015001000400
015001000400
    INDUSTRIALSHIELDS
    控制器 - 可编程逻辑(PLC) DIN 轨道 12 ~ 24VDC
015001000400 数据手册
Datasheet M-Duino 42+ LoRa 015001000400 Technical Features CONECTABLE PLC ARDUINO 24Vcc M-DUINO MODEL TYPE M-Duino LoRa Input Voltage 12 to 24Vdc (Fuse protection (2.5A) Polarity protection) Input rated voltage 24Vdc Rated Power 30 W I max. 1.5A Size 101x94.7x119.5 Clock Speed 16MHz Flash Memory 256KB of which 8KB used by bootloader SRAM 8KB EEPROM 4KB Communications & Accessories LoRa - I2C - Ethernet - USB - RS485 - RS232 - SPI - RTC - microSD Only for uploading or debugging. NOT connected as a serial USB consideration! Cannot be working in a final application Power supply voltage DC power supply 12 to 24Vdc Operating voltage range DC power supply 11.4 to 25.4Vdc Power consumption DC power supply 30 W MAX. External power supply Power supply voltage 24Vdc Power supply voltage 700Ma Dielectric strength 0 to 10Vac Input Impedance: 39K Separated PCB ground Rated Voltage: 10Vac 5 to 24Vdc I min: 2 to 12 mA Galvanic Isolation Rated Voltage: 24 Vdc Digital Isolated Input (24Vcc) - (x10) 5 to 24Vdc I min: 2 to 12 mA Galvanic Isolation Rated Voltage: 24 Vdc Interrupt isolated Input HS (24Vcc) * - (x3) 5 to 24Vdc I min: 2 to 12 mA Galvanic Isolation Rated Voltage: 24 Vdc * The Interrupt isolated Inputs can also work as Digital isolated Inputs OUTPUTS (x16) Analog Output 8bit (0-10Vcc) / PWM Isolated Output 8bit (24Vcc) - (x6) Analog Output * The configuration between Analog and PWM Isolated Outputs can be done by switch. Galvanic Isolation Diode Protected for Digital Isolated Output Rated Voltage: 24Vdc Digital Isolated Output (24Vcc) (x10) 5 to 24Vdc I max: 70 mA Galvanic Isolation Diode Protected for Digital Isolated Output Rated Voltage: 24Vdc 0 to 10Vac I max: 20 mA Separated PCB ground Rated Voltage: 10Vac * The Analog & PWM outputs PWM Isolated Output can also work as Digital 5 to 24Vdc outputs I max: 70 mA Expandability I2C : 127 elements  -  ModbusRTU RS485 : 32 elements - LoRa General Features Insulation resistance INPUTS (x25) An/Dig Input 10bit (0-10Vcc) - (x12) Original Arduino Mega included 20MΩ min.at 500Vdc between the AC terminals and the protective earth terminal. 2.300 VAC at 50/60 Hz for one minute with a leakage current of 10mA max. Between all the external AC terminals and the protective ground terminal. Shock resistance 80m/s2 in the X, Y and Z direction 2 times each. Ambient temperature (operating) 0º to 60ºC Ambient humidity (operating) 10% to 90% (no condensation) Ambient environment (operating) With no corrosive gas Ambient temperature (storage) -20º to 60ºC Power supply holding time 2ms min. Weight 490 g max. Pinout C ZONE B ZONE DataSheet Rev. 20210708 A ZONE 015001000400 A ZONE B ZONE 015001000400 C ZONE 015001000400 Performance Specifications Arduino Board Arduino Mega 2560 Control method Stored program method I/O control method Combination of the cyclic scan and immediate refresh processing methods. Programming language Arduino IDE. Based on wiring (Wiring is an Open Source electronics platform composed of a programming language. “similar to the C”) Microcontroller ATmega2560 http://arduino.cc/en/Tutorial/HomePage Install Arduino IDE and the Industrial Shields boards The steps to follow to install our equipment’s to Arduino IDE are:            • Open the Arduino IDE, versión 1.8.0 or superior. If you don’t have it yet , you can download here https://www.arduino.cc/en/Main/Software . • Press the “Preferences”option to “File” menu and open the preferences window. • In the text box  “Additional boards manager URLs”, add the direction: http://apps.industrialshields.com/main/arduino/boards/package_ind ustrialshields_index.json • Close the preferences window with the “OK”  button. • Click on “Tools” menu, and open the “Boards” submenu, and click the “Boards Manager” option, to open the Boards Manager window. • Search “industrialshields” to the search filter and select to the list and click “Install” • Close the “Boards Manager". Once it is performed that  steps, you are available to select each PLC that you wish to work on “Tools” ->  “Boards” : M-Duino…   To get more information: https://www.industrialshields.com/first-steps-with-the-industrialarduino-based-plc-s-and-the-panel-pc-s-raspberry-pi-based#boards Symbology Indicates that the equipment is suitable for direct current only; to identify relevant terminals Indicates that the equipment is suitable for alternating current only; to identify relevant terminals To identify the control by which a pulse is started. To identify an earth (ground) terminal in cases where neither the symbol 5018 nor 5019 is explicily required. To identify the switch by means of which the signal lamp(s) is (are) switched on or off. CE marking indicates that a product complies with applicable European Union regulations Warnings Unused pins should not be connected. Ignoring the directive may damage the controller.    Before using this product, it is the responsibility of the user to read the product’s User Guide and all accompanying documentation.   Industrial Shields PLCs must be powered between 12Vdc and 24Vdc. If a higher voltage is supplied to the equipment can suffer irreversible damage.   Maintenance must be performed by qualified personnel familiarized with the construction, operation, and hazards involved with the control.    Maintenance should be performed with the control out of operation and disconnected from all sources of power.    The Industrial Shields Family PLCs are Open Type Controllers. It is required that you install the M-Duino PLC in a housing, cabinet, or electric control room. Entry to the housing, cabinet, or electric control room should be limited to authorized personnel. Inside the housting, cabinet or electric control room, the Industrial Shields PLC must be at a minimum distance from the rest of the components of a minimum of 25 cm, it can be severely damaged.   Failure to follow these installation requirements could result in severe personal injury and/or property damage. Always follow these requirements when installing M-Duino family PLCs.    In case of installation or maintenance of the M-Duino please follow the instructions marked in the Installation and Maintenance section on the User Guide.    Do not disconnect equipment when a flammable or combustible atmosphere is present. Disconnection of equipment when a flammable or combustible atmosphere is present may cause a fire or explosion which could result in death, serious injury and/or property damage. Technical Support You can contact with us using the best channel for you: @ support@industrialshields.com www.industrialshields.com Visit our Blog, Forum orTicketing system 34 644 927 900 Use our chat service Indicates a potentially hazardous situation which, if not avoided, could result in death or serious injury Check the user guides To indicate hazards arising from dangerous voltages Visit our Channel
015001000400 价格&库存
很抱歉,暂时无法提供与“015001000400”相匹配的价格&库存,您可以联系我们找货
