Switches & Pilot Devices
ø30mm - TWND Series
New TWND Series — Full Size NEMA Pushbuttons
Signaling Lights
Relays & Sockets
New! TWND Series: Heavy duty switches built to last
Key features:
• Variety of button sizes up to 2 9/16” (65mm)
• LED illumination
With button sizes up to 2 9/16” (65mm), chrome plated zinc locking rings, die
cast zinc mounting threads, steel anti-rotation rings, and self cleaning contacts,
the TWNDs are here to stay.
The TWND series also offers LED illumination in full voltage and
transformer models.
• Transformer or full voltage
• Slow make, double break wiping contacts
Timers
• Rugged construction includes chrome plated zinc locking ring die cast
The rugged series of TWND switches offers both variety and durability in an
attractive design.
Regardless of your switching needs, the NEW TWND series provides the kind of
long lasting, industrial strength quality you’ve come to expect from IDEC.
• Modular construction for maximum flexibility
• Available assembled or as sub-components
File No. LR21451
R 50363567
Terminal Blocks
UL Listed
File No. E68961
Contactors
• UL Type 4X, 13 and IP65 watertight/oiltight panel
Certificate No.
2016010305902410
Circuit Breakers
1904041136
800-262-IDEC (4332) • USA & Canada
745
Relays & Sockets
Signaling Lights
ø30mm - TWND Series
Specifications
Conforming to Standards
EN60947-5-1, UL508, CSA C22-2 No.14
Approvals
CSA: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V)
UL: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons
TÜV: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V)
Operating Temperature
Operation: –25 to +50°C (illuminated versions) -25 ~ +70C non-illuminated
Storage: –40 to +80°C (without freezing) C-> °C
Vibration Resistance
5 to 55Hz, 98m/sec2 (10g) conforming to IEC60068-2-6
Shock Resistance
980m/sec2 (100g) conforming to IEC60068-2-27
Electric Shock Protection
Class 2 conforming to IEC60664-1
Degree of Protection
IP65 (from front of the panel) (conforming to IEC60529)
UL Type 1, 2, 3, 3R, 3S, 4, 4X, 5, 12, 13 (conforming to NEMA ICS6-110)
Mechanical Life
Momentary pushbuttons: 5,000,000 (1800 operations per hour)
All other switches: 500,000
Pollution Degree
(conforming to IEC60947-1)
3
Mechanical-Electrical Specifications
Rated Operational Characteristics
Rated Insulation Voltage
Rated Impulse Withstanding Voltage
øDielectric Strength
Rated Thermal Current
Minimum Switching Capacity
Contact Operation
Timers
Operating Force
AC-15: A600
600V
Between live and dead metal parts
2.5kV AC, 1 minute
10 Amp
5 mA at 3V AC/DC (applicable range may vary with operating conditions and load types)
Slow break NC or NO
Flush and extended pushbuttons—with 1NO or 1NC contact: 6.2±2N (momentary), 9.0±1.5N
Additional contacts—1NO or 1NC: +3.0N
Unit
Recommended Terminal Torque
HW-U Contact Block
Contactors
Illuminated Unit (*1)
Applicable Wire Size
Pilot Light
2
1.0 to 1.3
M3.5
Number of Wires
Crimping Terminal
ø0.5 to 1.6 mm (AWG14 to 22)
Solid Wire
ø1.7 to 2.0 mm (AWG12)
0.3 to 2.0 mm2 (AWG14 to 22)
Stranded Wire
2.1 to 3.5 mm2 (AWG12)
Crimping Terminal
Solid Wire
Stranded Wire
0.3 to 2.0 mm (AWG14 to 22)
Crimping Terminal
Solid Wire
Stranded Wire
ø0.3 to 2.0 mm (AWG14 to 22)
M3.5
0.6 to 1.0 (M3.0)
2
1.0 to 1.3 (M3.5)
1. * refers to the lamp terminals of the illuminated push buttons and selector switches.
Contact Resistance
Initial contact resistance of 50mΩ or less
4mm (NO and NC)
2mm (NO-EM and NC-LB)
LEDs: 6V: 8mA, 12V: 11mA, 24V: 11mA, 120V: 8.8mA, 240V: 8.6mA
Silver
Contact Gap
Terminal Blocks
Terminal Screw
2
2
1
2
1
Recommended Tightening
Torque (Nm)
1.0 to 1.3
1.0 to 1.3
1.2 to 1.3
1.0 to 1.3
1.2 to 1.3
Wire
LED Ratings
Contact Material
Contact Ratings
AC-15 (A600)
Contact Ratings by Utilization Category IEC 60947-5-1
DC-13 (P600)
Operational Voltage
Circuit Breakers
AC 50/60 Hz
Operation Current
DC
746
24V
48V
50V
110V
220V
440V
AC-12 Control of resistive loads & solid state loads
10A
10A
10A
6A
2A
AC-15 Control of electromagnetic loads (> 72VA)
10A
7A
5A
3A
1A
DC-12 Control of resistive loads & solid state loads
10A
5A
2.2A
1.1A
DC-13 Control of electromagnets
5A
2A
1.1A
0.6A
www.IDEC.com
1904041136
ø30mm - TWND Series
Non-Illuminated Pushbuttons (Assembled)
Signaling Lights
Relays & Sockets
Assembled Pushbuttons
A
B
D
1
10
NU
R
Function
Button Color
B: Momentary
O: Maintained
V: Pushlock Turn Reset
Y: Push-Pull
B: Black
R: Red
G: Green
S: Blue
W: White
Y: Yellow
Contact Arrangement
Blank: Octagonal
F: Full Shroud
G: Mushroom Shroud
P: Neoprene Boot
Timers
10: 1NO 01: 1NC
20: 2NO 02: 2NC
11: 1NO-1NC 22: 2NO-2NC
Bezel Shape
Button Shape
Series Designation
D: TWND Series
Contactors
1: Flush
2: Extended
3: Mushroom ø 40mm
4: Jumbo Mushroom ø 65mm
1. Use only when interpreting part numbers. Do not use for developing part numbers.
2. Custom contact configurations available, contact IDEC for details.
Terminal Blocks
Circuit Breakers
1904041136
747
Circuit Breakers
Terminal Blocks
Contactors
Timers
Relays & Sockets
Signaling Lights
ø30mm - TWND Series
Style
j Button Color Codes
Contacts
Momentary
Maintained
1NO
1NC
1NO-1NC
2NO
2NC
ABD110NUj
ABD101NUj
ABD111NUj
ABD120NUj
ABD102NUj
AOD110NUj
AOD101NUj
AOD111NUj
AOD120NUj
AOD102NUj
1NO
1NC
1NO-1NC
2NO
2NC
ABD210NUj
ABD201NUj
ABD211NUj
ABD220NUj
ABD202NUj
AOD210NUj
AOD201NUj
AOD211NUj
AOD220NUj
AOD202NUj
Extended with
Neoprene Boot†
1NO
1NC
1NO-1NC
2NO
2NC
ABPD210NUj
ABPD201NUj
ABPD211NUj
ABPD220NUj
ABPD202NUj
AOPD210NUj
AOPD201NUj
AOPD211NUj
AOPD220NUj
AOPD202NUj
Recessed
1NO
1NC
1NO-1NC
2NO
2NC
ABFD110NUj
ABFD101NUj
ABFD111NUj
ABFD120NUj
ABFD102NUj
AOFD110NUj
AOFD101NUj
AOFD111NUj
AOFD120NUj
AOFD102NUj
Extended with
Full Shroud
1NO
1NC
1NO-1NC
2NO
2NC
ABFD210NUj
ABFD201NUj
ABFD211NUj
ABFD220NUj
ABFD202NUj
AOFD210NUj
AOFD201NUj
AOFD211NUj
AOFD220NUj
AOFD202NUj
ø 40mm
Mushroom Head
1NO
1NC
1NO-1NC
2NO
2NC
ABD310NUj
ABD301NUj
ABD311NUj
ABD320NUj
ABD302NUj
AOD310NUj
AOD301NUj
AOD311NUj
AOD320NUj
AOD302NUj
ø 40mm
Mushroom Head
with Full Shroud
1NO
1NC
1NO-1NC
2NO
2NC
ABGD310NUj
ABGD301NUj
ABGD311NUj
ABGD320NUj
ABGD302NUj
AOGD310NUj
AOGD301NUj
AOGD311NUj
AOGD320NUj
AOGD302NUj
ø 65mm
Jumbo Mushroom Head
1NO
1NC
1NO-1NC
2NO
2NC
ABD410NUj
ABD401NUj
ABD411NUj
ABD420NUj
ABD402NUj
AOD410NUj
AOD401NUj
AOD411NUj
AOD420NUj
AOD402NUj
ø 65mm
Jumbo Mushroom Head
with Shallow Shroud
1NO
1NC
1NO-1NC
2NO
2NC
ABGD410NUj
ABGD401NUj
ABGD411NUj
ABGD420NUj
ABGD402NUj
AOGD410NUj
AOGD401NUj
AOGD411NUj
AOGD420NUj
AOGD402NUj
ø 65mm
Jumbo Mushroom Head
With Deep Shroud
1NO
1NC
1NO-1NC
2NO
2NC
ABFD410NUj
ABFD401NUj
ABFD411NUj
ABFD420NUj
ABFD402NUj
AOFD410NUj
AOFD401NUj
AOFD411NUj
AOFD420NUj
AOFD402NUj
Flush
Extended
Color
Code
Black
B
Green
G
Red
R
Blue
S
Yellow
Y
White
W
1. 65mm Jumbo mushroom not available in white.
2. Neoprene boot is not available in blue or white.
1. In place of j, specify the Button Color Code.
2. For sub-assembly part numbers, see next page.
4. †Neoprene boot available only in Black (B), Green (G), Red (R) and Yellow (Y).
748
www.IDEC.com
1904041136
ø30mm - TWND Series
Non-Illuminated Pushbuttons (Sub-Assembled)
Contact Block
Operator
Part Number
Momentary
Maintained
ABD1200T8
AOD1200T8
AOLFD2300T8
ø 40mm Mushroom/ø
65mm Jumbo
Mushroom
ABD3400T8
AOD3400T8
ABGD-300T
AOGD-300T
Style
Flush
ABD1BN-j
Extended
ABD2BN-j
ø 40mm Mushroom
ABD3BN-j
ø 65mm Jumbo
Mushroom
ABD4BN-j
AOGD-400T
In place of j, specify the Button Color Code. (See table previous page)
Contact Blocks
ABFD-400T
AOFD-400T
All Control Units
1NC
HW-U10-F
HW-U01-F
HW-U10R-F
(early make)
HW-U01R-F
(late break)
HW-DB
Circuit Breakers
Dummy Block
Part Number
1NO
Terminal Blocks
Style
ø 65mm Jumbo
Mushroom with
Deep Shroud
Contactors
ABGD-400T
Part Number
Timers
ALFD2300T8
ø 65mm Jumbo
Mushroom with
Shallow Shroud
Complete Part
Relays & Sockets
Extended with
Full Shroud
ø 40mm Mushroom
with Full Shroud
Buttons and Lenses
Style
Flush/Extended
Button
Signaling Lights
Operators
1. Dummy blocks (no contacts) are used with an odd number of contact blocks.
2. Combining HW-U10R-F and HW-U01R-F result in overlapping contacts (remain on, or
closed, when switch is moved between two positions).
1904041136
749
ø30mm - TWND Series
Signaling Lights
Stop Switches (Assembled)
Relays & Sockets
Assembled Stop Switches
A
V
(L)
D
3
22
11
Timers
NU
R
Function
Button/Lens Color Code
Y: Push-Pull
A: Amber
G: Green
R: Red
S: Blue
W: White
Y: Yellow
Illumination
Blank: None
L: Illuminated
(illuminated units only)
Series Designation
D: LED
D: TWND Series
Contact Arrangement
Button/Lens Size
10: 1NO 01: 1NC
20: 2NO 02: 2NC
3: 40mm Mushroom
Contactors
D
Illumination Circuit
Full Voltage:
66: 6VAC/DC
11: 12VAC/DC
22: 24AC/DC
Terminal Blocks
QH2: 120VAC
QM4: 240VAC
Transformer:
126: 120VAC step down transformer
246: 240VAC step down transformer
Circuit Breakers
486: 480VAC step down transformer
750
www.IDEC.com
1904041136
ø30mm - TWND Series
Stop Switches
Style
Contacts
Part Number
ø 40mm Pushlock Turn Reset
1NO-1NC
2NO
2NC
AVLD3l11DNUR*
AVLD3l20DNUR*
AVLD3l02DNUR*
Transformer
1NO-1NC
2NO
2NC
AVLD3 m 11DNUR*
AVLD3 m 20DNUR*
AVLD3 m 02DNUR*
Non-Illuminated
1NO
1NC
1NO-1NC
2NO
2NC
AYD310NUj
AYD301NUj
AYD311NUj
AYD320NUj
AYD302NUj
Non-Illuminated
ø 40mm Illuminated Pushlock Turn Reset
Full Voltage
ø 40mm Push-Pull
ø 40mm Illuminated Push-Pull
Full Voltage
1NO-1NC
2NO
2NC
AYLD3 m 11DNUk **
AYLD3 m 20DNUk **
AYLD3 m 02DNUk **
In place of j, specify the button color code
In place of k, specify the lens color code.
In place of l, specify the Full Voltage (lamp voltage) Code.
* Only available in red.
In place of m, specify the transformer voltage code.
**Not available in blue.
For nameplates and accessories, see page 769 and page 767.
For dimensions, see page 772.
G
Red
R
Blue
S
Yellow
Y
k Lens Color Codes
Color
Code
Amber
Green
Red
Blue
White
Yellow
A
G
R
S
W
Y
l Full Voltage Codes
Voltage
Code
6V AC/DC
66
12V AC/DC
11
24V AC/DC
22
120V AC
QH2
240V AC
QM4
m Transformer Voltage Codes
Voltage
Code
120VAC
126
240VAC
246
480VAC
486
Transformers step down to 6V.
Contactors
1.
2.
3.
4.
5.
6.
7.
8.
9.
AYLD3l11DNUk **
AYLD3l20DNUk **
AYLD3l02DNUk **
Green
Timers
Transformer
1NO-1NC
2NO
2NC
B
Relays & Sockets
AVD310NUR*
AVD301NUR*
AVD311NUR*
AVD320NUR*
AVD302NUR*
Code
Black
Signaling Lights
1NO
1NC
1NO-1NC
2NO
2NC
Color
Terminal Blocks
Circuit Breakers
1904041136
751
ø30mm - TWND Series
Stop Switches (Sub-Assembled)
Transformer*
Operator
Lamp
Button/Lens
Complete Part
* Not required for full voltage units.
Relays & Sockets
Signaling Lights
Operators
Lamps
Style
Style
Part Number
Voltage
6V AC/DC
12V AC/DC
24V AC/DC
120V AC
240V AC
LED
ø40mm Illuminated and
Non-illuminated
Pushlock Turn Reset
AVD000T8
ø 40mm Illuminated and
Non-illuminated Push-Pull
Part Number
LSTD-6l
LSTD-1l
LSTD-2l
LSTD-H2l
LSTD-M4l
1. In place of k, specify the LED color code.
2. The LED contains a current-limiting resistor
and a protection diode.
AYD000T8
Buttons and Lenses
Style
Part Number
Button for Pushlock Turn
Reset Stop Switches
(ø40mm, red only)
Timers
k Lens Color Codes
AVN3B-R
Color
Code
Black
Green
Red
Blue
Yellow
B
G
R
S
Y
Color
Code
Amber
Green
Red
Blue
White
A
G
R
S
W
l LED Color Codes
Color
Code
Amber
Green
Red
Blue
White
A
G
R
S
W
Contact Blocks
Lens for Illuminated Pushlock
Turn Reset Stop Switches
(ø40mm, red only)
AVLN3LU-R
Part Number
1NO
1NC
Style
All Control Units
Button for Push-Pull Stop
Switches (ø40mm)
AYD3BN-j
HW-U10-F
HW-U01-F
HW-U10R-F
(early make)
HW-U01R-F
(late break)
Contactors
Dummy Block
Lens for Illuminated Push-Pull
Stop Switches
(ø40mm)
2 pos*
AYLD3L-k
HW-DB
2. Combining HW-U10R-F and HW-U01R-F result in overlapping contacts.
Transformers
1. In place of j, specify the Button Color Code. (See table below)
2. In place of k, specify the LED Color Code.
3. *Not available in blue.
Style
Primary Voltage
(50/60Hz)
Part Number
120V AC
TW-F126B
240V AC
TW-F246B
480V AC
HW-L486
Terminal Blocks
Lamp Circuit Components
Style
Long Lamp Holder
Application
Used with Full-size Transformer and
two contact blocks
Used with Full Voltage Adaptor and
two contact blocks
Circuit Breakers
Lead Holder
Used with TW-LH2 holder when using
four contact blocks
Part Number
6V secondary voltage (uses 6V LED).
TW-LH2
Full Voltage Modules
Style
HW-LH3
Dummy Block with
Description
For use with
odd number
of contacts.
Finger-Safe
For use with
even number Finger-Safe
of contacts.
Part Number
HW-DA1FBN
TW-DA1FB
All Transformers step down to 6V (use 6V lamp).
752
www.IDEC.com
1904041136
ø30mm - TWND Series
Pilot Lights (Assembled)
Signaling Lights
Assembled Pilot Lights
A
P:
D
1
126
D
NU
R
Lens Color Code
Pilot Light
A:
Amber
G: Green
R: Red
S: Blue
W: White
Y: Yellow
Series Designation
D:
Relays & Sockets
Function
P
TWND Series
Lens Shape
1: Dome
D: LED
Rated Operational Voltage (Primary)
Full Voltage Type
66: 6VAC/DC
11: 12VAC/DC
22: 24VAC/DC
QH2: 120VAC
QM4: 240VAC
Timers
Transformer Type
126: 120V AC
246: 240V AC
486: 480V AC
Contactors
LED Pilot Lights
Style
k Lens Color Codes
Operating
Voltage
Part Number
Color
Code
LED
Amber
A
Green
G
Transformer Dome
APD1126DNUk
APD1246DNUk
APD1486DNUk
R
S
White
W
Yellow
Y
Full Voltage Dome
APD1lDNUk
Voltage
Code
6V AC/DC
66
12V AC/DC
11
24V AC/DC
22
120V AC
QH2
240V AC
QM4
Circuit Breakers
1. In place of k, specify the Lens/LED Color Code.
2. In place of l, specify the Full Voltage Code (LED voltage).
3. Yellow pilot light comes with white LED.
1904041136
Red
Blue
Terminal Blocks
120V AC
240V AC
480V AC
753
ø30mm - TWND Series
Pilot Lights (Sub-Assembled)
Transformer*
Operator
Lamp
Lens
Complete Part
Signaling Lights
One Each from Left Column
Operators
Part Number
Transformer or
FULL Voltage
Primary Voltage (50/60Hz)
Part Number
APD-F
APD09ST8
Required for all full voltage models. Two pieces each.
2 clips required for full voltage pilot lights
Transformers (only for Pilot Lights)
Lenses
Style
Style
Timers
One Selection from Right Column
Full Voltage Clips
Style
Relays & Sockets
plus
Primary Voltage
(50/60Hz)
Part Number
Part Number
LED
Dome Lens
120V AC
TWD-0126
240V AC
TWD-0246
480V AC
TWD-0486
APN106LN-k
6V secondary voltage (use 6V lamp).
Contactors
1. In place of k, specify the Lens Color Code.
Style
LED
Voltage
Part Number
6V AC/DC
LSTD-6l
12V AC/DC
LSTD-1l
24V AC/DC
LSTD-2l
120V AC
LSTD-H2l
240V AC
LSTD-M4l
l LED Color Codes
Color
Code
Color
Code
Amber
Green
Red
Blue
White
Yellow
A
G
R
S
W
Y
Amber
Green
Red
Blue
White
A
G
R
S
W
Yellow LED not available, use
white LED with Yellow lens.
2. The LED contains a current-limiting resistor and a protection diode.
Circuit Breakers
Terminal Blocks
k Lens Color Codes
Lamps
754
www.IDEC.com
1904041136
ø30mm - TWND Series
Signaling Lights
Relays & Sockets
Assembled Illuminated Pushbuttons
A
L
D
2
126
11
D
NU
R
Lens Color Code
L: Momentary Action
OL: Maintained Action
A: Amber
G: Green
R: Red
S: Blue
W: White
Y: Yellow
Bezel Shape
Blank: Octagonal
F: Full Shroud
Series Designation
Timers
Function
D: LED
D: TWND Series
Contact Arrangement
Lens Shape
2: Extended
3: Mushroom ø 40mm
Contactors
20: 2NO 02: 2NC
11: 1NO-1NC
Full Voltage Type
66: 6VAC/DC
11: 12VAC/DC
22: 24VAC/DC
QH2: 120VAC
QM4: 240VAC
Terminal Blocks
Transformer Type
126: 120V AC
246: 240V AC
486: 480V AC
2. All transformers step down to 6V.
Circuit Breakers
1904041136
755
ø30mm - TWND Series
k Lens Color Codes
Style
Contacts
Extended Lens
Signaling Lights
Full Voltage
1NO-1NC
2NO
2NC
Part Number
Momentary
Maintained
ALD2l11DNUk
ALD2l20DNUk
ALD2l02DNUk
AOLD2l11DNUk
AOLD2l20DNUk
AOLD2l02DNUk
Color
Code
Amber
Green
Red
Blue
White
Yellow
A
G
R
S
W
Y
Transformer
1NO-1NC
2NO
2NC
ALD2 m 11DNUk
ALD2 m 20DNUk
ALD2 m 02DNUk
AOLD2 m 11DNUk
AOLD2 m 20DNUk
AOLD2 m 02DNUk
Full Voltage
1NO-1NC
2NO
2NC
ALFD2l11DNUk
ALFD2l20DNUk
ALFD2l02DNUk
AOLFD2l11DNUk
AOLFD2l20DNUk
AOLFD2l02DNUk
Relays & Sockets
Extended Lens with Full Shroud
Transformer
1NO-1NC
2NO
2NC
ALFD2 m 11DNUk
ALFD2 m 20DNUk
ALFD2 m 02DNUk
AOLFD2 m 11DNUk
AOLFD2 m 20DNUk
AOLFD2 m 02DNUk
Voltage
Code
6V AC/DC
12V AC/DC
24V AC/DC
120V AC
240V AC
66
11
22
QH2
QM4
Voltage
Code
120VAC
126
240VAC
246
480VAC
486
(uses 6V LED).
1.
2.
3.
4.
5.
Full Voltage
1NO-1NC
2NO
2NC
ALD3l11DNUk
ALD3l20DNUk
ALD3l02DNUk
AOLD3l11DNUk
AOLD3l20DNUk
AOLD3l02DNUk
Transformer
1NO-1NC
2NO
2NC
ALD3 m 11DNUk
ALD3 m 20DNUk
ALD3 m 02DNUk
AOLD3 m 11DNUk
AOLD3 m 20DNUk
AOLD3 m 02DNUk
In place of m, specify the Transformer Voltage Code.
Light is independent of switch position.
Yellow pushbutton comes with white LED only.
Circuit Breakers
Terminal Blocks
Contactors
Timers
ø 40mm Mushroom Lens
756
www.IDEC.com
1904041136
ø30mm - TWND Series
Transformer*
Contact Block
Operator
LED
Lens
Complete Part
*Not required for full voltage types.
Lamps
Style
Part Number
Style
Extended
Momentary
Maintained
ALD2300T8
AOLD2300T8
LED
k Lens Color Codes
Voltage
6V AC/DC
12V AC/DC
24V AC/DC
120V AC
240V AC
Part Number
LSTD-6l
LSTD-1l
LSTD-2l
LSTD-H2l
LSTD-M4l
Code
A
G
R
S
W
Y
Color
Amber
Green
Red
Blue
White
Code
A
G
R
S
W
AOLFD2300T8
40mm Mushroom
ALD2300T8
AOLD2300T8
Relays & Sockets
ALFD2300T8
Color
Amber
Green
Red
Blue
White
Yellow
l LED Color Codes
Extended with
Full Shroud
Signaling Lights
Operators
Yellow lens only. Yellow
white LED.
Lenses
Part Number
1NO
1NC
Style
Style
Part Number
All Control Units
Extended
ALN06LU-k
HW-U10-F
HW-U01-F
HW-U10R-F
(early make)
HW-U01R-F
(late break)
ALN3LU-k
HW-DB
Contactors
Dummy Block
ø 40mm Mushroom
Timers
Contact Blocks
Transformers
Style
Part Number
120V AC
TW-F126B
240V AC
TW-F246B
480V AC
HW-L486
Style
Long Lamp Holder
Application
two contact blocks
two contact blocks
Lead Holder
Part Number
Transformers
6V secondary voltage (use 6V LED).
TW-LH2
Style
HW-LH3
Description
Dummy Block with
For use with
odd number
of contacts.
For use with
of contacts.
Finger-Safe
Part Number
HW-DA1FBN
Circuit Breakers
four contact blocks
Terminal Blocks
Primary Voltage
(50/60Hz)
TW-DA1FB
1904041136
757
ø30mm - TWND Series
Relays & Sockets
Signaling Lights
Non-Illuminated Selector Switches (Assembled)
Assembled Selector Switches
A
S
D
2
11
Function
Circuit Number
S: Selector Switch
(See Circuit # column of Selector Switch
Contact Arrangement Chart on beginning
on page 764.)
Contactors
Timers
Series Designation
D: TWND Series
Contact Arrangement Code
2: 2-Position
3: 3-Position
10: 1NO
20: 2NO
40: 4NO
11: 1NO-1NC
Spring Return Action
Operator Style Code
Blank: Maintained
1: Spring return from Right
2: Spring return from Left
3: 2-Way spring return from Left and Right
Blank: Knob Operator
L: Lever Operator
K: Key Operator
Number of Positions
01: 1NC
02: 2NC
04: 4NC
22: 2NO-2NC
2. Custom key removal codes available. Please contact IDEC for details.
Circuit Breakers
Terminal Blocks
NU – ( )
758
www.IDEC.com
1904041136
ø30mm - TWND Series
Non-Illuminated 2-Position Selector Switches
Style
Part Number
Mounting
1NO
1
2
O
O
X
O
1NC
1
2
X
O
O
O
1NO
1NC
1
2
O
X
X
O
2NO
1
2
O
O
X
X
2NC
1
2
X
X
O
O
1
2
3
4
1
2
3
4
O
X
O
X
O
O
X
X
X
O
X
O
X
X
O
O
2NO
2NC
2NO
2NC
R
Maintained
L
L
R
Spring Return
from Left
L
R
R
Knob
Lever
Key
Knob
Lever
Key
Knob
Lever
Key
Knob
Lever
Key
Knob
Lever
Key
ASD210NU
ASD2L10NU
ASD2K10NU
ASD201NU
ASD2L01NU
ASD2K01NU
ASD211NU
ASD2L11NU
ASD2K11NU
ASD220NU
ASD2L20NU
ASD2K20NU
ASD202NU
ASD2L02NU
ASD2K02NU
ASD2110NU
ASD21L10NU
ASD21K10NU
ASD2101NU
ASD21L01NU
ASD21K01NU
ASD2111NU
ASD21L11NU
ASD21K11NU
ASD2120NU
ASD21L20NU
ASD21K20NU
ASD2102NU
ASD21L02NU
ASD21K02NU
ASD2210NU
ASD22L10NU
ASD22K10NU
ASD2201NU
ASD22L01NU
ASD22K01NU
ASD2211NU
ASD22L11NU
ASD22K11NU
ASD2220NU
ASD22L20NU
ASD22K20NU
ASD2202NU
ASD22L02NU
ASD22K02NU
Knob
Lever
Key
ASD222NU
ASD2L22NU
ASD2K22NU
ASD2122NU
ASD21L22NU
ASD21K22NU
ASD2222NU
ASD22L22NU
ASD22K22NU
Knob
Lever
Key
ASD222NU-111
ASD2L22NU-111
ASD2K22NU-111
ASD2122NU-111
ASD21L22NU-111
ASD21K22NU-111
ASD2222NU-111
ASD22L22NU-111
ASD22K22NU-111
1. The truth table indicates the operating position of
contact block when the operator is switched to that
position.
X = On (closed contacts) O = Off (open contacts)
X X = Overlapping Contacts: Remain on (closed
contacts) when switch is moved between these two
positions.
2. All knob and lever selector switches come in black.
Other colors are available by ordering the knob or lever
separately.
3. Custom contact arrangements available, see page 764.
Style
Part Number
Spring Return from Right
Spring Return from Left
C
C
C
C
Spring Return Two-Way
O
O
O
X
Knob
Lever
Key
ASD320NU
ASD3L20NU
ASD3K20NU
ASD3120NU
ASD31L20NU
ASD31K20NU
ASD3220NU
ASD32L20NU
ASD32K20NU
ASD3320NU
ASD33L20NU
ASD33K20NU
2NC
1
2
O
X
X
X
X
O
Knob
Lever
Key
ASD302NU
ASD3L02NU
ASD3K02NU
ASD3102NU
ASD31L02NU
ASD31K02NU
ASD3202NU
ASD32L02NU
ASD32K02NU
ASD3302NU
ASD33L02NU
ASD33K02NU
2NO
2NC
1
2
3
4
X
O
O
X
O
O
X
X
O
X
X
O
Knob
Lever
Key
ASD322NU
ASD3L22NU
ASD3K22NU
ASD3122NU
ASD31L22NU
ASD31K22NU
ASD3222NU
ASD32L22NU
ASD32K22NU
ASD3322NU
ASD33L22NU
ASD33K22NU
1
2
3
4
1
2
3
4
1
2
3
4
X
X
O
O
O
O
O
O
X
O
X
O
X
O
O
X
O
X
O
X
O
X
O
X
Knob
Lever
Key
ASD322NU-309
ASD3L22NU-309
ASD3K22NU-309
ASD3122NU-309
ASD31L22NU-309
ASD31K22NU-309
ASD3222NU-309
ASD32L22NU-309
ASD32K22NU-309
ASD3322NU-309
ASD33L22NU-309
ASD33K22NU-309
Knob
Lever
Key
ASD322NU-310
ASD3L22NU-310
ASD3K22NU-310
ASD3122NU-310
ASD31L22NU-310
ASD31K22NU-310
ASD3222NU-310
ASD32L22NU-310
ASD32K22NU-310
ASD3322NU-310
ASD33L22NU-310
ASD33K22NU-310
Knob
Lever
Key
ASD340NU
ASD3L40NU
ASD3K40NU
ASD3140NU
ASD31L40NU
ASD31K40NU
ASD3240NU
ASD32L40NU
ASD32K40NU
ASD3340NU
ASD33L40NU
ASD33K40NU
1
2
3
4
O
X
O
X
O
X
X
O
X
O
X
O
O
O
O
O
X
X
X
X
Knob
Lever
Key
ASD304NU
ASD3L04NU
ASD3K04NU
ASD3104NU
ASD31L04NU
ASD31K04NU
ASD3204NU
ASD32L04NU
ASD32K04NU
ASD3304NU
ASD33L04NU
ASD33K04NU
2NO
2NC
4NO
4NC
X
O
X
O
R
L
R
L
R
L
C
R
Circuit Breakers
X
O
L
Terminal Blocks
1
2
R
Contactors
Mounting
Maintained
L
Contact
Operator Position
2NO
2NO
2NC
1904041136
Timers
Non-Illuminated 3-Position Selector Switches
Relays & Sockets
L
Spring Return
from Right
Signaling Lights
Contact
Operator
Position
759
Signaling Lights
ø30mm - TWND Series
Non-Illuminated Selector Switches (Sub-Assembled)
Contact Blocks
Relays & Sockets
Timers
Knob or Lever*
Color Insert*
Complete Part†
Handles and Inserts
Position
Description
Knob/Lever
3
2
Key
3
Contactors
Operators
2
Part Number
Maintained
ASD0201T8
Spring return from right
ASD0213T8
Spring return from left
ASD0224T8
Maintained, Cam 1
Maintained, Cam 2
ASD0302T8
ASD0306T8
Spring return from right, Cam 1
Spring return from right, Cam 2
ASD0314T8
ASD0310T8
Spring return from left, Cam 1
Spring return from left, Cam 2
ASD0323T8
ASD0328T8
Spring return from left/right, Cam 1
Spring return from left/right, Cam 2
ASD0335T8
ASD0339T8
Maintained
ASD0201KT8
ASD0213KT8
ASD0224KT8
Maintained, Cam 1
Maintained, Cam 2
ASD0302KT8
ASD0306KT8
ASD0302KT8B
ASD0310KT8B
ASD0323KT8
ASD0310KT8B
ASD0335KT8
ASD3K339KT8
Style
ASDHHY-j
Lever
ASDHHL-j*
Color Insert
TW-HC1-j
1. In place of j, specify the Color Code.
*Not available in yellow.
Contact Blocks
Style
All Control Units
Dummy Block
Knob/Lever Color
Code
Black
B
Blue
S
Green
G
Red
R
Yellow
Y
White
W
Part Number
Knob
1. Order knobs, levers, color inserts separately (see below).
2. For key switches, keys are removable in all maintained positions. Other options available,
3. See page 766 “Operator Truth Tables” for details of difference between cams.
j Color Codes
Terminal Blocks
Operator
1. *Not needed with key type switches.
2. †Knob type shown.
Style
Circuit Breakers
Part Number
1NO
1NC
HW-U10-F
HW-U01-F
HW-U10R-F
(early make)
HW-U01R-F
(late break)
HW-DB
1. Knob/Lever not available in white.
2. Color inserts not available in Black.
3. Lever not available in yellow.
760
www.IDEC.com
1904041136
ø30mm - TWND Series
Signaling Lights
Assembled Illuminated Selector Switches
SL
D
2
(2)
22
11
DN U – 111 – R
Function
Lens Color Code
SL: Illuminated Selector Switch
A: Amber
G: Green
R: Red
S: Blue
W: White
Y: Yellow
Series Designation
D: TWND series
Number of Positions
Relays & Sockets
A
Timers
Circuit Code Number
2: 2-Position
3: 3-Position
See Circuit # column of Selector Switch Contact Arrangement
Charts on page 764.
Blank: Maintained
3: Two-Way spring return from Left and Right
D: LED Lamp
Contactors
Transformer Type
136: 120V AC
256: 240V AC
486: 480V AC
Full Voltage Type
66: 6VAC/DC
11: 12VAC/DC
22: 24VAC/DC
QH2: 120VAC
QM4: 240VAC
Terminal Blocks
20: 2NO
02: 2NC
40: 4NO
04: 4NC
1904041136
Circuit Breakers
761
Mounting
1NO
1NC
1
2
1
2
1
2
1
2
3
4
1
2
3
4
2NO
2NC
2NO
2NC
Relays & Sockets
k Lens Color Codes
Style
Contact
Signaling Lights
ø30mm - TWND Series
2NO
2NC
Part Number
Operator
Position
L
R
O
X
O
O
X
X
O
X
O
X
O
O
X
X
X
O
X
X
O
O
X
O
X
O
X
X
O
O
Maintained
Lamp
Circuit Type
L
Spring Return
from Left
L
R
L
R
Transformer
Full Voltage
Transformer
Full Voltage
Transformer
Full Voltage
ASLD2 m11DNUk
ASLD2l11DNUk
ASLD2 m20DNUk
ASLD2l20DNUk
ASLD2 m02DNU-k
ASLD2l02DNU-104-k
ASLD21 m11DNUk
ASLD21l11DNUk
ASLD21 m20DNUk
ASLD21l20DNUk
ASLD21 m02DNU-k
ASLD21l02DNU-k
ASLD22 m11DNUk
ASLD22l11DNUk
ASLD22 m20DNUk
ASLD22l20DNUk
ASLD22 m02nDNU-k
ASLD22l02DNU-k
Transformer
Full Voltage
ASLD2 m22DNUk
ASLD2l22DNUk
ASLD21 m22DNUk
ASLD21l22DNUk
ASLD22 m22DNUk
ASLD22l22DNUk
Transformer
Full Voltage
ASLD2 m22DNU-111-k
ASLD2l22DNU-111-k
ASLD21 m22DNU-111-k
ASLD21l22DNU-111-k
2NO
2NC
2NO
2NC
4NO
4NC
Mounting
Contact
Timers
2NO
2NO
2NC
Contactors
A
Green
G
Red
R
Blue
S
White
W
Yellow
Y
Voltage
Code
6V AC/DC
66
12V AC/DC
11
24V AC/DC
22
120V AC
QH2
240V AC
QM4
Illuminated 3-Position Selector Switches, Maintained and Spring Return
2NC
Terminal Blocks
Code
ASLD22 m22DNU-111-k
ASLD22l22DNU-111-k
Style
Circuit Breakers
R
Color
Amber
1
2
1
2
1
2
3
4
1
2
3
4
1
2
3
4
1
2
3
4
1
2
3
4
Part Number
Operator Position
L
C
X
O
O
X
O
O
X
X
O
O
X
X
O
X
X
O
X
O
X
O
O
O
O
O
X
X
X
X
X
O
O
X
X
X
O
O
O
O
O
O
X
O
X
O
O
X
O
X
R
O
X
X
O
O
X
X
O
X
O
O
X
O
X
O
X
O
X
O
X
X
O
X
O
Maintained
Lamp
Circuit Type
L
C
Spring Return From Right
L
R
C
L
R
C
R
L
C
R
Transformer
Full Voltage
Transformer
Full Voltage
ASLD3 m 20DNUk
ASLD3l20DNUk
ASLD3 m 02DNUk
ASLD3l02DNUk
ASLD31 m 20DNUk
ASLD31l20DNUk
ASLD31 m 02DNUk
ASLD31l02DNUk
ASLD32 m 20DNUk
ASLD32l20DNUk
ASLD32 m 02DNUk
ASLD32l02DNUk
ASLD33 m 20DNUk
ASLD33l20DNUk
ASLD33 m 02DNUk
ASLD33l02DNUk
Transformer
Full Voltage
ASLD3 m 22DNUk
ASLD3l22DNUk
ASLD31 m 22DNUk
ASLD31l22DNUk
ASLD32 m 22DNUk
ASLD32l22DNUk
ASLD33 m 22DNUk
ASLD33l22DNUk
Transformer
Full Voltage
ASLD3 m 22DNU-309-k
ASLD3l22DNU-309-k
ASLD31 m 22DNU-309-k
ASLD31l22nDNU-309-k
ASLD32 m 22DNU-309-k
ASLD32l22DNU-309-k
ASLD33 m 22DNU-309-k
ASLD33l22DNU-309-k
Transformer
Full Voltage
ASLD3 m 22DNU-310-k
ASLD3l22DNU-310-k
ASLD31 m 22DNU-310-k
ASLD31l22DNU-310-k
ASLD32 m 22DNU-310-k
ASLD32l22DNU-310-k
ASLD33 m 22DNU-310-k
ASLD33l22DNU-310-k
Transformer
Full Voltage
ASLD3 m 40DNUk
ASLD3l40DNUk
ASLD31 m 40DNUk
ASLD31l40DNUk
ASLD32 m 40DNUk
ASLD32l40DNUk
ASLD33 m 40DNUk
ASLD33l40DNUk
Transformer
Full Voltage
ASLD3 m 04DNUk
ASLD3l04DNUk
ASLD31 m 04DNUk
ASLD31l04DNUk
ASLD32 m 04DNUk
ASLD32l04DNUk
ASLD33 m 04DNUk
ASLD33l04DNUk
1. In place of k, specify the Lens/LED Color Code, in place of l, specify the Full Voltage
(LED voltage) Code, in place of m, specify the Transformer Voltage Code.
2. The truth table indicates the operating position of contact block when the operator is
switched to that position.
X = On (Closed Contacts) O = Off (Open Contacts)
X X = Overlapping Contacts: Remain on (closed contacts) when switch is moved
between these positions
3. Yellow selector switch comes with white LED.
Voltage
Code
120VAC
240VAC
480VAC
136
256
486
(use 6V LED).
762
www.IDEC.com
1904041136
ø30mm - TWND Series
Transformer*
Contact Block
Operator
Lamp
Lens
Complete Part
Operators
Style
Position
Description
Part Number
2
Maintained
ASLD0201T8
3
Maintained, Cam 1
Maintained, Cam 2
ASLD0302T8
ASLD0306T8
ASLD0213T8
Operator
3
ASLD0224T8
ASLD0314T8
ASLD0310T8
ASLD0323T8
ASLD0328T8
ASLD0335T8
ASLD0339T8
Lenses
Style
TW-LH2
two contact blocks
Lead Holder
four contact blocks
HW-LH3
Style
Description
Dummy Block with
For use with
odd number
of contacts.
For use with
of contacts.
Part Number
Finger-Safe
HW-DA1FBN
TW-DA1FB
Transformers
Part Number
LSTD-6l
12V AC/DC
LSTD-1l
24V AC/DC
LSTD-2l
120V AC
LSTD-H2l
240V AC
LSTD-M4l
Style
Transformers
Part Number
120V AC
TW-F126B
240V AC
TW-F126B
480V AC
HW-L486
6V secondary voltage.
Contact Blocks
k Lens Color Codes
Part Number
l LED Color Codes
Color
Code
Color
Code
1NO
1NC
Amber
A
Amber
A
HW-U10-F
HW-U10-F
Green
G
Green
G
Red
R
Red
R
HW-U10R-F
(early make)
HW-U10R-F
(late break)
Blue
S
Blue
S
White
W
White
W
Yellow
Y
white LED.
Circuit Breakers
HW-DB
Terminal Blocks
Style
Primary Voltage
(50/60Hz)
Contactors
Voltage
6V AC/DC
Dummy Block
two contact blocks
Long Lamp Holder
k
Lamps
Part Number
Timers
ASLNHU-l
All Control Units
Application
Part Number
Knob
LED
Style
Relays & Sockets
2
Style
Signaling Lights
*Not required for full voltage units.
1904041136
763
ø30mm - TWND Series
Contact Arrangement Charts
L
How to Read Contact Arrangement Charts
Contact Block
Mounting Position
Circuit Number
Signaling Lights
* N/D = No designation
Position or mounting
contact blocks on operator
Truth table indicates the operating
operator is switched to that position.
Contact Block
Part Number
on (closed) when switch is moved
between these two positions
Part number to use when
ordering sub-assembly
contact blocks, as required
for use with corresponding
mounting position
Contact Arrangement Chart: 2-Position Selector Switches
Contact
Circuit
Number
1NO
N/D
1NC
N/D
Timers
Relays & Sockets
Style
N/D
1NO
1NC
103
Terminal Blocks
Contactors
600
1NO-EM
1NC-LB
601
2NO
N/D
2NC
N/D
N/D
Circuit Breakers
2NO
2NC
110
111
4NO
764
N/D
Mounting
Position
Operator
Position
2
1
Operator Position
Type and quantity of switch
contacts
4
3
To determine contact block mounting position, first make sure the selector switch is oriented as shown on the right
Contact Arrangement
R
Operator Part Number
Contact Block
Part Number
L
R
1
O
X
HW-U10-F
2
O
O
HW-DB
1
X
O
HW-U01-F
2
O
O
HW-DB
1
O
X
HW-U10-F
2
X
O
HW-U01-F
1
X
O
HW-U01-F
2
O
X
HW-U10-F
1
O
X
HW-U10R-F
2
X
O
HW-U01R-F
1
X
O
HW-U01R-F
2
O
X
HW-U10R-F
1
O
X
HW-U10-F
2
O
X
HW-U10-F
1
X
O
HW-U01-F
2
X
O
HW-U01-F
1
2
3
4
1
2
3
4
1
2
3
4
1
2
3
4
O
X
O
X
X
O
X
O
O
O
X
X
O
O
O
O
X
O
X
O
O
X
O
X
X
X
O
O
X
X
X
X
HW-U10-F
HW-U01-F
HW-U10-F
HW-U01-F
HW-U01-F
HW-U10-F
HW-U01-F
HW-U10-F
HW-U10-F
HW-U10-F
HW-U01-F
HW-U01-F
HW-U10-F
HW-U10-F
HW-U10-F
HW-U10-F
Description
Maintained
L
R
Spring Return
from Right
L
R
Spring Return
from Left
L
R
Knob/Lever
Key
Illuminated Knob
ASD0201T8
ASD0201KT8
ASLD0201T8
ASD0213T8
ASD0213KT8
ASLD0213T8
ASD0224T8
ASD0224KT8
ASLD0224T8
Knob/Lever
Key
Illuminated Knob
ASD0201T8
ASD0201KT8
ASLD0201T8
ASD0213T8
ASD0213KT8
ASLD0213T8
ASD0224T8
ASD0224KT8
ASLD0224T8
Knob/Lever
Key
Illuminated Knob
ASD0201T8
ASD0201KT8
ASLD0201T8
ASD0213T8
ASD0213KT8
ASLD0213T8
ASD0224T8
ASD0224KT8
ASLD0224T8
Knob/Lever
Key
Illuminated Knob
ASD0201T8
ASD0201KT8
ASLD0201T8
ASD0213T8
ASD0213KT8
ASLD0213T8
ASD0224T8
ASD0224KT8
ASLD0224T8
Knob/Lever
Key
Illuminated Knob
ASD0201T8
ASD0201KT8
ASLD0201T8
ASD0213T8
ASD0213KT8
ASLD0213T8
ASD0224T8
ASD0224KT8
ASLD0224T8
Knob/Lever
Key
Illuminated Knob
ASD0201T8
ASD0201KT8
ASLD0201T8
ASD0213T8
ASD0213KT8
ASLD0213T8
ASD0224T8
ASD0224KT8
ASLD0224T8
Knob/Lever
Key
Illuminated Knob
ASD0201T8
ASD0201KT8
ASLD0201T8
ASD0213T8
ASD0213KT8
ASLD0213T8
ASD0224T8
ASD0224KT8
ASLD0224T8
Knob/Lever
Key
Illuminated Knob
ASD0201T8
ASD0201KT8
ASLD0201T8
ASD0213T8
ASD0213KT8
ASLD0213T8
ASD0224T8
ASD0224KT8
ASLD0224T8
Knob/Lever
Key
Illuminated Knob
ASD0201T8
ASD0201KT8
ASLD0201T8
ASD0213T8
ASD0213KT8
ASLD0213T8
ASD0224T8
ASD0224KT8
ASLD0224T8
Knob/Lever
Key
Illuminated Knob
ASD0201T8
ASD0201KT8
ASLD0201T8
ASD0213T8
ASD0213KT8
ASLD0213T8
ASD0224T8
ASD0224KT8
ASLD0224T8
Knob/Lever
Key
Illuminated Knob
ASD0201T8
ASD0201KT8
ASLD0201T8
ASD0213T8
ASD0213KT8
ASLD0213T8
ASD0224T8
ASD0224KT8
ASLD0224T8
Knob/Lever
Key
Illuminated Knob
ASD0201T8
ASD0201KT8
ASLD0201T8
ASD0213T8
ASD0213KT8
ASLD0213T8
ASD0224T8
ASD0224KT8
ASLD0224T8
www.IDEC.com
1904041136
ø30mm - TWND Series
Contact Arrangement Chart: 3-Position Selector Switches
Style
Operator Position
Contact
Circuit
Number
202
1NO
1NC
302
N/D
2NO
301
304
N/D
N/D
2NO
2NC
308
310
X
O
O
HW-U10-F
2
X
X
O
HW-U01-F
1
O
X
X
HW-U01-F
2
O
O
X
HW-U10-F
1
X
O
X
HW-U10-F
2
X
X
O
HW-U01-F
1
O
X
O
HW-U01-F
2
O
O
X
HW-U10-F
1
X
O
O
HW-U10-F
2
O
O
X
HW-U10-F
1
X
O
X
HW-U10-F
2
O
O
X
HW-U10-F
1
O
X
O
HW-U01-F
2
X
X
O
HW-U01-F
1
O
X
X
HW-U01-F
2
X
X
O
HW-U01-F
1
2
3
4
1
2
3
4
1
2
3
4
1
2
3
4
1
2
3
4
X
O
O
X
O
O
X
O
X
X
O
X
X
X
X
X
O
X
O
X
O
O
X
O
X
O
X
HW-U10-F
HW-U10-F
HW-U01-F
HW-U01-F
HW-U01-F
HW-U10-F
HW-U01-F
HW-U10-F
HW-U10-F
HW-U01-F
HW-U10-F
HW-U01-F
HW-U10-F
HW-U01-F
HW-U01-F
HW-U10-F
HW-U01-F
HW-U10-F
HW-U01-F
HW-U10-F
O
O
O
O
X
X
X
X
X
X
O
O
O
O
O
O
X
X
O
X
O
O
X
O
X
O
X
X
O
X
O
X
O
L
C
R
L
C
R
L
C
R
L
C
R
Knob/Lever
Key
Illuminated Knob
ASD0302T8
ASD0302KT8
ASLD0302T8
ASD0314T8
ASD0314KT8
ASLD0314T8
ASD0323T8
ASD0323KT8
ASLD0323T8
ASD0335T8
ASD0335KT8
ASD0335T8
Knob/Lever
Key
Illuminated Knob
ASD0302T8
ASD0302KT8
ASLD0302T8
ASD0314T8
ASD0314KT8
ASLD0314T8
ASD0323T8
ASD0323KT8
ASLD0323T8
ASD0335T8
ASD0335KT8
ASD0335T8
Knob/Lever
Key
Illuminated Knob
ASD0306T8
ASD0306KT8
ASLD0306T8
ASD0310T8
ASD0301KT8
ASLD310T8
ASD0328T8
ASD0328KT8
ASLD0328T8
ASD0339T8
ASD0339KT8
ASLD0339T8
Knob/Lever
Key
Illuminated Knob
ASD0306T8
ASD0306KT8
ASLD0306T8
ASD0310T8
ASD0301KT8
ASLD310T8
ASD0328T8
ASD0328KT8
ASLD0323T8
ASD0339T8
ASD0339KT8
ASLD0339T8
Knob/Lever
Key
Illuminated Knob
ASD0302T8
ASD0302KT8
ASLD0302T8
ASD0314T8
ASD0314KT8
ASLD0314T8
ASD0323T8
ASD0323KT8
ASLD0323T8
ASD0335T8
ASD0335KT8
ASD0335T8
Knob/Lever
Key
Illuminated Knob
ASD0306T8
ASD0306KT8
ASLD0306T8
ASD0310T8
ASD0301KT8
ASLD310T8
ASD0328T8
ASD0328KT8
ASLD0328T8
ASD0339T8
ASD0339KT8
ASLD0339T8
Knob/Lever
Key
Illuminated Knob
ASD0306T8
ASD0306KT8
ASLD0306T8
ASD0310T8
ASD0301KT8
ASLD310T8
ASD0328T8
ASD0328KT8
ASLD0328T8
ASD0339T8
ASD0339KT8
ASLD0339T8
Knob/Lever
Key
Illuminated Knob
ASD0302T8
ASD0302KT8
ASLD0302T8
ASD0314T8
ASD0314KT8
ASLD0314T8
ASD0323T8
ASD0323KT8
ASLD0323T8
ASD0335T8
ASD0335KT8
ASD0335T8
Knob/Lever
Key
Illuminated Knob
ASD0302T8
ASD0302KT8
ASLD0302T8
ASD0314T8
ASD0314KT8
ASLD0314T8
ASD0323T8
ASD0323KT8
ASLD0323T8
ASD0335T8
ASD0335KT8
ASD0335T8
Knob/Lever
Key
Illuminated Knob
ASD0302T8
ASD0302KT8
ASLD0302T8
ASD0314T8
ASD0314KT8
ASLD0314T8
ASD0323T8
ASD0323KT8
ASLD0323T8
ASD0335T8
ASD0335KT8
ASD0335T8
Knob/Lever
Key
Illuminated Knob
ASD0306T8
ASD0306KT8
ASLD0306T8
ASD0310T8
ASD0301KT8
ASLD310T8
ASD0328T8
ASD0328KT8
ASLD0328T8
ASD0339T8
ASD0339KT8
ASLD0339T8
Knob/Lever
Key
Illuminated Knob
ASD0306T8
ASD0306KT8
ASLD0306T8
ASD0310T8
ASD0301KT8
ASLD310T8
ASD0328T8
ASD0328KT8
ASLD0328T8
ASD0339T8
ASD0339KT8
ASLD0339T8
Knob/Lever
Key
Illuminated Knob
ASD0306T8
ASD0306KT8
ASLD0306T8
ASD0310T8
ASD0301KT8
ASLD310T8
ASD0328T8
ASD0328KT8
ASLD0328T8
ASD0339T8
ASD0339KT8
ASLD0339T8
Terminal Blocks
309
1
R
Contactors
210
C
Two-Way
Timers
2NC
L
Maintained
Description
Relays & Sockets
303
Contact Block
Part Number
Signaling Lights
203
Mounting
Position
Spring Return Spring Return
from Right
from Left
1904041136
765
Circuit Breakers
1. Each operator sub-assembly is available as an “02” and an “06” for 3-position selector switches. The internal cam of an “02” is different from that of an “06”. This results in designated combinations
of open and closed contacts in the various operator positions.
2. N/D = No circuit number designation required in assembled part number.
3. X = On (closed contacts) O = Off (open contacts). X X Overlapping contacts remain on (closed) when switch is moved between these two positions.
ø30mm - TWND Series
Style
Operator Position
Circuit
Number
Contact
Mounting
Position
Signaling Lights
N/D
4NO
305
Relays & Sockets
N/D
4NC
314
L
C
1
2
3
4
1
2
3
4
1
2
3
4
1
2
3
X
O
X
O
X
O
X
O
O
X
O
O
O
O
O
O
O
O
X
4
X
R
Maintained
Description
L
X
X
X
X
O
X
O
X
X
X
X
X
X
O
X
O
O
O
O
HW-U10-F
HW-U10-F
HW-U10-F
HW-U10-F
HW-U10-F
HW-U10-F
HW-U10-F
HW-U10-F
HW-U01-F
HW-U01-F
HW-U01-F
HW-U01-F
HW-U01-F
HW-U01-F
HW-U01-F
X
O
HW-U01-F
X
X
O
X
O
X
O
Contact Block
Part Number
C
R
from Right
from Left
L
C
L
R
C
R
Two-Way
C
L
R
Knob/Lever
Key
Illuminated Knob
ASD0302T8
ASD0302KT8
ASLD0302T8
ASD0314T8
ASD0314KT8
ASLD0314T8
ASD0323T8
ASD0323KT8
ASLD0323T8
ASD0335T8
ASD0335KT8
ASD0335T8
Knob/Lever
Key
Illuminated Knob
ASD0306T8
ASD0306KT8
ASLD0306T8
ASD0310T8
ASD0301KT8
ASLD0310T8
ASD0328T8
ASD0328KT8
ASLD0328T8
ASD0339T8
ASD0339KT8
ASLD0339T8
Knob/Lever
Key
Illuminated Knob
ASD0302T8
ASD0302KT8
ASLD0302T8
ASD0314T8
ASD0314KT8
ASLD0314T8
ASD0323T8
ASD0323KT8
ASLD0323T8
ASD0335T8
ASD0335T8
ASD0335T8
Knob/Lever
Key
Illuminated Knob
ASD0306T8
ASD0306KT8
ASLD0306T8
ASD0310T8
ASD0301KT8
ASLD0301T8
ASD0328T8
ASD0328KT8
ASLD0328T8
ASLD0339T8
ASD0339KT8
ASLD0339T8
Timers
Use the following tables to build custom selector switches.
2 Position Selector Switches
Contact
Contactors
HW-U10-F (NO)
HW-U01-F (NC)
ASLD0201T8
HW-U10R-F (NO-EM)
Mounting
Position
Operator Position
Left
Right
L
O
X
R
O
X
L
X
O
R
X
O
L
O
X
R
O
X
L
X
O
R
X
O
Contact
HW-U10-F (NO)
ASD0302T8
ASLD0302T8
ASD0302KT8
HW-U01-F (NC)
HW-U10R-F (NO-EM)
HW-U10R-F (NC-LB)
Terminal Blocks
HW-U01R-F (NC-LB)
3 Position Selector Switches
Contact
HW-U10-F (NO)
Circuit Breakers
ASD0306T8
ASLD0306T8
ASD0306KT8
HW-U01-F (NC)
HW-U10R-F (NO-EM)
HW-U01R-F (NC-LB)
766
www.IDEC.com
Mounting
Position
Operator Position
Left
Center Right
L
X
O
O
R
O
O
X
L
O
X
X
R
X
X
O
L
X
O
O
R
O
O
X
L
O
X
X
R
X
X
O
Operator Position
Mounting
Position
Left
L
X
O
R
O
O
X
L
O
X
O
R
X
X
O
L
X
O
X
R
O
O
X
L
O
X
O
R
X
X
O
Center Right
X
1904041136
ø30mm - TWND Series
Accessories — TWND Series
Item
Lamp Removal Tool
Plastic Bezel
Rubber tool used to install or remove LED’s
Replacement locking ring/
bezel
OR-55
Standard octagonal units (chrome-pl.).
OG-81
Extended, non-illuminated (chrome-pl.).
OG-82
Extended, illuminated (chrome-pl.).
OG-83L
Jumbo Mushroom Shallow Shroud
ABN4G
Jumbo Mushroom Deep Shroud
ABN4F
Black plastic locking ring/bezel
Used to cover and protect
pushbuttons
Part Number
OGP11B
In place of j, specify Neoprene Rubber Boot color:
B (black), G (green), R (red), Y (yellow)
Relays & Sockets
Boot/Cover
Description/Usage
Signaling Lights
Metal Bezel
Appearance
OC-11 j
Flush units (clear plastic -40˚ to +60˚C).
OC-121
Extended units (clear plastic -40˚ to +60˚C).
OC-122
Plastic washer
For nameplates or panels that should not be scratched.
OGL-D1T
Thrust washer/Anti-rotation ring for use with notched panel cutout.
OGL-D1S
Anti-Rotation Ring
Long Lamp Holder
OB-11
Grey rubber (-5˚ to +60˚C)
OB-13
Tab #250 17/64” x 3/64” (6.35mm x 0.8mm): Single tab
Used with Transformer and two contact blocks
Used with Full Voltage Adaptor and two contact blocks
TW-FA4
TW-LH2
HW-LH3
Lock Out Adaptor
Used to provide lockout protection for TWTD pushbuttons and knob selectors.
ø 1-13/64” (30mm)
OL-KL1
Full Voltage Clips
Primary Voltage (50/60Hz) Required for all full voltage pilot lights. Two pieces each. 2 clips
required for full voltage pilot lights.
APD-F
Replacement Keys
Pair of keys (#0)
TW-SK
Circuit Breakers
Used with TW-LH2 holder when using four contact blocks
Terminal Blocks
Lead Holder
1904041136
Contactors
Terminal Tab Adaptor
Plugs used to fill unused 30mm
panel cutouts.
OBP-11
Metal with locking nut attached
Timers
Mounting Hole Plug
Plastic with locking nut attached.
767
Signaling Lights
ø30mm - TWND Series
Accessories TWND Series continued
Item
Appearance
Description/Usage
Part Number
1NC
Contact Blocks
(with side entry)
These contacts are applicable for wires terminated
by ring, fork, terminals, not recommended for bare
wire connections.
Contact Blocks
(without side entry)
by ring, fork, or ferule terminals, and also bare wire
connections.
1NO
HW-U01
HW-U01-MAU
HW-U01R
HW-U01R-MAU
(with side entry)
HW-U10
HW-U10-MAU
HW-U10R
HW-U10R-MAU
(with side entry)
HW-U01-F
HW-U01-MAU-F
HW-U01R-F
HW-U01R-MAU-F
(no side entry)
HW-U10-F
HW-U10-MAU-F
HW-U10R-F
HW-U10R-MAU-F
(no side entry)
Fingersafe Covers for TWND Series
Description
Used with
Part Number
Fingersafe terminal cover, for full voltage
pilot lights, adds 3mm to overall depth
Full voltage pilot lights
APD-PVL
Fingersafe terminal cover, adds 1.5mm to
overall depth
Transformer pilot lights
N-VL3
Circuit Breakers
Terminal Blocks
Contactors
Timers
Relays & Sockets
Item
768
www.IDEC.com
1904041136
ø30mm - TWND Series
Nameplates — TWND Series
Faceplates
NALD
NAKD
1.95" (50mm)
2.24" (57.5mm)
Ø1.19"
(30.5mm)
Ø1.19"
(30.5mm)
Signaling Lights
1.85" (47.5mm)
1.95" (50mm)
2.03" (52mm)
1.56" (40mm)
Dimensions
NAQD
Ø1.19"
(30.5mm)
5mm
Description
Part Number
NALD-B (black)
NALD-R (red)
NAKD-B (black)
NAKD-R (red)
NAQD-B (black)
NAQD-R (red)
Nameplate
(engraved)
NALD-j
NAKD-j
NAQD-j
Relays & Sockets
Nameplate
(blank)
1. Nameplates are made of 0.031” aluminum. Lettering is white letters engraved on black background.
2. In place of j, insert either the standard legend code from table below or custom engraving delimited by “ “.
Standard Legend Codes
Pushbuttons
Legend
OPEN
OUT
RAISE
RESET
REVERSE
RUN
SLOW
START
STOP*
STOP
TEST
UP
I (Int’l On)
O (Int’l Off)
EMO
Code
116
117
118
119
120
121
122
123
124
125
126
127
150
151
152
Legend
AUTO-MAN
CLOSE-OPEN
DOWN-UP
FAST-SLOW
FOR-REV
HAND-AUTO
HIGH-LOW
JOG-RUN
LEFT-RIGHT
LOWER-RAISE
MAN-AUTO
OFF-ON
ON-OFF
OPEN-CLOSE
RAISE-LOWER
Code
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
Legend
REV-FOR
RUN-JOG
RUN-SAFE
SAFE-RUN
SLOW-FAST
START-STOP
STOP-START
UP-DOWN
Selector Switches
Code
216
217
218
219
220
221
222
223
Legend
AUTO-MAN-OFF
AUTO-OFF-MAN
CLOSE-OFF-OPEN
DOWN-OFF-SLOW
FAST-OFF-SLOW
FOR-OFF-REV
LEFT-OFF-RIGHT
LOWER-OFF-RAISE
OFF-MAN-AUTO
OFF-SLOW-FAST
OFF-1-2
OPEN-OFF-CLOSE
SLOW-OFF-FAST
SUMMER-OFF-WINTER
UP-OFF-DOWN
1-OFF-2
HAND-OFF-AUTO
Code
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
Contactors
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
Pushbuttons/Selector Switches
Legend
Timers
AUTO
CLOSE
DOWN
EMERG.STOP*
FAST
FORWARD
HAND
HIGH
IN
INCH
JOG
LOW
LOWER
OFF
ON
Code
Terminal Blocks
1. *Available in Red as standard legend code 104 and 124. To order engraved nameplate and codes, add legend code to nameplate part number.
Character height based on the number of characters, space and size of nameplate. Standard character size is 3/16”.
2. Nameplates with standard legends are the same list price as blank nameplates. Special engravings, additional cost.
To specify engraving instructions, use the Nameplate order form on next page.
Circuit Breakers
1904041136
769
Custom engraved Nameplates Order Form — TWND Series
Copy this order form and use it to specify Letter Height, Custom Engravings, Location of Engraving on Nameplate, and Quantity Desired.
To ensure engraving accuracy, fax it to your IDEC representative. or Distributor.
Your Company Name:__________________________________________
IDEC Rep/Distributor Contact:__________________________________
Your Name:__________________________________________
PO number (if known):__________________________________
Telephone:__________________________________________
IDEC Rep/Distributor Phone:__________________________________
IDEC Rep/Distributor Fax & Email:__________________________________
Fax & Email:__________________________________________
NALD Nameplate
Step 1.
Choose Letter Size - 7/64” or 1/8”.
Check the box for the letter size you
want. Then write your lettering in box
below checkboxes. Note: 1/8” size letters cannot exceed 13 characters.
Engraving
Location
Relays & Sockets
Signaling Lights
ø30mm - TWND Series
Sample Letter Sizes
7/64”
16 characters max
(for 7/64” size letters)
1/8”
13 characters max
(for 1/8” size letters)
Letter Size
7/64” Letters:
1/8” Letters:
Letter Size
Step 2.
Specify Quantity.
Enter the number of
nameplates desired
in the box on the right.
NAKD Nameplate
1
2
3
4
5
6
7
8
9 10 11 12 13 14 15 16
2
3
4 5
6
7
8 9 10 11 12 13 14 15 16 17
Step 1.
letters cannot exceed 9 characters.
Engraving
Location
Timers
Qty
Step 2.
Enter the number of
nameplates desired
1
Sample Letter Sizes
Qty
1/8” Letters:
NAQD Nameplate
Step 1.
1
2
3
7/64”
20 characters max
1/8”
16 characters max
Letter Size
below checkboxes.
16 characters.
Engraving
Location
Terminal Blocks
Contactors
Specify Quantity.
Letter Size
4
5
Circuit Breakers
Step 2.
6
7
8 9 10 11 12 13 14 15 16 17 18 19 20
Specify Quantity.
Sample Letter Sizes
Enter the number of
nameplates desired
3/32” Letters:
770
1/8” Letters:
Qty
www.IDEC.com
1904041136
ø30mm - TWND Series
Switch Engraving Order Form – TWND Series
Copy this order form and use it to specify Letter Height, Maximum Number of Lines and Text to be engraved.
To insure engraving accuracy, fax it to your IDEC representative or Distributor.
Telephone:
Name:
Fax:
Address:
Email:
Signaling Lights
Your Company:
PO:
Part Number to be Engraved:
Please check one of the boxes below to indicate your choice of engraving options:
ø29mm, ø40mm Mushroom Head
65mm
Jumbo
Mushroom
Square
Switch
Engraving
Engraving
Area 1
# of
Lines
Letter
Height
Max. Characters
Per Line
5/32
7
# of
Lines
1
Letter
Height
Max. Characters
Per Line
3/4
4
1
1/8
8
5/32
7
5/16
5/16
5
5
2
8
1/8
8
4
2
Custom*
4
Max. Characters
Per Line
5/32
7
1/8
8
1
5/32
8
5/32
8
1/8
9
1/8
9
4
1
5
1/8
5
5/32
7
1/8
7
1. Above mentioned specifications hold true for standard size pushbuttons (round and square).
2. †Engraving Area 2 can be engraved for 40mm mushroom head
non-Illuminated pushbutton only.
3. Engraving is done on the button itself for non-Illuminated push buttons and on marking plate for illuminated push buttons and pilot
lights.
4. Please enter text exactly how you want it engraved, take care to
emphasize capital or small letters.
5/32
7
1/8
8
Line 3:
1/8
8
Line 4:
Line 2:
1/8 Letters:
5/32 Letters:
Terminal Blocks
3
Engraving
Area 2
5/32
Enter text to be engraved: Sample Letter Sizes
Line 1:
2
1
Max. Characters
Per Line
Contactors
Round
Switch
Letter
Height
6
3
*Engraving is possible, but character size will be
smaller than standard sizes.
# of
Lines
1/4
Engraving
Area 1
Letter
Height
Timers
3
1/8
# of
Lines
Relays & Sockets
Area 2†
All engraving is 5/8mm
wide.
Custom*
Circuit Breakers
For IDEC Internal Use Only:
Work Order #:
1904041136
771
Dimensions (mm)
Pushbutton
ø35
Mushroom Pushbutton w/Full Shroud
29.6
Panel Thickness 0.8 to 6.5
Mushroom
Mushroom w/Full Shroud
Jumbo Mushroom
ø 1.56” (40mm)
0.858” (22mm)
0.936” (24mm)
1.13” (29mm)
ø 1.56” (40mm)
ø 1.87” (48mm)
ø 2.54” (65mm)
Mushroom, Pushlock Turn
Reset and Push-Pull
ø 1.56” (40mm)
*0.975” (25mm)
**0.975” (25mm)
ø 1.56” (40mm)
ø 1.56” (40mm)
23.5
Full Voltage
ø24
ø35
29.6
ø39
Dimension A
Dimension B
Flush w/Full Shroud
0.975” (25mm)
0.995” (25.5mm)
ø 0.936” (24mm)
ø 0.936” (24mm)
Extended w/Full Shroud
0.741” (19mm)
0.761” (19.5mm)
ø 0.936” (24mm)
ø 0.936” (24mm)
ø 1.56” (40mm) Mushroom
Pushlock Turn Reset,
Push-Pull
*0.975” (25mm)
**0.975” (25mm)
ø 1.56” (40mm)
ø 1.56” (40mm)
45.4 (1block)
65.4 (2 or 3 blocks)
85.4 (4 blocks)
29.4
40
23.6
Pilot Lights
M3 Terminal
Screw
Panel Thickness
0.8 to 7.5
46
5
21.5
23.5
36
23.6
38
Illuminated
Pushbuttons
Panel Thickness 0.8 to 7.5
41.4
ø24
ø35
ø24.6
ø35
w/Transformer
40
*Dimension when operator is in reset position.
**Dimension when operator is in pull position.
Selector Switches
Lever
90° 2-position
(3-position)
45°
45°
90° 2-position
(3-position)
45°
45°
25.1
ø35
Panel Thickness
0.8 to 7.5
41.4
ø25
ø35
41.4
Key
90° 2-position
(3-position)
45°
45°
Panel Thickness
0.8 to 7.5
41.4
Knob
ø35
Timers
ø 0.975” (25mm)
ø 0.975”(25mm)
ø 1.11” (28.5mm)
45.4
65.4
75.5 (2 blocks), 95.5 (4 blocks)
Contactors
Dimension B
0.351” (9mm)
0.566” (14.5mm)
0.663” (17mm)
ø48
41.4
Signaling Lights
29.6
ø39
9
65.4(3 or 4 blocks)
43.9 (1 or 2 blocks)
63.9 (3 or 4 blocks)
Terminal Blocks
Dimension A
Flush
Extended
45.4 (1 or 2 blocks)
Relays & Sockets
Pushbuttons
41.4
ø30mm - TWND Series
65.4 (3 or 4 blocks)
29.4
40
21.1
21.1
29.4
40
16.5
37.1
29.4
40
Illuminated Knob
90° 2-position
45°
(3-position)
45°
Circuit Breakers
ø25
ø35
Panel Thickness
0.8 to 7.5
45.4
65.4
772
27.6
29.6
40
www.IDEC.com
1904041136
ø30mm - TWND Series
Selector Switches Panel Cut-Out
R0.8 max.
4.8
ø3
0.5 +
+0.2
1. *Jumbo Mushroom < 2.61” (66mm)
2. Minimum mounting centers are applicable to switches with one
stack of contact blocks. When mounting two stacks of contact
blocks, minimum centers should allow for access to wiring.
3. The ø 0.195” (ø 5mm) recess is necessary when either the
nameplate or anti-rotation ring is used.
Square: 55
Round: 42 (*1)
Signaling Lights
50 (*1)
IlluminatedSelector Switches
Pushbutton Clear Boot
OGL-31
82.5
ø32.6
93
30
70
Relays & Sockets
6.5
ø3
4
ø30
.5
18 (OC-31)
22 (OC-32)
ø3
9
ø34
24.8
Waterproof
Rubber
Gasket
29.5
0.5t
30
0.
ø4
ø40
ø30
R6
Outside diameter: ø50
Inside diameter: ø44
Mounting Hole Rubber Plug
0.8
10
2.8
Panel Thickness
0.8 to 3.2
OB-31
Anti-Rotation Ring
5
OC-31
Lock-Out Adaptor
5
OL-KL1
2
Key Hole ø8
Timers
Finger-Safe Cover
N-VL3
(6 .24”
.2m
m
1.20” (30.4mm)
0.63”
(16mm)
NVL3
(24mm)
0.41”
(10.5mm)
Contactors
0.19”
(4.7mm)
0.94”
0.68”
(17.2mm)
APD-PVL
Terminal Blocks
.413”
(10.5mm)
.354”
(9mm)
m)
.2m
1.45” (37mm)
1904041136
1.73” (44mm)
Circuit Breakers
APDPVL
(6
1.26” (32mm)
6”
.25
773
ø30mm - TWND Series
Operating Instructions
Adjustment for Panel Thickness
Insallation of LED Illuminated Units
Each unit is shipped with several waterproof gaskets which are 0.06” (1.5mm)
and 0.12” (3mm) thick. Combine the gaskets for a dimension approximately equal
to panel thickness and install between the bezel and the body of the unit.
Transformer units are recommended for use in areas subjected to inductive
noise.
Application Example For Push-To-Test Pilot Light
A typical application of illuminated pushbuttons is a push-to-test pilot light
which can be used to check the lamp/LED circuit.
Signaling Lights
Transformer/AC-Adapter Circuit
Start
Panel
Cut-Out
Unit
Stop
Trim
Washer
M2
L
Thrust
Washer
C
NC
M2
Nameplate
NO
Relays & Sockets
T
Test
Pilot
Light
Full Voltage Circuit
Start
Stop
Selector Switches
The operator shaft of each unit has a recess to identify in which direction to
install the handle. Align the handle with the recess. Press color insert (TW-HC1)
into the Standard Operating Positions.
OLS
M
A trim washer must be used with a thrust washer or a nameplate to prevent the
control unit from rotating in the mounting hole. When using anti-rotation rings
(trim washer with thrust washer or nameplate), install as shown below.
Timers
L
L
M
NC
NO
T
C
L
Test
Pilot
Light
Standard Operation Positions
2-Position, 90°
3-Position, 45°
1
1
Contactors
2
Non-Illuminated 3-Position Operators
1
1
1
Circuit Breakers
Terminal Blocks
2
774
www.IDEC.com
1904041136
