114-2-12PZ
114-2-12PZ
    IGUS
    BRACKET FOR 14/EZ14 WITH 1.46W
114-2-12PZ 数据手册
® 14 Price Index e-chain system® E2 Mini Series 14 .79 Features & Benefits Flammability class UL 94 Series 14 Special Features / Options CleanRoom Mounting bracket with integrated strain relief Dirt-repellent exterior Snap-open along inner radius with film-hinge Cleanroom Class 1 (ISO class 3) ESD Classification: Electrically conductive ESD/ ATEX version upon request UL94-V2 Classifications Assembly Tips Easy to assemble and disassemble Usage Guidelines • For applications with low loads • Fast installation of the cables • For gliding applications ➤ Series 15 Zipper • For long unsupported lengths ➤ Series 15 Zipper 4.75 Order Example: Complete e-chain® Please indicate chain length or number of links. Example: 3.28 ft (1 m) 14-2-038-0 e-chain® 1 Set 114-2-12PZ Mounting Bracket e-chain system® E2 Mini Series 14 Installation Dimensions ® .84 .50 FLB .17 0 S (FLG) S (FLB) FLG .82 0 1.64 2.46 3.28 4.10 Legend 4.92 S = Length of travel Unsupported length in ft FLB / FLG R = Bending radius H = Nominal clearance height 0 1.64 3.28 4.92 Length of travel S in ft 6.56 8.20 9.84 D = Overlength e-chain® radius in final position K = π • R + safety buffer HF = Required clearance height S 1.20 (30.5) Pitch per link: = 1.20” (30.5 mm) Links per ft (m): = 10.06 (33) .98 (25) Fixed end HF = H + .79 (20) R H - .98 (25) Moving end H S/2 D .79 Unsupported e-chains ® feature positive camber over short travels. This must be accounted for when specifying the clearance height. Please refer to Installation dimensions for further details. .67 .34 FLB H HF FLG Short Travels Unsupported PDF: igus.com/e-chain-pdfs Product information: igus.com/e-chains Further information ➤ Design, Chapter 1 1.01 Fill weight lbs/ft Short travel, unsupported length ● FLB = unsupported with permitted sag ● FLG = unsupported with straight upper run 14 For center mount applications: 1.50 (38) Chain length = / s 2 +K The required clearance height: HF = H + .79 in. (20 mm) (with 0.34 lbs/ft (0.5 kg/m) fill weight. Please consult igus® if space is particularly restricted. R 1.10 (028) 1.50 (038) 1.89 (048) 2.95 (075) 3.94 (100) 4.92 (125) H 3.19 (81) 3.98 (101) 4.76 (121) 6.89 (175) 8.86 (225) 10.83 (275) D 3.39 (86) 3.78 (96) 4.17 (106) 5.24 (133) 6.22 (158) 7.20 (183) K 6.02 (150) 7.42 (185) 8.61 (215) 11.81 (300) 14.96 (380) 17.91(455) Speed / acceleration FLG max. 6.56 ft/s (20 m/s) / max. 656 ft/s2 (200 m/s2) Speed / acceleration FLB max. 9.84 ft/s (3 m/s) / max. 19.69 ft/s2 (6 m/s2) Gliding speed / acceleration (maximum) max. 9.84 ft/s (3 m/s) / max. 32.8 ft/s2 (10 m/s2) Material - permitted temperature Flammability Class, igumid NB igumid G / -40°F (-40°C) up to +248°F (+120° C) VDE 0304 IIC UL94 V2 Technical Data F° Details of material properties ➤ Chapter 1 4.76 e-chain system® E2 Mini Series 14 ® 14 Series 14 - e-chain® snap-open along the inner radius Internet: igus.com email: sales@igus.com QuickSpec: igus.com/quickspec 4.77 .79 (20) .98 (25) Part Number Structure .63” max. R 14- 2- 038- 0 Color - Black Bending radius Width Series S Fixed end HF = H + .79 (20) R H - .98 (25) Moving end H S/2 D .98 (25) Telephone 1-800-521-2747 igus® e-chain system® Ba Bi 1.20 (30.5) 1.50 (38) Supplement part number with required radius. Example: 14-2- 038 -0 Pitch: 1.20 in. (30.5 mm) per link links/ft (m) = 10.06 (33) Bi Part Number in. (mm) Ba Weight in. (mm) lbs/ft (kg/m) 14-1- -0 .59 (15) 1.02 (26) ≈ 0.21 (0.31) 14-2- -0 .98 (25) 1.42 (36) ≈ 0.22 (0.32) 14-3- -0 1.50 (38) 1.93 (49) ≈ 0.27 (0.40) 14-4- -0 1.97 (50) 2.40 (61) ≈ 0.28 (0.41) Choose from the radii below for all of the above sizes R adius (mm) Example: 14-2- 038 -0 R 028 038 048 075 100 125 1.10 (028) 1.50 (038) 1.89 (048) 2.95 (075) 3.94 (100) 4.92 (125) H 3.19 (81) 3.98 (101) 4.76 (121) 6.89 (175) 8.86 (225) 10.83 (275) D 3.39 (86) 3.78 (96) 4.17 (106) 5.24 (133) 6.22 (158) 7.20 (183) K 6.02 (150) 7.42 (185) 8.61 (215) 11.81 (300) 14.96 (380) 17.91(455) 0=Standard color black. For other colors see Chapter 1 e-chain system® E2 Mini Series 14 Mounting Brackets ® 14 Moving end 114...1P(Z) 90° • • • • One-piece mounting bracket Corrosion resistant Available preassembled Inner and outer attachment possible • Available with or without strain relief tiewrap plates Moving end 114...1P(Z) .67 (17) Part Number Structure Fixed end 114...2P(Z) .28 (7) .55 (14) Possible installation configurations - Fixed end 114...2P(Z) .67 (17) .67 (17) .55 (14) 114- .28 (7) 2- 12- P PZ With tiewrap plate Without tiewrap plate Width .16 (4) B A A B Complete Set .26 (6.5) For Chain Type Part No. Full set with Tiewrap Plate Mounting brackets for selected chain type Part No. Full Set without Tiewrap Plate Dimension A in. (mm) Dimensions B in. (mm) 14.1 114-1-12-PZ 114-1-12-P — — 1.04 (26.3) 14.2 114-2-12-PZ 114-2-12-P .39 (10) 1.43 (36.3) 14.3 114-3-12-PZ 114-3-12-P .91 (23) 1.94 (49.3) 14.4 114-4-12-PZ 114-4-12-P 1.38 (35) 2.41 (61.3) Full set, for both ends: 114- 2- 12- PZ Full set, each part with pin/bore + tiewrap plate Single-part order: 114- 2- 1- PZ Mounting bracket with bore + tiewrap plate 114- 2- 2- PZ Mounting bracket with pin + tiewrap plate PDF: igus.com/e-chain-pdfs Product information: igus.com/e-chains Polymer, one-piece Additional Accessories Quickfix - mounting bracket with dowel, upon request Part No. 114-3-12QZ 4.78
114-2-12PZ 价格&库存
很抱歉,暂时无法提供与“114-2-12PZ”相匹配的价格&库存,您可以联系我们找货
