks Contactors Spring return two-way H L C R D 13. Key is retained at j and removable at  positions. 14. Two keys are supplied. 15. For Standard Bezel part numbers specify bezel shape in place of j. 1 (round), 2 (square), 3 (rectangular) 16. For Flush Bezel part numbers specify: -bezel shape in place of l. 6 (round), 7 (square), 8 (rectangular) - bezel material in place of m. M (metallic), Blank (black) 17. See page page 522 for contact operation. 18. See page page 531 for dimensions. 19. For additional security, wave keys also available. Add the letter “S” before the “T” in the part no. Example: LB1K-31ST1A Besides the standard wave key (key number 0H), six other keys are available. To order other keys, specify the key number as shown below: Example: LB1K-31ST2B-1H (Key number is indicated on the key cylinder. Standard keys do not have a key number indication.) Circuit Breakers (blank): Standard wave key (0H) 1H to 2H: Reversible wave key 3H to 6H: Non-reversible wave key 20. If ordering standard wave key (0H), subcomponents are available, see next page. 21. If ordering other than standard wave key (for example, key number 6H), only completed switches are available. 518 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - LB Series Switches & Pilot Devices Key Selector Switches (Sub-assembled) Contact Block Operator Completed Unit + = Style Terminal Style Solder/Tab Contact Part Number Silver SPDT LB-T5 DPDT LB-T6 3PDT LB-T7 SPDT LB-T1V DPDT LB-T2V 3PDT LB-T3V Gold Position 2 3 Position 2 Round 2 2 Square 3 Part number 3 LB7K-3n Spring from right LB7K-31n Spring from left LB7K-32n LB1K-2n Spring from right LB1K-21B 2 Maintained LB1K-3n Spring from right LB1K-31n Spring from left LB1K-32n Maintained LB8K-2n Spring from right LB8K-21B Maintained Rectangular 3 LB8K-3n Spring from right LB8K-31n Spring from left LB8K-32n Spring from both LB8K-33D Maintained LB2K-2n Spring from right LB2K-21B Flush Mount (metallic) Maintained LB2K-3n Spring from right LB2K-31n Spring from left LB2K-32n 2 Maintained LB6MK-2n Spring from right LB6MK-21B Maintained Round 3 LB6MK-3n Spring from right LB6MK-31n Spring from left LB6MK-32n Spring from both LB6MK-33D Maintained LB3K-2n Spring from right LB3K-21B 2 Maintained LB3K-3n Spring from right LB3K-31n Spring from left LB3K-32n Contactors Rectangular LB7K-2n Spring from right LB7K-21B Spring from both LB7K-33D Maintained Spring from both LB2K-33D 2 Maintained Maintained Square Spring from both LB1K-33D Standard (plastic) LB6K-3n Spring from right LB6K-31n Spring from left LB6K-32n Timers 3 Function Part number LB6K-2n Spring from right LB6K-21B Spring from both LB6K-33D 3 Shape Function Maintained Maintained Round Operator Style Shape Flush Mount (plastic) Relays & Sockets PCB Material Signaling Lights Contact Block Maintained LB7MK-2n Spring from right LB7MK-21B Maintained Square 3 Spring from both LB3K-33D LB7MK-3n Spring from right LB7MK-31n Spring from left LB7MK-32n Spring from both LB7MK-33D Maintained LB8MK-2n Spring from right LB8MK-21B Terminal Blocks 2 Maintained Rectangular 3 LB8MK-3n Spring from right LB8MK-31n Spring from left LB8MK-32n Spring from both LB8MK-33D 22. In place of n specify retention option code from table below. 23. For standard wave key operators, add "S" to part number before the key retention code from table below. (For example, LB6K-2B with wave key would be LB6K-2SB.) 1705151131 Code Circuit Breakers n Retention Option Code Code Description Description A Key not retained in any position (removable in all positions) E Key retained in center only (3-position only) B Key retained in right position only G Key retained in right and center (3-position only) C Key retained in left position only H Key retained in left and center (3-position only) D Key retained in left and right (3-position only) 800-262-IDEC (4332) • USA & Canada 519 Switches & Pilot Devices Switches & Pilot Devices ø16mm - LB Series Lever Switches (Assembled) Style Operator Position Standard Bezel (black) 2-position Maintained Solder/Tab Terminal (silver contacts) PC Board Terminal (gold contacts) SPDT LBjT-2T5 LBjT-2T1V DPDT LBjT-2T6 LBjT-2T2V 3PDT LBjT-2T7 LBjT-2T3V DPDT LBjT-3T2 LBjT-3T6V 3PDT LBjT-3T3 LBjT-3T7V DPDT LBjT-33T2 LBjT-33T6V 3PDT LBjT-33T3 LBjT-33T7V U D 3-position Flush Bezel (black) Maintained U C D Spring return from top/bottom Relays & Sockets Signaling Lights Contact U C D 24. For all part numbers, specify bezel in place of j. 1 (standard bezel), 6 (flush bezel). 25. See page page 522 for contact operation,. 26. See page page 533 for dimensions. Timers Lever Switches (Sub-assembled) Contact Block Operator Contactors + Contact Block Terminal Style Silver Solder/Tab Terminal Blocks = Operator Material Gold Gold Contact Part Number SPDT LB-T5 DPDT LB-T6 3PDT LB-T7 SPDT LB-T1 DPDT LB-T2 3PDT LB-T3 SPDT LB-T1V DPDT LB-T2V 3PDT LB-T3V Style Round Standard (Plastic) Position Function Part Number 2 Maintained LB1T-2 Maintained LB1T-3 Spring rerturn from both LB1T-33 Maintained LB6T-2 Maintained LB6T-3 Spring return from both LB6T-33 3 Round Flush Mount (Plastic) 2 3 Circuit Breakers PCB Completed Unit 520 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - LB Series Switches & Pilot Devices Buzzers (Assembled) Style Shape Voltage Standard Bezel Flush Bezel Solder/Tab Terminal PC Board Terminal Solder/Tab Terminal PC Board Terminal Black Bezel 12V DC – – LB6Z-1T03 LB6Z-1T03V 24V DC – – LB6Z-1T04 LB6Z-1T04V 12V DC LB3Z-1T03 LB3Z-1T03V LB8Z-1T03 LB8Z-1T03V 24V DC LB3Z-1T04 LB3Z-1T04V LB8Z-1T04 LB8Z-1T04V 12V DC – – LB6MZ-1T03 LB6MZ-1T03V 24V DC – – LB6MZ-1T04 LB6MZ-1T04V 12V DC – – LB8MZ-1T03 LB8MZ-1T03V 24V DC – – LB8MZ-1T04 LB8MZ-1T04V Round Signaling Lights Rectangular Relays & Sockets Metallic Bezel Round Rectangular Timers 27. IP54 Rated. 28. For IP40 rating, use part number LB3Z-104K. 29. See page page 534 for dimensions. Buzzers (Sub-assembled) Operator Completed Unit + Contact Block = Operator Terminal Style PCB Style Voltage 24V DC Shape LB-T00 Standard (Plastic) Rectangular LB3Z-103 LB3Z-104 Round LB6Z-103 LB6Z-104 LB-T00V Flush Mount (Plastic) Rectangular LB8Z-103 LB8Z-104 Round LB6MZ-103 LB6MZ-104 Rectangular LB8MZ-103 LB8MZ-104 Flush Mount (Metallic) 800-262-IDEC (4332) • USA & Canada 12V DC Circuit Breakers Mounting Style Terminal Blocks Part Number Solder/Tab 1705151131 Contactors Contact Block 521 Switches & Pilot Devices Switches & Pilot Devices ø16mm - LB Series Contact Operation Selector Switch, Illuminated Selector Switch, Key Selector Switch Operator Position & Contact Operation (Top View) Position Left Contact Center Right NO1 NC1 L R NO1 NC1 SPDT R L C1 Spring return from right Signaling Lights Maintained C1 Left Right NO1 NC1 NO2 NC2 90° 2-position Left Right NO1 NC1 NO2 NC2 DPDT C1 C2 C1 C2 Left Center Right NO1 NC1 NO2NC2 NO3 NC3 Left Center Right NO1 NC1 NO2 NC2 NO3 NC3 3PDT C1 C2 C3 C1 C2 C3 Left Right NO1 NC1 NO2 NC2 Left Right NO1 NC1 NO2 NC2 Left Right NO1 NC1 NO2 NC2 Relays & Sockets DPDT 45° 3-position L C C1 R Maintained L C R C L L C R R Spring return from Spring return from Spring return tworight left way C1 C2 C1 C2 C2 Left Center Right NO1NC1 NO2NC2 NO3NC3 Left Center Right NO1NC1 NO2NC2 NO3NC3 Left Center Right NO1NC1 NO2NC2 NO3NC3 C1 C1 C1 3PDT C2 C3 C2 C3 C2 C3 Lever Switch Lever Position & Contact Operation (Top View) Position Contact Down Center Up NO1 NC1 NO1 NC1 Timers SPDT C1 Left Right NO1 NC1 NO2 NC2 U 90° 2-position C1 Left Right NO1 NC1 NO2 NC2 DPDT D C1 Maintained C2 C1 C2 Left Center Right NO1 NC1 NO2NC2 NO3 NC3 Left Center Right NO1 NC1 NO2 NC2 NO3 NC3 3PDT Contactors C1 Terminal Blocks 45° 3-position C3 C1 U U C C C3 DPDT C1 D D Maintained C2 Left Right NO1 NC1 NO2 NC2 Left Right NO1 NC1 NO2 NC2 Spring return two-way C2 C1 C1 C2 C2 Left Center Right NO1NC1 NO2NC2 NO3NC3 Left Center Right NO1NC1 NO2NC2 NO3NC3 Left Center Right NO1NC1 NO2NC2 NO3NC3 C1 C1 C1 3PDT C2 C3 C2 C3 C2 C3 Mounting Hole Layout (mm) Flush Bezels 18 1 *1. Rectangular: 24mm 3PDT: 22 ∗1 23.2mm *2. 3PDT: 21mm 22 ∗1 22 ∗1 +0.2 0 18.2 22 ∗1 +0.2 0 22 ∗1 18.2 22 ∗1 +0.2 0 24.2 28 +0.2 0 18.2 +0.2 0 18.2 +0 0 .2 24.2 +0.2 0 24.2 +0.2 0 22 ∗2 2 18.2 +0.2 0 8. 18.2 +0.2 0 ø1 +0 0 .2 Rectangular 22 ∗2 2 22 ∗2 8. 22 ∗2 ø1 +0 0 .2 22 ∗2 2 22 ∗2 8. 22 ∗2 ø1 +0 .2 0 18 ∗ 6.2 Square 22 ∗2 Round LB1/LB2/LB3 22 ∗2 Standard Bezels ø1 Circuit Breakers C2 Left Right NO1 NC1 NO2 NC2 28 1. 3PDT: 23.2mm 28 2. Switches with Guard: 45mm When using the LB series with a rubber boot or terminal cover, make sure to note the dimensions on pages page 537 and page 538. 522 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - LB Series Switches & Pilot Devices PC Board Drilling Layout (mm) Notes for Designing PC Board and Circuit 1. 2. 3. 4. Use 1.6mm-thick glass epoxy PC board with drilled holes. Design a circuit so that the LB series can operate within the rated voltage and current range. Make sure that inrush current and voltage do not exceed the rating. Minimum applicable load is 5V AC/DC, 1mA on gold contacts. Since the *2.8mm-wide terminal touches the PC board as shown below , short circuit may occur with pattern lines. Design a circuit that prevents short circuits. SPDT/DPDT Contacts ∗2.8 ∗2.8 ∗2.8 ∗2.8 2.4 5 ∗2.8 5 2.4 Mounting Switch terminal Side ∗2.8 ∗2.8 ∗2.8 5 Soldered Side Soldered Side Mounting Side ∗2.8 5 COM Terminal 2.4 5 5 NO Terminal (0.8) SW Terminal SW Terminal (0.8) SW Terminal COM Terminal 2.4 6.0 ∗2.8 2.4 2.4 (0.8) (0.8) +0 0 .1 .2 SW Terminal SW Terminal 9ø1 SW Terminal +0 0 .1 .2 NO Terminal Mounting Side Mounting Side Timers 9ø1 1.6 (PC Board) NC Terminal NC Terminal Soldered Side 1.6 (PC Board) (0.5) (0.5) (0.5) (0.5) 6.0 8 Mounting Side Mounting SideLamp terminal Soldered Side 2.4 (0.8) 8 Soldered Side (0.8) (0.8) +0 0 .1 .2 9ø1 SW Terminal DPDT Lamp Terminal 8 Soldered Side Relays & Sockets SW Terminal DPDT 9Lamp Terminal ø1 . SW Terminal2 0+0.1 SPDT (0.8) (0.8) COM Terminal (0.5) 8 (0.5) 5 5 ∗2.8 COM Terminal NO Terminal ∗2.8 NC Terminal 2.4 ∗2.8 ∗2.8 NO Terminal 1.6 (PC Board) ∗2.8 (0.8) (0.8) 1.6 (PC Board) NC Terminal 3PDT Contacts 1.6 (PC Board) 1.6 (PC Board) ∗2.8 Lamp Terminal (+) Lamp Terminal (−) Lamp Terminal (+) Lamp Terminal (−) 6.95 (0.5) SW Terminal SPDT (0.8) 4.0 (0.8) 4.0 (0.5) (0.5) 6.95 (0.5) (0.8)(0.8) (0.8) 3.85 3.85 Signaling Lights (0.5) (0.5) PC Board Drilling Layout (Bottom View) 3PDT Contacts 9- ø1 .2 ot e ot 5 9.3 (N (N e 1.45 2) le ho r ed g rill ratin leve d ø6 ope king te 3) r c o o o f el (N th Contactors .2 ø1 8- le ho r d g e li e atin lev ) l dr er ing 3 e p 6 ø o ck ot 0.5 for e lo (N th 3.85 1 (Note 1) 1.95 (Note 1) 6.95 8 Terminal Blocks 1 ( Note 1) 5 5 10 2) 5 SPDT/DPDT Contacts 8 5. When designing, note the alignment of the center lines of the contact blocks and operators. 6. The diameter of the terminal hole is ø1.2. 7. Hole diameter may vary to meet installation requirements. Determine the location and the size of the hole so that the locking lever can be operated. Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 523 Switches & Pilot Devices Dimensions (mm) Illuminated Pushbuttons Standard Bezels Locking Ring Round 8 ø1 3.85 5.7 Mounting Plate 6.95 6.95 Signaling Lights Square 0.6 ø18 0.8W × 0.5t LOCK 6 5 18 5 6 1 Rectangular 3 17.8 3 1 2.8W × 0.5t 15.8 Relays & Sockets Panel Thickness: 0.5 to 3.2 mm Gasket 3.85 Switches & Pilot Devices ø16mm - LB Series 2 17.8 8.8 ∗ 5.5 7 PC Board Terminal 20.9 24 9 Solder/Tab Terminal Flush Bezels SPDT/DPDT Contacts Panel Thickness: 0.5 to 3.2 mm Round Gasket ø22 3.85 3.85 Locking Ring Round 2 ø2 11 22.5 2.6 1 1.2 2-R0.6 Square Square 22 22 Mounting Bracket 11 22.5 6.95 ∗ Solder/Tab Terminal 6.95 Timers Panel Thickness: 0.5 to 3.2 mm Gasket 0.8W × 0.5t LOCK 22 30.4 ∗ 5.5 Terminal Blocks Rectangular 1 6 3 2 17.8 [PC Board Terminal] 7 27.9 [Solder/Tab Terminal] 2 2 28 5.2 [With Guard] 28 [With Guard] Terminal Arrangement (Bottom View) Illuminated Pushbuttons Lamp Terminal (+) Lamp TOP Terminal (+) 22 Lamp Terminal (−) Pilot Lights TOP 12 22 24 14 24 21 X2 Lamp 11 Terminal (−) 21 X1 Circuit Breakers Rectangular 6 5 5 15.8 17.8 3 1 2.8W × 0.5t 11 22.5 Contactors 24.2 TOP 12 X1 14 X2 Lamp Terminal (+) Lamp Terminal (−) Lamp Terminal (+) X1 Lamp Terminal (−) X2 TOP X1 X2 11 (SPDT contacts on the right(SPDT only) contacts on the right only) Pilot Lights 524 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - LB Series Switches & Pilot Devices Standard Bezels Panel Thickness: 0.5 to 3.2 mm Gasket 1 2.6 1.2 Locking Ring Round 5.7 2-R0.6 8 ø1 Square ∗ Solder/Tab Terminal Mounting Ring 0.6 Signaling Lights 18 18 3 3 Rectangular 3 3 15.8 17.8 2.8W × 0.5t 0.8W × 0.5t LOCK ∗ 2 17.8 8.8 [PC Board Terminal] 20.9 24 9 [Flush] [Solder/Tab Terminal] Relays & Sockets 7 5.5 [Dome] 14.4 5.7 [Dome] Timers Flush Bezels Panel Thickness: 0.5 to 3.2 mm Round Gasket 2 ø2 3.85 Locking Ring Contactors Square 6.95 Mounting Bracket 22 0.8W × 0.5t LOCK Rectangular 2.6 3 17.8 2 5.5 ∗ PC Board Terminal 7 27.9 2 Solder/Tab Terminal 28 1.2 3 6 22 6 Terminal Blocks 17.8 15.8 1 1 2.8W × 0.5t 2-R0.6 ∗ Solder/Tab Terminal Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 525 Switches & Pilot Devices Non-Illuminated Pushbuttons Standard Bezels Panel Thickness: 0.5 to 3.2 mm Gasket Locking Ring Round 8 ø1 5.7 3.85 3.85 Switches & Pilot Devices ø16mm - LB Series Signaling Lights 6.95 6.95 Square Mounting Plate 0.6 18 0.8W × 0.5t 2.8W × 0.5t LOCK Rectangular 1 2.6 6 18 5 1.2 6 5 15.8 17.8 1 1 8.8 2 17.8 5.5 7 Panel Thickness: 0.5 to 3.2 mm Gasket Locking Ring 1.95 8 1.95 8 8 8 0.6 18 2.8W × 0.5t Rectangular 2.6 1 1 6 1 18 5 6 5 2-R0.6 1.2 20.8 18.8 11.9 8 ø1 Square LOCK Timers Round 5.7 0.8W × 0.5t 11.1 ∗ 2 23 8.8 7 5.5 PC Board Terminal Contactors ∗ Solder/Tab Terminal 9 Mounting Plate 20.9 ∗ Solder/Tab Terminal 24 9 Solder/Tab Terminal Terminal Arrangement (Bottom View) SPDT/DPDT Contacts 3PDT Contacts TOP TOP TOP TOP 22 22 12 12 32 22 3212 22 12 24 24 14 14 34 24 3414 24 14 21 21 11 11 31 21 3111 21 11 on the right only) (SPDT contacts(SPDT on the contacts right only) Circuit Breakers Terminal Blocks 2-R0.6 Solder/Tab Terminal PC Board Terminal Relays & Sockets 20.9 24 526 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - LB Series Switches & Pilot Devices Non-Illuminated Pushbuttons Flush Bezels Panel Thickness: 0.5 to 3.2 mm Gasket Locking Ring 2 ø2 3.85 3.85 Round 6.95 Mounting Bracket 0.8W × 0.5t 22 2.8W × 0.5t Rectangular 22 1.2 6 5 5 * 2 5.5 PC Board Terminal ∗ 7 27.9 2 Relays & Sockets 17.8 2.6 1 1 6 1 LOCK 17.8 15.8 Signaling Lights 6.95 Square 2-R0.6 28 ∗ Solder/Tab Terminal Solder/Tab Terminal Timers Contactors Terminal Blocks Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 527 Switches & Pilot Devices Selector Switches Standard Bezels Panel Thickness: 0.5 to 3.2 mm Gasket Locking Ring 3.85 3.85 2.6 1 2-R0.6 Round 6.95 ∗ Solder/Tab Terminal Mounting Ring 6.95 1.2 Signaling Lights Round 8 ø1 8 ø1 0.6 Relays & Sockets 8 8 8 8 1.95 [SPDT/DPDT] 1.95 Square Square 18 18 [3PDT] 0.8W × 0.5t 2.8W × 0.5t Rectangular 1 18 5 10.9 6 5 15.8 17.8 Rectangular 6 1 LOCK 18 Switches & Pilot Devices ø16mm - LB Series Timers 17.8 [SPDT/DPDT] 8.8 2 5.5 [PC Board Terminal] 7 20.9 8.7 24 24 15.5 [Knob Operator PC Board Terminal] [Knob Operator] [Lever Operator] 8.7 11.9 20.8 18.8 Contactors LOCK 18.1 11.1 23 [Lever Operator] Circuit Breakers Terminal Blocks [3PDT] 528 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - LB Series Switches & Pilot Devices Selector Switches Flush Bezels Panel Thickness: 0.5 to 3.2 mm Round Square Square 6.95 6.95 Mounting Bracket 0.8W × 0.5t Signaling Lights Rectangular Rectangular 22 6 22 5 5 6 1 1 22 22 2.8W × 0.5t LOCK 17.8 15.8 2 ø2 3.85 3.85 Round 2 ø2 Gasket Locking Ring 2 5.5 17.8 2 ∗ 7 PC Board Terminal 8.5 27.9 Knob Operator Solder/Tab Terminal 28 28 Knob Operator Lever Operator 2.8W × 0.5t 1 6 6 1 2.6 1.2 2-R0.6 2 7 27.9 ∗ Solder/Tab Terminal 11.1 Relays & Sockets ∗ Lever Operator Solder/Tab Terminal Panel Thickness: 0.5 to 3.2 mm Gasket Locking Ring Round Round 2 2 ø2 8 8 8 8 1.95 1.95 ø2 Square Square Mounting Bracket 0.8W × 0.5t 1 Rectangular 6 22 22 5 5 6 1 Rectangular Timers 20.8 18.8 11.9 22 22 2.8W × 0.5t LOCK 11.1 ∗ 2 5.5 23 2 PC Board Terminal 8.5 27.9 7 28 28 Knob Operator Lever Operator Knob Operator Solder/Tab Terminal 2.6 2-R0.6 1.2 1.2 6 6 1 1 ∗ 2 7 27.9 ∗ Solder/Tab Terminal 11.1 Contactors Lever Operator Solder/Tab Terminal Terminal Arrangement (Bottom View) SPDT/DPDT Contacts 3PDT Contacts TOP TOP TOP TOP 12 22 12 32 22 12 32 22 12 24 14 24 14 34 24 14 34 24 14 21 11 21 11 31 21 11 31 21 11 Terminal Blocks 22 contacts on the right only) (SPDT contacts on the (SPDT right only) Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 529 Switches & Pilot Devices Illuminated Selector Switches Standard Bezels Panel Thickness: 0.5 to 3.2 mm 2.6 1 2-R0.6 ∗ Solder/Tab Terminal 8 ø1 LOCK 6.95 Square 6.95 Signaling Lights Round 3.85 3.85 Gasket Locking Ring 1.2 Switches & Pilot Devices ø16mm - LB Series Mounting Ring 0.8W × 0.5t 0.6 2.8W × 0.5t 1 6 18 3 6 5 5 17.8 15.8 1 3 18 Rectangular 17.8 Relays & Sockets 2 5.5 ∗ 9.6 7 20.9 17.5 24 [Solder/Tab Terminal] [PC Board Terminal] Flush Bezels 1 Panel Thickness: 0.5 to 3.2 mm 2.6 Timers Gasket 3.85 3.85 6.95 1.2 2-R0.6 6.95 Locking Ring ∗ Solder/Tab Terminal Mounting Bracket 2.8W × 0.5t 2 1 ø2 6 3 2 17.8 Round 6 1 3 5 5 15.8 17.8 Contactors 0.8W × 0.5t LOCK ∗ 5.5 7 2.4 27.9 Terminal Blocks 10.3 [PC Board Terminal] Terminal Arrangement (Bottom View) Lamp Terminal (+) TOP 22 TOP 12 X1 Circuit Breakers [Solder/Tab Terminal] 24 Lamp Terminal (−) 14 X2 21 Lamp Terminal (+) Lamp Terminal (−) X1 X2 11 (SPDT contacts on the right only) 530 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - LB Series Switches & Pilot Devices Key Selector Switches Standard Bezels With Wave Key Panel Thickness: 0.5 to Thickness: 3.2 mm Panel 0.5 to 3.2 mm Gasket Gasket Locking Ring 3.853.85 6.956.95 8 18 2.8W × 0.5t 0.8W × 0.5t 2.8W × 0.5t 18 Rectangular Rectangular 6 18 18 14 14 6 66 5 5 55 17.8 2 17.8 2 5.5 [SPDT/DPDT] [SPDT/DPDT] LOCK ∗ ∗ 5.5 10.2 20.9 8.8 10.2 7 20.9 24 24 31.3 31.3 Key No. :N/A to 2H [Solder/Tab Terminal] [Solder/Tab Terminal] [PC Board Terminal] [PC Board Terminal] Key No. :N/A to 2H 11.911.9 8.5 8.5 LOCK 8.8 7 5.5 5.5 15.815.8 Square Square Relays & Sockets 17.817.8 0.6 [3PDT] [3PDT] 0.8W × 0.5t 1 1 LOCK 20.820.8 0.6 8 8 8 8 8 8 LOCK 18.818.8 Mounting Ring Mounting Ring 8 1.951.95 [SPDT/DPDT] [SPDT/DPDT] 1.951.95 2-R0.6 ∗ Solder/Tab Terminal ∗ Solder/Tab Terminal 8 ø1 8 ø1 Signaling Lights 6.956.95 2-R0.6 Round Round 1 2.6 1 2.6 1 1.2 1.2 1 3.853.85 Locking Ring Key No. :3H to 6H Key No. :3H to 6H 11.1 Timers 11.1 23 23 [3PDT] [3PDT] With Standard Key Panel Thickness: 0.5 to Thickness: 3.2 mm Panel 0.5 to 3.2 mm Gasket Gasket Ring Locking 2.6 3.853.85 1 1.2 1.2 2.6 3.853.85 Locking Ring 1 8 ø1 8 ø1 8 8 8 18 2.8W × 0.5t 0.8W × 0.5t 2.8W × 0.5t 18 Rectangular Rectangular 1 18 18 1 66 5 6 1 1 [3PDT] 0.8W × 0.5t [3PDT] 6 5 55 15.815.8 17.817.8 Square Square 17.8 2 17.8 2 5.5 5.5 8.8 9 7 20.9 8.8 9 7 20.9 24 25.1 24 25.1 [Solder/Tab Terminal] [Solder/Tab Terminal] 11.911.9 [PC Board Terminal] [PC Board Terminal] ∗ ∗ Circuit Breakers 18.818.8 0.6 Terminal Blocks LOCK LOCK 0.6 Ring 8 1.951.95 8 8 8 8 LOCK [SPDT/DPDT] [SPDT/DPDT] LOCK Mounting Ring Mounting 1.951.95 6.956.95 [SPDT/DPDT] [SPDT/DPDT] Contactors 2-R0.6 6.956.95 2-R0.6 ∗ Solder/Tab Terminal ∗ Solder/Tab Terminal 20.820.8 Round Round 11.1 11.1 23 23 [3PDT] [3PDT] 1705151131 Key Selector Switches 800-262-IDEC (4332) • USA & Canada 531 Switches & Pilot Devices 2.6 3.85 Round Round Bracket 8 8 1 6 7 ∗ 27.9 2 8.5 5.5 8.5 Round Round 6.95 ∗ Solder/Tab Terminal 8 1.95 1.95 6.95 6.95 2-R0.6 ∗ Solder/Tab Terminal Rectangular 8 6 1 Rectangular 6 22 1 5 5 1 2.8W × 0.5t 2 6 [3PDT] 2 ∗ 5.5 2 5.5 22 6 1 5 5 20.8 18.8 11.9 20.8 18.8 11.9 17.8 17.8 15.8 8 8 8 1.95 8 8 Contactors 15.8 23 [3PDT] [SPDT/DPDT] 2.8W × 0.5t 22 11.1 11.1 [SPDT/DPDT] 23 0.8W × 0.5t 0.8W × 0.5t LOCK 17.8 Square 22 [3PDT] LOCK 2 ø2 Square [3PDT] LOCK 17.8 Mounting Bracket 2 ø2 Mounting [SPDT/DPDT] Bracket [SPDT/DPDT] LOCK Panel Thickness: 0.5 to 3.2 mm 3.85 3.85 3.85 2-R0.6 Gasket Locking Ring 6.95 1.2 3.85 2.6 1.2 Timers 1 2.6 Key No. :3H to 6H Key No. :3H to 6H Gasket Locking Ring Panel Thickness: 0.5 to 3.2 mm 1.95 1 Terminal Blocks 28 Key No. :N/A to 2H Key No. :N/A to 2H [Solder/Tab Terminal] With Standard Key 7 ∗ 27.9 [PC Board7 Terminal] [PC Board Terminal] 2 27.9 28 18.1 18.1 [Solder/Tab Terminal] 28 [Solder/Tab Terminal] Terminal Arrangement (Bottom View) SPDT/DPDT Contacts TOP 22 Circuit Breakers 28 24.3 27.9 [Solder/Tab Terminal] [PC Board7 Terminal] 24.3 [PC Board Terminal] 22 14 2 2 ∗ 5.5 5.5 22 14 6 1 23 [3PDT] [SPDT/DPDT] Rectangular 1 5 5 6 [3PDT] Rectangular 22 6 1 5 5 20.8 18.8 11.9 20.8 18.8 11.9 15.8 17.8 17.8 15.8 8 8 1.95 8 8 Signaling Lights Relays & Sockets 2 23 11.1 [SPDT/DPDT] 17.8 22 2.8W × 0.5t 2.8W × 0.5t 0.8W × 0.5t 11.1 17.8 [3PDT] 0.8W × 0.5t LOCK LOCK Square Square [3PDT] LOCK ø Mounting Bracket Mounting [SPDT/DPDT] [SPDT/DPDT] LOCK 2 ø2 22 5.5 6.95 ∗ Solder/Tab Terminal 8 1.95 1.95 6.95 6.95 ∗ Solder/Tab Terminal 2-R0.6 6.95 1.2 2-R0.6 Locking Ring 3.85 1 2.6 1.95 1 Gasket Panel Thickness: 0.5 to 3.2 mm Locking Ring Panel Thickness: 0.5 to 3.2 mm Gasket 3.85 3.85 Flush Bezels With Wave Key 1.2 Switches & Pilot Devices ø16mm - LB Series 12 24 14 21 11 3PDT Contacts TOP TOP TOP 22 12 24 14 21 11 32 22 12 34 24 14 31 21 11 32 22 12 34 24 14 31 21 11 (SPDT contacts on the right only) (SPDT contacts on the right only) 532 www.IDEC.com 1705151131 1 Locking Ring 2.6 2-R0.6 Standard Bezels 1.95 8 8 8 6.95 6 1.95 1.95 1 5 1.95 5 1 1 1 6 5 5 6 6 3.85 6 3.85 [Solder/Tab Terminal] 6.95 6.95 1.95 1.95 3.85 8 8 3.85 3.85 3.85 8 8 6.95 Bracket 6.95 6.95 6.95 2 ø2 6 8 8 8 6 1.95 1.95 1.95 1 [SPDT/DPDT] 1 1.95 Mounting Bracket 0.8W × 0.5t Mounting 0.8W ×Bracket 0.5t 5 8 5 1.95 8 ∗ 8 2 8 8 17.8 5.5 7 [3PDT] [3PDT] 27.9 4.4 17 2 [Solder/Tab Terminal] 0.8W × 0.5t 17.8 7 1 6 ∗ 2 27.9 7 5.5 ∗ 4.4 27.9 17 7 4.4 27.9 4.4 17 20.8 18.8 11.9 11.1 [PC BoardLOCK Terminal] [Solder/Tab Terminal] Terminal] Terminal] [Solder/Tab Terminal] [PC Board Terminal][PC Board[Solder/Tab 18.8 11.9 LOCK 2 ø2 Terminal Blocks [SPDT/DPDT] [3PDT] 2 ø2 6 1 5 6 65 ∗ 2 5.5 17 LOCK ø2 1 6 15.8 5 5 6 1 1 11.12 5.523 17.8 17.8 [SPDT/DPDT] [SPDT/DPDT] 20.8 24 23 6.95 6.95 15.8 8 17.8 8 20.8 5 5 18.8 11.9 17.8 15.8 17.8 17.8 20.9 Contactors LOCK 15.8 10.8 7 Locking Ring Locking Ring 0.8W × 0.5t 0.8W × 0.5t LOCK 0.8W0.8W × 0.5t× 0.5t LOCK 0.8W × 0.5t [PC Board Terminal] LOCK Terminal Arrangement (Bottom View) 11.1 11.1 23 SPDT/DPDT [3PDT]Contacts [3PDT] TOP 8 ø1 [3PDT] [3PDT] Mounting [3PDT] [SPDT/DPDT] 23 ø1 8 ø1 Locking Ring ∗ [SPDT/DPDT] LOCK [SPDT/DPDT] 1.95 [3PDT] 8 2.8W × 0.5t 6 1 6 15.8 11.9 20.8 18.8 3.85 18.8 3.85 2-R0.6 11.1 ∗ Solder/Tab Terminal 23 ∗[3PDT] Solder/Tab Terminal ∗ Solder/Tab Terminal 18.8 11.9 8 8 8 8 1 5 5 17.8 11.9 1.2 1.2 11.1 2-R0.6 23 24 [3PDT] [Solder/Tab Terminal] Timers 11.1 20.8 8 8 8 8 1.95 1 6.95 1.95 17.8 8 15.8 8 8 8 1 18.8 5 5 20.8 17.8 15.8 15.8 20.8 18.8 1.211.9 20.8 1.2 2-R0.6 20.9 Gasket 2 17.8 5.5∗ 2.6 Bezels Flush 1 10.8 7 LOCK 0.8W × 0.5t [3PDT] 2.8W × 0.5t [PC Board Terminal] 0.8W × 0.5t LOCK 0.8W × 0.5t 2.8W × 0.5t Panel Thickness: 0.5 to 3.2 mm 2-R0.6 11.9 1 ∗ 2 5.5 [3PDT] 10.8 ∗ 2 7 20.9 24 10.8 2 17.8 [SPDT/DPDT] 5.5 11.1 [SPDT/DPDT] 7 20.9 24 5.5Board Terminal] [Solder/Tab Terminal] [PC [SPDT/DPDT] LOCK 23 ∗ Solder/Tab Terminal [PC Board Terminal] LOCK [Solder/Tab Terminal] [PC Board Terminal] [3PDT] LOCK Mounting Panel Thickness: Bracket 0.5 to 3.2 mmPanel Thickness: Panel Thickness: 0.5 to 3.2 mm 0.5 to 3.2 mm [SPDT/DPDT] 1 2.6 2.6 Gasket Gasket Gasket Locking Ring 17.8 8 ø1 Relays & Sockets 17.8 2.6 0.6 [SPDT/DPDT] 6 1.2 6.95 [SPDT/DPDT] [SPDT/DPDT] LOCK 1 2.8W × 0.5t Mounting Ring Signaling Lights 1.95 Mounting 0.6 Ring [SPDT/DPDT] 17.8 LOCK Locking Ring Mounting 0.8W × 0.5t 0.6 Ring ∗ Solder/Tab Terminal ∗ Solder/Tab Terminal Panel Thickness: 0.5 to 3.2 mm [3PDT] 2-R0.6 LOCK 2-R0.6 ∗ Solder/Tab Terminal 1.95 Locking Ring 3.85 1.2 1.2 2-R0.6 Locking Ring Gasket 2.6 3.85 1 8 2.6 2.6 0.6 0.5 to 3.2 mm Panel Thickness:[SPDT/DPDT] 0.5 to 3.2 mm Gasket Gasket 3.85 1 1 Mounting Lever Switches PanelRing Thickness: 6.95 ∗ Solder/Tab Terminal ø16mm - LB Series Switches & Pilot Devices 1.2 3.85 Switches & Pilot Devices 3PDT Contacts 23 [3PDT] TOP TOP TOP 12 22 12 32 22 12 32 22 12 24 14 24 14 34 24 14 34 24 14 21 11 21 11 31 21 11 31 21 11 Circuit Breakers 22 (SPDT contacts on the right only) (SPDT contacts on the right only) 1705151131 800-262-IDEC (4332) • USA & Canada 533 Switches & Pilot Devices Buzzers Standard Bezels IP54 Gasket Panel Thickness: 0.5 to 3.2 mm Locking Ring 2.6 1 2-R0.6 1.2 Switches & Pilot Devices ø16mm - LB Series * Solder/Tab Terminal Signaling Lights Mounting Ring LOCK 0.8W × 0.5t 3 17.8 3 3 3 17.8 2.8W × 0.5t 15.8 17.8 Relays & Sockets 0.6 * 2 8.8 5.5 7 [PC Board Terminal] IP40 Gasket 23.8 20.9 9 [Solder/Tab Terminal] Terminal Arrangement (Bottom View) Panel Thickness: 0.5 to 3.2 mm Locking Ring Flush & Standard IP54 TOP Buzzer terminal (+) X1 Buzzer terminal (–) Timers Mounting Ring 0.6 IP40 17.8 1.2 2-R0.6 Round * Solder/Tab Terminal 1.2 ø 17.8 2 5.5 [PC Board Terminal] Gasket * 7 27.9 2 28 [Solder/Tab Terminal] Panel Thickness: 0.5 to 3.2 mm Locking Ring 2.6 1 Rectangular 22 3 3 23.8 Flush Bezels 2.8W × 0.5t 3 3 0.8W × 0.5t 15.8 17.8 9 ø22 Mounting Bracket LOCK 14.6 Panel Thickness: 0.5 to 3.2 mm Gasket Locking Ring 2.6 1 2-R0.6 1.2 Contactors X2 Terminal Blocks * Solder/Tab Terminal Mounting Ring LOCK 0.8W × 0.5t 17.8 3 3 2.8W × 0.5t 3 3 15.8 17.8 0.6 Circuit Breakers 17.8 2 5.5 [PC Board Terminal] 534 * 8.8 7 20.9 23.8 9 [Solder/Tab Terminal] www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - LB Series Switches & Pilot Devices Accessories Item Material Part Number Remarks Metal: Nickel-plated brass MT-001 Used to tighten the locking ring when installing the units on to the panel. Stainless Steel MT-101 Used to remove the lens or button. Locking Ring Wrench ø18.0mm 60.0mm Signaling Lights Lens Removal Tool 60.0mm Switch Guard (180° Spring return) For round / square standard units For rectangular units Guard: Polyacetal Base: Polyarylate Note: not applicable for flush mounted units. Select operator with built-in switch guard. Degree of protection: IP65 With the gasket mounted on the switch, attach the switch guard and mount on the panel. See page page 538 for dimensions. Timers 1. For round units LA9Z-K3 Degree of protection: IP65 Used to protect standard pushbuttons and illuminated pushbuttons from inadvertent operation. See page page 538 for dimensions. With the gasket mounted on the switch, attach the switch guard and mount on the panel. Relays & Sockets AL-KH6SP Switch Guard for Single Board Mounting LB9Z-D1 2 2. For square units Silicon Rubber LB9Z-D2 Degree of protection: IP65 See page page 537 for dimensions. See page page 540 for mounting. Contactors For Standard Bezels Guard: Polyacetal Base: Polyarylate For rectangular standard units Rubber Boot for Standard Bezels 1 AL-K6SP 3 3. For rectangular units LB9Z-D3 Mounting Hole Plug Metal Locking nut: Polyacetal AL-BM6 Degree of protection: IP65 Tightening torque: 0.1 to 0.29 N•m See page page 537 for dimensions. AL-B6 Degree of protection: IP65 See page page 537 for dimensions. Gasket: Nitrile rubber Terminal Blocks Plug: Metal (Zinc diecast) Mounting Hole Plug Rubber Nitrile rubber (black) Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 535 Switches & Pilot Devices Accessories con’t Item Material Rubber Boot for Flush Bezels 1 Signaling Lights Switches & Pilot Devices ø16mm - LB Series 2 Part Number 1. For round units 2. For square units Remarks LB9Z-D6 LB9Z-D7 Silicon Rubber Degree of protection: IP65 See page page 537 for dimensions. See page page 540 for mounting. For Flush Bezels Relays & Sockets 3 3. For rectangular units LB9Z-D8 1. For round units LB9Z-BS6 Mounting Hole Plug 1 Plug: Polyamide (Black) 2 Timers 2. For square units Gasket: Nitrile rubber LB9Z-BS7 Mounting Plate: Stainless Steel Degree of protection: IP65 Panel thickness: 0.5 to 3.2mm See page page 537 for dimensions. Contactors 3 Terminal Cover 1 2 3. For rectangular units LB9Z-BS8 1. For SPDT/DPDT contacts LB9Z-VL2 See page page 538 for dimensions. LB9Z-VL3 Circuit Breakers Terminal Blocks 2. For 3PDT contacts 536 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - LB Series Switches & Pilot Devices Accessory Dimensions (mm) Rubber Boot Standard Bezel For round units (LB9Z-D1) For square units (LB9Z-D2) For rectangular units (LB9Z-D3) 26 11.5 11.5 Signaling Lights 11.5 20 ø2 0 20 Flush Bezel For round units (LB9Z-D6) For square units (LB9Z-D7) For rectangular units (LB9Z-D8) 24 30 4 4 4 Relays & Sockets 24 4 ø2 Mounting Hole Plug Standard Bezels ø1 6. 2 12 ø1 6. 2 2.5 +0 0 .2 AL-BM6 +0 0 .2 AL-B6 ø17.8 Timers Mounting Hole Layout Gasket Locking Ring Panel Thickness: 0.5 to 6 mm Mounting Hole Layout Flush Bezels F or square units (LB9Z-BS7) Panel Thickness: 0.5 to 3.2 mm Gasket Mounting Plate Locking Ring F or rectangular units (LB9Z-BS8) Contactors F or round units (LB9Z-BS6) 2 22 22 ø2 18.1 28 Mounting Hole Layout .2 +00 .2 18 18.2 +0.2 0 Mounting Hole Layout Terminal Blocks Mounting Hole Layout 2 +0.2 0 24.2 18.2 +0.2 0 ø Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 537 Switches & Pilot Devices Accessory Dimensions (mm) con’t Terminal Cover Standard Bezel For SPDT/DPDT contacts (LB9Z-VL2) 29.9 For 3PDT contacts (LB9Z-VL3) 29.9 TOP TOP 4.4 12.5 19.6 20.6 12.5 2.2 Signaling Lights 17.6 Switches & Pilot Devices ø16mm - LB Series 24.8 Switch Guard for Standard Bezel Models For round / square units (AL-K6SP) 34 For rectangular units (AL-KH6SP ) 24.0 18.0 33 13.0 23.5 11.0 13.0 23.5 11.0 Relays & Sockets 22 R Panel Thickness 0.5 to 2.0 14 For Single Board Mounting (LA9Z-K3) 32.6 Panel Thickness 0.5 to 3.2 R 8.8 22 Note: The panel depth is the same for switches with or without switch guards. Both models can be installed on the same PC board. 4.8 14 11 13 23.5 Timers 33 22 24 8.8 0 ø3. 4.8 Logo Stamping Key No. Stamping Logo Stamping Key No. 22 Key No. 14 22 Key No. Non-reversible Wave Key 0H 8.8 6.3 1.8 22 Key No. Stamping 14 4.8 8.1 7 8.8 Key No. Stamping Logo Stamping 0H 0H 22 8.8 Key No. Stamping Logo Stamping 14 14 6.3 6.3 8.8 Logo Stamping Key No. 22 14 6.3 Key No. Stamping Logo Stamping Key No. Key No. Stamping Logo Stamping Key No. 3H 3H Circuit Breakers Key No. 22 3H Terminal Blocks 14 4.8 Contactors Reversible Wave Key 18 Key No. 22 14 Wave Key Logo Stamping 8.8 0H Standard Key 22 8.8 12.4 Key No. Stamping 3H Key No. Stamping 538 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - LB Series Switches & Pilot Devices Replacement Parts Item Lens Marking Plate Part Number Remarks For round units Polyarylate ø15.4 H4mm AL6M-Lk For square units Polyarylate 15.4, H4mm AL6Q-Lk Specify the color code in place of k in the part number. A: Amber, C: Clear, G: Green, R: Red, S: Blue, Y: Yellow For rectangular units Polyarylate W21.4 x H4 x D15.4mm AL6H-Lk Note: Use a clear lens for or white (PW) illumination. For round units Polyarylate 15.4, H4mm AB6M-Bk For square units Polyarylate 15.4, H4mm AB6Q-Bk For rectangular units Polyarylate W21.4 x H4 x D15.4 AB6H-Bk For round units Acrylic ø13.7 H0.8 AL6M-k For square units Acrylic 13.7, H0.8mm AL6Q-k For rectangular units Acrylic W19.7 x H0.8 (0.4) x D13.7mm AL6H-k For all units Polyamide ø17.9, H3.9mm LB9Z-LNP For standard bezel Metal (Stainless steel) 17.9, t0.6mm LB9Z-LP1 For flush bezel Metal (Stainless steel) W21 x H8.2 x D20.6 t0.8mm LB9Z-LP6 For key selector switches Nickel-plated Brass AS6-SK See page page 538 for dimensions. LA9Z-SK-n Specify Wave key number in place of n in the part number. 0H: Standard wave key (reversible) 1H to 2H: Reversible wave key 3H to 6H: Non-reversible wave key See page page 538 for dimensions. Signaling Lights Button Material Specify the color code in place of k in the part number. B: Black, G: Green, R: Red, S: Blue W: White, Y: Yellow Relays & Sockets Specify the color code in place of k in the part number. B: Black, W: White Locking Ring Anti-rotation Ring Timers Anti-rotation Ring Spare Standard Key Contactors Spare Wave key Non-reversible Wave Key For Wave key selector switches Diecast zinc alloy (nickel plated) W14 x H2 x D30.8mm Terminal Blocks Reversible Wave Key LB Series Replacement LED Unit                     Item LED Unit Part Number DC5V LB9Z-LED5k AC/DC12V LB9Z-LED1k AC/DC24V LB9Z-LED2k kColor Code A G PW R S 8. Specify color code in place of the k in the part number. R: Red, G: Green, A: Amber, S: Blue, PW: White 9. All illuminated LB series contain an LED unit. 10. Use a white (PW) LED unit for yellow (Y) illumination. 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1705151131 Rated Operating Voltage 539 Switches & Pilot Devices Switches & Pilot Devices ø16mm - LB Series Precautions & Instructions
 • Turn off the power to the LB series control units before installation, removal, wiring, maintenance, and inspection. Failure to turn power off may cause electrical shocks or fire hazard. • To avoid burning your hand, use the lamp holder tool when replacing the lamps. Instructions Wiring Signaling Lights  Safety Precautions • For wiring, use wires of a proper size to meet voltage and current requirements. Solder correctly according to the instructions in "Wiring" and "Notes on Terminal Cover." Improper soldering may cause overheating and create a fire hazard. Also, when using tab terminals, use receptacles of appropriate size. 1. Solder the terminals at 350°C within 3 seconds using a 60W soldering iron. Sn-Ag-Cu type is recommended. When soldering, do not touch the LB series with the soldering iron. Also ensure that no tensile force is applied to the terminals. Do not bend the terminal or apply excessive force to the terminal. 2. Use non-corrosive liquid flux. Removing and Installing the Contact Block 3. Turn the locking lever on the contact block in the direction opposite to the arrow on the housing. Then the contact block can be removed. 4. Insert the contact block with the TOP markings on the contact block and the operator placed in the same direction. Then lock the units, turning the locking lever in the direction of the arrow. Relays & Sockets Terminal Cover Solder/tab terminal Insert the terminal cover into the contact block with the TOP markings on the contact block and the terminal cover in the same direction. Note: When wiring, insert the lead wires into the terminal cover holes before soldering. After wiring, terminal covers cannot be installed. Standard Bezel locking lever Panel Mounting Remove the contact block from the operator. Insert the operator into the panel cut-out from the front, then install the contact block to the operator. Flush Bezel Standard Bezel Timers Panel ➀ Anti-rotation Ring Contactors Operating Environment • Do not use the LB series where corrosive gases exist or under an environment exceeding the operating temperature and humidity ranges. Otherwise, damage such as contact failure or change of the surface color may occur. • Major parts of the switch are plastic. Scratches or damage may occur when scraped with a sharp object or if excessive load or shock is applied. Note that this may cause operation and appearance failure of the operator and bezel. • Application of detergent, cutting oil, or special chemicals to the switch may result in operation and/or appearance failure such as a change in surface color. TOP ➁ Locking Ring TOP  Contact Block Flush Bezel Panel Terminal Blocks Handling Contacts (micro switch) When using NC (normally closed) and NO (normally open) contacts of the same microswitch, avoid connections of different voltages, or connections of different types of power supplies. Failure to observe this instruction may cause a short-circuit. ➀Anti-rotation Ring TOP ➁ Locking Ring TOP Circuit Breakers  Contact Block Notes on Mounting Use the optional ring wrench (MT-001) to mount the operator onto the panel. Tightening torque should not exceed 0.7 N·m. Do not use pliers. Excessive tightening will damage the locking ring. 540 www.IDEC.com 1705151131
LB-T60 价格&库存
很抱歉,暂时无法提供与“LB-T60”相匹配的价格&库存,您可以联系我们找货
LB-T60
  • 1+70.20000
库存:6
LB-T60
  • 1+134.184191+17.36031
  • 5+117.094175+15.14926
  • 10+110.3935010+14.28235
  • 25+102.1183125+13.21173
  • 50+96.2655350+12.45452
  • 100+90.73742100+11.73931
库存:8
