RJ2S-CL-A240
RJ2S-CL-A240
    IDEC(日本和泉)
    SOCKETABLE
    通用 继电器 DPDT(2 Form C) 240VAC 线圈 可插
RJ2S-CL-A240 数据手册
www.idec.com 800-262-IDEC PCB Mounting Hole Layout 20.0 20.0 7.5 7.5 20.0 5.0 5.0 5.0 5.0 5.0 5.0 7.5 7.5 7.5 (1.9) 20.0 20.0 7.5 7.5 20.0 20.0 55 (A2) (A2) 11 (A1) (A1) 11 (A1) (A1) 88 (A2) (A2) 20.0 5.0 5.0 11 (A1) (A1) 88 (A2) (A2) 20.0 6-ø 1.3 hol 6-6ø es -1ø.31 .h3ohl eosle s (1.9) 4(11) 4(11) 4(11) • Operational life: 200K cycles at full resistive AC load; 50 million cycles, no load 1 (A1) • Blade model has optional green, non-polarized LED 3(14) 3(14) 3(14) 4(11) 5 (A2) • RoHS compliant Specifications 4(11) 4(11) 1 (A1) 2(12) 3(11) 4(14) 2(12) 8 3(11) 2(12) 3(11)4(14) 4(14) (A2) 7 6 77 66 1 (A1) 8 (A2) 5 55 3(11) 4(14) 3(11) 3(11)4(14) 4(14)6 66 5 55 5.0 (2.6) (2.6) (2.6) 0.5 1.0 0.5 (1.9) 0.3 (1.9) 0.5 13 max. 1.0 0.5 0.5 1.0 0.529 max. (28.8) (12.7) 1313max. max. (12.7) 2929max. (12.7) max.(28.8) (28.8) 20.0 (2.6) 8-ø 1.3 hol 8-8ø es 5.0 -1ø.3 5.0 1.h 3ohle osle s 0.5 0.5 1.0 0.5 0.3 0.5 0.5 13 max. 1.0 0.5 0.5 1.0 (12.7) (1.9) 29 max. (28.8) 0.5 (1.9) 1313max. 0.5 max. (12.7) 2929max. (12.7) max.(28.8) (28.8) 7.5 7.5 7.5 (2.6) (2.6) (2.6) 20.0 20.0 11 (A1) (A1) 88 (A2) (A2) 6-ø 1.3 hol 6-6ø es -1ø.31 .h3oh leosl es (1.9) • Contact rating: Blade: 8A (DPDT), 12A (SPDT) PCB: 8A (DPDT & DPST-NO), 12A (SPDT & SPST-NO), 16A (SPDT & SPST-NO) 5.0 11 (A1) (A1) 88 (A2) (A2) 1 (A1) 2(12) 3(11) 4(14) 2(12) 8 3(11) 2(12) 3(11)4(14) 4(14) 7(22) 6(21) 5(24) (A2) 7(22) 7(22)6(21) 6(21)5(24) 5(24) 1 (A1) 8 (A2) 3(11) 4(14) 3(11) 3(11)4(14) 4(14) 6(21) 5(24) 6(21) 6(21)5(24) 5(24) For more information on the these and other IDEC relays, visit: www.idec.com/relay IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.idec.com ©2007 IDEC Corporation. All Rights Reserved. Catalog No. RJ9Y-DS100-1 03/07 10K Gerneral Information (1.9) (1.9) (1.9) • Compact size: Blade: 12.7 x 27 x 28.8 mm PCB: 12.7 x 25.5 x 28.8 mm 3(14) 2(12) 3(14) 3(14) 2(12) 5 2(12) (A2) Features Blade Models 5.0 7.5 7.5 1.0 7.5 7.5 7.5 3.5 3.5 (2.6) (2.6) (2.6) 0.5 3.5 20.0 8-8ø -1ø.3 1.h 3ohle osle s (2.6) (2.6) 25.5 max. (25.3) 0.3 es 7.5 7.5 (2.6) (2.6) (2.6) (2.6) (2.6) 20.0 20.0 1 (A1) PCB Models ! Now Available RJ Series Relays hol (2.6) (1.9) 11 (A1) (A1) 55 (A2) (A2) 7.5 25.5 max. (25.3) 0.3 4.0 25.5 max. (25.3) 0.3 4.0 25.5 max. (25.3) 0.3 4.0 4-4ø -1ø.31 .h3ohl eosle s 1.3 5.0 1.3 ho 5.0 5.0 les 5.0 5.0 0.5 1.0(1.9) 0.5 (1.9) 0.3 0.5 13 max. 1.0 0.5 0.5 1.0 0.529 max. (28.8) (12.7) 1313max. max. (12.7) 2929max. (12.7) max.(28.8) (28.8) 25.5 max. (25.3) 0.3 0.3 0.3 4.0 4.0 RJ1V-A-* DPST-NO 25.5 max. (25.3) 25.5 max. (25.3) 0.3 0.3 4.0 4.0 0.3 0.3 4-ø (Bottom View) 3.5 20.0 8-ø 0.5 0.3 0.5 0.5 13 max. 1.0 0.5 0.5 1.0 (12.7) 29 max. (28.8) 0.5 1313max. 0.5 max. (12.7) 2929max. (12.7) max.(28.8) (28.8) 25.5 max. (25.3) 0.3 25.5 max. (25.3) 25.5 max. (25.3) 0.3 0.3 4.0 4.0 RJ2V-C-* DPDT 25.5 max. (25.3) 25.5 max. (25.3) 0.3 0.3 4.0 4.0 0.3 0.3 20.0 20.0 0.3 0.5 0.3 0.3 RJ1V-AH-* SPST-NO High Capacity 0.5 1.0(1.9) 0.5 (1.9) 0.5 13 max. 1.0 0.5 29 max. (28.8) 0.5 1.0 (12.7) 0.5 1313max. max. 2929max. max.(28.8) (28.8) (12.7) (12.7) (1.9) 4.0 25.5 max. (25.3) 25.5 max. (25.3) 0.3 0.3 4.0 4.0 0.3 0.3 RJ1V-CH-* SPDT High Capacity 5-ø 1.3 hol 3.5 5-5ø es -1ø.31 3.5 .h3oh 3.5 3.5 leosl 3.5 es 4.0 RJ1V-A-* SPST-NO 25.5 max. (25.3) 25.5 max. (25.3) 0.3 0.3 4.0 4.0 0.3 0.3 PCB Internal Circuit Diagrams (Bottom View) 0.5 0.5 1.0 0.5 0.3 0.5 0.5 0.5 0.5 13 max. 1.0 1.0 29 max. (28.8) 0.5 (12.7) (1.9) 0.5 (1.9) 1313max. max. 2929max. (12.7) max.(28.8) (28.8) (12.7) 4.0 25.5 max. (25.3) 25.5 max. (25.3) 0.3 0.3 PCB Relay Dimensions (mm) RJ1V-C-* SPDT NEW No. of poles Contact Configuration Contact Rating Contact Material Enclosure Ratings Contact Resistance Operating Time Release Time Between contact & coil Dielectric Between contacts of same poles Strength Between contacts of different poles Damage limits Vibration Resistance Operating extremes RJ1S RJ2S 1 SPDT 12A 2 DPDT 8A AgNi – 50 milliohms max 15ms max 10ms max 5,000V AC, 1 minute 1,000V AC, 1 minute – 3,000V AC, 1 min. 10-55Hz, amplitude 0.75mm 10-55Hz, amplitude 0.75mm Damage limits Shock Resistance 100m/s2 min (10G) Operating extremes AC DC Electrical Life @ AC Full Rated Load DC Operating Temperature Operating Humidity Dimensions (H x W x D mm) Weight (Approx.) 1,000m/s2 min (100G) 30,000,000 operations 50,000,000 operations 200,000 operations 100,000 operations -40 to 70º C 5 to 85% RH 12.7 x 27 x 28.8 19g Mechanical Life PCB Models RJ1V RJ1V (High CapacRJ2V ity) 1 1 2 SPDT, SPST-NO DPDT, DPST-NO 12A 16A 8A AgNi AgSnIn AgNi Flux protection 50 milliohms maxNote 1 15ms maxNote 2 10ms maxNote 2 5,000V AC, 1 minute 1,000V AC, 1 minute – 3,000V AC, 1 min. 10-55Hz, amplitude 0.75mm 10-55Hz, amplitude 0.75mm NO contact: 200m/s2 (20G) NC contact: 100m/s2 (10G) 1,000m/s2 min (100G) 30,000,000 operations 50,000,000 operations 200,000 operations 100,000 operations -40 to 70º CNote 3 5 to 85% RH 12.7 x 25.5 x 28.8 SPDT: 17g, SPST-NO: 16g DPDT: 17g, DPST-NO: 16g Notes: 1. Measured using 5V DC, 1A voltage drop method. 2. Measured at the rated voltage (at 20ºC), excluding contact bounce time. 3. 100% rated voltage. Ordering Information PCB Models Blade Models RJ Contact Configuration 1 - SPDT 2 - DPDT S-C RJ - Options Blank - Standard L - LED Coil Voltage D12 - 12V DC D24 - 24V DC D48 - 48V DC D100 - 100-110V DC A24 - 24V AC A120 - 120V AC A240 - 240V AC Number of Poles 1 - SP (Single Pole) 2 - DP (Double Pole) VContact Configuration C - FORM C (DT Double Throw) A - FORM A (ST Single Throw) Contact Configuration Blank - Standard H - High Capacity Type (RJ1 only) Coil Voltage D5 - 5V DC D6 - 6V DC D12 - 12V DC D24 - 24V DC D48 - 48V DC D100 - 100-110V DC A24 - 24V AC A120 - 120V AC A240 - 240V AC Specifications con’t on following page www.idec.com 800-262-IDEC www.idec.com 800-262-IDEC Contact Ratings Socket Dimensions - for Blade Relays (mm) NO NC NO 2 poles NC 12A AC250V DC125V DC5V 100mA 16A AC250V DC125V DC5V 100mA AC250V DC125V 8A M3 Terminal Screws M3 Terminal Screws 32.5 (4.7) 4.5 ±0.1 6.0 ±0.1 4.0±0.1 DC5V 100mA M3 Terminal Screws M3 Terminal Screws SJ1S-61 7.0 ±0.1 AC250V DC30V M3 Terminal Screws 14.0 DC5V 100mA M3 Terminal Screws (Terminal Arrangement) 1 5 4.0 ±0.1 15.0 ±0.1 SJ2S-05B M3 Terminal Screws M3 Terminal Screws M3 Terminal Screws SJ2S-07L M3 Terminal Screws M3 Terminal Screws SJ1S-61 32.5 (4.3) DC5V 10mA 20.0 ±0.1 5.0 ±0.1 2 3 4 8 7 6 5 36.5 s AC DC Coil Ratings le ho PCB Models A24 A120 A240 50Hz 43.9 8.8 4.3 60Hz 50Hz 60Hz 37.5 47.5 41.1 7.5 8.7 7.4 3.7 4.3 3.7 Rated Current (mA) ±15% (at 20ºC) 243 6,400 25,570 Coil Resistance (ohms)±10% (at 20ºC) Without LED1 With LED1 12V D12 44.2 48.0 271 24V 48V 100-110V 5V 6V 12V 24V 48V 100-110V D24 D48 D100 D5 D6 D12 D24 D48 D100 22.1 11.0 5.3 - 5.8 106 88.3 44.2 22.1 11.0 5.3 - 5.8 25.7 10.7 5.2 - 5.7 – – – – – – 1,080 4,340 18,870 47.2 67.9 271 1,080 4,340 18,870 Minimum Pickup Voltage Dropout Voltage Maximum Allowable Voltage3 80% max 30% min 140% Operating Characteristics2 Minimum Pickup Voltage Dropout Voltage Maximum Allowable Voltage3 1.0 Operating Characteristics2 Power Consumption 4.0 With LED1 Coil Voltage Code Rated Voltage Blade Models .3 24V 120V 240V Blade & PCB Models Without LED1 Coil Resistance (ohms)±10% (at 20ºC) M3 Terminal Screws M3 Terminal Screws Blade Relay Dimensions (mm) 0.9VA (60Hz) RJ1S RJ2S Power Consumption Bottom view 70% max 170% 10% min Bottom view 0.53W 160% SQ Socket Dimensions - for PCB Relays (mm) 70% max 170% 10% min 0.53-0.64W SQ2V-07B SQ1V-07B 160% Notes: 1. LED Indicator is only available on Blade relays. 2. Operating characteristics are against rated values at 20ºC. 3. The maximum allowable voltage is the maximum value which can be applied to the relay coils. Accessories Socket Part Numbers RJ1V (Std) RJ1SRJ2S RJ1VRJ2V H (HC), H (HC), Socket Specifications Socket Type DIN Rail Standard DIN Rail Fingersafe PCB Mount DIN Rail Standard DIN Rail Fingersafe PCB Mount Socket Part Number SJ1S-05B SJ1S-07L SJ1S-61 SJ2S-05B SJ2S-07L SJ2S-61 DIN Rail Fingersafe PCB Mount DIN Rail Fingersafe PCB Mount SQ1V-07B* SQ1V-63 SQ2V-07B* SQ2V-63 *Hold-down clip or spring must be removed to use with RJ relays. SJ1S Specifications Blade Models RJ1S (Std) PCB Models Relay Type Rated Insulation Voltage Applicable Wire Applicable Crimping Terminal Screw Size Weight SJ2S 250V AC/DC Max up to 2 - #14 AWG 2mm2 x 2 M3 Slotted-Phillips screw 30g 34g 3 1 ø1 Rated Voltage Rated Current (mA) ±15% (at 20ºC) 4 Terminal Arrangement 8- Coil Ratings Coil Voltage Code 2 5.0 ±0.1 7.5±0.1 PCB Models High Capacity Type AC250V DC30V SJ1S-07L 1.0 NC 1 pole 6A 6A/3A 4A 4A/2A M3 Terminal Screws s le ho NO 12A 12A 8A 8A 12A 12A 12A 6A 16A 16A 16A 8A 8A 8A 8A 4A SJ1S-05B 6 1. Standard Type 250V AC 250V AC 250V AC 250V AC AC250V DC30V AC250V DC30V AC250V DC30V AC250V DC30V AC250V DC30V AC250V DC30V Inductive Load cos_=0.3 L/R=7ms 7.5A 7.5A 4A 4A 7.5A 6A 7.5A 3A 8A 8A 8A 4A 4A 4A 4A 2A Minimum Applicable Load 36.5 2 poles Resistive Load Allowable Switching Voltage 4.0 Blade Models 1 pole NO NC NO NC Voltage Allowable Switching Current ø 5- Contact Ratings Contact Rated Load 14.0 Type Allowable Contact Power Resistive Inductive Load Load AC3000V AC1875VA AC3000V AC1875VA AC2000V AC1000VA AC2000V AC1000VA AC3000V AC1875VA DC360W DC180W AC3000V AC1875VA DC180W DC90W AC4000V AC2000VA DC480W DC240W AC4000V AC2000VA DC240W DC120W AC2000V AC1000VA DC240W DC120W AC2000V AC1000VA DC120W DC60W SQ1V-63 SQ1V-63 PCB pin layout SQ2V-63 SQ2V-63 PCB pin layout www.idec.com 800-262-IDEC www.idec.com 800-262-IDEC Contact Ratings Socket Dimensions - for Blade Relays (mm) NO NC NO 2 poles NC 12A AC250V DC125V DC5V 100mA 16A AC250V DC125V DC5V 100mA AC250V DC125V 8A M3 Terminal Screws M3 Terminal Screws 32.5 (4.7) 4.5 ±0.1 6.0 ±0.1 4.0±0.1 DC5V 100mA M3 Terminal Screws M3 Terminal Screws SJ1S-61 7.0 ±0.1 AC250V DC30V M3 Terminal Screws 14.0 DC5V 100mA M3 Terminal Screws (Terminal Arrangement) 1 5 4.0 ±0.1 15.0 ±0.1 SJ2S-05B M3 Terminal Screws M3 Terminal Screws M3 Terminal Screws SJ2S-07L M3 Terminal Screws M3 Terminal Screws SJ1S-61 32.5 (4.3) DC5V 10mA 20.0 ±0.1 5.0 ±0.1 2 3 4 8 7 6 5 36.5 s AC DC Coil Ratings le ho PCB Models A24 A120 A240 50Hz 43.9 8.8 4.3 60Hz 50Hz 60Hz 37.5 47.5 41.1 7.5 8.7 7.4 3.7 4.3 3.7 Rated Current (mA) ±15% (at 20ºC) 243 6,400 25,570 Coil Resistance (ohms)±10% (at 20ºC) Without LED1 With LED1 12V D12 44.2 48.0 271 24V 48V 100-110V 5V 6V 12V 24V 48V 100-110V D24 D48 D100 D5 D6 D12 D24 D48 D100 22.1 11.0 5.3 - 5.8 106 88.3 44.2 22.1 11.0 5.3 - 5.8 25.7 10.7 5.2 - 5.7 – – – – – – 1,080 4,340 18,870 47.2 67.9 271 1,080 4,340 18,870 Minimum Pickup Voltage Dropout Voltage Maximum Allowable Voltage3 80% max 30% min 140% Operating Characteristics2 Minimum Pickup Voltage Dropout Voltage Maximum Allowable Voltage3 1.0 Operating Characteristics2 Power Consumption 4.0 With LED1 Coil Voltage Code Rated Voltage Blade Models .3 24V 120V 240V Blade & PCB Models Without LED1 Coil Resistance (ohms)±10% (at 20ºC) M3 Terminal Screws M3 Terminal Screws Blade Relay Dimensions (mm) 0.9VA (60Hz) RJ1S RJ2S Power Consumption Bottom view 70% max 170% 10% min Bottom view 0.53W 160% SQ Socket Dimensions - for PCB Relays (mm) 70% max 170% 10% min 0.53-0.64W SQ2V-07B SQ1V-07B 160% Notes: 1. LED Indicator is only available on Blade relays. 2. Operating characteristics are against rated values at 20ºC. 3. The maximum allowable voltage is the maximum value which can be applied to the relay coils. Accessories Socket Part Numbers RJ1V (Std) RJ1SRJ2S RJ1VRJ2V H (HC), H (HC), Socket Specifications Socket Type DIN Rail Standard DIN Rail Fingersafe PCB Mount DIN Rail Standard DIN Rail Fingersafe PCB Mount Socket Part Number SJ1S-05B SJ1S-07L SJ1S-61 SJ2S-05B SJ2S-07L SJ2S-61 DIN Rail Fingersafe PCB Mount DIN Rail Fingersafe PCB Mount SQ1V-07B* SQ1V-63 SQ2V-07B* SQ2V-63 *Hold-down clip or spring must be removed to use with RJ relays. SJ1S Specifications Blade Models RJ1S (Std) PCB Models Relay Type Rated Insulation Voltage Applicable Wire Applicable Crimping Terminal Screw Size Weight SJ2S 250V AC/DC Max up to 2 - #14 AWG 2mm2 x 2 M3 Slotted-Phillips screw 30g 34g 3 1 ø1 Rated Voltage Rated Current (mA) ±15% (at 20ºC) 4 Terminal Arrangement 8- Coil Ratings Coil Voltage Code 2 5.0 ±0.1 7.5±0.1 PCB Models High Capacity Type AC250V DC30V SJ1S-07L 1.0 NC 1 pole 6A 6A/3A 4A 4A/2A M3 Terminal Screws s le ho NO 12A 12A 8A 8A 12A 12A 12A 6A 16A 16A 16A 8A 8A 8A 8A 4A SJ1S-05B 6 1. Standard Type 250V AC 250V AC 250V AC 250V AC AC250V DC30V AC250V DC30V AC250V DC30V AC250V DC30V AC250V DC30V AC250V DC30V Inductive Load cos_=0.3 L/R=7ms 7.5A 7.5A 4A 4A 7.5A 6A 7.5A 3A 8A 8A 8A 4A 4A 4A 4A 2A Minimum Applicable Load 36.5 2 poles Resistive Load Allowable Switching Voltage 4.0 Blade Models 1 pole NO NC NO NC Voltage Allowable Switching Current ø 5- Contact Ratings Contact Rated Load 14.0 Type Allowable Contact Power Resistive Inductive Load Load AC3000V AC1875VA AC3000V AC1875VA AC2000V AC1000VA AC2000V AC1000VA AC3000V AC1875VA DC360W DC180W AC3000V AC1875VA DC180W DC90W AC4000V AC2000VA DC480W DC240W AC4000V AC2000VA DC240W DC120W AC2000V AC1000VA DC240W DC120W AC2000V AC1000VA DC120W DC60W SQ1V-63 SQ1V-63 PCB pin layout SQ2V-63 SQ2V-63 PCB pin layout www.idec.com 800-262-IDEC PCB Mounting Hole Layout 20.0 20.0 7.5 7.5 20.0 5.0 5.0 5.0 5.0 5.0 5.0 7.5 7.5 7.5 (1.9) 20.0 20.0 7.5 7.5 20.0 20.0 55 (A2) (A2) 11 (A1) (A1) 11 (A1) (A1) 88 (A2) (A2) 20.0 5.0 5.0 11 (A1) (A1) 88 (A2) (A2) 20.0 6-ø 1.3 hol 6-6ø es -1ø.31 .h3ohl eosle s (1.9) 4(11) 4(11) 4(11) • Operational life: 200K cycles at full resistive AC load; 50 million cycles, no load 1 (A1) • Blade model has optional green, non-polarized LED 3(14) 3(14) 3(14) 4(11) 5 (A2) • RoHS compliant Specifications 4(11) 4(11) 1 (A1) 2(12) 3(11) 4(14) 2(12) 8 3(11) 2(12) 3(11)4(14) 4(14) (A2) 7 6 77 66 1 (A1) 8 (A2) 5 55 3(11) 4(14) 3(11) 3(11)4(14) 4(14)6 66 5 55 5.0 (2.6) (2.6) (2.6) 0.5 1.0 0.5 (1.9) 0.3 (1.9) 0.5 13 max. 1.0 0.5 0.5 1.0 0.529 max. (28.8) (12.7) 1313max. max. (12.7) 2929max. (12.7) max.(28.8) (28.8) 20.0 (2.6) 8-ø 1.3 hol 8-8ø es 5.0 -1ø.3 5.0 1.h 3ohle osle s 0.5 0.5 1.0 0.5 0.3 0.5 0.5 13 max. 1.0 0.5 0.5 1.0 (12.7) (1.9) 29 max. (28.8) 0.5 (1.9) 1313max. 0.5 max. (12.7) 2929max. (12.7) max.(28.8) (28.8) 7.5 7.5 7.5 (2.6) (2.6) (2.6) 20.0 20.0 11 (A1) (A1) 88 (A2) (A2) 6-ø 1.3 hol 6-6ø es -1ø.31 .h3oh leosl es (1.9) • Contact rating: Blade: 8A (DPDT), 12A (SPDT) PCB: 8A (DPDT & DPST-NO), 12A (SPDT & SPST-NO), 16A (SPDT & SPST-NO) 5.0 11 (A1) (A1) 88 (A2) (A2) 1 (A1) 2(12) 3(11) 4(14) 2(12) 8 3(11) 2(12) 3(11)4(14) 4(14) 7(22) 6(21) 5(24) (A2) 7(22) 7(22)6(21) 6(21)5(24) 5(24) 1 (A1) 8 (A2) 3(11) 4(14) 3(11) 3(11)4(14) 4(14) 6(21) 5(24) 6(21) 6(21)5(24) 5(24) For more information on the these and other IDEC relays, visit: www.idec.com/relay IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.idec.com ©2007 IDEC Corporation. All Rights Reserved. Catalog No. RJ9Y-DS100-1 03/07 10K Gerneral Information (1.9) (1.9) (1.9) • Compact size: Blade: 12.7 x 27 x 28.8 mm PCB: 12.7 x 25.5 x 28.8 mm 3(14) 2(12) 3(14) 3(14) 2(12) 5 2(12) (A2) Features Blade Models 5.0 7.5 7.5 1.0 7.5 7.5 7.5 3.5 3.5 (2.6) (2.6) (2.6) 0.5 3.5 20.0 8-8ø -1ø.3 1.h 3ohle osle s (2.6) (2.6) 25.5 max. (25.3) 0.3 es 7.5 7.5 (2.6) (2.6) (2.6) (2.6) (2.6) 20.0 20.0 1 (A1) PCB Models ! Now Available RJ Series Relays hol (2.6) (1.9) 11 (A1) (A1) 55 (A2) (A2) 7.5 25.5 max. (25.3) 0.3 4.0 25.5 max. (25.3) 0.3 4.0 25.5 max. (25.3) 0.3 4.0 4-4ø -1ø.31 .h3ohl eosle s 1.3 5.0 1.3 ho 5.0 5.0 les 5.0 5.0 0.5 1.0(1.9) 0.5 (1.9) 0.3 0.5 13 max. 1.0 0.5 0.5 1.0 0.529 max. (28.8) (12.7) 1313max. max. (12.7) 2929max. (12.7) max.(28.8) (28.8) 25.5 max. (25.3) 0.3 0.3 0.3 4.0 4.0 RJ1V-A-* DPST-NO 25.5 max. (25.3) 25.5 max. (25.3) 0.3 0.3 4.0 4.0 0.3 0.3 4-ø (Bottom View) 3.5 20.0 8-ø 0.5 0.3 0.5 0.5 13 max. 1.0 0.5 0.5 1.0 (12.7) 29 max. (28.8) 0.5 1313max. 0.5 max. (12.7) 2929max. (12.7) max.(28.8) (28.8) 25.5 max. (25.3) 0.3 25.5 max. (25.3) 25.5 max. (25.3) 0.3 0.3 4.0 4.0 RJ2V-C-* DPDT 25.5 max. (25.3) 25.5 max. (25.3) 0.3 0.3 4.0 4.0 0.3 0.3 20.0 20.0 0.3 0.5 0.3 0.3 RJ1V-AH-* SPST-NO High Capacity 0.5 1.0(1.9) 0.5 (1.9) 0.5 13 max. 1.0 0.5 29 max. (28.8) 0.5 1.0 (12.7) 0.5 1313max. max. 2929max. max.(28.8) (28.8) (12.7) (12.7) (1.9) 4.0 25.5 max. (25.3) 25.5 max. (25.3) 0.3 0.3 4.0 4.0 0.3 0.3 RJ1V-CH-* SPDT High Capacity 5-ø 1.3 hol 3.5 5-5ø es -1ø.31 3.5 .h3oh 3.5 3.5 leosl 3.5 es 4.0 RJ1V-A-* SPST-NO 25.5 max. (25.3) 25.5 max. (25.3) 0.3 0.3 4.0 4.0 0.3 0.3 PCB Internal Circuit Diagrams (Bottom View) 0.5 0.5 1.0 0.5 0.3 0.5 0.5 0.5 0.5 13 max. 1.0 1.0 29 max. (28.8) 0.5 (12.7) (1.9) 0.5 (1.9) 1313max. max. 2929max. (12.7) max.(28.8) (28.8) (12.7) 4.0 25.5 max. (25.3) 25.5 max. (25.3) 0.3 0.3 PCB Relay Dimensions (mm) RJ1V-C-* SPDT NEW No. of poles Contact Configuration Contact Rating Contact Material Enclosure Ratings Contact Resistance Operating Time Release Time Between contact & coil Dielectric Between contacts of same poles Strength Between contacts of different poles Damage limits Vibration Resistance Operating extremes RJ1S RJ2S 1 SPDT 12A 2 DPDT 8A AgNi – 50 milliohms max 15ms max 10ms max 5,000V AC, 1 minute 1,000V AC, 1 minute – 3,000V AC, 1 min. 10-55Hz, amplitude 0.75mm 10-55Hz, amplitude 0.75mm Damage limits Shock Resistance 100m/s2 min (10G) Operating extremes AC DC Electrical Life @ AC Full Rated Load DC Operating Temperature Operating Humidity Dimensions (H x W x D mm) Weight (Approx.) 1,000m/s2 min (100G) 30,000,000 operations 50,000,000 operations 200,000 operations 100,000 operations -40 to 70º C 5 to 85% RH 12.7 x 27 x 28.8 19g Mechanical Life PCB Models RJ1V RJ1V (High CapacRJ2V ity) 1 1 2 SPDT, SPST-NO DPDT, DPST-NO 12A 16A 8A AgNi AgSnIn AgNi Flux protection 50 milliohms maxNote 1 15ms maxNote 2 10ms maxNote 2 5,000V AC, 1 minute 1,000V AC, 1 minute – 3,000V AC, 1 min. 10-55Hz, amplitude 0.75mm 10-55Hz, amplitude 0.75mm NO contact: 200m/s2 (20G) NC contact: 100m/s2 (10G) 1,000m/s2 min (100G) 30,000,000 operations 50,000,000 operations 200,000 operations 100,000 operations -40 to 70º CNote 3 5 to 85% RH 12.7 x 25.5 x 28.8 SPDT: 17g, SPST-NO: 16g DPDT: 17g, DPST-NO: 16g Notes: 1. Measured using 5V DC, 1A voltage drop method. 2. Measured at the rated voltage (at 20ºC), excluding contact bounce time. 3. 100% rated voltage. Ordering Information PCB Models Blade Models RJ Contact Configuration 1 - SPDT 2 - DPDT S-C RJ - Options Blank - Standard L - LED Coil Voltage D12 - 12V DC D24 - 24V DC D48 - 48V DC D100 - 100-110V DC A24 - 24V AC A120 - 120V AC A240 - 240V AC Number of Poles 1 - SP (Single Pole) 2 - DP (Double Pole) VContact Configuration C - FORM C (DT Double Throw) A - FORM A (ST Single Throw) Contact Configuration Blank - Standard H - High Capacity Type (RJ1 only) Coil Voltage D5 - 5V DC D6 - 6V DC D12 - 12V DC D24 - 24V DC D48 - 48V DC D100 - 100-110V DC A24 - 24V AC A120 - 120V AC A240 - 240V AC Specifications con’t on following page
RJ2S-CL-A240 价格&库存
很抱歉,暂时无法提供与“RJ2S-CL-A240”相匹配的价格&库存,您可以联系我们找货
RJ2S-CL-A240
  • 1+149.359691+19.32367
