Datasheet
M-Duino 38R+
LoRa
015001000300
Analog or PWM Isolated Output can be configured by switch.
Technical Features CONECTABLE PLC ARDUINO 24Vcc M-DUINO
MODEL TYPE
M-Duino LoRa
Input Voltage
12 to 24Vdc (Fuse protection (2.5A) Polarity protection)
Input rated voltage
24Vdc
Rated Power
30 W
I max.
1.5A
Size
101x94.7x119.5
Clock Speed
16MHz
Flash Memory
256KB of which 8KB used by bootloader
SRAM
8KB
EEPROM
4KB
Communications
& Accesories
I2C, Ethernet, USB, RS485, RS232, SPI , LoRa, RTC, microSD
An/Dig Input 10bit
(0-10Vcc) - (x8)
Digital Isolated Input
(24Vcc) - (x3)
Only for uploading or debugging. NOT connected as a serial
USB consideration! Cannot be working in a final application
General Features
Power supply voltage
DC power supply
Operating voltage range
DC power supply
12 to 24Vdc
11.4 to 25.4Vdc
Power consumption
DC power supply
30 W MAX.
External power supply
24Vdc
700Ma
Insulation resistance
20MΩ min.at 500Vdc between the AC
terminals and the protective earth terminal.
Dielectric strength
INPUTS (x11)
Expandability
0 to 10Vac
Input Impedance: 39K
Separated PCB ground
Rated Voltage: 10Vac
5 to 24Vdc
I min: 2 to 12 mA
Galvanic Isolation
Rated Voltage: 24 Vdc
5 to 24Vdc
I min: 2 to 12 mA
Galvanic Isolation
I2C: 127 elements - ModbusRTU with RS485: 32
elements - LoRa
OUTPUTS (x22)
Analog Output 8bit (010Vcc) / PWM
Isolated Output 8bit
(24Vcc) - (x6)
* The Analog & PWM
outputs can also work as
Digital outputs,
The
configuration
between Analog and PWM
Isolated Outputs can be
done by switch.
Analog Output
0 to 10Vac
I max: 20 mA
PWM Isolated Output
5 to 24Vdc
I max: 70 mA
Galvanic Isolation
Diode Protected for
Digital Isolated Output
Rated Voltage: 24Vdc
220V Vdc
Digital Isolated
Output Relay - (x16) I max: 5A
Galvanic Isolation
Diode protected for Relay
Imax 24Vdc: 410 mA
Original
Arduino Mega
included
2.300 VAC at 50/60 Hz for one minute with a
leakage current of 10mA max.
Between all the external AC terminals and the
protective ground terminal.
Shock resistance
80m/s2 in the X, Y and Z direction
2 times each.
Ambient temperature (operating)
0º to 60ºC
Ambient humidity (operating)
10% to 90% (no condensation)
Ambient environment (operating)
With no corrosive gas
Ambient temperature (storage)
-20º to 60ºC
Power supply holding time
2ms min.
Weight
609g max.
Pinout
C ZONE
A ZONE
DataSheet Rev. 20201002
B ZONE
015001000300
A ZONE
B ZONE
015001000300
C ZONE
015001000300
Performance Specifications
Arduino Board
Arduino Mega 2560
Control method
Stored program method
I/O control method
Combination of the cyclic scan and immediate refresh processing methods.
Programming language
Arduino IDE. Based on wiring (Wiring is an Open Source electronics platform composed of a programming language. “similar to the C”)
Microcontroller
ATmega2560
http://arduino.cc/en/Tutorial/HomePage
Install Arduino IDE and the Industrial Shields boards
The steps to follow to install our equipment’s to Arduino IDE
are:
• Open the Arduino IDE, versión 1.8.0 or superior. If you don’t have it
yet , you can download here
https://www.arduino.cc/en/Main/Software .
• Press the “Preferences”option to “File” menu and open the
preferences window.
• In the text box “Additional boards manager URLs”, add the direction:
http://apps.industrialshields.com/main/arduino/boards/package_ind
ustrialshields_index.json
• Close the preferences window with the “OK” button.
• Click on “Tools” menu, and open the “Boards” submenu, and click the
“Boards Manager” option, to open the Boards Manager window.
• Search “industrialshields” to the search filter and select to the list and
click “Install”
• Close the “Boards Manager". Once it is performed that steps, you are
available to select each PLC that you wish to work on “Tools” ->
“Boards” : M-Duino…
To get more information:
https://www.industrialshields.com/first-steps-with-the-industrialarduino-based-plc-s-and-the-panel-pc-s-raspberry-pi-based#boards
Symbology
Indicates that the equipment is suitable for direct current only; to
identify relevant terminals
Indicates that the equipment is suitable for alternating current
only; to identify relevant terminals
To identify the control by which a pulse is started.
To identify an earth (ground) terminal in cases where neither the
symbol 5018 nor 5019 is explicily required.
To identify the switch by means of which the signal lamp(s) is
(are) switched on or off.
CE marking indicates that a product complies with applicable
European Union regulations
Warnings
Unused pins should not be connected. Ignoring the directive may damage the
controller.
Before using this product, it is the responsibility of the user to read the
product’s User Guide and all accompanying documentation.
Industrial Shields PLCs must be powered between 12Vdc and 24Vdc. If a
higher voltage is supplied to the equipment can suffer irreversible damage.
Maintenance must be performed by qualified personnel familiarized with the
construction, operation, and hazards involved with the control.
Maintenance should be performed with the control out of operation and
disconnected from all sources of power.
The Industrial Shields Family PLCs are Open Type Controllers. It is required
that you install the M-Duino PLC in a housing, cabinet, or electric control
room. Entry to the housing, cabinet, or electric control room should be limited
to authorized personnel.
Inside the housting, cabinet or electric control room, the Industrial Shields
PLC must be at a minimum distance from the rest of the components of a
minimum of 25 cm, it can be severely damaged.
Failure to follow these installation requirements could result in severe
personal injury and/or property damage. Always follow these requirements
when installing M-Duino family PLCs.
In case of installation or maintenance of the M-Duino please follow the
instructions marked in the Installation and Maintenance section on the User
Guide.
Do not disconnect equipment when a flammable or combustible atmosphere
is present.
Disconnection of equipment when a flammable or combustible atmosphere
is present may cause a fire or explosion which could result in death, serious
Technical Support
You can contact with us using the best channel for you:
@ support@industrialshields.com
Visit our Blog, Forum orTicketing system
34 644 927 900
Use our chat service
Indicates a potentially hazardous situation which,
if not avoided, could result in death or serious injury
Check the user guides
To indicate hazards arising from dangerous voltages
Visit our Channel
很抱歉,暂时无法提供与“015001000300”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6393.156811+831.08970
