013002000100
013002000100
    INDUSTRIALSHIELDS
    控制器 - 可编程逻辑(PLC) DIN 轨道 12 ~ 24VDC
013002000100 数据手册
Datasheet 10 I/Os Digital Module CPU ESP32 013002000100 Technical Features PLC 10 I/Os DIGITAL MODULE - ESP32 MODEL TYPE 10 I/Os Input Voltage 12 to 24Vdc (Fuse protection (2.5A) Polarity protection) Input rated voltage 24Vdc Rated Power 30 W I max. 1.5A Size 100x45x115 Clock Speed External: 240 MHz Internal: 8 MHz Flash Memory 4 MB SRAM 4 MB PSRAM 2 MB Communications A ZONE USB - RS485 - ETHERNET - WiFi (2.4 - 2.5GHz) - BLE (2.4022.480 GHz) General Features Power supply voltage DC power supply 12 to 24Vdc Operating voltage range DC power supply 11.4 to 25.4Vdc Power consumption DC power supply 30 VAC MAX. External power supply Power supply voltage 24Vdc Power supply voltage 300Ma 20MΩ min.at 500Vdc between the AC terminals and the protective earth terminal. Insulation resistance Dielectric strength 2.300 VAC at 50/60 Hz for one minute with a leakage current of 10mA max. Between all the external AC terminals and the protective ground terminal. Shock resistance 80m/s2 in the X, Y and Z direction 2 times each. Ambient temperature (operating) 0º to 60ºC Ambient humidity (operating) 10% to 90% (no condensation) Ambient environment (operating) With no corrosive gas Ambient temperature (storage) -20º to 60ºC Power supply holding time 2ms min. Weight 350g max. INPUTS (x10) Dig Input 10bit (0-10Vcc) - (x16) 0 to 3.3 to 24 Vdc Input Impedance: 27K Separated PCB ground Rated Voltage: 10Vac 220 Vac (3 – 48 Vdc) Input Impedance: 54K Rated Voltage: 220 VAc I min: 2 to 12 mA Opto-isolation Rated Voltage: 24 Vdc Antipolarity + Overcurrent (220 Ac) OUTPUTS (x10) Digital Isolated Output - (x10) Imax 24 Vdc: 1 A ModbusRTU with RS485: 32 elements DataSheet Rev. 20201007 Expandability 24 Vdc (23,2 Vdc) I max: 300mA Opto-isolation Rated Voltage: 24 Vdc 013002000100 A ZONE 013002000100 Performance Specifications CPU ESPRESSIF ESP-WROOM-32U Control method Stored program method I/O control method Combination of the cyclic scan and immediate refresh processing methods. Programming language Arduino IDE. Based on wiring (Wiring is an Open Source electronics platform composed of a programming language. “similar to the C”) Microcontroller ESP32 http://arduino.cc/en/Tutorial/HomePage Install Arduino IDE and the Industrial Shields boards The steps to follow to install our equipment’s to Arduino IDE are:            • Open the Arduino IDE, versión 1.8.0 or superior. If you don’t have it yet , you can download here https://www.arduino.cc/en/Main/Software . • Press the “Preferences”option to “File” menu and open the preferences window. • In the text box  “Additional boards manager URLs”, add the direction: http://apps.industrialshields.com/main/arduino/boards/package_ind ustrialshields_index.json • Close the preferences window with the “OK”  button. • Click on “Tools” menu, and open the “Boards” submenu, and click the “Boards Manager” option, to open the Boards Manager window. • Search “industrialshields” to the search filter and select to the list and click “Install” • Close the “Boards Manager". Once it is performed that  steps, you are available to select each PLC that you wish to work on “Tools” ->  “Boards” : M-Duino…   To get more information: https://www.industrialshields.com/first-steps-with-the-industrialarduino-based-plc-s-and-the-panel-pc-s-raspberry-pi-based#boards Symbology Indicates that the equipment is suitable for direct current only; to identify relevant terminals Indicates that the equipment is suitable for alternating current only; to identify relevant terminals To identify the control by which a pulse is started. To identify an earth (ground) terminal in cases where neither the symbol 5018 nor 5019 is explicily required. To identify the switch by means of which the signal lamp(s) is (are) switched on or off. CE marking indicates that a product complies with applicable European Union regulations Warnings Unused pins should not be connected. Ignoring the directive may damage the controller.    Before using this product, it is the responsibility of the user to read the product’s User Guide and all accompanying documentation.   Industrial Shields PLCs must be powered between 12Vdc and 24Vdc. If a higher voltage is supplied to the equipment can suffer irreversible damage.   Maintenance must be performed by qualified personnel familiarized with the construction, operation, and hazards involved with the control.    Maintenance should be performed with the control out of operation and disconnected from all sources of power.    The Industrial Shields Family PLCs are Open Type Controllers. It is required that you install the M-Duino PLC in a housing, cabinet, or electric control room. Entry to the housing, cabinet, or electric control room should be limited to authorized personnel. Inside the housting, cabinet or electric control room, the Industrial Shields PLC must be at a minimum distance from the rest of the components of a minimum of 25 cm, it can be severely damaged.   Failure to follow these installation requirements could result in severe personal injury and/or property damage. Always follow these requirements when installing M-Duino family PLCs.    In case of installation or maintenance of the M-Duino please follow the instructions marked in the Installation and Maintenance section on the User Guide.    Do not disconnect equipment when a flammable or combustible atmosphere is present. Disconnection of equipment when a flammable or combustible atmosphere is present may cause a fire or explosion which could result in death, serious injury and/or property damage. Technical Support You can contact with us using the best channel for you: @ support@industrialshields.com www.industrialshields.com Visit our Blog, Forum orTicketing system 34 644 927 900 Use our chat service Indicates a potentially hazardous situation which, if not avoided, could result in death or serious injury Check the user guides To indicate hazards arising from dangerous voltages Visit our Channel
013002000100 价格&库存
很抱歉,暂时无法提供与“013002000100”相匹配的价格&库存,您可以联系我们找货
  • 1+2641.296971+343.36006
